You need root.
Download a terminal emulator from Play Store, boot tab fresh and type:
su
dmesg >/mnt/sdcard/dmesg.txt
cat proc/cmdline >/mnt/sdcard/cmdline.txt
cat proc/mtd > /mnt/sdcard/mtd.txt
dd if=/dev/mtd/mtd1 of=/sdcard/kernel.img bs=4096
dd if=/dev/mtd/mtd2 of=/sdcard/boot.img bs=4096
dd if=/dev/mtd/mtd3 of=/sdcard/recovery.img bs=4096
dd if=/dev/mtd/mtd8 of=/sdcard/system.img bs=4096
Files are now on your internal sdcard. Copy the files to PC and zip them. Upload the archive and post a link here.
I will check.
Ok, tab has MTK5931 wifi. So you can use all my builds for Chuwi V88.
Can you just make clear what tab do you have excatly? I 'd like to upload the kernel to the archive.
2014/06/28
Thx Oma
You want to know the exact typ:
http://www.cat-sound.com/cat-galactica2-highlight.html
Marketing Name Galactica 2014 and the internal Name Galactica 2.
I hope that helps
Ok, kernel is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1894
Try this one: http://crewrktablets.arctablet.com/?p=2736
xministerPer aspera ad astra, we rock the Tablets !
Fine.
What is the orientation mismatch? 90 degree clock/counterclockwise?
What is wrong with the stock kernel?
2013/06/04
ro.sf.hwrotation must be set to "0" in build.prop than rotation and camera are correct.
Both cameras, Bluetooth and WLAN works fine.
3G and GPS has no function at this time, need more investigation at this.
Stock kernel is limited at max 1,416 GHz for longer accu life but processor is RK3188 (not T) that can run up to 1,6 GHz (sometimes more with OC/UV). A CPU setting with performance at 1,6 GHz would be great.
Many thanks for your support.
63 Guest(s)
Devices in use: Desktop (60), Phone (3)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
