CM 10.1 - Help me fix problems
Port cm from Crew RKTablets version, but there are some problems which need to be sloved - I NEED HELP
regent
31
2014/01/16 - 01:32
Unfortunately I haven't found anything. It's a pity that a m8pro fix is available but it doesn't work. Maybe someone could read the logs and understand what's causing the problem.
Maybe you should try to do it, too, to be sure that wifi is not working
Schokobecher
32
2014/12/19 - 00:09
@Oma7144
Any love for this tab? Anything I could do for a nice KK Rom?
Thanks Received: 1374
33
2014/12/19 - 09:09
Yes, the CM11 build should work: http://crewrktablets.arctablet.com/?p=3591
Replace parameter and kernel before flash. Install model fix after first boot into CWM.
110 Guest(s)
Devices in use: Desktop (91), Phone (19)
3187
wetpax
thesandhu18
Rxne
iamhouse
marcammi
Topics: 6030
Members: 261438
