2013/04/11
@ souzafl
My battery drain seems to be OK also.
Maybe you want to test lujji's rom:
2013/04/11
@ souzafl
I am not 100% sure but I estimate I have a working time about 4 hours. With Android 4.2 it was about 5-6 hours - if I am not wrong.
1. Did you try to copy the default keymapper from the stockrom and install it on lujji's rom (after deleting the tincore keymapper) ?
2. Getting familiar with Tincore is not the hardest part. Take 2 hours and you should get it.
Good luck.
2015/02/19
With flash livestream watching over wireless and a little android gaming, i would also estimate my battery lasting not less than 4 hours. But I also have nothing else installed that would drain battery, and I tend to kill apps (like playstore) completely instead of letting them linger in the background.
On my mobile running CM11, there is a menu entry "battery use" which I wanted to point you to, to see what uses up your battery. But oh, the jxd rom doesn´t have it. hum.. to bad, it was really usefull.
This seems to be the equivalent app on play store: https://play.google.com/store/apps/details?id=com.gsamlabs.bbm
edit: okay, I installed that app together with the root companion, it shows very handy stats, you should give it a try.
2015/05/25
I tried to install this rom on my JXD device. At first i wanted to upgrade the loader to V2 as the instructions said, but unfortunately i stuck at the very beginning.Â
In the Development Tool i tried to "Erase ID Block" but it is saying that "This operation did not do, because of not supporting".
Do you have any ideas how i can get through?
2013/04/11
@ playa
sorry for the late reply. No problem if you go from 4.2 to 4.4. The firmware includes the correct loader and it will be flashed correctly. But if you want to go back from 4.4 to 4.2 there is no other way than to flash the loader1 first. That's the only reason that it would be fine if you are familiar with changing the loader.
Once again: You can flash the 4.4 firmware when you are on 4.2 without anything more. And I think you are satisfied with the 4.4 rom. So no need to think about going back to 4.2.
Good luck.
2013/04/11
witzdestages said
OK, have a backup via cwm on my external sd-card and flashed the rom that you recommend (the 2nd rom that work on my jxd).You can only make a rom with internal sd-card? everything (internal)/nothing (int. sd-card)?
I dont need 2 partitions but if its not posible than 6GB/7GB
Can you overvclock the cpu to 1,6Ghz?
AND how can i turn off this annoying Buttons on the Display?
With the CrewRKTablets_Odys_Iron_Omni_.4.4_v1.4.1_for_S7800B_lujji-Kernel rom i can play games they are have too many bugs on the original firmware and your rom have the same bugs.
If you like you can try different partition settings and lujji's last kernel. Don't forget to give feedback if and what works for you.
(Link removed)Â
About what "annoying Buttons on the Display" are you speaking ?
71 Guest(s)
Devices in use: Desktop (64), Phone (7)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
