Fine. Thank you for feedback!
2013/05/23
KitKat on radxa, yes grand OMAster. Will look futher into this later, followed ifive mini3 with radax kernel. load was proper and boot normal. Two immediate problems 1) shut down has to be done through the reboot app, no power icon on menu bar. 2) cpu running at 1.41 to 1.60 constant with init. on. Will shut this off in pimp my rom and see if changes. if not could be due to Hdmi running monitor???
Later friend, but this flavor is really close, THANKS as always CaPPyBoB
2013/05/23
Oma after working with builds the OTG on both not working and the cpu on KitKat is idling at 1.2 and runs at 1.4 to 1.6. Kitkat version needs to be shut down using an app. Wish I had the knowledge to fix, looks like 4.2.2 simple fix, for KitKat looks to be kernel and mali is my guess.
Later, thanks again
52 Guest(s)
Devices in use: Desktop (42), Phone (10)
hellander
elousstad
relaytester
revoltown
tdomnic024
