2014/03/26
Since the developer keeps saying they are "testing" (and this has been for over 5 months now), I have given up all hope from them.
Requesting a 4.4 Rom For the Cube U39GT. There is a clone out there called the IconBit Thor ZX (NT-0907S) and also the iFIVE x2 seems to appears to have the identical hardware, and there IS a 4.4 out there for that. The only 4.4 Cube has pushed out is for their U30GT
Specs: Cube U39GT Specs
Current Roms:
-Any help will be MUCH appreciated.
The following users say thank you to kadwish for this useful post:
Jonok, killain
Pls upload a dmesg and a logcat log. I'd like to see your hardware.
Jonok, killainPer aspera ad astra, we rock the Tablets !
2014/03/26
So sorry it took so long to get back. Enclosed is the dmesg:
<6>[ 0.000000] Initializing cgroup subsys cpu
<5>[ 0.000000] Linux version 3.0.36+ (arron@development-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #271 SMP PREEMPT Tue Jul 23 19:39:53 CST 2013
<4>[ 65.891566] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.52.WFD) init.
<4>[ 65.891819] =========== WLAN placed in POWER ON ========
<6>[ 66.498278] mmc1: new high speed SDIO card at address 0001
<4>[ 66.501020] FW_PATH = /system/etc/firmware/fw_RK903.bin
<4>[ 66.501034] NVRAM_PATH = /system/etc/firmware/nvram_RK903_26M.cal
<4>[ 66.530481] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
<4>[ 69.256019] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
Ok, RK903 wifi.
Try the Odys Iron v1.2 build: http://crewrktablets.arctablet.com/?p=2982
Change kernel in folder rockdev/Images before flash.
Kernel Cube U39GT: http://crewrktablets.arctablet.com/?wpfb_dl=1602
Kernel IconBit Thor ZX (NT-0907S) : http://crewrktablets.arctablet.com/?wpfb_dl=1653
Edit: final model fix: http://crewrktablets.arctablet.com/?wpfb_dl=1826
2012/10/31
Hi OMA,
I just tested, boot fine but without bootlogo after the cube's one. accelerometer seem inverted, touchscreen don't work but i have OTG cable and combo RF trackball/keyboard for testing it (it's works). The two APN (back and front) works!!!, the Wifi & sound works too. the DPI seem low (it's normal ?) confirmed by CPU-Z => 160dpi and 3Dscore seem low with nenamark 2 than before with stock Firmware.
PS: i test with cube kernel.
Do you want more infos/opinions-on-teclast-p90hdst or logcat ?
The following users say thank you to primus for this useful post:
killain
Sorry, the 160dpi comes with the fix
Yes, a dmesg and a logcat log please.
2012/10/31
I ll post they're later because i have problems with root :/. But i''ve found a way for fixing accelerometer inverted => i reported value from build.prop from cube firm :
ro.sf.fakerotation=true
ro.sf.hwrotation=270
and
ro.sf.lcd_density=240
for dpi fix
and i reflashed the fix (CrewRKTablets_KK_4.4.2_Iron_v1.2_model fix_AOC_Q70S15_2) with build.prop modified and rotation and game work fine with accelerometer and i found a module for touchscreen from original firm "ft5406.ko" and integrate it.
But i've got a problem with APN preview => it's rotate 90° (anti-clockwise). i test to integrate camera.rk30board.so from original firm. I test they and report it later.
And thanks again for you help
Jonok, killain
2012/10/31
Hi again OMA,
I just saved my logcat & dmesg (attachements). My trick on accelerometer works for games or launcher but not for my 2 APN (back & front). And i joint too my modified file (build.prop)
PS: Sorry i forgot. Do you want dmesg & logcat from original ROM & Kernel too ? (But not today, because i go to work)
If you don't have touch, use an usb-mouse.
Try this fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1826
Is the touch module running? Download a terminal emulator from Play Store and type lsmod.
2014/03/26
127|u0_a71@grouper:/ $ lsmod
wlan 458451 0 - Live 0x00000000
cdc_acm 13266 0 - Live 0x00000000
ftdi_sio 29129 0 - Live 0x00000000
pl23003 10561 0 - Live 0x00000000
cp210x 11073 0 - Live 0x00000000
snd_usb_audio 75637 0 - Live 0x00000000
snd_usbmidi_lib 15884 1 snd_usb_audio, Live 0x00000000
snd_rawmidi 15636 1 snd_usbmidi_lib, Live 0x00000000
snd_hwdep 4944 1 snd_usb_audio, Live 0x00000000
md4 33190 0 - Live 0x00000000
cifs 245765 0 - Live 0x00000000
rtk_btusb 20897 0 - Live 0x00000000
mcs7830 5049 0 - Live 0x00000000
dm9601 5600 0 - Live 0x00000000
tcp_veno 1409 0 - Live 0x00000000
tun 13050 0 - Live 0x00000000
isofs 30335 0 - Live 0x00000000
wdf 69910 0 - Live 0x00000000
sr_mod 12988 0 - Live 0x00000000
sg 20434 0 - Live 0x00000000
cdrom 33656 1 sr_mod, Live 0x00000000
cuse 4129 0 - Live 0x00000000
crc_itu_t 1059 1 udf, Live 0x00000000
hubenable 565 [permanent], Live 0x00000000
tp 35050 0 - Live 0x00000000
vpu_service 11717 0 - Live 0x00000000
rk29_ipp 9957 1 - Live 0x00000000 (c)
mali 152932 40 - Live 0x00000000
ump 28166 19 mali, Live 0x00000000
rk30xxnand_ko 314328 0 - Live 0x00000000
u0_a71@grouper:/ $
78 Guest(s)
Devices in use: Desktop (69), Phone (9)
hans41
rickybk
soniya07
ironmangitar
