Mediacom Smartpad 8.0 S4 (M-MP84S4) Kitkat 4.4.2 problems
LolloPS
Forum Posts: 28
2014/05/24 - 20:15
i've to delete somenthing?? or only reflash the rom (i've to eraseIDB?) and install the fix twice?
PS=the hw decoding in portrait stopped working ...i've now to enable also "Disable Hw overlays"to make it working again
2014/05/24 - 20:19
Yes, reflash (no eraseIDB necessary) and run the fix twice (first time it will delete something).
LolloPS
Forum Posts: 28
2014/05/24 - 20:40
ok installed the fix twice touchscreen bluetooth and wifi working :) but the camera is UpsideDown ....i've modified again "ro.sf.hwrotation=270" from 270 to 90 in build.prop to make right
LolloPS
Forum Posts: 28
2014/05/24 - 20:45
in the stock video player ....if i select to miniaturize the video (the button with the card airplane ..i don't know how to describe it ) ...the video remain black
2014/05/24 - 20:57
Ok, corrected rotation to 90.
How about MX-Player?
LolloPS
Forum Posts: 28
2014/05/24 - 21:03
ok i tried mx player and works good ;) no problems
2014/05/25 - 10:01
For documentation purpose one will find all files here: http://crewrktablets.arctablet.com/?p=2736
LolloPS
Forum Posts: 28
2014/05/25 - 10:08
Thank You Oma!!!! :) Have you modified something new in the fix?
2014/05/25 - 10:13
Just the rotation.
dani7710
2014/05/29 - 01:41
thanks you oma,
im relase rom
http://www.androidiani.com/forum/altri-tablet-mediacom/405678-rom-mp84s4-smartpad-s4-8-0-oma-kit-kat-android-4-4-2-a.html
your kernel upload not working perfect. I changed kernel whit stock mediacom and run fine, only bug is turn always on wifi for use bluetooth.
one question, from rom odys iron the memory is unified, puts everything in internal memory.
how can you do this for the chuwi rom? many users would want it.
thanks and sorry my english by google translate.
2014/05/29 - 10:01
The kernel is from the MP84S4 stock image and named feng #28 preempt 05.09.2013. What is wrong with that kernel? Which one do you use?
In the archive there is also a kernel from the Prestigio MultiPad 4 Quantum 7.85 (PMP5785c), named jim #6 preempt 07.12.2013: http://crewrktablets.arctablet.com/?wpfb_dl=1763
When you turn of wifi, the mt5931.ko gets unloaded. Consequently no BT.
There are mounting solutions with a large internal memory partition and no internal sdcard. There is no advantage compared to the normal way.
icewell
Forum Posts: 12
2014/05/31 - 23:11
Thanks for all, Oma. I'm installed your KitKat. But application Google Hangouts not working. What could be a problem? This application says me: Couldn't sign in, possibly because there's a problem with Google account permissions.
2014/06/01 - 00:14
This is a problem of gms-core. When play-services update is driven by google+ or hangouts it will generate such problems.
Do a factory reset and install the patched google+ app first. Then let the updates go.
hints:
- do not install google+ from Play Store; use this one (can be updated later)
- go to settings/performance and set CPU mode to normal
icewell
Forum Posts: 12
2014/06/01 - 01:33
Did as you said. The problem remained. Hangouts not working.
dani7710
2014/06/01 - 03:02
Unfortunately, the kernel does not scale up to 1,6ghz. stop scaling at 1,4ghz.
to force 1,6ghz is it necessary put min 1,6ghz max 1,6 ghz,
i do not know the name of the kernel. from italian forum called "stock mediacom" and is safe not prestigio kernel.
im upload for you. is more 8mb.
https://mega.co.nz/#!u44AWKxC!juWjGfcAjd8GyQptCuYcHjmPAUNSZoeT4nbkVvK4ZIs
Unified 6gb memory has many advantages (from odys iron rom): all photo-shot/video saved from internal memory, all additional file from play store saved from internal memory, all app, all game... all file.
unfortunately I can not figure out how to get it done at the ROM chuwi, not for me, some of my forum users had tried the rom odys iron and lacks this thing that puts everything internal memory store
 the little bugs bluetooth is not a problem. wifi in Italy is always on
80 Guest(s)
Devices in use: Desktop (69), Phone (10), Tablet (1)
Shincozen
karim78190
mario millan
estelavg
Skyzhay
HorstG
