2014/10/13
aspen01 said
I have explained myself badly. I installed the new rom kk and I had problems with real racing as explained before. then I installed another rom as written in my previous post. I understand that you have installed the rom kk and haven't had any problems with real racing I have not been able to make it work. What version you have installed by real racing? shame because the rom and very fluid and fast.
But are you sure you installed THIS KK rom? or are you referring to the stock KK rom?
I just installed latest version from market and let it download the game data. No problems with screen.
2014/10/13
pogodancer said
@ ADz83Thanks for your support. I was off a few days. Do you have an old (2013 device) or the newer T-model (2014) ?
Nice to have another german user here in this native german forum.Â
I'm not 100% but I think I have a -T device as I had the power/sleep bug on some roms before the fixed kernels were released.
Sorry m8 but I'm English, what made you think I was German?Â
2013/04/11
@ ADz83
Thanks. It's fine that you have the more crappy T-device. Because if you have no issues with the rom that means that it should work for most of the users. Users with old devices just me seem to be more free of issues.
I thought you were german because your LMGTFY-link comes in german language. But I think that was because my browsers settings. Never mind. Glad to have you here. Thanks for your support.
@ Aspen
This app is used in lots of roms for rotation adjustment. Mostly it is included in the system/apps:
Good luck.
2014/10/13
pogodancer said
@ ADz83Thanks. It's fine that you have the more crappy T-device. Because if you have no issues with the rom that means that it should work for most of the users. Users with old devices just me seem to be more free of issues.
@ Aspen
Good luck.
Yeah no issues so far except the usual crappy wifi which I have had in all roms. Lujji's new kernel seems to have a new Wifi driver so may give his new rom or just kernel a try as well. However this new KK build seems most stable and smooth for me so farÂ
2015/01/14
hello ... just install the version provided by pogodancer friend, but she's different from the pictures of the original post. How do I replace the bottom bar of android and also the battery information and the wi-fi data clock in the bar (top bar)? Is there any way to improve aa josgos compatibility in google play?
Thanks for any help!
2013/04/11
@ souzafl
Install GravityBox with XposedFramwork. It lets you customize the statusbar (top) and navigation bar (bottom), make them transparent and make them disappear.
Install Play Store Fix with XposedFramwork. Set the DPI to 160 or 240 and restart your tablet. Now the Playstore compatibility should be better.
Good luck.
2015/01/14
my friend thank you for your help. is working very well. Now there is the possibility of a kernel for this ROM 1.6GHz while maintaining the standard keymapper? I am also having problems with real racing game. it only works with the image vertically. installed APP rotate, but it did not work. is there another option?
2013/04/11
@Â zippyzuppi
1. Yes you can flash this rom over the stock 4.2.Â
2. For flashing the loader you have to enter the flashmode just like you flash a whole firmware with the RKbatchTool. It is not mandatory to flash the loader2 when you come from a 4.2-firmware (loader1) but it has the advance that the nand will be cleaned. And it makes you understanding and gives you experience about the need of using the correct loader before flashing another firmware. Never forget to think of the loader before changing the firmware.
2015/02/19
Thanks for your answers - and so I get into the flashmode first, just like you described before flashing the image, by pressing Vol UP and Power off.
But do I have to repeat this, meaning, get into the flashmode again, before flashing the rest of the image or can I just change to the according Utility?
...and sorry for crossposting, I was a bit desperate yesterday.
2013/04/11
@ zippyzuppi
Once in the flashmode you can first use the developer tool to flash/delete/erase the loader. If you have finished this you can directly open the other tool RKbatchTool and you can go on working without rebooting. You will still remain in the flashmode for doing several operations - No need to reboot manually.
The following users say thank you to pogodancer for this useful post:
zippyzuppiMost Users Ever Online: 749
70 Guest(s)
Devices in use: Desktop (63), Phone (7)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
