2014/11/24
pogodancer said
@ nirolf- you see the external sdcard and you can use it ? Correct ?
>> yes, thats correct
- you won't have a separate internal space like you know it from other roms. All available space is used for apps and files in the same manner.
- if you want to be my test dummy I could try to give you a Rom with 14GB of unified storage.
>> yes, why not
But is still have problem 2 : cant move from internal storage to external sd card
(the options doesnt show up in system -> apps ( i have nomove to sdcard button !! )
(i meant like this
and it seems that the SDFix: KitKat Writable MicroSDÂ Â is already applied
(and i have another chines tablet with kitkat, where the move to sd card option is available
so, i dont get whats preventing this option to show up)
2014/11/24
pogodancer said
@ nirolfThis Rom doesn't have the feature to send apps to sd.
>> can this be enabled in the build ?
If you want that you have to use apps like Link2SD. Somewhere in this thread another user found an app for moving folders. Have a look.
Should I upload a 14GB testrom for you tonight ?
>> whenever you have some time, no rush, thank you, and good night
2014/12/31
Hello OMA, i have a little problem here...
the camera is upside donw, all the other apps have the correct rotation.
how did i fix it?
i tried to install this, but not fix the error:Â http://crewrktablets.arctablet.com/?wpfb_dl=1369
can u help me?
thanks
Our OmniRom provides the possibility to customize orientations. Use a Root Explorer to edit build.prop settings:
ro.sf.fakerotation=false
ro.sf.hwrotation=0
ro.camera.front.orientation=0
ro.camera.back.orientation=0
pogodancerPer aspera ad astra, we rock the Tablets !
2015/07/23
I have a 16GB JXD s7800B und download this CrewRKTablets_Odys_Iron_Omni_.4.4_v1.4.1_for_S7800B_lujji-Kernel ROM and ist works an my Tablet, but i have only 6GB, how can i get other unused storage back?
all other (all) ROMs fail by "upgrade". Ca any one make a 16GB version of this?
2013/04/11
@ witzdestages
I recommend to use this rom:
If you still have problems with the internal space let me know and we can try to solve it.
2013/04/11
@ witzdestages
But you don't have working headphones with the Omni rom. Do you ?
It is not possible for me to make the Omni rom with unfied storage. But if you like I can try to change the partition sizes for you. It's trial and error. You have to flash each time completely until we got the right size for you.
Wait for your reply.
2015/07/23
OK, have a backup via cwm on my external sd-card and flashed the rom that you recommend (the 2nd rom that work on my jxd).
You can only make a rom with internal sd-card? everything (internal)/nothing (int. sd-card)?
I dont need 2 partitions but if its not posible than 6GB/7GB
Can you overvclock the cpu to 1,6Ghz?
AND how can i turn off this annoying Buttons on the Display?
With the CrewRKTablets_Odys_Iron_Omni_.4.4_v1.4.1_for_S7800B_lujji-Kernel rom i can play games they are have too many bugs on the original firmware and your rom have the same bugs.
105 Guest(s)
Devices in use: Desktop (92), Phone (13)
jackthomas
hakhiem
jenom
kfwacky
fer30
culo1
