2014/08/22
pogodancer said
@ alighieroI downloaded the rom file again and flashed it with RKbatchTool without any issue (see screenshot).
The error is definitely on your side (other gamepad-model, crappy USB-cable, Windows drivers ...). I already recommended to go back to the last rom you had before which was satisfying for you.
here is the error. I do not understand the truth tried everything to destellas and always follows.
2013/04/11
... because Oma's and the Crew's unofficial CyanogenMod 11 (KK 4.4.4) has landed on my gamepad JXD S7800B with 8GB:
CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1_JXD-S7800B_beta
Feel free to post any issues to optimize. Thanks.
The following users say thank you to pogodancer for this useful post:
pogodancer said
... because Oma's and the Crew's unofficial CyanogenMod 11 (KK 4.4.4) has landed on my gamepad JXD S7800B with 8GB:CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1_JXD-S7800B_beta
is this newer than the 1.4 version in the first post? what is the difference?
2013/04/11
@ GrimyHR
Both are KitKat 4.4.4 roms. But these are 2 completely different roms. The one is an Omni and the other is CyanogenMod. Find more informations about those customs roms with Google.
Oma made the last version of Omni (1.4) in August 2014. His Cyanogen rom (1.1) was made in June 2014. I think the CM11 (yet) is for people who want a Cyanogen rom because they are getting used to or just to test. The CM11 is not perfect yet. If you want a perfect and reliable rom you should use the Omni rom. As far as I have seen everything works. The hardware buttons and sticks should work out of the box without any issues.
Have a try. The roms are freeware.
2014/08/21
pogodancer said
@ GrimyHRBoth are KitKat 4.4.4 roms. But these are 2 completely different roms. The one is an Omni and the other is CyanogenMod. Find more informations about those customs roms with Google.
ok thanks, didnt notice
oh, and what kernel are these roms using? a custom one, or jxd stock, and if stock which one?
2013/04/11
@ GrimyHR
But you can replace the kernel if you have a better one. Let me know then I can make an update if you like. But please don't share this rom with other kernels or other changes in another forum than this one. Because it's Oma's and the Crew's work. This should not be forgotten. Thanks for understanding.
2012/11/19
Thanks!
2012/10/25
Could you give the kernel build please ?
I have the last version of the tablet, and the ONLY rom usuable with it is :
http://boards.dingoonity.org/jxd-devices/power-button-reboot-issues-here%27s-a-new-kernel-to-fix/
Mine has : 3.0.36+ Yunboa@server-249 #5
Built on June 5 09:36 CST 2014
83 Guest(s)
Devices in use: Desktop (75), Phone (8)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
