2013/10/22
Hello all,
I have a question regarding the RK31 CM10.1 ROM, I have this one flashed on my chuwi v88 tablet.
The problem i'm having is that the internal storage isn't showing 4GB, it says i have like 100MB. The NAND flash part of 10GB is showing perfectly. But because of the internal storage is no 4GB i can't install any apps. It says i don't have enough storage available.
I followed the instructions perfectly, i also flashed the format NAND file.
On the previous ROM i flashed from OMA i didn't have this problem (JB 4.2.2 version).
Does anyone have a clue about what it could be?
Thanks in advance!
Greets soulvayne
Flash again incl. eraseIDB.
soulvaynePer aspera ad astra, we rock the Tablets !
2013/11/01
Boot into recovery and mount data, maybe also format the data partition. Seemed to fix it for me.
Hey OMA, thanks very much for cooking this ROM. Its awesome.
Quick question regarding this ROM, my kids are trying to run Plants vs Zombies 1 and 2, and they start but then bomb out after a few seconds. Any ideas?
Could it be because I mounted and formatted the data partition rather than re-trying EraseIDB and flash as you've recommended to soulvayne?
The CM build is not compatible with Plants vs Zombies. The game crashes with a segfaut. Sorry, no idea for now.
2013/11/15
Hi.
I flashed this ROM in my Pipo M9 (kernel.img has been replaced as well). All works normally, except one problem: Pipo M9 does not have hardware volume buttons. Is any possibility enable software volume buttons n status bar? Volume control in settings works nomally.
Thanks!
73!
Michael
Cat's ShadowPer aspera ad astra, we rock the Tablets !
135 Guest(s)
Devices in use: Desktop (132), Phone (3)
