JXD S7800B Gamepad 8GB - KitKat CyanogenMod 11 Rom
Rom download
ADz83
Forum Posts: 19
2014/10/16 - 05:27
pogodancer said
@ ADz83
Because of the unified storage you cannot use mass storage. When you connect your device via USB you can access it as MTP from your computer.
Unified storage?
Is there any way to revert back to standard storage so that I can enable mass?  I dont have this issue on CM11 for other devices  :(
This is the only real issue I have noticed so far.
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/10/16 - 17:25
@ ADz83
This isn't an issue. It is normally and wanted with some roms. For the Omni and CM11 rom for S7800B there is no way to change it.
But where is the problem ? You connect your device via USB and open its storages as an MTP device. You can access (copy to and from it) just like you are working with a mass storage device.
You can read more about this rom here:
RK31: Odys IRON – CM11 Edition
ADz83
Forum Posts: 19
2014/10/16 - 18:01
pogodancer said
@ ADz83
It can cause many problems with programs because it's not shown as a real drive in Windows or other USB compatible devices.   Mass storage is just an all round much more compatible option for many scenarios.  It's not just for moving files.
Thanks for link.
ADz83
Forum Posts: 19
2014/10/16 - 18:08
..by the way,  will you be porting updated versions when released?  :)
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/10/16 - 19:31
For sure I will update the S7800B-rom when there is an update from Oma and the Crew.
The following users say thank you to pogodancer for this useful post:
ADz83
ADz83
Forum Posts: 19
2014/10/16 - 19:33
Thanks, much appreciated  :)
Out of curiosity,  do you have any info on how you port the rom over to the S7800B?
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/10/16 - 19:50
When you want to make a rom from a similar hardware make running you need a lot of luck to find one that fits. Mostly you have to change the kernel. When the rom is booting you have to do minor changes for having the right rotation, resolution, camera, sound and partition tables. It's a bit tricky and I recommend to be sure to know what to do when playing with these things.
ADz83
ADz83
Forum Posts: 19
2014/10/26 - 18:27
Had to stop using this,  seems there is an issue with the D-pad etc as controls seem to be rotated and couldnt seem to map anything properley  :(
Will keep an eye out for updates  :)
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/11/22 - 18:40
I updated the image in post #1 from Oma's version 1.1 up to 1.2.
Use TincoreKeymapper for changing the dpad directions.
Have phun.
Edzward
Rio de Janeiro - Brazil
2014/12/03 - 13:42
Have phun.
If don't want or can't use Tincore I believe that you can manually edit the keylayout to correct controller orientation. If I recall correctly the file is located at /system/usr/keylayout/generic.kl
Here is a little rundown. I'm at work and don't have my device with me right now.
1 - Use your preferred root file explorer and navigate to /system/usr/keylayout/ and look for the generic.kl file, backup it (copy and rename adding .bkp, .copy, .original to the end, use something easy to find if you need).
2 - Open the generic.kl file in you text editor and look for the keys corresponding to the DPAD. It should be around 100-something.
3 - The DPAD is rotated counter-clockwise which means you have to change the layout as follows:
UP->LEFT
RIGHT->UP
DOWN->RIGHT
LEFT->DOWN
3b (optional) - In the same file, swap the buttons A->B and X->Y.
4 - Save and Reboot. You should have the correct orientation now.
5 - Go to the first post.
6 - Hit thanks and done.
Note that for some games you still need Tincore to the right stick to work, but that solution should cover most games and emulators.
The following users say thank you to Edzward for this useful post:
pogodancer
Thanks Received: 1385
2014/12/03 - 17:43
Pls find attached different config files. May be that helps.
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/12/07 - 18:59
@ Oma
Thanks but your files did not do any changes.
@ Edzward
Thanks. These changes help to correct the Dpad. I will take it for the next firmware updates.
But I do not understand: Why isn't it possible to give the directions for axxis 3 and axxis 4 to the right analog stick. Which other files than the keylaout.kl and the keychars.kcm are reliable for the hardware buttons ???
Edit:
The GamepadTest app from Playstore shows the right analog stick as z and Rz. But it is not recognized in some android games like Dead Trigger 2. This should be possible to change anyway - but I don't know how ???
jcelis
Forum Posts: 13
2014/12/10 - 16:39
hello @pogodancer, if you please provide the link CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1_for_S7800B_BETA
which is the best rom for me.
in CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.2_for_S7800B_lujji-Kernel
there is a bug that does not work .emu emulators eg NES.emu, snes9x, neo.emu, etc.
awaiting the link CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1_for_S7800B_BETA
thank you very much
pogodancer
Forum Posts: 127
Thanks Received: 35
2014/12/10 - 18:05
@ jcelis
Which kernel ? Old 1.09. with headphones or lujji's new one ?
jcelis
Forum Posts: 13
2014/12/10 - 18:18
pogodancer said
@ jcelis
please reupload old version CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.1
this version to my work very well ..
if possible thanks !!
pd: and version CrewRKTablets_Odys_Iron_CM11_4.4.4_v1.2_for_S7800B_lujji-Kernel,  " kernel lujji "
Any idea how to fix friend's problem?
Currently Online: 2256667898, mogabi
84 Guest(s)
Devices in use: Desktop (77), Phone (9)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
