ct1020w carrefour (yifang m1010fp)(rk3188-8gb-10.1"-1280x800-no bluethooth) bricked ,need firmware!!!!
ct1020w carrefour(yifang m1010fp) bricked please help me !!!!
robdanmar
Forum Posts: 12
2014/08/03 - 17:14
Rk30sdk 4.2.2 jdq39 2013/11/11 use now
2014/08/03 - 19:27
Firmware form Odys Xelio Extreme or Pipo M8 or whatever?
robdanmar
robdanmar
Forum Posts: 12
2014/08/03 - 19:37
in use Pipo M8
I will try Odys Xelio Extreme
thanks!!!
power on = charge ok
power off and battery low = problem of level battery (= 0%)
robdanmar
Forum Posts: 12
2014/08/07 - 04:30
Hi friend
Charge and discharge for 3 oportinities and work ok
Thanks for your asistance
2014/08/07 - 07:21
Fine that the tab is back to life.
robdanmar
Forum Posts: 12
2014/08/10 - 21:45
Hi friend
Original kernel 3.3.6+     4.4.3.   #192      6 nov 2013
In use               3.3.6+     4.4.3.   #19.     30 sep 2013
Diferences?
Thanks!!!!
2014/08/10 - 22:24
I do not understand.
robdanmar
Forum Posts: 12
2014/08/10 - 22:31
Diferences in kernel original and kernel ROM flash for debrick tablet (problem battery = power charge and power on = status battery bad, charge disconected and power on status battery is ok)
robdanmar
Forum Posts: 12
2015/01/30 - 21:13
I've done some tests, and I tried 2 roms:
· "Odys Xelio 10 Extreme" works great with the device. It's the same as the original but cameras doesn't work
(original Yifang m1011fp Tablet, has two cameras: front 0.3 mpx - back 2.0 mpx)
· In "Pipo M8 Pro wifi RileyROM 2.1.2", cameras do work. But I have the (already explained) problem of the battery (if I turned the Tablet off, and then on, device would show no percentage of battery, unless I turn it on when plugged in to the charger). Or, if plugged in for five minutes while device is locked, that way I can see the correct percentage.
Is there any way to extract Pipo's cameras, and add those to Xelio rom?
I mean, adding them now as it is, or having to start over?
Thanks, I'm hoping for your replies.
2015/01/31 - 09:24
Pls check this build: http://crewrktablets.arctablet.com/?p=2982
Change kernel in folder rockdev/Images: http://crewrktablets.arctablet.com/?wpfb_dl=1808
In CWM install this fix: http://crewrktablets.arctablet.com/?wpfb_dl=1886
robdanmar
Forum Posts: 12
2015/02/01 - 21:08
No work does not start , pipo m8 pro, install misc and boot of xelio 10, work camera and batery and sd card memory internal no work :(
Please update.zip with camera fix friend to install to original recovery
Continuous with xelio 10 installing and cameras not work
clockwordmod instaling for arctools does not work ,black screen in recovery
Sorry my english is bad, son write yesterday
Astrobus
2015/02/28 - 07:00
Hi I think that I have the same Tablet, a Kelyx MF1011FP, would it possible to flash a Kit Kat rom to it?
50 Guest(s)
Devices in use: Desktop (48), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
