JXD S7800B Gamepad 8GB - KitKat Stock Rom
Rom Download
witzdestages
Forum Posts: 11
46
2015/07/31 - 22:22
1. error @ 10GB
2. success @ 8GB
3. cant play games: Unlawfull Activity
4. NOT 1,6Ghz
5. How do you change the partition size of this rom and how to overclock the cpu?
pogodancer
Forum Posts: 127
Thanks Received: 35
47
2015/08/02 - 13:20
@ witzdestages
Please try the 8GB and 9GB with overclocked kernel and give feedback:
link removed
witzdestages
Forum Posts: 11
48
2015/08/24 - 16:06
 I flashed the 9GB and i have MAX 1416MHz ?
pogodancer
Forum Posts: 127
Thanks Received: 35
49
2015/08/24 - 18:13
@ witzdestages
1. The 9GB version works ?
2. Which app did you install to overclock ?
Try these:
S7800B_V4.4.4_1.6GHz_KK_2014-12-16_mod_09GB_OC
Please give feedback soon.
witzdestages
Forum Posts: 11
50
2015/08/25 - 00:25
1. The 9 GB works but i have only 1416MHz
2. AnTuTu CPU Master Free v2.5.3
I try it tomorrow
witzdestages
Forum Posts: 11
51
2015/08/26 - 15:16
9 GB -> still 1416MHz
witzdestages
Forum Posts: 11
52
2015/09/09 - 01:51
Can i use 3G sticks with this?
pogodancer
Forum Posts: 127
Thanks Received: 35
53
2015/09/09 - 19:21
@ witzdestages
Sorry for replying late.
If you cannot overclock the kernels I recommend you to install lujjis firmware. He posted it on dingoonity.
No idea, how to use a 3G stick. As I don't have the device anymore you should ask at dingoonity. Thanks.
153stars
54
2016/01/02 - 05:24
Is this FW from newest jxd release http://www.jxdofficial.com/firmware they don't seem to include date and version info. I have been using this one on my granddaughters unit .
I would like to add that nofrillscpu set on interactive seems to cause deepsleep problem on some units with this or Lujji's FW. ondemand seems to fix the problem.Hers would sometimes freeze playing android games without nofrills cpu. Battery and temps are so much better using nofrillscpu it's very valuable to this unit.
Thanks for your work.
pogodancer
Forum Posts: 127
Thanks Received: 35
55
2016/01/02 - 20:32
@ 153
Yes it's the same firmware as my latest and the lujji firmware.
boyington
France
56
2017/11/18 - 07:44
Congratulations for the rom with 9 go, ( S7800B_V4.4.4_1.4GHz_KK_2014-12-16_mod_09GB_OC.img ) it's superb and the storage  is there with a sd of 64 go, it's very good. I tried to put a recovery, but I have error messages with e: can t mount sdcard ... and no possible to wipe, no backup, nothing. Please do you have a good recovery who works with your nice rom? possible to link to download and install it please?
==> I just have a problem with keymapper, on the home page if I click on the physical button to keymapper, the settings appear 1 time, if you press again, the settings disappear, but if you press again, nothing comes, no settings, the button remains inactive.
I m very happy find your forum !
Greetings.
BoyingTon
pogodancer a dit
@ ADz83
1. Partition size: I didn't test to change it. If you like I can make a testrom without any guarantee for you. Which size do you prefer ?
2. Clockwork recovery: If you are playing around flashing different recoveries. You also could test this one without guarantee:
recovery_CWM_test_s7800b
Let me know if it works. If not I will remove the link to prevent confusion.
==> Have u got the link and info how to install the recovery pls ? Possible tactile recovery landscape ?
 Thank...
Edit 22 / 11 :
After testing, I love the Rom, with its possible settings GRAVITYBOX I love, but there is a problem:
When I play a game, need for speed or assassin creed, or other, the table crashes always after a few minutes, it goes out suddenly, without warning, and it's hard to turn it on again afterwards must insist that it lights up.Would you have other links with a different size, I search with the maximum of space + SD card, it's really sad because the rom with 9 go was top. Do you have the same with 8go or 7 go, or 10 go that works surely?
Wise is it possible to install another rom with the partition settings kept at 9 GB without reinstalling all applications please?
Thank you very much.
boyington
France
57
2017/11/29 - 02:51
Hello
After many testing games, all the times crash with the rom 9 go, I have read the topic, and install the kitkat rom with 12 go with this page ( 14go don t possible to install, message error, but 12 go is ok ):
https://boards.dingoonity.org/jxd-devices/(s7800)-kitkat-custom-firmware-(android-4-4-4)/
I have installed the kernel with 1704 mhz, and all is good, with program :  no frill cpu control  in interactive mode, and all is good and very speed tablet !!! i play 1 hour NDF most wanted games, and no crash, all is good.
I have change the name in the build because it s samsung in the s7800b with this rom ( i remember I9350 samsung or else ) But xposed frameworks don' t works with samsung name ! i change the name with JXD model s7800b, and after Xposed was install directly and with no problem, before with the name Samsung in my tablet , impossible install xposed. I change the name and detail JXD info with this : Kernel Tuner in aptoide, very easy with this appli.  If that s can help...   😉
My JXD now is very very speed and stable with this rom, This rom is very good too for play or works, i have install canal + TV France, and all is very good. but no mapper when i push the physical button on the JXD, and i hate tincore mapper, it s for my children's and it s very hard for him. Pls have u a solution to have the mapper button with the last mapper like your rom, not tincore ? Please. I hope it s possible because i want to have the same like your rom, or the lasted in french language mapper, like the official JXD firmware.
I have install very easy the recoveru cwn with your great program find here : ARCTOOLS   <==  top top top and easy !!! Thank you for this great program appli ! I recommanded it now for all !
 For info, i think i have more good wifi with this help find here :
http://www.phonandroid.com/forum/pour-root-ameliorer-la-vitesse-de-votre-connexion-wifi-et-4g-t115272.html
I have add this in my jxd : in the  build.prop  file
# Added by xbillou
net.tcp.buffersize.default=6144,87380,110208,6144,16384,110208
net.tcp.buffersize.edge=6144,26280,35040,6144,16384,35040
net.tcp.buffersize.evdo_b=6144,262144,1048576,6144,262144,1048576
net.tcp.buffersize.gprs=6144,8760,11680,6144,8760,11680
net.tcp.buffersize.hsdpa=6144,262144,1048576,6144,262144,1048576
net.tcp.buffersize.hspa=6144,87380,262144,6144,16384,262144
net.tcp.buffersize.lte=262144,524288,3145728,262144,524288,3145728
net.tcp.buffersize.umts=6144,87380,110208,6144,16384,110208
net.tcp.buffersize.wifi=262144,524288,1048576,262144,524288,1048576
I have test before add text and after, and it s true, i have more good wifi in my test too...
==> Please help me to have the last mapper like your rom please...
Sorry if my english is small, i m french and used a tranlator.
Greetings.
Patrice.
PS : just a question, is it normal to have porn page link in the end of your forum ? Or it s my PC ?
I have this : End page forum with porn !Image Enlarger
84 Guest(s)
Devices in use: Desktop (51), Phone (32), Tablet (1)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
