JXD S7800B Gamepad 8GB - KitKat Omni Rom
Rom download
pogodancer
Forum Posts: 127
Thanks Received: 35
46
2014/08/27 - 21:31
Please my friends, don't destroy your devices. I absolutely cannot understand your problems. I think I flashed my S7800B about 50 times. I installed THIS (Omni Rom) five times and never had any small problem. After I went back to absolutely stock to check if there is a problem, but there wasn't one. Now I am playing around with CyanogenMod. Some weeks agon I installed the stock-beta-KitKat with 2-generation-loader. Here there was a little problem (just to delete IDB) to go back to JellyBean (loader 1). But I never had a real problem.
I always could help myself by long pressing the power button oder by using the reset button. So I absolutely cannot recommend you to open your devices.
By the way, I also tried Maetels, WebClaws and Yamatos roms. But the best til now is Omas Omni Rom. At the moment I am playing around with CyanogenMod. I am curios if it will work on my device.
But back to topic. Please be careful with your devices. I cannot image that opening and shortening is necessary. No matter what rom you use.
alighiero
Forum Posts: 20
47
2014/08/27 - 23:52
I've tried a thousand times to have this ROM and does not always give problems. which will not be the problem but you can not flash always fails. if you say that is the best that we all have the same problem? if you want we use team viewer and try to install the rom on my JXD. really causing the error.
the only way to repair the damage is by doing the following:
neither I nor this forum we become liable for damage caused to your device
- You open the console
- Beside left joistick this NAND
- Connect the USB cable to the JXD
- By pressing the Volume Up button
- With a metal pin or make jumper pin 8 and 9 (they only make contact)
- Have pressed the power button.
- And make the contact pins
- Will recognize them quickly JXD
- Hold the power button
- Flash the stock firmware 1.14
pogodancer
Forum Posts: 127
Thanks Received: 35
48
2014/08/28 - 06:39
Did you try another USB cable for flashing ?
alighiero
Forum Posts: 20
49
2014/08/28 - 08:28
Course. but continues to set the same error. any other ideas to get it?
I want this "ROM" eager. pity that fails.
pogodancer
Forum Posts: 127
Thanks Received: 35
50
2014/08/28 - 13:45
When I am back from work I will download the latest version from Post 1 and install it to be sure that the file is not corrupt.
In the meantime you could try to install my stockrom mod 1.5 (newer than 1.14). You find it in the s7800b thread on android-Hilfe.de. If you also cannot install this you maybe have another device than me or your USB cable is crappy.
pogodancer
Forum Posts: 127
Thanks Received: 35
51
2014/08/28 - 17:37
@ alighiero
I downloaded the rom file again and flashed it with RKbatchTool without any issue (see screenshot).
The error is definitely on your side (other gamepad-model, crappy USB-cable, Windows drivers ...). I already recommended to go back to the last rom you had before which was satisfying for you.
RKbatchTool-1.PNGImage Enlarger
alighiero
Forum Posts: 20
52
2014/08/28 - 18:48
I used this cable to flash the stock ROM and does not give problem. the driver already I can flash other custom rom. and the model is exactly JXD S7800b.
pass me by private message the link of your stock mod 1.5 please
that is not what fails. but many are also the same. that have come to completely bricking their consoles
sorry for my bad English I use google translator
My recommendation would be to put a video step by step how you install the rom if the event we are doing something wrong.
pogodancer
Forum Posts: 127
Thanks Received: 35
53
2014/08/28 - 19:31
The following users say thank you to pogodancer for this useful post:
alighiero
alighiero
Forum Posts: 20
54
2014/08/28 - 19:36
Thank you. and we do have that I want to install this Omni Kitkat Rom. help please.
wild blood is compatible with stock rom 1.5 mod ??
pogodancer
Forum Posts: 127
Thanks Received: 35
55
2014/08/28 - 20:19
answer
alighiero
Forum Posts: 20
56
2014/08/28 - 20:39
pogodancer said
answer
I meant the other rom. stock mod 1.5?
to this: Stock Rom Mod 1.5
pogodancer
Forum Posts: 127
Thanks Received: 35
57
2014/08/28 - 21:09
@ alighiero
Give me 6 Euro and I will test it. LOL.
alighiero
Forum Posts: 20
58
2014/08/28 - 21:15
pogodancer said
@ alighiero
I got it from a clandestine way (I'm a badass)
help me to find the best solution to install the "omni ROM"
pogodancer
Forum Posts: 127
Thanks Received: 35
59
2014/08/28 - 21:29
@ alighiero
Sorry I cannot help you. Please let's finish this question. Thanks.
alighiero
Forum Posts: 20
60
2014/08/28 - 21:34
pogodancer said
@ alighiero
it's okay. follow. what will be the problem installing "Omni rom"? I destallado and 10 times and still the same problem. flashe from windows xp and windows 7 and from the same.
76 Guest(s)
Devices in use: Desktop (70), Phone (6)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
