2014/05/02
hi.
I have a tablet Kiano Elegance 9.7 to zanetti. based on the chip rk3188 , mali 400 . 2 mb ram.
I am looking for the android kitkat, you have something like this??
I uploaded his recovery, and has a root.
I greet. greg
specification:
Ekran | IPS 9,7″ 2048 x 1536 |  |
System | Android 4.2 | Â |
Procesor | cztery rdzenie Rockchip RK3188 1,6GHz | Â |
RAM | 2GB | Â |
Pamięć | 16GB |  |
Akumulator | 8000 mAh | Â |
Aparat, kamerka | 2 Mpix, 0,3 Mpix | Â |
Złącza | microSD, microUSB, microHDMI |  |
GPS | no | Â |
Bluetooth | yes 4.0 | Â |
HDMI | yes, micro | Â |
3G | no |
Download a terminal emulator from Play Store and type:
su
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd >/mnt/sdcard/mtd.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
dmesg >/mnt/sdcard/dmesg.txt
Upload the files to a file hoster. I will check.
No, we need all the images, flashable as a fall-back position. Other files are needed to get an idea of your hardware.
2014/05/02
ok my friend.
I prepared 3 files
these are the links:
part 1:
http://www23.zippyshare.com/v/11575340/file.html
part 2:
http://www23.zippyshare.com/v/3451962/file.html
part3:
http://www23.zippyshare.com/v/16301696/file.html
I keep my fingers crossed for you.
Please write if everything is fine with these files
Looks good.
ro.build.display.id=rk30sdk-eng 4.2.2 JDQ39 eng.root.20130805.165218 test-keys
kernel yf #38 preempt 05.08.2013: http://crewrktablets.arctablet.com/?wpfb_dl=1737
stock recovery is gone, this is a CWM
RK903 wifi-chip
And the wifi-chip will give us the challenge ... for now no KK build available, which will run on your JB stock kernel.
PD: parameter file attached, so you can restore the firmware by RKAndroidTool
2014/05/02
thx for your time.
but do not fully understand. the purpose for which you gave me kernel?
what do I do with it? replace uploading this rom for example? : http://crewrktablets.arctablet.com/?p=3319
I think it is the same tablet.
write me simply because I'm not quite sure what to do.
Nothing for the moment.
The linked build use another wifi-chip (RTL8723), so not compatible. However, just changing the kernel will be the way ...
I come back to you, when there is a suitable build for RK903 wifi. A lot of other guys are also keen on this
Let me have a look. Where can I find the firmware?
2014/05/02
here is the link
http://www.rgmedia.home.pl/Upload/Elegance9.7Android4.4.7z
is the official rom and it works
The following users say thank you to gebe14 for this useful post:
Yes, full customer build. I will publish that later on our site.
What is the first step (key-combination) to make the tab visible for RKBatchtool? Are there instructions to flash the stock firmware?
63 Guest(s)
Devices in use: Desktop (59), Phone (3), Tablet (1)
jenom
kfwacky
fer30
culo1
dfrt
PQNY
