Kitkat ROM request for Bauhn AT-HK97 Tablet
Bauhn branded RK3188T 9.7" 1024x768 tablet
freddofrog
46
2015/03/17 - 23:08
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2504
Hi Oma,
Installed that fix, but on reboot I just get the Bauhn splash screen then black.
Dmesg has only 1 line:
klogctl: Operation not permitted
Logcat below:
--------- beginning of /dev/log/main
I/ARMAssembler(  105): generated scanline__00000077:03545404_00000000_00000000 [ 29 ipp] (43 ins) at [0x411df1f0:0x411df29c] in 423208 ns
I/ARMAssembler(  105): generated scanline__00000077:03545404_00000A02_00000000 [ 30 ipp] (52 ins) at [0x411df2a0:0x411df370] in 67958 ns
Thanks Received: 1385
47
2015/03/18 - 18:49
Ups sorry, this was for CM11. Here is the right one for the KK build: http://crewrktablets.arctablet.com/?wpfb_dl=2510
freddofrog
freddofrog
48
2015/04/22 - 13:55
Hi Oma,
Thanks a lot! That worked (donation already on it's way). Sorry I didn't get back to you earlier - crazy few weks.
A couple more things though:
- Bluetooth doesn't work
-Screen rotation is incorrect for apps. I keep wanting to rotate the tablet clockwise 90 degrees to read it properly.
-Screen rotation doesn't change for launcher
-Front and back camera are upside-down
Is it possible to fix those?
49
2015/05/17 - 12:49
Ok, on which build are you now? And which fix did you install?
freddofrog
50
2015/05/17 - 13:26
On build: "Oma RK31 Iron KK v1.2-24.05.2013"
Loaded this fix:
Latest dmesg: http://pastebin.com/vHuTL6Cb
Latest logcat: http://pastebin.com/rhHAKpvw
freddofrog
52
2015/05/17 - 14:44
Try again: http://crewrktablets.arctablet.com/?wpfb_dl=2527
Hi Oma,
Good news! Firefox is now the right way up as is Nova Launcher (I set the screen orientation to auto in Nova Settings).
No luck, sadly with BT. Still can't see any devices, or be seen by my laptop or phone.
Camera is rotated 90 degrees (I need to turn my head left to make it look right).
KK is so much faster than the old build this thing had. It's given a creaky old tablet a new lease on life!
Cytryn
Forum Posts: 35
Thanks Received: 4
54
2015/05/18 - 13:10
Im using also Odys IRON CrewRKTablets KK 4.4.2 v1.2. For camera need to replace '/system/lib/libcameraservice.so' with one from previous version KK 4.4.2 v1.1 (in this build camera worked ok) or Rk30 kitkat rom. I can upload u fix if u want.
Currently Online: avv2011
81 Guest(s)
Devices in use: Desktop (71), Phone (10), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
