REQUEST : 4.4 for Prestigio PMP7079
I'm looking for 4.4 ROM for Prestigio Multipad 4 Diamond 7.85 PMP 7079D .
Shanti7777
Forum Posts: 18
2014/08/13 - 09:38
Now rear camera works good, but front camera is rotated 180 degrees.
Update: After change rotation front camera in build.prop to 90  camera works good.
Update: To rotate screen I use free apk https://play.google.com/store/apps/details?id=com.spydiko.rotationmanager is better for me.
I try performance governor, when tablet work all is ok, but after screen off after some minutes is switch off (go sleep).
Update: In SetCpu I set governor to performance and when screen is off I set ondemand and now tablet don't switch off.
After set mali to static 594Mhz gpu works with good speed, scaling frequency doesn't work good.
My script: link
Doesn't work light sensor.
Overclock:
With standard kernel(Ram 336,1.2v) + mali.sh I have ~19600 in antutu (2800 in 3D)
Ram 400,1.25v + mali.sh   20088 in Antutu (3700 in 3D)  kernel400_1250
Ram 528,1.275v + mali.sh  20945 in Antutu (3991 in 3D)  kernel528_1275
Thanks Received: 1385
2014/08/14 - 21:37
Ok, here is the final model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2005
The rotate app is just a workaround to control the phantom touch bug of the stock kernel.
Shanti7777
Forum Posts: 18
2014/08/14 - 22:23
Big thx Oma for help.
2014/08/14 - 22:37
Ok, documented now: http://crewrktablets.arctablet.com/?p=3555
Pls share with other Prestigio users.
Shanti7777
Forum Posts: 18
2014/08/15 - 12:29
Still light sensor doesn't work, and when I use governor "performance" when screen off tablet switched off.
2014/08/15 - 15:18
For the light sensor I have no solution.
It is not the idea that the tab runs @ max speed. Tab normally will use only two steps: 312 and 816 MHz.
So, pls stay with interactive governor.
Btw. the instability you see is the reason why a lot of manufacturers limited their kernel @ 1,4 GHz.
Shanti7777
Forum Posts: 18
2014/08/15 - 17:40
I use performance when I play games like "DeadTrigger2" then I change governor to interactive.
2014/08/21 - 11:38
Can you pls test if this corrects the reversed rotation of some game apps?
Shanti7777
Forum Posts: 18
2014/08/22 - 16:44
Yes, this patch work, now I haven't rotation bug. Thx.
If I install new version this rom I must do factory reset in CWM? /data and /sdcard0 is on the same partition, after format /data I lost everything from sdcard0.
2014/08/22 - 17:43
Just flash boot and system.
Shanti7777
Forum Posts: 18
2014/08/22 - 19:54
After I use rotate patch I have strange Power menu:
"Roaming - Prefered System
[empty]
Roaming Banner OF
Roaming - Full Service Functionality"
Icons of the left are ok (plane,etc...), work also ok.
When I choose first position( Power off) I see:
"Voice
Sync  "
I choose second position and I see reboot menu.
Third position on plane mode, but I can't it off.
2014/08/22 - 19:56
Can I have a screenshot?
Shanti7777
Forum Posts: 18
2014/08/22 - 20:18
I will make foto with my phone, now I install update, but you have error in link on forum to version 1.4.1 and 1.4, when click on it I download version 1.3.
After install version 1.4.1 with fix power menu work correct.
2014/08/22 - 22:29
Corrected the links now. Sorry.
Foto is not necessary ... I guess this is the result of an omni source update in between.
Shanti7777
Forum Posts: 18
2014/08/23 - 20:10
Something with Multiwindow is nor right. When I use multiwindow and rotate tablet, one application is on full screen and second aplication is on top left corner and use 3/4 screen,after rotate all back to normal.
77 Guest(s)
Devices in use: Desktop (67), Phone (10)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
