CM 10.1 - Help me fix problems
Port cm from Crew RKTablets version, but there are some problems which need to be sloved - I NEED HELP
Thanks Received: 1374
2014/01/06 - 20:07
We already tried that without success. I don't know what the manufacturer patched to make wifi work with giving kernel. No chance without having the tab. Sorry.
regent
2014/01/06 - 20:18
1) is a problem of not proper formated NAND
- try again using stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=910
- flash CWM after first boot (tick parameter and recovery)
2) open the terminal and type: cat /sys/class/rkwifi/chip
- post the result
- install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=1361
1st issue is solved! I should have tried it. You are the best
I flashed model fix with no luck for wifi/bluetooth.
In terminal when I type
u0_a7@android:/ $  cat /sys/class/rkwifi/chip
I get this
RK903u0_a7@android:/ $
2014/01/06 - 20:40
Ok. Can you load rkwifi.ko manually.
insmod /system/lib/modules/rkwifi.ko
lsmod
regent
2014/01/06 - 21:02
wlan 458395 0 - Live 0x00000000
but nothing changes....
2014/01/06 - 21:21
Ok, boot tab fresh and try to enable wifi a few times. Load rkwifi.ko. Then:
dmesg >/mnt/sdcard/dmesg.txt
Upload the logs.
regent
2014/01/06 - 21:47
I rebooted but the logs are still big. Sorry about that
https://dl.dropboxusercontent.com/u/57398528/dmesg.txt
https://dl.dropboxusercontent.com/u/57398528/logcat.txt
EDIT: Some logs I pointed out.
dmesg :
<4>[   52.945500] Current WiFi chip is AP6330.
<4>[   53.116762] =======================================================
<4>[   53.116803] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[   53.116845] =======================================================
<4>[   53.116876] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.49.WFD) init.
<4>[   53.117046] =========== WLAN placed in POWER ON ========
<3>[   53.117115] ANDROID-ERROR) wifi_set_power = 1
<6>[   53.117142] rk29sdk_wifi_power: 1
<6>[   53.378669] wifi turn on power
<3>[   53.378730] ANDROID-ERROR) wifi_set_carddetect = 1
<6>[   53.997967] wifi shut off power
<4>[   53.997989] =========== WLAN placed in RESET ========
<4>[   54.081944] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903_ag.bin
<4>[   54.088540] Dongle Host Driver, version 1.28.13.1.1 (r)
<4>[   54.088546] Compiled in drivers/net/wireless/bcmdhd on Mar 18 2013 at 10:57:53
<4>[   54.088596] wl_android_wifi_on in
<3>[   54.088613] ANDROID-ERROR) wifi_set_power = 1
<6>[   54.088635] rk29sdk_wifi_power: 1
<6>[   54.341202] wifi turn on power
<4>[   54.341224] =========== WLAN going back to live  ========
logcat:
01-06 21:40:07.970 D/WifiService(  414): setWifiEnabled: true pid=491, uid=10036
01-06 21:40:07.990 D/WifiHW  (  414): Read wifi chip type OK ! wifi_chip_type = RK903
01-06 21:40:07.990 D/WifiHW  (  414): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
01-06 21:40:09.030 E/WifiStateMachine(  414): Failed to reload STA firmware java.lang.IllegalStateException: command '8 softap fwreload wlan0 STA' failed with '400 8 Softap operation failed (No such file or directory)'
01-06 21:40:09.870 E/WifiConfigStore(  414): Error parsing configurationjava.io.FileNotFoundException: /data/misc/wifi/ipconfig.txt: open failed: ENOENT (No such file or directory)
01-06 21:40:09.880 E/WifiStateMachine(  414): Failed to set frequency band 0
01-06 21:40:09.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:10.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:10.990 D/AudioHardware(  106): AudioHardware pcm playback is going to standby.
01-06 21:40:10.990 D/AudioHardware(  106): closePcmOut_l() mPcmOpenCnt: 1
01-06 21:40:11.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:12.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:12.930 E/Lights  (  414): write_int failed to open sys/class/leds/rk29_key_led/brightness
01-06 21:40:13.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:14.890 E/WifiHW  (  414): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-06 21:40:14.900 D/CommandListener(   99): Clearing all IP addresses on wlan0
01-06 21:40:14.900 E/WifiP2pService(  414): P2p socket connection failed
01-06 21:40:14.910 D/ConnectivityService(  414): ConnectivityChange for WIFI: DISCONNECTED/DISCONNECTED
waseem.gani
Forum Posts: 23
2014/01/07 - 04:44
sir,
give a fix for odys ieos quad tablet....
regent
2014/01/07 - 14:00
dmesg :
logcat:
I managed to fix in logcat the
by adding manually the file from other ROM
I created p2p0 (which seems blank in other ROMS) but the
is still there
Is wifi messed up with WIFI Direct or something like that? Is there any way to fix it? I really love CM and your work is amazing.
Please Oma provide us, your Paypal account too.
regent
2014/01/07 - 17:36
@Oma7144
I am refreshing this page badly waiting for an answer of yours LaughLaughLaughCool
waseem.gani
Forum Posts: 23
2014/01/07 - 17:40
sir,
hoping to get a fix for these problems from you soon....
2014/01/07 - 19:34
For Pipo M8pro try this: http://crewrktablets.arctablet.com/?wpfb_dl=1363
regent
2014/01/07 - 20:11
Same logs as above when I flashed Oma_CM10.1_v1.3.2_Modell_fix_Pipo_M8pro.
The only new things I pointed out were in logcat below
01-07 20:00:06.760 E/WifiConfigStore(  413): configuration found for missing network, ignored
01-07 20:00:06.860 E/wpa_supplicant( 1523): wpa_driver_wext_driver_cmd failed (-1): BTCOEXSCAN-STOP
01-07 20:00:06.860 E/wpa_supplicant( 1523): wpa_driver_wext_driver_cmd failed (-1): RXFILTER-STOP
01-07 20:00:06.870 E/wpa_supplicant( 1523): wpa_driver_wext_driver_cmd failed (-1): COUNTRY GB
01-07 20:00:06.870 I/wpa_supplicant( 1523): wlan0: CTRL-EVENT-DRIVER-STATE HANGED
01-07 20:00:06.870 E/WifiStateMachine(  413): Failed to set country code GB
01-07 20:00:06.870 E/wpa_supplicant( 1523): wpa_driver_wext_driver_cmd failed (-1): SETBAND 0
01-07 20:00:06.870 E/WifiStateMachine(  413): Failed to set frequency band 0
01-07 20:00:06.870 D/CommandListener(   99): Setting iface cfg
01-07 20:00:06.870 D/CommandListener(   99): Trying to bring up p2p0
01-07 20:00:06.880 E/WifiHW  (  413): Unable to open connection to supplicant on "/data/misc/wifi/sockets/p2p0": No such file or directory
01-07 20:00:11.890 D/ConnectivityService(  413): ConnectivityChange for WIFI: DISCONNECTED/DISCONNECTED
01-07 20:00:11.890 D/ConnectivityService(  413): Attempting to switch to mobile
01-07 20:00:11.890 D/ConnectivityService(  413): Attempting to switch to ETHERNET
01-07 20:00:12.150 I/wpa_supplicant( 1523): wlan0: CTRL-EVENT-TERMINATING
01-07 20:00:12.150 D/Tethering(  413): InitialState.processMessage what=4
01-07 20:00:12.150 D/Tethering(  413): sendTetherStateChangedBroadcast 0, 0, 0
2014/01/09 - 12:18
Is the module loaded by default?
regent
2014/01/09 - 13:03
It is not. But even if I load it manually, I have the same result.
Should I try to load it with fresh install, before turning on wifi? Because as you see in above logs, wifi is looping ON/OFF. Only with fresh install I can manage to load module, before turning on wifi
At this moment I am using a 4.2.2 ROM (metarom V004). I am willing to try anything, you propose, cause I love CM. I can also keep system files, if needed from this ROM, and use it on CM. Just tell me.
gabitzu73
2014/01/15 - 19:18
Have you found anything?I'm so sad because our tablets can not run CyanogenmodCry
PS. Sorry ,run CM but without wifi & bluetooth !
Currently Online: JSun
137 Guest(s)
Devices in use: Desktop (109), Phone (27), Tablet (2)
hacktes
Walldos
MOUNIR 1923
cynthiavd
rafi462
PillowMan
Topics: 6010
Members: 260639
