2014/05/20
Hi guys i have a Mediacom Smartpad 8.0 S4 (M-MP84S4) ...it's a clone of Prestigio Multipad 4 Quantum 7.85 .......... It has Rtl8723 chip .
i have installed successfully kitkat 4.4.2 using the Odys Iron KK rom (thank you guys!!!!!!!!!) ...
i replaced the kernel with the kernel of prestigio (capped at 1,4ghz) , used parameter for 8gb tabs and modified the lcd density in build.prop to 160 ...everything is working fine (camera...wifi...bluetooth..)
But there are a few bugs :
1)No Hw decoding in portrait (see below ...in chuwi v88 rom is working fine!)
2)No battery info (see below)
3)Contacts app doesn't load (see below)
4)tablet doesn't charge when it's turned off (as soon as i use the ac adapter it boots to android and doesn't stay off)
PS=If i use the stock mediacom kernel (1,6ghz) the camera doesn't work (camera app crash if i select front camera o record a video) but the tab charges fine when it's turned off
I installed successfully also the chuwi v88 Kitkat rom v2.3 by OMA (Thank you for your works!!!!!!!)....the battery info is working , the camera is working (it takes pictures and videos flipped 90 degrees....how to fix??), hw decoding in portrait working fine if i select "Disable overlay HW" and "Force Rendering GPU" in developer settings.....contacts app is working fine....but NO wifi and bluetooth....this is the steps that i made to make it boot:
1)replaced kernel with the stock mediacom kernel
2)modified ro.sf.hwrotation=270 from 270 to 0 in build.prop
3)used all idc files in system/usr/idc from odys iron rom to make touchscreen work
4)copied "sensors.rk30board.so" from odys iron rom to make accelerometer work
Now i want to ask you if there is a method to inject the driver for Rtl8723 in the chuwi v88 rom or if there is a method to fix the bugs that i listed ... thank you guys !!
1) it should work in reversed landscape (trun tab by 180 degrees)
3) use 3rd party contact app
cam: what about the Iron kernel?
2014/05/20
1) it should work in reversed landscape (trun tab by 180 degrees)3) use 3rd party contact app
Oma thanks for the reply!!! anyway after a lot attempts i have wifi and bluetooth working with your rom for the chuwi !
this are the steps that i made to make it working =
1)unpacked boot.img of Odys Iron and Chuwi V88....replaced the file "init.connectivity.rc" in the chuwi boot.img with the one from the Odys Iron and repacked. Replaced the kernel with the stock Mediacom Kernel.
2)Flashed The Rom and copied this files from the Odys Iron Rom to the chuwi rom :
---system/bin/ bcm_supplicant , esp_hostapd ,esp_supplicant , hostapd , hostapd_cli , rtl_hostapd ,rtl_supplicant ,wpa_supplicant , wpa_supplicant_mt5931
---system/etc/firmware rtk8723_bt_config , rtk8723a , sd8686.bin , sd8686_helper.bin , WIFI_RAM_CODE
---system/etc/init.d 94bluetooth
---system/etc/bluetooth auto_pair_devlist.conf , bt_did.conf , bt_stack.conf
---system/etc/wifi p2p_supplicant.conf , p2p_supplicant_overlay.conf , wpa_supplicant.conf , wpa_supplicant_overlay.conf
---system/lib/hw sensors.rk30board.so , bluetooth.default.so
---system/lib/modules 8723as.ko , 8723au.ko , mt7601ap.ko , mt7601sta.ko , mtprealloc7601Usta.ko , rkwifi.ko , rkwifi.ko.3.0.8+ , rkwifi.oob.ko , rtk_btusb.ko , rtl8150.ko
---all the files from system/usr/idc (to make touchscreen work)
---system/lib libbluetooth.so , libbluetooth_jni.so , libbluetoothd.so , libbt-hci.so , libbtio.so , libbt-utils.so
---system/vendor/lib libbt-vendor.so , libbt-vendor-rtl.so , performance_info.xml
3)Than a changed "ro.sf.hwrotation=270" from 270 to 90 that fixed the camera
After that the bluetooth and wifi worked perfect...there are files that i dont' have to copy??? i'm not an expert so i made a lot of attempts
PS= there is a tool in linux that unpack and repack boot.img of rk3188?? i used a tool in windows called RK3xxx_firmware_tools but with the repacked boot.img the tablet doesn't charge when it's off
Looks good.
No simple linux tool. I guess you mean the SergioPoverony Tool ... it should work.
2014/05/20
Looks good.No simple linux tool. I guess you mean the SergioPoverony Tool ... it should work.
yes exactly ...btw your rom is great and now everything is working fine wifi..bt.. hdmi...audio...hw decoding ..and it has a fast boot time .. only 45 seconds
so i will try again with SergioPoverony Tool ...thank you Oma!! 😉
2014/05/20
Oma excuse me but there is a method to use external sd as internal?? i have to mod "fstab.rk30board.bootmode.emmc" in boot.img ?? and than flash the rom?? thank you in advance
Ps= i've managed to fix the issue of charging of the tablet when it's off ...it was a problem with the repacking of boot.img
Update = i managed to swap the memories 🙂
Fine. Which V88 rom did you use?
2014/05/20
Fine. Which V88 rom did you use?- Oma -
Hi Oma! I used your rom for the chuwi...the v2.3 ...i haven't tried the new build (v3.0) because it is build for gen2 loader and the mediacom has a 1st gen loader
I had problems with bluetooth ...it was working fine but suddenly sometimes it was working sometimes not...if i turn on and off wifi and bluetooth in rapid succession...the bluetooth stops working ...or the tablet reboot itself...
a friend managed to fix that ...he said that some permission for the files were wrong ..and the script in init.d loading rtk_btusb.ko wasn't working well ...i don't know..i have to test it
PS=i've tested also a cm10.1 build you made for chuwi v88...but i had the same problems with bluetooths
PS=i don't know if you need it but this is the link for the stock 4.2.2 rom extracted from the tablet Stock Rom Mediacom
sorry for my english
2014/05/20
Oma excuse me but when i have the problem of bluetooth ...this appears in the logcat
PS= i noticed that bluetooth works perfect if the wifi it's on ...the problems begin when wifi it's off
05-24 14:17:22.201 D/BluetoothA2dp(2106): onBluetoothStateChange: up=false
05-24 14:17:22.201 E/BluetoothA2dp(2106):
05-24 14:17:22.201 E/BluetoothA2dp(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@41ab5540
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:121)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.201 E/BluetoothA2dp(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.201 D/BluetoothHeadset(922): onBluetoothStateChange: up=false
05-24 14:17:22.201 E/BluetoothHeadset(922):
05-24 14:17:22.201 E/BluetoothHeadset(922): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@41994450
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:239)
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.201 E/BluetoothHeadset(922): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.201 E/BluetoothHeadset(922): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.201 D/BluetoothHeadset(763): onBluetoothStateChange: up=false
05-24 14:17:22.201 E/BluetoothHeadset(763):
05-24 14:17:22.201 E/BluetoothHeadset(763): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@41c8d598
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:239)
05-24 14:17:22.201 E/BluetoothHeadset(763): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:484)
05-24 14:17:22.201 E/BluetoothHeadset(763): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1129)
05-24 14:17:22.201 E/BluetoothHeadset(763): at com.android.server.BluetoothManagerService.access$2800(BluetoothManagerService.java:47)
05-24 14:17:22.201 E/BluetoothHeadset(763): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:864)
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.os.Handler.dispatchMessage(Handler.java:102)
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.os.Looper.loop(Looper.java:136)
05-24 14:17:22.201 E/BluetoothHeadset(763): at android.os.HandlerThread.run(HandlerThread.java:61)
05-24 14:17:22.201 D/BluetoothHeadset(2106): onBluetoothStateChange: up=false
05-24 14:17:22.201 E/BluetoothHeadset(2106):
05-24 14:17:22.201 E/BluetoothHeadset(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@41aba6a8
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:239)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.201 E/BluetoothHeadset(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.201 E/BluetoothPan(763):
05-24 14:17:22.201 E/BluetoothPan(763): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@41ae5788
05-24 14:17:22.201 E/BluetoothPan(763): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothPan(763): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothPan(763): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:199)
05-24 14:17:22.201 E/BluetoothPan(763): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:484)
05-24 14:17:22.201 E/BluetoothPan(763): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1129)
05-24 14:17:22.201 E/BluetoothPan(763): at com.android.server.BluetoothManagerService.access$2800(BluetoothManagerService.java:47)
05-24 14:17:22.201 E/BluetoothPan(763): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:864)
05-24 14:17:22.201 E/BluetoothPan(763): at android.os.Handler.dispatchMessage(Handler.java:102)
05-24 14:17:22.201 E/BluetoothPan(763): at android.os.Looper.loop(Looper.java:136)
05-24 14:17:22.201 E/BluetoothPan(763): at android.os.HandlerThread.run(HandlerThread.java:61)
05-24 14:17:22.201 D/BluetoothMap(2106): onBluetoothStateChange: up=false
05-24 14:17:22.201 E/BluetoothMap(2106):
05-24 14:17:22.201 E/BluetoothMap(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothMap$2@41945aa0
05-24 14:17:22.201 E/BluetoothMap(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.201 E/BluetoothMap(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.201 E/BluetoothMap(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.201 E/BluetoothMap(2106): at android.bluetooth.BluetoothMap$1.onBluetoothStateChange(BluetoothMap.java:66)
05-24 14:17:22.201 E/BluetoothMap(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.201 E/BluetoothMap(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.201 E/BluetoothMap(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.211 E/BluetoothPan(2106):
05-24 14:17:22.211 E/BluetoothPan(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@41939750
05-24 14:17:22.211 E/BluetoothPan(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.211 E/BluetoothPan(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.211 E/BluetoothPan(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.211 E/BluetoothPan(2106): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:199)
05-24 14:17:22.211 E/BluetoothPan(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.211 E/BluetoothPan(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.211 E/BluetoothPan(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.211 D/BluetoothInputDevice(2106): onBluetoothStateChange: up=false
05-24 14:17:22.211 E/BluetoothInputDevice(2106):
05-24 14:17:22.211 E/BluetoothInputDevice(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@4191abf8
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:199)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.211 E/BluetoothInputDevice(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.211 D/BluetoothA2dp(763): onBluetoothStateChange: up=false
05-24 14:17:22.211 E/BluetoothA2dp(763):
05-24 14:17:22.211 E/BluetoothA2dp(763): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@41d032e0
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:121)
05-24 14:17:22.211 E/BluetoothA2dp(763): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:484)
05-24 14:17:22.211 E/BluetoothA2dp(763): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1129)
05-24 14:17:22.211 E/BluetoothA2dp(763): at com.android.server.BluetoothManagerService.access$2800(BluetoothManagerService.java:47)
05-24 14:17:22.211 E/BluetoothA2dp(763): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:864)
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.os.Handler.dispatchMessage(Handler.java:102)
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.os.Looper.loop(Looper.java:136)
05-24 14:17:22.211 E/BluetoothA2dp(763): at android.os.HandlerThread.run(HandlerThread.java:61)
05-24 14:17:22.211 D/BluetoothHeadset(922): onBluetoothStateChange: up=false
05-24 14:17:22.211 E/BluetoothHeadset(922):
05-24 14:17:22.211 E/BluetoothHeadset(922): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@4193ce60
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:239)
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.211 E/BluetoothHeadset(922): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.211 E/BluetoothHeadset(922): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.211 E/BluetoothHeadset(922): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@4195ec00
05-24 14:17:22.211 D/BluetoothPbap(2106): onBluetoothStateChange: up=false
05-24 14:17:22.221 E/BluetoothPbap(2106):
05-24 14:17:22.221 E/BluetoothPbap(2106): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@41949780
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:931)
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.app.ContextImpl.unbindService(ContextImpl.java:1602)
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.content.ContextWrapper.unbindService(ContextWrapper.java:529)
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:122)
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55)
05-24 14:17:22.221 E/BluetoothPbap(2106): at android.os.Binder.execTransact(Binder.java:404)
05-24 14:17:22.221 E/BluetoothPbap(2106): at dalvik.system.NativeStart.run(Native Method)
05-24 14:17:22.221 D/BluetoothManagerService(763): Bluetooth State Change Intent: 11 -> 10
05-24 14:17:22.221 E/BluetoothManagerService(763): recoverBluetoothServiceFromError
05-24 14:17:22.221 D/BluetoothMapService(2462): onReceive
05-24 14:17:22.241 W/ContextImpl(2106): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1486 android.content.ContextWrapper.startService:494 android.content.ContextWrapper.startService:494 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115
05-24 14:17:22.251 D/DockEventReceiver(2106): finishStartingService: stopping service
05-24 14:17:22.281 D/dalvikvm(885): GC_CONCURRENT freed 396K, 16% free 3039K/3596K, paused 4ms+2ms, total 25ms
05-24 14:17:22.541 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:22.721 D/BluetoothManagerService(763): Sending off request.
05-24 14:17:22.721 D/BluetoothAdapterState(2462): CURRENT_STATE=OFF, MESSAGE = USER_TURN_OFF
05-24 14:17:22.721 D/BluetoothManagerService(763): Calling onBluetoothServiceDown callbacks
05-24 14:17:22.721 D/BluetoothManagerService(763): Broadcasting onBluetoothServiceDown() to 5 receivers.
05-24 14:17:22.721 D/BluetoothAdapterService(2462): Cleaning up adapter native....
05-24 14:17:22.721 D/bt_vendor(2462): op for 4
05-24 14:17:22.721 I/bt_userial_vendor(2462): device fd = 71 close
05-24 14:17:22.721 E/bt_userial_vendor(2462): close(fd:71) FAILED result:-1
05-24 14:17:22.721 D/BTSNOOP-DISP(2462): btsnoop_close
05-24 14:17:22.721 D/bt_vendor(2462): cleanup
05-24 14:17:22.721 D/bt_vendor(2462): op for 0
05-24 14:17:22.721 D/bt_upio (2462): is_emulator_context : 0
05-24 14:17:22.721 D/bt_upio (2462): is_rfkill_disabled ? [0]
05-24 14:17:22.761 D/bt_upio (2462): Delay 500ms for bluetooth power up
05-24 14:17:23.081 D/dalvikvm(885): GC_CONCURRENT freed 393K, 16% free 3040K/3596K, paused 1ms+2ms, total 15ms
05-24 14:17:23.211 D/AudioHardware(495): AudioHardware pcm playback is going to standby.
05-24 14:17:23.211 V/AudioHardware(495): closeMixer_l() mMixerOpenCnt: 1
05-24 14:17:23.211 D/AudioHardware(495): closePcmOut_l() mPcmOpenCnt: 1
05-24 14:17:23.261 W/bt-btu (2462): btu_task start abort!
05-24 14:17:23.261 I/GKI_LINUX(2462): gki_task_entry: gki_task task_id=0 [BTU] terminating
05-24 14:17:23.261 I/GKI_LINUX(2462): GKI_exit_task: GKI_exit_task 0 done
05-24 14:17:23.261 I/GKI_LINUX(2462): GKI_destroy_task: GKI_shutdown(): task [BTU] terminated
05-24 14:17:23.261 E/BluetoothServiceJni(2462): Callback env check fail: env: 0x400a7f28, callback: 0x400281e8
05-24 14:17:23.261 E/BluetoothServiceJni(2462): Callback: 'adapter_state_change_callback' is not called on the correct thread
05-24 14:17:24.821 D/dalvikvm(885): GC_CONCURRENT freed 394K, 16% free 3040K/3596K, paused 2ms+3ms, total 28ms
05-24 14:17:25.541 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:25.731 D/BluetoothManagerService(763): Message: 42
05-24 14:17:25.731 D/BluetoothManagerService(763): MESSAGE_RESTART_BLUETOOTH_SERVICE: Restart IBluetooth service
05-24 14:17:26.451 D/dalvikvm(885): GC_CONCURRENT freed 392K, 16% free 3042K/3596K, paused 4ms+2ms, total 27ms
05-24 14:17:28.551 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:28.731 D/BluetoothManagerService(763): Message: 100
05-24 14:17:28.731 E/BluetoothManagerService(763): MESSAGE_TIMEOUT_BIND
05-24 14:17:28.951 D/dalvikvm(885): GC_CONCURRENT freed 400K, 16% free 3045K/3596K, paused 3ms+5ms, total 39ms
05-24 14:17:30.851 D/dalvikvm(885): GC_CONCURRENT freed 403K, 16% free 3044K/3596K, paused 4ms+2ms, total 32ms
05-24 14:17:31.551 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:32.051 D/dalvikvm(885): GC_CONCURRENT freed 394K, 16% free 3041K/3596K, paused 5ms+4ms, total 39ms
05-24 14:17:33.871 D/dalvikvm(763): GC_CONCURRENT freed 997K, 13% free 7455K/8536K, paused 7ms+7ms, total 75ms
05-24 14:17:34.341 W/SocketClient(493): write error (Broken pipe)
05-24 14:17:34.341 D/ConnectivityService(763): handleInetConditionChange: no active default network - ignore
05-24 14:17:34.351 D/dalvikvm(1054): GC_CONCURRENT freed 384K, 17% free 3316K/3980K, paused 1ms+1ms, total 12ms
05-24 14:17:34.551 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:35.251 D/dalvikvm(885): GC_CONCURRENT freed 397K, 16% free 3044K/3596K, paused 3ms+2ms, total 20ms
05-24 14:17:36.171 D/dalvikvm(885): GC_CONCURRENT freed 396K, 16% free 3041K/3596K, paused 3ms+2ms, total 19ms
05-24 14:17:37.561 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:37.861 D/dalvikvm(885): GC_CONCURRENT freed 388K, 16% free 3041K/3596K, paused 3ms+3ms, total 32ms
05-24 14:17:39.631 D/dalvikvm(885): GC_CONCURRENT freed 399K, 16% free 3043K/3596K, paused 4ms+3ms, total 27ms
05-24 14:17:40.561 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:41.331 D/dalvikvm(885): GC_CONCURRENT freed 402K, 16% free 3045K/3596K, paused 3ms+2ms, total 35ms
05-24 14:17:42.081 D/dalvikvm(885): GC_CONCURRENT freed 369K, 15% free 3062K/3596K, paused 1ms+1ms, total 11ms
05-24 14:17:43.111 D/AudioHardware(495): AudioHardware pcm playback is exiting standby.
05-24 14:17:43.111 V/AudioHardware(495): open pcm_out driver
05-24 14:17:43.111 D/AudioHardware(495): openPcmOut_l() mPcmOpenCnt: 0
05-24 14:17:43.111 D/alsa_pcm(495): pcm_open(0x0003f000)
05-24 14:17:43.111 D/alsa_pcm(495): pcm_open() period sz multiplier 16
05-24 14:17:43.111 D/alsa_pcm(495): pcm_open() period cnt 6
05-24 14:17:43.111 D/alsa_pcm(495): pcm_open() period_cnt 6 period_sz 1024 channels 2
05-24 14:17:43.111 V/AudioPolicyManagerBase(495): releaseOutput() 2
05-24 14:17:43.111 V/AudioHardware(495): openMixer_l() mMixerOpenCnt: 0
05-24 14:17:43.111 V/AudioHardware(495): open playback normal
05-24 14:17:43.111 V/AudioHardware(495): write() wakeup setting route SPK
05-24 14:17:43.181 D/BluetoothAdapter(2106): 1100622888: getState() : mService = null. Returning STATE_OFF
05-24 14:17:43.181 D/LocalBluetoothManager(2106): setting foreground activity to non-null context
05-24 14:17:43.191 D/BluetoothAdapter(2106): 1100622888: getState() : mService = null. Returning STATE_OFF
05-24 14:17:43.201 D/dalvikvm(2106): GC_CONCURRENT freed 448K, 11% free 4389K/4908K, paused 1ms+4ms, total 23ms
05-24 14:17:43.541 D/BluetoothManagerService(763): enable(): mBluetooth =null mBinding = false
05-24 14:17:43.541 D/BluetoothManagerService(763): Message: 1
05-24 14:17:43.541 D/BluetoothManagerService(763): MESSAGE_ENABLE: mBluetooth = null
05-24 14:17:43.561 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:44.161 D/dalvikvm(885): GC_CONCURRENT freed 383K, 15% free 3065K/3596K, paused 2ms+2ms, total 16ms
05-24 14:17:44.251 V/AudioPolicyManagerBase(495): stopOutput() output 2, stream 1, session 56
05-24 14:17:44.681 D/dalvikvm(885): GC_CONCURRENT freed 392K, 15% free 3068K/3596K, paused 1ms+1ms, total 12ms
05-24 14:17:45.561 D/dalvikvm(885): GC_CONCURRENT freed 406K, 15% free 3061K/3596K, paused 2ms+2ms, total 18ms
05-24 14:17:46.091 D/BTSNOOP-DISP(2462): btsnoop_close
05-24 14:17:46.091 D/bt_vendor(2462): cleanup
05-24 14:17:46.091 D/bt_vendor(2462): op for 0
05-24 14:17:46.091 D/bt_upio (2462): is_emulator_context : 0
05-24 14:17:46.091 D/bt_upio (2462): is_rfkill_disabled ? [0]
05-24 14:17:46.091 E/NetdConnector(763): NDC Command {211 bandwidth gettetherstats} took too long (29582ms)
05-24 14:17:46.121 D/bt_upio (2462): Delay 500ms for bluetooth power up
05-24 14:17:46.551 D/BluetoothManagerService(763): Message: 100
05-24 14:17:46.551 E/BluetoothManagerService(763): MESSAGE_TIMEOUT_BIND
05-24 14:17:46.571 I/wpa_supplicant(2969): [CTRL_IFACE]wlan0: SIGNAL_POLL
05-24 14:17:46.621 I/GKI_LINUX(2462): gki_task_entry: gki_task task_id=2 [A2DP-MEDIA] terminating
05-24 14:17:46.621 I/GKI_LINUX(2462): GKI_exit_task: GKI_exit_task 2 done
05-24 14:17:46.621 I/GKI_LINUX(2462): gki_task_entry: gki_task task_id=1 [BTIF] terminating
05-24 14:17:46.951 D/NetUtils(763): dhcp_do_request failed : wlan0 (new)
05-24 14:17:46.951 E/DhcpStateMachine(763): DHCP failed on wlan0: Timed out waiting for DHCP to finish
05-24 14:17:47.001 D/dalvikvm(885): GC_CONCURRENT freed 394K, 16% free 3054K/3596K, paused 0ms+1ms, total 10ms
05-24 14:17:47.111 D/AudioHardware(495): AudioHardware pcm playback is going to standby.
Ok, let me try.
Install the v2.3 build fresh.
Change the boot.img: http://crewrktablets.arctablet.com/?wpfb_dl=1766
Change the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1017
Install this fix: http://crewrktablets.arctablet.com/?wpfb_dl=1765
LolloPSPer aspera ad astra, we rock the Tablets !
2014/05/20
Ok, let me try.Install the v2.3 build fresh.
ok i'm downloading it i'll let you know the results ! Thank You Oma !!!!!!!!
2014/05/20
ok i've downloaded v2.3 rom ...changed boot.img and kernel in rockdev folder...eraseIDB and than flashed ...used kk format and than installed the fix ...
the tab booted but touchscrenn doesn't work it is recognized as touchpad and showing a little ball ...also it's invercted
...also wifi and bluetooth doesn't work ...i noticed that only few files of model fix you gave to me installed....even if the installation of the model fix didn't give me errors ...system hasn't enough space?
i'm doing something wrong?? i have to use the fix after the first boot?
UPDATE= if i want to copy the files with the file manager even if it has root access it gives me error
UPDATE 2= 1)i copied all the idc files from odys iron rom (ft5x_ts.idc / gslX680.idc / gt80x.idc /
ilitek_i2c.idc /qwerty2.idc / qwerty.idc / sis_touch.idc / ssd253x_ts.idc)
...touchscreen now works!!
2)i copied manually the files you gave me in the fix and now Bluetooth and wifi works perfect!! i tried to send a file and reiceive and everything is working ....also now i can turn off bt and wifi as i want ...bluetooth doesn't stop working
3)the camera was upside down...i changed "ro.sf.hwrotation=270" from 270 to 90 and
now it's perfect (that fixed also hdmi that was upside down)
UPDATE 3= ok HDMI is working perfect also with Audio
UPDATE 4= the hw decoding in portrait works ...
UPDATE 5 = the tablet charge when it's off
PS= what is the voice "Performance " in system settings? also the tab starts with Governor "Performance" and a min frequency of 512mhz(stock is 312mhz) how to change that?
So the only problem is that the fix in recovery doesn't install well... anyway thank you for your work !!! and i'm waiting for a your response ! thank you again Oma!!
Fine!
There is an extra menue in settings called performance. Set it to "normal".
Pls upload a dmesg log and the result of cat proc/mtd.
2014/05/20
Fine!There is an extra menue in settings called performance. Set it to "normal".
ok i've extracted them
PS= the kernel it's not the stock one , right? have you modified it? the stock kernel that i have is "8,192 KB"
Ok, foud it. There is not enough space left in the system. So we need to delete something first.
Download the fix again http://crewrktablets.arctablet.com/?wpfb_dl=1765
and install it twice.
64 Guest(s)
Devices in use: Desktop (56), Phone (8)
