kiano elegance 9,7 by zanetti without 3g
gebe14
Forum Posts: 13
2014/06/10 - 17:19
you need to turn off the tablet, connect the USB cable to the computer, and holding vol up holding down the power key, and you hear the sound in the windows, then the tablet is in flash mode.
that's what you meant?
this is instructions :
http://kiano.pl/wp-content/uploads/2014/06/Aktualizacja_oprogramowania_do_4.4_dla_elegance_97_by_Zanetti-2.pdf
Thanks Received: 1379
gebe14
Forum Posts: 13
2014/06/11 - 08:41
thank you, it works
if anything .. to go back to the stock rom, I have to change the loader?
2014/06/11 - 17:40
Stock KitKat is also gen 2 loader. In this case not.
When you'd like to go back to stock JB you need to flash the gen 1 loader first.
renatan7a
mormak
Poland
2014/06/23 - 10:33
Oma7144 - great work with rom for kiano elegance 9,7 by zanetti without 3G.
I have a question for you. Is there any chance for the same rom for model Kiano Elegance 9,7 by zanetti with 3G.
Please note that 3G model has a different specification than a model with no 3G.
Links:
1) instruction: http://kiano.pl/wp-content/uploads/2014/06/Aktualizacja_oprogramowania_do_4.4_dla_elegance_97_3G_by_Zanetti-1.pdf
2) stock rom: http://www.rgmedia.home.pl/Upload/Elegance9.73GAndroid4.4.7z
2014/06/23 - 20:19
Possibly only the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1875
Check it out.
gebe14
Forum Posts: 13
2014/08/26 - 11:51
hello.
a lot of people are asking the Polish forum for rom to Kiano 3g.
giving the above link you mean to replace kernel you provided to rom Kiano without 3g?
OuTchOrN
2015/03/12 - 09:26
Hello, is some possibly to run CM 11 on this tablet (Kiano Elegance 9,7 by zanetti without 3g)?
I try to install Odys Iron CM11, but he stuck on Kiano Display, and i had to use resset button.
Cytryn
Forum Posts: 35
Thanks Received: 4
2015/05/07 - 14:11
U have to use Oma's rom for Rk3188 which uses selinux kernel , probably u will need some fixes too, same for kiano elegance 9.7 with 3G.
Jakby co jestem na forum.android.com.pl ta sama ksywaCool
Cytryn
Forum Posts: 35
Thanks Received: 4
2015/05/07 - 18:50
You should try this http://crewrktablets.arctablet.com/?wpfb_dl=1737 for CM11 not kitkat selinux kernel
111 Guest(s)
Devices in use: Desktop (104), Phone (6), Tablet (1)
st14n_
KJC3101
uszoesaldana
hARCo86
Lyledowers23
vivianzhang
