2014/08/22
pogodancer said
@Â alighieroStay cool. I don't know how you got an softbrick. But take a coffee or an beer and do this:
1. Push the reset button with a thin stick so you can hear or feel a "click".
2. Start the RKbatchTool on your computer and load the firmware.
3. Hold and keep volume+ on the device
4. Connect the device to the computer via USB
5. Hold the power button until the RKbatchTool shows "green".
6. Choose RESTORE in the RKbatchTool
If this does not work do this:
3. Start Oma's RKandroidTool (post #1)Â
4. Hold and keep volume+ on the device
5. Connect the device to the computer via USB
6. Hold the power button until the RKbatchTool shows "green".
7. "Erase IDB" in RKandroidTool
8. Choose RESTORE in the RKbatchTool
3. Start Oma's RKdevelopeTool (post #1)Â
7. "Erase ID Block" + "Erase All Blocks" in RKdevelopeTool
MOST IMPORTANT IS TO STAY COOL.
2014/08/22
pogodancer said
@ alighieroDid Omni Rom work ?
Which rom you had before Omni Rom ?
did not work because when flashing "Omni rom" gave me the problem.
first time I tried to put Kitkat. before MAETEL LEOPARD CUSTOM FIRMWARE had worked great and my jxd. 'm sad not to be able to repair my gamepad.
2014/08/22
pogodancer said
@ alighieroI am 100% sure you can reflash your device again to make it work. You can not destroy a Rockchip device easily.Â
him down twice and I always mark error.
Thanks in advance
2014/08/22
pogodancer said
@ alighieroNice to hear that your device is running again. My files are not corrupt. But I recommend you to stay on the stockrom or to flash Maetels rom again which you were happy with.
Maybe you have a T-model and maybe Omas firmware does not work with it ?
thanks friend. I tried flashing it in many ways and I can not have this rom.
the rom looks great and I really like. I want it installed. can you help me is there any other way to install it?
2014/08/27
alighiero said
Now windows does not recognize my JXD, try to reset from the reset button and still does not recognize it, probe the power button and volume up and nothing.
apparently is a total brick. can someone help me relive my console please
Hi alighiero,Â
how did you repair your device and got back to stock firmware? I have exacty the same problem.
Mann thanks in advance
2014/08/21
alighiero said
my jxd repair. has the stock firmware. but I can not install this rom. following the steps of the file "txt" always marks error. You can upload a video tutorial to install it? or the file is corrupt mega?
Thanks in advance
i also got an error in rockchip batch tool after flashing this rom, restarted by holding power butom for several seconds, went in to recovery, wiped and than restarted again and it worked, well at least instalation worked and rom booted, webclaws rom works much better, especially wifi, and dont use maetels roms
2014/08/22
Legosan said
apparently is a total brick. can someone help me relive my console pleaseHi alighiero,Â
you have to remove the chip and there JXD alongside the pad. connect via USB and hold the Volume Up botton. with some metal then you do a short pin 8 and 9. and ready the PC recognizes it immediately.
2014/08/22
Thanks in advancei also got an error in rockchip batch tool after flashing this rom, restarted by holding power butom for several seconds, went in to recovery, wiped and than restarted again and it worked, well at least instalation worked and rom booted, webclaws rom works much better, especially wifi, and dont use maetels roms
almost 95% of the check rom gives me the error. as I enter the recovery menu after flashing this firmware? you pass me the link of the rom WebClaws? please the best of the Rom.
2014/08/27
alighiero said
you have toremove thechipand thereJXDalongside thepad.connectvia USB andholdtheVolume Up botton. with somemetalthenyou doa shortpin8and 9. and readythePCrecognizes itimmediately.
Sorry, i don't get it.
- Connecting via USB => Check
- Hold Volume Up button => Check
- Remove Chip (sdcard) => Check
What do you mean by "do a short pin 8. and 9."?Â
76 Guest(s)
Devices in use: Desktop (68), Phone (8)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
