Qilive 8QC / Archos 80b Platinum
No Custom ROM ?
juronius
Forum Posts: 12
2015/03/20 - 11:36
Sorry for my english, i'm french.
I had a Auchan Qilive 8QC rebrand of Archos 80b Platinum :
- Display : 7.9 inches
- CPU : RK3188 quad core 1.6GHz
- GPU : Mali 400
- RAM : 1Gb DDR3
- Stockage : 8Gb
- Board : RK30board
- HDMI, Wifi and Bluetooth
- Bootloader gen2
I don't find a custom rom for my tablet, i tested this oma's rom for rk3188, (chuwi, pipo, onda, etc...) but after flash with rkandroidtool, this tablet don't reboot to recovery and not boot.
no check bootloader and parameter with 8Gb ...
Only restore in flashtool with update.img downloaded on archos web site.
If exist a custom ROM, OMA or CM10/11 for my tablet ? How to proced ?
Thank for helps.
2015/03/20 - 11:43
I have moved your topic to the Crew custom firmware section.
Oma will probably ask you for a stock firmware for your device, is there available from Qilive ? or a compatible one from ARCHOS (that is tested to work on your tablet) ? Do you have direct download links for that ?
juronius
Forum Posts: 12
2015/03/20 - 11:53
Thank.
The Qilive Stock ROM isnot available but the Archos Stock ROM work !
The HowTo : http://www.archos.com/faq/index.php?sid=1040580&action=artikel&cat=55&id=148
The Archos Stock ROM for 80b Platinum : http://files.archos.com/recovery/fw/elements/archos_80bplatinum/update.img
I'have a backup of my tablet before flash with archos rom, make with "online nandroid backup".
juronius
Forum Posts: 12
2015/03/20 - 13:19
If is useful :
- cmdline :
console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00140000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00002000@0x00080000(kpanic),0x0012C000@0x00082000(system),-@0x001AE000(userdata) bootver=2013-08-20#2.05 firmware_ver=4.1.1
- mdt :
dev: size erasesize name
mtd0: 00400000 00004000 "misc"
mtd1: 00800000 00004000 "kernel"
mtd2: 01000000 00004000 "boot"
mtd3: 02000000 00004000 "recovery"
mtd4: 04000000 00004000 "backup"
mtd5: 08000000 00004000 "cache"
mtd6: 00400000 00004000 "kpanic"
mtd7: 25800000 00004000 "system"
mtd8: 19e400000 00004000 "userdata"
- dmesg :
2015/03/20 - 18:32
Ok tab has AP6330 wifi.
<4>[ 27.473602] wifi name AP6330
<4>[ 27.473633] FW_PATH = /system/etc/firmware/fw_RK903_ag.bin
<4>[ 27.473648] NVRAM_PATH = /system/etc/firmware/nvram_AP6330.txt
Why do you think the tab has a gen2 bootloader? Which kernel did you use to test other builds?
juronius
Forum Posts: 12
2015/03/20 - 20:11
Hello !
I think a gen2 because a CWM Recovery for Rockchip generic (RK3066, RK3188) not work but "(OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2)" it work !
I do not have succed a switch kernel. My version kernel is 3.0.36 ...
Thank's.
2015/03/20 - 20:51
Archos 80b Platinum kernel #59 preempt 22 Sep 2013 is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2518
Check the Omni build out: http://crewrktablets.arctablet.com/?p=3555
juronius
Forum Posts: 12
2015/03/21 - 14:26
Hello !
I must flash loader and parameter 8Gb ?
It's good cRom 1.4.1 at download ?
Thank again.
juronius
Forum Posts: 12
2015/03/23 - 09:14
Hello !
I try :
Loader => RK3188Loader(L)_1.24.bin
parameter => parameter_8GB
kernel => kernel.img (for Qilive 8QC / Archos 80b Platinum)
Download file failed, now found RKAndroid MaskRom Rock Usb, restore with archos flashing tool.
Edit : retry with only kernel.img (for Qilive 8QC / Archos 80b Platinum) without loader.
Download file failed :'(
Edit :
Retry with parameter_8GB now boot on recovery but
E:Can't find misc
E:Can't mount /cache/recovery/command
E:Can't find misc
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
E:Can't find misc
Now i only have recovery, i choice "reboot system now" after "wipe data/factory reset", it reboot into recovery.
I tried with "Oma RK31 KK CWM Recovery Gen2 Loader" http://crewrktablets.arctablet.com/?wpfb_dl=1640
After reset factory, no errors but after reboot and no fix su, i waiting 4min and plus but no boot, i 4 penguins in display.
Erf !
-- Wiping data..
Formating /data...
Formating /cache...
Formating /sd-ext...
No app2sd partition found. Skipping format of /sd-ext.
Formating /sdcard/.android_secure...
Error mounting /sdcard/.android_secure!
Skipping format...
Data wipe complete.
juronius
Forum Posts: 12
2015/03/24 - 13:50
Hello !
I win to flash my tablet :
- Flash bootloader to 1.24 with OMA Refresh tool
- Flash 2/7 with parameter 8GB and kernel for Qilive 8QC/ Archos 80b Platinum
- Reboot into CWM for gen1 (no misc errors)
- Wipe Cache/Factory Reset
- Reboot system now (no fix recovery, no fix su)
Waiting a 4/6min it work ! But i error display : Der Prozess "com.android.systemui" wurde beendet
- Shutdown my tablet
- Boot into recovery
- Apply 160dpi fix from external_sd
- Reboot system now
No error display ! But Wifi and BT not work !
Thank's  for helps !
juronius
Forum Posts: 12
2015/03/25 - 09:44
Hello !
If is useful :
Thank's.
Edit :
Logcat with Archos ROM :
03-25 10:09:34.921 D/WifiHW ( 377): Read wifi chip type OK ! wifi_chip_type = RK903
03-25 10:09:34.921 D/WifiHW ( 377): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
03-25 10:09:36.031 D/WifiHW ( 377): Wifi driver is ready for now. timeout=149
03-25 10:09:36.031 D/WifiHW ( 111): Eneter: wifi_change_fw_path, fwpath = /system/etc/firmware/fw_bcm4329.bin.
03-25 10:09:34.971 D/BluetoothAdapterService(1091894080)( 8360): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@41151480
Logcat with OmniROM :
03-24 14:42:03.760 D/WifiHW ( 491): Read wifi chip type OK ! wifi_chip_type = RK903
03-24 14:42:03.760 D/WifiHW ( 491): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
03-24 14:42:04.640 D/WifiHW ( 491): Wifi driver is ready for now. timeout=149
03-24 14:42:04.640 E/WifiHW ( 107): Failed to open wlan fw path param (No such file or directory)
03-24 14:42:17.640 D/BluetoothAdapter( 1704): 1101285640: getState() :  mService = null. Returning STATE_OFF
Why fw_bcm4329.bin ?
juronius
Forum Posts: 12
2015/04/14 - 07:59
It always no work :'(
Please help me, thank's.
radar100
2016/06/03 - 23:33
Hello!
Also I have a Qilive 8QC and I install this ROM on my device.
You managed to get the Wifi working?
What more does not work?
How to apply the 160dpi fix from external sd?
Thank you
78 Guest(s)
Devices in use: Desktop (74), Phone (4)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
