DNS AirTab P100QW. Need help troubleshooting KK.
Please, help solving 2 problems I ran into having installed RK3188: V88 by Oma – KitKat 4.4.4 Edition on DNS AirTab P100QW
Lainrad
2014/10/19 - 23:44
Good day to you, dear sires. Got a little problem here.
It's pretty hard for me, not being a developer, to figure it out, so please, help me.
Tried to install a RK3188: V88 by Oma – KitKat 4.4.4 Edition on this tablet.
DNS AirTab P100QW specs:
  • Rockchip 3188 Quad Core
  • 2GB DDR3
  • 16GB Internal Nand FLASH
  • 10.1" 1920x1200
  • Stock OS JB 4.2.2
  • Kernel 3.0.36+
The Kernel version seems to match, so I tried just to unpack our stock rom and paste it into this one. The firmware booted up, but there appears to be a couple of serious problems.
The first problem is a non-working wifi module. I suppose the root of it is that the firmware contains mt5931 drivers and my P100QW has an mt6620 adapter(there were drivers for it in the lib/module folder of the original firmware). Bluetooth is not working either, but it's not as much of a bother as wifi is.
My question is: Will the drivers from the original OS version work, or maybe I can find them somewhere else.
The second one is the touchscreen, it seems to be in some kind of mouse mode(the pressing is depicted on the screen as a round dot-like cursor, not directly under the finger, but acting like some touchpad) and working in the landscape mode only(it doesn't rotate along with the desktop).
Here's our Stock rom.
Help me, please, I'm stuck.
Lainrad
2014/10/20 - 08:28
Thanx a lot, I'll try digging in that directon.
Though they had no touch thing, could you please pinpoint me the way to go with this one?
2014/10/20 - 22:26
Kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2192
Touch screen is: ft5x0x - here is a fix: http://crewrktablets.arctablet.com/?wpfb_dl=2052
Lainrad
2014/10/20 - 22:59
Thank you so much, I'm beyond grateful for your help.
65 Guest(s)
Devices in use: Desktop (60), Phone (5)
hans41
rickybk
soniya07
ironmangitar
