2013/12/09
Hi, Oma,
After I tried your cm10.1 rom for Yuandao (vido) N90ii DualCore, which are very successfully (only a small bug: when rotating the screen, there is always a big flash on the screen lasting for less than 1 second, and resume to normal), I would like to ask if your cm10.1 rom for RK3188 can work for my N90FHDRK? I can't find a kernel for N90FHDRK. Does your rom support N90FHDRK's retainer display? Will you put Ad_hoc wifi support by default for your rom?
Thanks!
If this is unacceptable for you then use the lastest v1.3.5 build: http://forum.xda-developers.com/showpost.php?p=48501953&postcount=802
I added wifi ad-hoc to our to-do list.
N90FHDRK is a high resolution tab. We don not have such a tab. Consequently there is no development for.
fuyun1965Per aspera ad astra, we rock the Tablets !
2013/12/09
Thanks for your reply.
1. I will try the lastest v1.3.5 build for my N90ii DualCore RK3066.
2. I will try the Ad-hoc fix as you provided, and will let you know the result.
3. Regarding N90FHDRK, do you think I can try "Oma_RK31_Chuwi_V88_CM10.1_4.2.2_v1.3.1"? I couldn't find the right kernel for N90FHDRK.
Thanks again!
Chan
2013/12/09
Hi, Oma, Can I install your Kitkat rom into my N90FHDRK?
Now already the next question is asked.
But please, answer the question first with the ad-hoc fix.
netlars
2013/12/09
Hi, Dear Oma, I would like to inform you that your wifi ad-hoc fix doesn't work for my N90ii DualCore with your RK3066 CM10.1 rom. Thanks! Please let me know if you have other solution.
First test wifi ad-hoc: http://crewrktablets.arctablet.com/?wpfb_dl=1303
114 Guest(s)
Devices in use: Desktop (103), Phone (11)
smalec
marek.test@gmail.com
MINIX2021
extendedtn
salimdz16
anonymunbekannter14
