2013/12/25
hello
I did something stupid!
I wanted to update my risk CT1020w carrefour with a firmware that seemed appropriate and I brick my tablet ...
The upgrade of the tablet works, it is recognized if plugged into usb to pc but the screen stays black.
I tried to install different firmware for different tablet very similar to mine but the result does not change.
who can help me??
Thanks anyway
When it is a yifang M1010P then the firmware for Odys Xelio 10 Extreme or Pipo M8 pro should work:
http://www.android-hilfe.de/odys-forum/493328-odys-xelio-10-extreme-quad-2-gb-ram-16-gb-4.html
2013/12/25
Thank you!!!!!!!!!!!!
My tab now si live!!!!!
My carrefour ct1020w reborn with firmware of odys xelio extreme
🙂Â
Have only one problem ....the CAM in  Ct1020w si 2.0 MP and 0.3 MP ,odys xelio estreme have 5.0 and 2.0 MP .
The CAM not function!!!!!!!!
Can resolve the problem ?????
Sorry for  my bad english ......
Cam driver is in the kernel, so not really. Maybe check the hardware of the Pipo M8 pro.
Best would be to find an other CT1020w user who can dump the firmware.
Glad to hear that!
M1011P - is this a typo?
What is the efeect with the battery?
2014/07/31
hi friend thanks for answer!!!
my kelyx m1011fp is yifang 1011
same hardware 1010 and carrefour 1020
charge battery a full
erase for terminal batterystats.bin
su
rm /data/system/batterystats.bin
indicator 100%
spend battery 100% until shoot down
charge tablet in off to 100%
power on and battery indicator 1%, 5 minutes, 16% and 10 minutes 100% (charger conected)
is this regular?
stabilized with the following battery loads ?
thanks for your time!!!
Seems not the same hardware. Do you have still the genuine kernel?
2014/07/31
no backup, brick my tablet and no backup
hardware working 100% new rom
only problem in the battery status
whats the difference in hardware two tablet
touch 5 pointsÂ
screen 1280x800 ips
1gb ram
16gb rom
(original 2gb +14, now 4gb +12)
working bluetooth, wifi, cameras, etc... 100% good
thanks for your timeÂ
solution?
Yes, the problem is in the kernel.
Which firmware and kernel do you use on your Kelyx M1011FP?
55 Guest(s)
Devices in use: Desktop (44), Phone (11)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
