Kitkat ROM request for Bauhn AT-HK97 Tablet
Bauhn branded RK3188T 9.7" 1024x768 tablet
ELIAS
Forum Posts: 15
31
2014/06/08 - 13:44
ziacko
the original firmware was available here - http://public.tempoaustralia.com/fw/at-hk97/
But it doesn't open anymore.
I've uploaded the  copy here - http://goo.gl/UdT6I7
Enjoy.
The root procedure is described here - http://www.slatedroid.com/topic/88850-rooting-rk3188-tablets/
The following users say thank you to ELIAS for this useful post:
ziacko
ziacko
32
2014/06/08 - 23:57
Thank you so much. You have no idea how badly I struggled with this especially considering that my coding experience is C++ and openGL. I'd really like to learn more aboutt this topic and help noobz like myself.
ziacko
33
2014/06/12 - 06:15
ok my tablet is now back ot normal but now i have 14 gigs worth of app space MWUAHAHAHAHHA! ive now got Deus ex: the fall, real reacing 3, XCOM, worms 3, Need for speed most wanted, the walking dead season 1, minecraft and Baldurs gate 1 all running well on my tablet. ive also put my entire 3D engine onto the tablet and i can compile it using c4droid and makefiles! thanks ELIAS!
Thanks Received: 1385
34
2014/06/19 - 19:20
RK903 wifi now working: http://forum.xda-developers.com/showpost.php?p=53272169&postcount=1774
v2.1 build is here: http://crewrktablets.arctablet.com/?p=2982
Maybe this works also for AT-HK97.
- Oma
freddofrog
35
2015/03/15 - 14:59
- Oma
Hi Oma,
I tried this build on my AT-HK97 (I'm a total n00b, first time flashing an android tablet).
I managed to install the driver, erase IDB and "Run". Run writes to flash, checks and say "Run OK", but tablet never boots into CWM. The screen just flashes.
Also: I copied the CrewRKTablets_KK_Iron_Format NAND.zip to an SD card and put it in the tablet. I also unzipped it onto the SD card (I wasn't sure which was right).
Help?
36
2015/03/15 - 15:05
You need to change the kernel in folder rockdev/Images first: http://crewrktablets.arctablet.com/?wpfb_dl=1724
CWM stuff is always in .zip format, so do not unpack.
freddofrog
37
2015/03/16 - 13:54
Hi Oma - thanks! That got me further, but not all the way.
Now I get a screen (in German) that asks to set the language. Every few seconds I get a dialog box that says , 'Unfortunately the process com.android.SystemUI has stopped'. It's quite hard to dismiss it and proceed to set the language (to English in my case).
Eventually I manage to set the language, and press the next button and it gives me 'Select Wi-FI' (continuing with the annoying dialog), saying 'To see available networks, turn Wi-Fi on'. I skip this step (I guess it means WiFi doesn't work) but I still can't get rid of that dialog for long.
After a few more steps I can get into the android desktop (choosing Nova launcher?), but I can't get rid of that dialog for more than half a second or so.
Also, the screen flickers slightly.
Here's a logcat log: http://pastebin.com/9WwqJ9VP
K
38
2015/03/16 - 17:01
Pls install the 160dpi fix via CWM.
freddofrog
39
2015/03/17 - 05:58
Hi Oma,
Wow! Thanks again. Installed CrewRKTablets_KK_4.4.2_Iron_v1.2_160dpi.zip. That worked. Screen not flickering, and I'm not getting the dialog.
But: wifi doesn't work.
I click the wifi on switch, it stays grayed out,  i still see "To see available networks, turn Wi-Fi on" and I can't turn the wifi button off (it hangs).
Another logcat: http://pastebin.com/JFYk1pWn
40
2015/03/17 - 06:12
Interesting log. It says RK901 wifi and loads a mt5931.ko. Can I have a dmesg log pls?
freddofrog
41
2015/03/17 - 06:19
Oh dear - interesting sounds ominous.
Here's the dmesg: http://pastebin.com/ACuD3W7b
freddofrog
42
2015/03/17 - 06:27
I got the firmware upgrade I was running previously from here: http://public.tempoaustralia.com/fw/at-hk97/
I don't know if that has any hints in it.
Looking through previous messages in this thread, it looks like some people have been editing rc.init, but I don't know what to look for to change (or even how to do it).
K
43
2015/03/17 - 06:29
Hehe - just german usage of English language ;-)
<4>[ 31.008603] Current WiFi chip is AP6210.
But indeed ominous! I will have a deeper look into that tomorrow latest.
freddofrog
44
2015/03/17 - 06:36
If it helps at all, I can setup an adb server you can connect to (in about 30 minutes).
45
2015/03/17 - 17:47
Pls install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2504
Currently Online: avv2011
81 Guest(s)
Devices in use: Desktop (71), Phone (10), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
