2014/01/23
don't know if the obligatory language is english here, but I will do so. If german ok, please answer in german.
I bought a Odys Prime Plus some days ago and are now testing the stock rom. For now no problem. But I guess in some days or weeks I will feel the request of installing KitKat.
But for the first step I want only to have CWM recovery? Will that be no problem for the Odys Prime with the stock-rom? Or do I need to fear any problems?
Thanks a lot and just want to say: You do a really great job!
killah78
Prime Plus is the Prime with 3G?
The Prime was rooted - how about the Prime Plus?
du kannst einfach CWM flashen, WICHTIG ist aber, das du die PARAMETER (Partitionslayout) aus deinem Stock Rom nutzt.
Viel Glück
netlars
Ansosten hier ist auch noch was: http://www.arctablet.com/blog/forum/arctools-application/clockworkmod-cwm-recovery-easy-install-on-rk3066-and-rk3188-devices/
58 Guest(s)
Devices in use: Desktop (50), Phone (8)
