CM 10.1 - Help me fix problems
Port cm from Crew RKTablets version, but there are some problems which need to be sloved - I NEED HELP
yoavst
Forum Posts: 51
2013/10/27 - 16:32
Hi!
I've tried to install this ROM, made by crewrktablets - http://crewrktablets.arctablet.com/?p=1950
I've changed the kernel to the kernel from lastest DarthJabba ROM, so the ROM has successfully installed and it somehow work.
BUT there are few problems:
- Every reboot the language changed to deutsch (maybe something in the build prop).
- Can't turn on WIFI.
- It don't recognize the internal storage for apps (it recognize the internal storage of the 28GB, not the 4GB)
- the Orantion is reverse - when the device is landscape >> it turn to portait and when the device is portait >> it turn to landscape
SO,
@Admin, @DarthJabba or any other developers, please try to fix those problems or port it successfully :)
2013/10/27 - 16:55
I'm moving this topic to Crew RKTablets forum section as it's probably the best place to get help from the developers from the Crew, Oma, netlars and the other guys of the team.
DarthJabba and other devs are welcome to join the discussion as well Wink
- fixed language to Deutsch should be fixable on build.prop file
- WiFI may be a driver loading issue
- as for storage space for apps, I am not sure I correctly understand the issue.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
2013/10/27 - 17:04
@yoavst
look at the site:
"Chuwi V88 Beta v1.3.1 new - orientation issues fixed, gapps updated"
28 Gb is correct
sd memory, data memory, cpu memory
it's a beta
regards
yoavst
Forum Posts: 51
2013/10/27 - 17:10
I know it's beta, but gmail was also beta for long time :P
P.S: @Admin - it says that there is 0.00b in the first internal storage
2013/10/27 - 17:20
Which tab (maybe this got lost through the move)?
Do a clean install incl. eraseIDB and run the format_NAND fix.
Wifi and sensor are typical problems unsing other hardware.
yoavst
Forum Posts: 51
2013/10/27 - 17:32
CUBE U30GT2.
Tried with format_nand fix, same result :)
it same RK3188 but 1900X1200 10.1 inch screen
2013/10/27 - 17:35
Ok, then it's clear. Build will not work on tabs with high resolution/retina screen.
yoavst
Forum Posts: 51
2013/10/27 - 17:41
Why can't it work with high resolution screen. and how that belong to the Wifi and internal storage problem?
affs
Murcia (Spain)
Forum Posts: 13
Thanks Received: 17
2013/10/29 - 07:35
________________________________________________________________________________________________________
Hello, I have adapted their ROM "CM10.1 on rk31board" for what the tablet U30GT2:
  • Replaced the kernel chuwi V88 by kernel U30GT2 standard
  • Before run format_NAND_fix mount data and sdcard > memory ok
  • Set Value ro.sf.lcd_density = 240 on build.prop for HD
The ROM works OK except:
- Can not turn-on Wifi
- Can not turn-on Bluettooth
Any idea of what could happen.
Thank you very much.
affs
Murcia (Spain)
Forum Posts: 13
Thanks Received: 17
2013/10/29 - 07:42
Where is the WiFi driver in the ROM?
yoavst
Forum Posts: 51
2013/11/08 - 11:04
waseem.gani
Forum Posts: 23
2014/01/04 - 11:06
Same problem im also facing after flashing cm10.1 on my odys ieos quad tablet..
Not able to turn on wifi and bluetooth....
Any one can give me a fix for it pls....
regent
2014/01/06 - 19:04
I managed to flash and boot CM 10.1 on a Pipo M8 pro (rk3188) with proper kernel. I also flashed Format NANDand and fixed the sensor with the fix x=y_y=-x_z=z.  But I have some issues.
1) Data partition cannot be mounted through CWM and it is no manageable. Like a permission problem. Everytime I reboot, system is reverted to defaults. (German language and stock Apps)
2) wifi & bluetooth cannot turn on
I understand that 2 is driver problem so can anyone "guide" me how to port them from stock ROM?
Thanks in advance
2014/01/06 - 19:31
1) is a problem of not proper formated NAND
- try again using stock recovery first: http://crewrktablets.arctablet.com/?wpfb_dl=910
- flash CWM after first boot (tick parameter and recovery)
2) open the terminal and type: cat /sys/class/rkwifi/chip
- post the result
- install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=1361
waseem.gani
Forum Posts: 23
2014/01/06 - 20:00
- post the result
sir,
please provide fix for odys ieos quad wifi and bluetooth
problems in cm10.1 and can you please give me the touchwiz theme and theme chooser of your cm10 to install and use.
69 Guest(s)
Devices in use: Desktop (64), Phone (5)
cutierogue
hans41
