2015/12/29
How can I install this firmware with cwm recovery and my sd card with a file .zip ?
 "My only dream is freedom, then I dream of freedom."
2015/12/29
I want to try this method with your firmware.
http://seasonsroad.com/2015/05/FTFtoZIP/
but it's not possible because my PC no detect device. and I don't have bootload and when I connect my device with sideload and a try to communicate with devices I've error message "failed"
2015/12/29
it's ok I try this solution
and a flash your rom oma xoro pad with this methode and my  devices reboot correctly . I am very happy and when I have my money I donate because you have a GOOD job.
Does BatterySpy (see Play Store) track the stats?
Let me have a dmesg log.
- Oms -
Reboot tab, open a terminal and type:
su
dmesg >/mnt/sdcard/dmesg.txt
2015/12/29
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.36+ (root@ubuntu-0A) (gcc version 4.4.3 (GCC) ) #132 SMP PREEMPT Wed Nov 20 14:41:19 CST 2013
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: RK30board
[ 0.000000] memory reserve: Memory(base:0x76800000 size:512M) reserved for
[ 0.000000] memory reserve: Memory(base:0x6f000000 size:120M) reserved for
[ 0.000000] memory reserve: Memory(base:0x6cc00000 size:36M) reserved for
[ 0.000000] memory reserve: Memory(base:0x6c400000 size:8M) reserved for
[ 0.000000] memory reserve: Total reserved 676M
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] CPU SRAM: copied sram code from c0e79000 to fef00100 - fef02410
[ 0.000000] CPU SRAM: copied sram data from c0e7b310 to fef02410 - fef02b88
[ 0.000000] sram_log: 4q ?& : 4q ?) !?, # 0q *! ! 3q @ 3q
[ 0.000000] CLKDATA_MSG: pll_flag = 0x00
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[ 0.000000] DDR DEBUG: version 1.00 20130510
[ 0.000000] DDR DEBUG: DDR3 Device
[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Total Capability=2048MB
[ 0.000000] DDR DEBUG: init success!!! freq=300MHz
[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x3, DGSL=1 extra clock, DGPS=90
[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.000000] On node 0 totalpages: 351232
[ 0.000000] free_area_init_node: node 0, pgdat c0e76340, node_mem_map c2140000
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 48432 pages, LIFO batch:15
[ 0.000000] HighMem zone: 2352 pages used for memmap
[ 0.000000] HighMem zone: 298704 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c314f000 s6976 r8192 d13504 u32768
[ 0.000000] pcpu-alloc: s6976 r8192 d13504 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 347136
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00140000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00008000@0x0000a000(boot),0x00010000@0x00012000(recovery),0x00020000@0x00022000(backup),0x00040000@0x00042000(cache),0x00800000@0x00082000(userdata),0x00002000@0x00882000(kpanic),0x0012a000@0x00884000(system),-@0x009ae000(user) bootver=2013-06-20#1.24 firmware_ver=4.2.2
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 196MB 1176MB = 1372MB total
[ 0.000000] Memory: 1365224k/1365224k available, 731928k reserved, 1204224K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[ 0.000000] vmalloc : 0xf7000000 - 0xfe800000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf6800000 ( 872 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0408000 - 0xc0732000 (3240 kB)
[ 0.000000] .text : 0xc0732000 - 0xc0e05980 (6991 kB)
[ 0.000000] .data : 0xc0e06000 - 0xc0e781a8 ( 457 kB)
[ 0.000000] .bss : 0xc0e7c024 - 0xc1923e58 (10912 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:352
[ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] rk_timer: version 1.2
[ 0.000000] Console: colour dummy device 80x30
[ 0.008609] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
[ 0.017638] pid_max: default: 32768 minimum: 301
[ 0.022904] Mount-cache hash table entries: 512
[ 0.028456] Initializing cgroup subsys debug
[ 0.033193] Initializing cgroup subsys cpuacct
[ 0.038118] Initializing cgroup subsys freezer
[ 0.043060] CPU: Testing write buffer coherency: ok
[ 0.129236] CPU1: Booted secondary processor
[ 0.169223] CPU2: Booted secondary processor
[ 0.209225] CPU3: Booted secondary processor
[ 0.209259] Brought up 4 CPUs
[ 0.226557] SMP: Total of 4 processors activated (6525.87 BogoMIPS).
[ 0.233847] devtmpfs: initialized
[ 0.243332] NET: Registered protocol family 16
[ 0.248284] last_log: 0xcbd00000 map to 0xf7004000 and copy to 0xc0e801e0 (version 2.1)
[ 0.272190] DVFS MSG: AVS Value(index=0): 120 120 119 119 123 120 120 119 123 120
[ 0.291136] lcdc0 is used as primary display device contoller!
[ 0.297646] lcdc1 is used as external display device controller!
[ 0.404598] rk29sdk_wifi_bt_gpio_control_init: init finished
[ 0.412197] console [ttyFIQ0] enabled, bootconsole disabled
[ 0.421330] Registered FIQ tty driver cbc63cc0
[ 0.433123] bio: create slab at 0
[ 0.437357] wm831x_dcdc_init
[ 0.437567] wm831x_ldo_init
[ 0.437931] SCSI subsystem initialized
[ 0.438130] usbcore: registered new interface driver usbfs
[ 0.438238] usbcore: registered new interface driver hub
[ 0.440413] usbcore: registered new device driver usb
[ 0.440808] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[ 0.441144] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[ 0.441437] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[ 0.441571] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[ 0.441764] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[ 0.489335] rk30-adc rk30-adc: rk30 adc: driver initialized
[ 0.489559] timed-gpio: probe of timed-gpio failed with error -22
[ 0.489676] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.490114] Bluetooth: Core ver 2.16
[ 0.490180] NET: Registered protocol family 31
[ 0.490214] Bluetooth: HCI device and connection manager initialized
[ 0.490263] Bluetooth: HCI socket layer initialized
[ 0.490299] Bluetooth: L2CAP socket layer initialized
[ 0.490349] Bluetooth: SCO socket layer initialized
[ 0.491264] rk fb probe ok!
[ 0.496196] act8846_set_init,line=17
[ 0.496227] act8846_set_init:g_pmic_type=3
[ 0.498019] act8846_set_init act_dcdc1 =1200000mV end
[ 0.499925] act8846_set_init vdd_core =1000000mV end
[ 0.501806] act8846_set_init vdd_cpu =1000000mV end
[ 0.503684] act8846_set_init act_dcdc4 =3200000mV end
[ 0.504930] act8846_set_init act_ldo1 =1000000mV end
[ 0.506710] act8846_set_init act_ldo2 =1250000mV end
[ 0.508489] act8846_set_init act_ldo3 =1800000mV end
[ 0.510273] act8846_set_init act_ldo4 =3300000mV end
[ 0.512054] act8846_set_init act_ldo5 =3300000mV end
[ 0.513834] act8846_set_init act_ldo6 =3300000mV end
[ 0.514976] act8846_set_init act_ldo7 =1800000mV end
[ 0.516753] act8846_set_init act_ldo8 =2800000mV end
[ 0.516798] act8846_set_init,line=78 END
[ 0.516862] i2c-core: driver [act8846] using legacy suspend method
[ 0.516906] i2c-core: driver [act8846] using legacy resume method
[ 0.516957] wm831x_i2c_init
[ 0.517325] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 2...
[ 0.517698] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 1...
[ 0.518070] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 0...
[ 0.518134] wm831x 1-0034: Failed to read parent ID: -11
[ 0.518180] wm831x: probe of 1-0034 failed with error -11
[ 0.518600] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.518892] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.519180] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.519244] tps65910 1-002d: tps65910_set_bits:read from reg 3f failed
[ 0.519521] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.519810] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.520098] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.520161] tps65910 1-002d: read from reg 46 failed
[ 0.520198] tps65910 1-002d: Error in configuring external control EN1
[ 0.520245] tps65910 1-002d: Failed to initialise ext control config
[ 0.520599] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.520890] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.521179] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.521242] tps65910 1-002d: tps65910_set_bits:read from reg 20 failed
[ 0.521289] set_machine_constraints: VIO: failed to enable
[ 0.521376] tps65910 1-002d: failed to register tps65910-pmic regulator
[ 0.521429] tps65910-pmic: probe of tps65910-pmic failed with error -11
[ 0.521838] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 2...
[ 0.522129] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 1...
[ 0.522418] i2c i2c-1: No ack, Maybe slave(addr: 0x2d) not exist or abnormal power-on, retry 0...
[ 0.522480] tps65910 1-002d: Read from reg 0x22 failed
[ 0.522516] The device is not tps65910
[ 0.522660] tps65910: probe of 1-002d failed with error -11
[ 0.522901] Switching to clocksource rk_timer
[ 0.528617] Switched to NOHz mode on CPU #0
[ 0.529263] Switched to NOHz mode on CPU #3
[ 0.529287] Switched to NOHz mode on CPU #1
[ 0.529300] Switched to NOHz mode on CPU #2
[ 0.530022] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf709c000
[ 0.530101] fb0:win0
[ 0.530106] fb1:win1
[ 0.530110] fb2:win2
[ 0.530198] rk3188 lcdc0 clk enable...
[ 0.598041] rk3188 lcdc0 clk disable...
[ 0.687430] fb0:phy:6cc00000>>vir:f8000000>>len:0x2400000
[ 0.687701] rk_fb_register>>>>>fb0
[ 0.688004] rk_fb_register>>>>>fb1
[ 0.688052] rk3188 lcdc0 clk enable...
[ 0.688139] lcdc0: dclk:199500000>>fps:58
[ 0.688173] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[ 0.713266] lcdc0 wakeup from standby!
[ 0.713296] lcdc0 win0 open,atv layer:1
[ 0.761521] rk3188 lcdc0 probe ok!
[ 0.761613] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf70a8000
[ 0.761686] fb0:win0
[ 0.761691] fb1:win1
[ 0.761696] fb2:win2
[ 0.761775] rk3188 lcdc1 clk enable...
[ 0.786869] rk3188 lcdc1 clk disable...
[ 0.786909] fb2:phy:6cc00000>>vir:f8000000>>len:0x2400000
[ 0.787174] rk_fb_register>>>>>fb2
[ 0.787469] rk_fb_register>>>>>fb3
[ 0.787499] rk3188 lcdc1 probe ok!
[ 0.793796] NET: Registered protocol family 2
[ 0.793952] IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.794280] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.794812] TCP bind hash table entries: 32768 (order: 6, 393216 bytes)
[ 0.795406] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.795457] TCP reno registered
[ 0.795486] UDP hash table entries: 128 (order: 0, 4096 bytes)
[ 0.795545] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
[ 0.795895] NET: Registered protocol family 1
[ 0.796110] RK29 Backlight Driver Initialized.
[ 0.885431] HW LT Success>>:times:1
[ 0.894649] anx6345_init..lc:2--bw:10
[ 0.895550] edp anx6345 probe ok
[ 0.895756] Unpacking initramfs...
[ 0.960576] Freeing initrd memory: 1280K
[ 0.960688] PMU: registered new PMU device of type 0
[ 0.961964] rk3188 cpufreq version 2.0, suspend freq 816 MHz
[ 0.962882] Loaded driver for PL330 DMAC-1 rk29-pl330
[ 0.962927] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.963152] Loaded driver for PL330 DMAC-2 rk29-pl330
[ 0.963196] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[ 0.963922] highmem bounce pool size: 64 pages
[ 0.964107] ashmem: initialized
[ 0.969020] fuse init (API version 7.16)
[ 0.970239] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.970301] io scheduler noop registered
[ 0.970334] io scheduler deadline registered
[ 0.970424] io scheduler cfq registered (default)
[ 0.978785] rga: Driver loaded succesfully
[ 0.979040] rk_serial.c v1.4 2013-04-16
[ 0.979336] rk_serial rk_serial.0: dma_rx_buffer 0xffdfc000
[ 0.979382] rk_serial rk_serial.0: dma_rx_phy 0x6b3da000
[ 0.979431] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess
[ 0.979483] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[ 1.116808] cfg80211: Calling CRDA to update world regulatory domain
[ 1.153002] rk_serial rk_serial.0: membase 0xf70c0000
[ 1.153076] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[ 1.312985] rk_serial rk_serial.3: membase 0xf70c8000
[ 1.313190] Rockchip ion module(version: 1.0) is successfully loaded
[ 1.314631] loop: module loaded
[ 1.314683] Android kernel panic handler initialized (bind=kpanic)
[ 1.315155] PPP generic driver version 2.4.2
[ 1.315298] PPP Deflate Compression module registered
[ 1.315329] PPP BSD Compression module registered
[ 1.347873] PPP MPPE Compression module registered
[ 1.347914] NET: Registered protocol family 24
[ 1.348013] usbcore: registered new interface driver asix
[ 1.348069] usbcore: registered new interface driver cdc_ether
[ 1.348123] usbcore: registered new interface driver dm9620
[ 1.348177] usbcore: registered new interface driver SR9700_android
[ 1.348235] usbcore: registered new interface driver net1080
[ 1.348287] usbcore: registered new interface driver cdc_subset
[ 1.348343] usbcore: registered new interface driver zaurus
[ 1.348386] cdc_ncm: 04-Aug-2011
[ 1.348436] usbcore: registered new interface driver cdc_ncm
[ 1.348470] Rockchip WiFi SYS interface (V1.00) ...
[ 1.348525] Initializing USB Mass Storage driver...
[ 1.348580] usbcore: registered new interface driver usb-storage
[ 1.348616] USB Mass Storage support registered.
[ 1.348718] usbcore: registered new interface driver usbserial
[ 1.348775] USB Serial support registered for generic
[ 1.348826] usbcore: registered new interface driver usbserial_generic
[ 1.348867] usbserial: USB Serial Driver core
[ 1.348907] USB Serial support registered for GSM modem (1-port)
[ 1.348966] usbcore: registered new interface driver option
[ 1.348999] option: v0.7.2:USB Driver for GSM modems
[ 1.560858] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
[ 1.560903] usb20_otg usb20_otg: DWC OTG Controller
[ 1.561033] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[ 1.561100] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[ 1.561137] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
[ 1.561226] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.561271] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.561318] usb usb1: Product: DWC OTG Controller
[ 1.561348] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[ 1.561385] usb usb1: SerialNumber: usb20_otg
[ 1.561719] hub 1-0:1.0: USB hub found
[ 1.561754] hub 1-0:1.0: 1 port detected
[ 1.564425] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xf7180000
[ 1.774873] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.774914] usb20_host usb20_host: DWC OTG Controller
[ 1.774977] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[ 1.775040] usb20_host usb20_host: irq 49, io mem 0x00000000
[ 1.775112] DWC_OTG: Init: Port Power? op_state=1
[ 1.775144] DWC_OTG: Init: Power Port (0)
[ 1.775199] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.775246] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.775290] usb usb2: Product: DWC OTG Controller
[ 1.775323] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[ 1.775358] usb usb2: SerialNumber: usb20_host
[ 1.775671] hub 2-0:1.0: USB hub found
[ 1.775704] hub 2-0:1.0: 1 port detected
[ 1.842802] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.842847] android_usb gadget: Number of LUNs=2
[ 1.842881] lun0: LUN: removable file: (no medium)
[ 1.842909] lun1: LUN: removable file: (no medium)
[ 1.843108] android_usb gadget: android_usb ready
[ 1.843280] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[ 1.843503] usbcore: registered new interface driver xpad
[ 1.843562] usbcore: registered new interface driver usb_acecad
[ 1.843595] acecad: v3.2:USB Acecad Flair tablet driver
[ 1.843662] usbcore: registered new interface driver aiptek
[ 1.843693] aiptek: v2.3 (May 2, 2007):Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
[ 1.843738] aiptek: Bryan W. Headley/Chris Atenasio/Cedric Brun/Rene van Paassen
[ 1.843799] usbcore: registered new interface driver gtco
[ 1.843829] GTCO usb driver version: 2.00.0006
[ 1.843875] usbcore: registered new interface driver hanwang
[ 1.843930] usbcore: registered new interface driver kbtab
[ 1.843960] kbtab: v0.0.2:USB KB Gear JamStudio Tablet driver
[ 1.844018] usbcore: registered new interface driver wacom
[ 1.844048] wacom: v1.52:USB Wacom tablet driver
[ 3.693421] input: ct36x_ts as /devices/platform/rk30_i2c.2/i2c-2/2-0001/input/input1
[ 3.701431] ct36x_ts 2-0001: CT363 Successfully initialized
[ 3.701735] sensor_register_slave:mma8452,id=14
[ 3.701773] sensor_register_slave:lis3dh,id=4
[ 3.709127] using rtc device, rtc_hym8563, for alarms
[ 3.709192] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[ 3.709282] i2c /dev entries driver
[ 3.710025] lirc_dev: IR Remote Control driver registered, major 250
[ 3.710076] IR NEC protocol handler initialized
[ 3.710112] IR RC5(x) protocol handler initialized
[ 3.710148] IR RC6 protocol handler initialized
[ 3.710184] IR JVC protocol handler initialized
[ 3.710218] IR Sony protocol handler initialized
[ 3.710252] IR RC5 (streamzap) protocol handler initialized
[ 3.710294] IR LIRC bridge handler initialized
[ 3.710327] Linux video capture interface: v2.00
[ 3.710627] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[ 3.711040] i2c i2c-0: No ack, Maybe slave(addr: 0x62) not exist or abnormal power-on, retry 2...
[ 3.711430] i2c i2c-0: No ack, Maybe slave(addr: 0x62) not exist or abnormal power-on, retry 1...
[ 3.711812] i2c i2c-0: No ack, Maybe slave(addr: 0x62) not exist or abnormal power-on, retry 0...
[ 3.711878] cw2015 0-0062: Error update mode
[ 3.711921] cw2015: probe of 0-0062 failed with error -11
[ 3.711996] i2c-core: driver [cw2015] using legacy suspend method
[ 3.712042] i2c-core: driver [cw2015] using legacy resume method
[ 3.712092] start_charge_logo_display
[ 3.712122] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 3.712384] rk29-wdt rk29-wdt.0: starting watchdog timer
[ 3.712892] device-mapper: uevent: version 1.0.3
[ 3.713280] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 3.713466] Bluetooth: HCI UART driver ver 2.2
[ 3.713506] Bluetooth: HCI H4 protocol initialized
[ 3.713542] Bluetooth: HCILL protocol initialized
[ 3.713628] cpuidle: using governor ladder
[ 3.713663] cpuidle: using governor menu
[ 3.759128]
[ 3.759132] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc0]
[ 3.764227] rk29_sdmmc_change_clk_div..1961.. newDiv=62, newCLK=299Khz [sd_mmc]
[ 3.764326] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sd_mmc]
[ 3.764549] .Line3965..The End of SDMMC-probe Ver.5.05 The last modify date is 2013-05-08. [sdio]
[ 3.765939] usbcore: registered new interface driver usbhid
[ 3.765979] usbhid: USB HID core driver
[ 3.766246] logger: created 256K log 'log_main'
[ 3.766319] logger: created 256K log 'log_events'
[ 3.766396] logger: created 256K log 'log_radio'
[ 3.766467] logger: created 256K log 'log_system'
[ 3.766544] mt6622_probe.
[ 3.766565] [MT6622] mt_bt_power_init
[ 3.807219]
[ 3.807222] mmc_attach_sd..1219.. ===== Begin to identify card as SD-card. [mmc0]
[ 4.054614] rk29_sdmmc_change_clk_div..1961.. newDiv=0, newCLK=37125Khz [sd_mmc]
[ 4.054811] mmc0: new high speed SD card at address 0003
[ 4.067617] mmcblk0: mmc0:0003 SB02G 1.83 GiB
[ 4.073045]
[ 4.073056] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0]
[ 4.073175] msdos_partition..530... ==== The sdcard has MBR. [mmc0]
[ 4.073258] msdos_partition..543... ==== partition-1, size=1920000KB [mmc0]
[ 4.073345] msdos_partition..571... ==== main partition-1....[mmc0]
[ 4.073425] mmcblk0: p1
[ 4.074329] mmc_rescan_try_freq..1718.. ===== Initialize SD-card successfully. [mmc0]
[ 4.074444]
[ 4.074453] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 4.093078] rk29_sdmmc_change_clk_div..1961.. newDiv=42, newCLK=294Khz [sdio]
[ 5.108471] RT5631 4-001a: dapm: unknown pin HP_L
[ 5.108552] RT5631 4-001a: dapm: unknown pin HP_R
[ 5.126259] asoc: RT5631 HiFi rk29_i2s.1 mapping ok
[ 5.126781] ALSA device list:
[ 5.126811] #0: RK29_RT5631
[ 5.126947] GACT probability NOT on
[ 5.126984] Mirror/redirect action on
[ 5.127015] u32 classifier
[ 5.127037] Actions configured
[ 5.127069] Netfilter messages via NETLINK v0.30.
[ 5.127151] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.127592] ctnetlink v0.93: registering with nfnetlink.
[ 5.127670] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.127721] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.128136] xt_time: kernel timezone is -0000
[ 5.128349] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.128596] arp_tables: (C) 2002 David S. Miller
[ 5.128685] TCP cubic registered
[ 5.128713] Initializing XFRM netlink socket
[ 5.129306] NET: Registered protocol family 10
[ 5.130150] Mobile IPv6
[ 5.130203] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.130393] IPv6 over IPv4 tunneling driver
[ 5.131276] NET: Registered protocol family 17
[ 5.131337] NET: Registered protocol family 15
[ 5.226314] Bluetooth: RFCOMM TTY layer initialized
[ 5.226375] Bluetooth: RFCOMM socket layer initialized
[ 5.226413] Bluetooth: RFCOMM ver 1.11
[ 5.226437] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.226473] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.226610] NET: Registered protocol family 35
[ 5.395455] CAT66121: Reg[0-3] = 0x[54].[49].[12].[16]
[ 5.483421] cat66121_hdmi 2-004c: cat66121 hdmi i2c probe ok
[ 5.483567]
[ 5.483569] *****************sensor_mod_init..sp2518..
[ 5.495806] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 5.495898] Registering SWP/SWPB emulation handler
[ 5.498771] rk3066b-camera version: v0.2.31 Zoom by ipp
[ 5.499142] ddrfreq: verion 2.4 20130427
[ 5.499171] ddrfreq: normal 528MHz video 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
[ 5.500206] ddrfreq: change freq to 528 MHz when normal
[ 5.500592] i2c i2c-0: sensor_probe: gs_mma8452,0xcbdb8a00
[ 5.500847] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 2...
[ 5.501110] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 1...
[ 5.501373] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 0...
[ 5.501637] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 2...
[ 5.501899] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 1...
[ 5.502161] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 0...
[ 5.502424] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 2...
[ 5.502686] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 1...
[ 5.502948] i2c i2c-0: No ack, Maybe slave(addr: 0x1d) not exist or abnormal power-on, retry 0...
[ 5.503020] sensor_chip_init:fail to read gs_mma8452 devid:0xff
[ 5.503074] i2c i2c-0: sensor_probe failed -11
[ 5.503081]
[ 5.503121] sensors: probe of 0-001d failed with error -11
[ 5.503169] i2c i2c-0: sensor_probe: gs_lis3dh,0xcbdb8c00
[ 5.503449] sensor_chip_init:gs_lis3dh:devid=0x33,ops=0xc0e57384
[ 5.505784] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-0019/input/input2
[ 5.506074] sensor_irq_init:use irq=175
[ 5.506214] sensor_misc_device_register:miscdevice: mma8452_daemon
[ 5.506251] sensor_probe:initialized ok,sensor name:lis3dh,type:1,id=4
[ 5.506260]
[ 5.506376] sensor_init: Probe name sensors
[ 5.506416] sensor-dev.c v1.3 add sensor debug support 2013-3-15
[ 5.507621] rtc_hym8563 1-0051: setting system clock to 2015-12-31 06:36:16 UTC (1451543776)
[ 5.508314] Freeing init memory: 3240K
[ 5.885663] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 5.927411] init: /dev/hw_random not found
[ 5.927512] keychord: using input dev rk29-keypad for fevent
[ 5.927691] init: cannot open '/initlogo.rle'
[ 6.163052] Probe sp2518_back success
[ 6.393125] i2c i2c-3: 1 i2c clients have been registered at 0x30
[ 6.395685] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[ 6.396127] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[ 6.402619] error: ov2659 mismatched pid = 0x0
[ 6.522971] camera 33-1-ov2659_front: Probe ov2659_front failed
[ 6.666013] gp_rknand_info = : 0xcbfc0000
[ 6.666095] rk30_chip_set:1
[ 6.666138] request IRQ_NANDC irq , ret=0.........
[ 6.666171] FTL INFO:Version = 438,Date = 20130620
[ 6.666261] FlashCopyProgBuf1=0xc17c6000
[ 6.666301] ATime: 40 ns AHB: 148 timming: 1081
[ 6.666327] No.1 FLASH INFO:89 88 24 4b a9
[ 6.666352] No.2 FLASH INFO:89 88 24 4b a9
[ 6.668044] ATime: 32 ns AHB: 148 timming: 1061
[ 6.668213] ATime: 32 ns AHB: 148 timming: 1061
[ 6.668235] randomizer = 0 , EccBits = 18 pSpec->pReadRetrial = 0
[ 6.727937] totalLogicBlkRaw = 3952
[ 6.727966] gBootMedia = 1 gSdmmcFwPartOffset =0!
[ 6.727995] rknand_buffer.c version: 4.38 20121130!
[ 6.741092] 10 cmdlinepart partitions found on MTD device rk29xxnand
[ 6.741125] Creating 10 MTD partitions on "rk29xxnand":
[ 6.741160] 0x000000400000-0x000000800000 : "misc"
[ 6.753287] 0x000000800000-0x000001400000 : "kernel"
[ 6.755397] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 6.755577] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 6.755753] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 6.755794]
[ 6.755796] ov5640 write reg(0x3008, val:0x80) failed, try to write again!
[ 6.755980] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 6.756156] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 6.756333] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 6.756374]
[ 6.756377] ov5640 write reg(0x3008, val:0x80) failed, try to write again!
[ 6.756559] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 6.756733] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 6.756905] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 6.756945]
[ 6.756947] ov5640 write reg(0x3008, val:0x80) failed, try to write again!
[ 6.756995] soft reset ov5640 failed
[ 6.757015] sensor_probe set request af_pin
[ 6.763194] 0x000001400000-0x000002400000 : "boot"
[ 6.872973] camera 33-2-ov5640_back_1: Probe ov5640_back_1 failed
[ 6.885912] 0x000002400000-0x000004400000 : "recovery"
[ 6.891258] 0x000004400000-0x000008400000 : "backup"
[ 6.896426] 0x000008400000-0x000010400000 : "cache"
[ 6.901510] 0x000010400000-0x000110400000 : "userdata"
[ 6.907621] 0x000110400000-0x000110800000 : "kpanic"
[ 6.913327] apanic: Bound to mtd partition 'kpanic'
[ 6.913354] apanic: No panic data available
[ 6.913509] 0x000110800000-0x000135c00000 : "system"
[ 6.927727] 0x000135c00000-0x0003dc000000 : "user"
[ 6.934791] startBlk = 43 sysProtAddr = 42
[ 6.939500] fs_mgr: parse_link_device : in
[ 6.943462] fs_mgr: parse_link_device : ---- part_num = 9, path = /devices/virtual/mtd/mtd9/mtdblock9, is_emmc = 0
[ 6.954037] fs_mgr: parse_link_device : path = NULL
[ 6.958773] fs_mgr: parse_link_device : path = NULL
[ 6.965635] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 6.990382] EXT4-fs warning (device mtdblock5): ext4_clear_journal_err:4157: Filesystem error recorded from previous mount: IO failure
[ 6.993053] EXT4-fs warning (device mtdblock5): ext4_clear_journal_err:4158: Marking fs in need of filesystem check.
[ 6.993339] EXT4-fs (mtdblock5): warning: mounting fs with errors, running e2fsck is recommended
[ 6.993662] EXT4-fs (mtdblock5): recovery complete
[ 6.993835] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.025276] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115531
[ 7.025518] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115237
[ 7.025583] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115242
[ 7.026486] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115241
[ 7.038640] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 16411
[ 7.038702] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 16410
[ 7.038737] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 16409
[ 7.038782] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 16408
[ 7.038822] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115415
[ 7.106112] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 7.107196] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 7.108283] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 7.108325]
[ 7.108327] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 7.109408] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 7.109862] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 7.110315] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 7.110355]
[ 7.110358] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 7.110818] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 7.111459] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 7.112154] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 7.112196]
[ 7.112198] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 7.112246] read chip id high byte failed
[ 7.243029] camera 33-3-gc2035_back_2: Probe gc2035_back_2 failed
[ 7.473094] i2c i2c-3: 1 i2c clients have been registered at 0x30
[ 7.717311] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 116138
[ 7.717431] EXT4-fs (mtdblock6): ext4_orphan_cleanup: deleting unreferenced inode 115836
[ 7.717496] EXT4-fs (mtdblock6): 11 orphan inodes deleted
[ 7.717531] EXT4-fs (mtdblock6): recovery complete
[ 7.725462] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.727859] EXT4-fs error (device mtdblock5): ext4_mb_generate_buddy:736: group 0, 31215 blocks in bitmap, 31216 in gd
[ 7.727925] Aborting journal on device mtdblock5-8.
[ 7.728160] EXT4-fs (mtdblock5): Remounting filesystem read-only
[ 7.728212] EXT4-fs error (device mtdblock5) in ext4_reserve_inode_write:5669: Journal has aborted
[ 7.728367] EXT4-fs error (device mtdblock5) in ext4_evict_inode:212: Journal has aborted
[ 7.751088] UMP: Using OS memory backend, allocation limit: 1073741824
[ 7.751124] UMP: UMP device driver -e1a6a37 loaded
[ 7.840156] Mali: Mali400 inside of rk3188!
[ 7.840198] Mali: mali freq table num : 6
[ 7.840221] Mali: mali freq table :Mali: 133,Mali: 200,Mali: 266,Mali: 399,Mali: 594,Mali: 798,Mali:
[ 7.840283] Mali: init mali clock success
[ 7.952976] Probe sp2518_front_1 success
[ 8.187092] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 8.187551] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 8.188101] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 8.188145]
[ 8.188148] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 8.188794] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 8.189492] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 8.190194] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 8.190234]
[ 8.190237] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 8.190895] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2...
[ 8.191615] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1...
[ 8.192334] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0...
[ 8.192375]
[ 8.192377] gc2035 read reg(0xf0 val:0xc0) failed, try to read again!
[ 8.192424] read chip id high byte failed
[ 8.323507] camera 33-5-gc2035_front_2: Probe gc2035_front_2 failed
[ 8.324725] Mali: Mali device driver loaded
[ 8.583118] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.583966] ipp irq 47
[ 8.584275] IPP init, version rk30-ipp 1.003
[ 8.591698] <> GT911 driver install.
[ 8.736976] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess
[ 8.738956] init: /dev/hw_random not found
[ 8.756787] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
[ 8.765099] healthd: wakealarm_init: timerfd_create failed
[ 8.770950] healthd: No charger supplies found
[ 8.770962] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3'
[ 8.774969] healthd: BatteryStatusPath not found
[ 8.774996] healthd: BatteryHealthPath not found
[ 8.775021] healthd: BatteryPresentPath not found
[ 8.775045] healthd: BatteryCapacityPath not found
[ 8.775068] healthd: BatteryVoltagePath not found
[ 8.775093] healthd: BatteryTemperaturePath not found
[ 8.775128] healthd: BatteryTechnologyPath not found
[ 8.775190] binder: 105:105 transaction failed 29189, size 0-0
[ 8.946580] VPU_SERVICE: failed on clk_get pd_video
[ 8.946628] vpu: power on
[ 8.946680] VPU_SERVICE: checking hw id 4831
[ 8.958338] vpu: power off...done
[ 8.958399] VPU_SERVICE: init success
[ 8.958770] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 8.958828] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[ 8.959028] iManufacturer_store rockchip
[ 8.959078] iProduct_store Nexus 7
[ 8.959105] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[ 9.063205] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
[ 9.065079] init: powerctl: cannot expand '${sys.powerctl}'
[ 9.065129] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
[ 9.065181] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
[ 9.085562] warning: `daemonsu' uses 32-bit capabilities (legacy support in use)
[ 9.127466] init: untracked pid 125 exited
[ 9.127847] android_usb: already disabled
[ 9.130498] init: untracked pid 131 exited
[ 9.273081] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.273736] iSerial_store YO618256QC
[ 9.273820] [rknand_sys_storage_ioctl:90] rknand_sys_storage_ioctl in
[ 9.273860] [rknand_sys_storage_ioctl:103] RKNAND_GET_DRM_KEY
[ 9.273896] [rknand_sys_storage_ioctl:365] return ret = 0
[ 9.364672] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.369668] fs_mgr: parse_link_device : in
[ 9.369730] fs_mgr: parse_link_device : ---- part_num = 9, path = /devices/virtual/mtd/mtd9/mtdblock9, is_emmc = 0
[ 9.369834] fs_mgr: parse_link_device : path = NULL
[ 9.369873] fs_mgr: parse_link_device : path = NULL
[ 9.370050] .428.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
[ 9.370086] .459.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
[ 9.449170] .428.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
[ 9.449660] .428.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
[ 9.623143] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.630029] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.760963] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.762736] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 9.780956] init: untracked pid 136 exited
[ 9.803209] DWC_OTG: dwc_otg_hcd_enable, disable host controller
[ 9.843974] rk fb use 3 buffers
[ 9.963383] init: untracked pid 205 exited
[ 10.263424] sp2518 sensor_ioctl cmd(0x3) is unknown !
[ 10.373143] sp2518 sensor_ioctl cmd(0x3) is unknown !
[ 13.394025] init: untracked pid 449 exited
[ 13.394387] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 13.400206] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 13.413580] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 13.470955] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 13.603369] init: untracked pid 451 exited
[ 13.694193] request_suspend_state: wakeup (3->0) at 13641215004 (2015-12-31 06:36:24.676325294 UTC)
[ 13.887670] sp2518 sensor_ioctl cmd(0x3) is unknown !
[ 13.993355] sp2518 sensor_ioctl cmd(0x3) is unknown !
[ 16.236736] DWC_OTG: ********session end intr,soft disconnect************************
[ 16.613276] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 18.678792] init: untracked pid 728 exited
[ 18.679157] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 18.691309] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 18.699294] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 18.720231] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 18.763194] init: untracked pid 730 exited
[ 19.572967] DWC_OTG: ********vbus detect*********************************************
[ 23.774345] init: untracked pid 737 exited
[ 23.774429] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 23.787815] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 23.804163] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 23.819914] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 23.873295] init: untracked pid 739 exited
[ 28.834292] init: untracked pid 770 exited
[ 28.853189] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 28.860394] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 28.979605] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 29.000217] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 29.103431] init: untracked pid 772 exited
[ 30.572969] DWC_OTG: ********vbus detect*********************************************
[ 33.112499] init: untracked pid 779 exited
[ 33.113342] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 33.120132] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 33.273414] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 33.338532] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 33.453235] init: untracked pid 781 exited
[ 38.463457] init: untracked pid 788 exited
[ 38.467390] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 38.471514] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 38.484938] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 38.534673] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 38.593273] init: untracked pid 790 exited
[ 43.604466] init: untracked pid 797 exited
[ 43.608623] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 43.617509] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 46.763402] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 47.474760] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 47.553239] init: untracked pid 799 exited
[ 48.563227] init: untracked pid 808 exited
[ 48.563268] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 48.569591] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 48.694281] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 48.830578] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 48.943268] init: untracked pid 810 exited
[ 53.957485] init: untracked pid 818 exited
[ 53.957556] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 53.964062] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 54.094201] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 54.116645] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 54.203239] init: untracked pid 820 exited
[ 56.826016] healthd: battery l=0 v=0 t=0.0 h=1 st=1 chg=
[ 56.832380] request_suspend_state: wakeup (0->0) at 56779415009 (2015-12-31 06:37:07.814525591 UTC)
[ 57.170287] Current WiFi chip is MT5931.
[ 57.811624] initRssiHistory.
[ 57.811650] =======================================================
[ 57.811689] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 57.811719] =======================================================
[ 57.811749] MT5931 SDIO WiFi driver (Powered by Rockchip,Ver 3.10) init.
[ 57.811778] ## Calling platform_driver_register
[ 57.811847] ## wifi_probe
[ 57.811906] wifi_set_power = 1
[ 57.811924] rk29sdk_wifi_power: 1
[ 58.065982] wifi turn on power
[ 58.122974] wifi_set_carddetect = 1
[ 58.122997] rk29sdk_wifi_set_carddetect:1
[ 58.123027] mmc1: slot status change detected(0-1)
[ 58.123418] wl_android_wifictrl_func_add success.
[ 58.144830] init: untracked pid 849 exited
[ 58.322984]
[ 58.322987] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1]
[ 58.368271]
[ 58.368274] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 58.399441] rk29_sdmmc_change_clk_div..1961.. newDiv=0, newCLK=24750Khz [sdio]
[ 58.400183] mmc1: new high speed SDIO card at address 0001
[ 58.539364] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 58.574427] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 58.614829] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 58.631837] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 58.650749] acc_open
[ 58.653023] acc_release
[ 58.683878] init: untracked pid 851 exited
[ 58.863861] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1]
[ 58.944188] Current WiFi chip is MT5931.
[ 58.944669] p2p Launch
[ 58.944686] glRegisterP2P
[ 58.945434] Launch success, fgIsP2PRegistered TRUE.
[ 58.963495] init: no such service 'p2p_supplicant'
[ 59.246699] .428.. MMC0 receive the message sd-Checking from VOLD.[sd_mmc]
[ 60.027424] init: no such service 'fuse_external_sd'
[ 60.031317] .428.. MMC0 receive the message sd-Mounted from VOLD.[sd_mmc]
[ 64.056795] init: untracked pid 1092 exited
[ 64.067871] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 64.076368] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 67.153562] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 67.199169] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 67.343290] init: untracked pid 1094 exited
[ 68.095889] init: untracked pid 1127 exited
[ 68.153510] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 68.193795] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 68.273749] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 68.323792] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 68.990449] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 68.997680] initRssiHistory.
[ 69.016272] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 69.023445] init: untracked pid 1129 exited
[ 69.068203] init: no such service 'fuse_internal_sd'
[ 69.318083] --> mtk_cfg80211_testmode_cmd()
[ 69.322382] --> mtk_cfg80211_testmode_sw_cmd()
[ 69.327273] --> mtk_cfg80211_testmode_cmd()
[ 69.331531] --> mtk_cfg80211_testmode_sw_cmd()
[ 69.336557] --> mtk_cfg80211_testmode_cmd()
[ 69.340902] --> mtk_cfg80211_testmode_sw_cmd()
[ 69.345934] --> mtk_cfg80211_testmode_cmd()
[ 69.350202] --> mtk_cfg80211_testmode_sw_cmd()
[ 69.355118] --> mtk_cfg80211_testmode_cmd()
[ 69.359348] --> mtk_cfg80211_testmode_sw_cmd()
[ 69.364263] --> mtk_cfg80211_testmode_cmd()
[ 69.368502] --> mtk_cfg80211_testmode_sw_cmd()
[ 70.083597] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
[ 71.002816] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 71.017810] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 73.012104] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 73.642500] init: untracked pid 1340 exited
[ 73.656087] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 73.662886] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 75.845526] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 75.916508] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 75.983518] init: untracked pid 1342 exited
[ 76.590471] qtaguid: iface_stat: stat_update() lo not found
[ 76.592502] qtaguid: iface_stat: stat_update() lo not found
[ 76.592576] qtaguid: iface_stat: stat_update() lo not found
[ 76.592613] qtaguid: iface_stat: stat_update() lo not found
[ 76.592660] qtaguid: iface_stat: stat_update() lo not found
[ 76.594220] qtaguid: iface_stat: stat_update() lo not found
[ 76.594338] qtaguid: iface_stat: stat_update() lo not found
[ 76.594394] qtaguid: iface_stat: stat_update() lo not found
[ 76.594430] qtaguid: iface_stat: stat_update() lo not found
[ 76.594475] qtaguid: iface_stat: stat_update() lo not found
[ 78.912973] p2p0: no IPv6 routers present
[ 78.995499] init: untracked pid 1373 exited
[ 78.995567] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 79.002581] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 79.117260] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 79.193974] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 79.233476] init: untracked pid 1375 exited
[ 80.702994] wlan0: no IPv6 routers present
[ 83.247013] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 83.247063] init: untracked pid 1442 exited
[ 83.259821] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 83.794925] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 83.815260] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 83.863321] init: untracked pid 1444 exited
[ 84.121116] --> mtk_cfg80211_testmode_cmd()
[ 84.123032] --> mtk_cfg80211_testmode_sw_cmd()
[ 84.123370] --> mtk_cfg80211_testmode_cmd()
[ 84.123395] --> mtk_cfg80211_testmode_sw_cmd()
[ 84.123568] --> mtk_cfg80211_testmode_cmd()
[ 84.123614] --> mtk_cfg80211_testmode_sw_cmd()
[ 88.875760] init: untracked pid 1628 exited
[ 88.905534] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 88.917180] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 88.993449] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 89.034172] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 89.083489] init: untracked pid 1630 exited
[ 93.734025] --> mtk_cfg80211_testmode_cmd()
[ 93.734083] --> mtk_cfg80211_testmode_sw_cmd()
[ 93.734772] --> mtk_cfg80211_testmode_cmd()
[ 93.734799] --> mtk_cfg80211_testmode_sw_cmd()
[ 93.734978] --> mtk_cfg80211_testmode_cmd()
[ 93.735006] --> mtk_cfg80211_testmode_sw_cmd()
[ 93.808674] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 93.814657] init: untracked pid 1888 exited
[ 93.816343] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 93.826176] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 94.569595] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 94.633471] init: untracked pid 1890 exited
[ 98.641983] init: untracked pid 2058 exited
[ 98.646313] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 98.655418] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 98.673540] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 99.359454] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 99.463403] init: untracked pid 2060 exited
[ 103.471967] init: untracked pid 2072 exited
[ 103.472025] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 103.485255] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 103.496476] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 103.508566] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 103.563208] init: untracked pid 2074 exited
[ 107.105262] init: untracked pid 2014 exited
[ 108.111929] init: untracked pid 2149 exited
[ 108.203141] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 108.206698] init: untracked pid 2029 exited
[ 108.213732] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 108.440623] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 108.501832] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 108.573524] init: untracked pid 2151 exited
[ 111.595745] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 113.584127] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 113.584279] init: untracked pid 2271 exited
[ 113.597515] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 114.123611] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 114.825266] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 114.863255] init: untracked pid 2273 exited
[ 118.875498] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 118.875510] init: untracked pid 2332 exited
[ 118.889571] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 118.925149] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 118.947537] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 119.053334] init: untracked pid 2334 exited
[ 119.893592] qtaguid: iface_stat: stat_update() lo not found
[ 119.893731] qtaguid: iface_stat: stat_update() lo not found
[ 119.893800] qtaguid: iface_stat: stat_update() lo not found
[ 119.893833] qtaguid: iface_stat: stat_update() lo not found
[ 119.893893] qtaguid: iface_stat: stat_update() lo not found
[ 119.899362] qtaguid: iface_stat: stat_update() lo not found
[ 119.899449] qtaguid: iface_stat: stat_update() lo not found
[ 119.899506] qtaguid: iface_stat: stat_update() lo not found
[ 119.899540] qtaguid: iface_stat: stat_update() lo not found
[ 119.899621] qtaguid: iface_stat: stat_update() lo not found
[ 120.072868] qtaguid: iface_stat: stat_update() lo not found
[ 120.073012] qtaguid: iface_stat: stat_update() lo not found
[ 120.073069] qtaguid: iface_stat: stat_update() lo not found
[ 120.073100] qtaguid: iface_stat: stat_update() lo not found
[ 120.073142] qtaguid: iface_stat: stat_update() lo not found
[ 120.075449] qtaguid: iface_stat: stat_update() lo not found
[ 120.075532] qtaguid: iface_stat: stat_update() lo not found
[ 120.075602] qtaguid: iface_stat: stat_update() lo not found
[ 120.075633] qtaguid: iface_stat: stat_update() lo not found
[ 120.075670] qtaguid: iface_stat: stat_update() lo not found
[ 121.103430] qtaguid: iface_stat: stat_update() lo not found
[ 121.103693] qtaguid: iface_stat: stat_update() lo not found
[ 121.103854] qtaguid: iface_stat: stat_update() lo not found
[ 121.103917] qtaguid: iface_stat: stat_update() lo not found
[ 121.104009] qtaguid: iface_stat: stat_update() lo not found
[ 121.105701] qtaguid: iface_stat: stat_update() lo not found
[ 121.105810] qtaguid: iface_stat: stat_update() lo not found
[ 121.105896] qtaguid: iface_stat: stat_update() lo not found
[ 121.105950] qtaguid: iface_stat: stat_update() lo not found
[ 121.106023] qtaguid: iface_stat: stat_update() lo not found
[ 121.833759] --> mtk_cfg80211_testmode_cmd()
[ 121.833835] --> mtk_cfg80211_testmode_sw_cmd()
[ 121.834105] --> mtk_cfg80211_testmode_cmd()
[ 121.834134] --> mtk_cfg80211_testmode_sw_cmd()
[ 121.834336] --> mtk_cfg80211_testmode_cmd()
[ 121.834362] --> mtk_cfg80211_testmode_sw_cmd()
[ 123.060808] init: untracked pid 2561 exited
[ 123.060951] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 123.068481] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 123.185327] qtaguid: iface_stat: stat_update() lo not found
[ 123.185409] qtaguid: iface_stat: stat_update() lo not found
[ 123.185459] qtaguid: iface_stat: stat_update() lo not found
[ 123.185489] qtaguid: iface_stat: stat_update() lo not found
[ 123.185526] qtaguid: iface_stat: stat_update() lo not found
[ 123.186982] qtaguid: iface_stat: stat_update() lo not found
[ 123.187076] qtaguid: iface_stat: stat_update() lo not found
[ 123.187124] qtaguid: iface_stat: stat_update() lo not found
[ 123.187154] qtaguid: iface_stat: stat_update() lo not found
[ 123.187210] qtaguid: iface_stat: stat_update() lo not found
[ 123.317405] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 124.006758] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 124.053335] init: untracked pid 2563 exited
[ 127.114825] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 127.318758] qtaguid: iface_stat: stat_update() lo not found
[ 127.318903] qtaguid: iface_stat: stat_update() lo not found
[ 127.318987] qtaguid: iface_stat: stat_update() lo not found
[ 127.319044] qtaguid: iface_stat: stat_update() lo not found
[ 127.319104] qtaguid: iface_stat: stat_update() lo not found
[ 127.320578] qtaguid: iface_stat: stat_update() lo not found
[ 127.320667] qtaguid: iface_stat: stat_update() lo not found
[ 127.320750] qtaguid: iface_stat: stat_update() lo not found
[ 127.320799] qtaguid: iface_stat: stat_update() lo not found
[ 127.320873] qtaguid: iface_stat: stat_update() lo not found
[ 128.315377] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 128.316460] init: untracked pid 2715 exited
[ 128.332218] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 128.405611] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 128.493543] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 128.583530] init: untracked pid 2717 exited
[ 132.343490] qtaguid: iface_stat: stat_update() lo not found
[ 132.343620] qtaguid: iface_stat: stat_update() lo not found
[ 132.343683] qtaguid: iface_stat: stat_update() lo not found
[ 132.343737] qtaguid: iface_stat: stat_update() lo not found
[ 132.343835] qtaguid: iface_stat: stat_update() lo not found
[ 132.346249] qtaguid: iface_stat: stat_update() lo not found
[ 132.346328] qtaguid: iface_stat: stat_update() lo not found
[ 132.346421] qtaguid: iface_stat: stat_update() lo not found
[ 132.346460] qtaguid: iface_stat: stat_update() lo not found
[ 132.346504] qtaguid: iface_stat: stat_update() lo not found
[ 133.558474] init: untracked pid 2932 exited
[ 134.123134] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 134.132771] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 134.495975] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 134.515538] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 134.564549] init: untracked pid 2934 exited
[ 135.388120] qtaguid: iface_stat: stat_update() lo not found
[ 135.389382] qtaguid: iface_stat: stat_update() lo not found
[ 135.389482] qtaguid: iface_stat: stat_update() lo not found
[ 135.389561] qtaguid: iface_stat: stat_update() lo not found
[ 135.389779] qtaguid: iface_stat: stat_update() lo not found
[ 135.415383] qtaguid: iface_stat: stat_update() lo not found
[ 135.415651] qtaguid: iface_stat: stat_update() lo not found
[ 135.415883] qtaguid: iface_stat: stat_update() lo not found
[ 135.416251] qtaguid: iface_stat: stat_update() lo not found
[ 135.416437] qtaguid: iface_stat: stat_update() lo not found
[ 135.419052] init: untracked pid 2016 exited
[ 135.638102] init: untracked pid 2031 exited
[ 137.962953] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 138.380637] init: untracked pid 2988 exited
[ 139.050885] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 139.071721] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 139.323651] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 139.422326] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 139.493524] init: untracked pid 2990 exited
[ 140.155041] init: untracked pid 2738 exited
[ 140.228152] init: untracked pid 2747 exited
[ 143.239775] init: untracked pid 3046 exited
[ 143.241517] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 143.242257] qtaguid: iface_stat: stat_update() lo not found
[ 143.242875] qtaguid: iface_stat: stat_update() lo not found
[ 143.242956] qtaguid: iface_stat: stat_update() lo not found
[ 143.243063] qtaguid: iface_stat: stat_update() lo not found
[ 143.243119] qtaguid: iface_stat: stat_update() lo not found
[ 143.250475] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 143.329170] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 143.355593] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 143.413295] init: untracked pid 3048 exited
[ 148.193821] init: untracked pid 2740 exited
[ 148.203544] init: untracked pid 3171 exited
[ 148.203873] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 148.216640] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 148.569029] init: untracked pid 2756 exited
[ 148.823618] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 148.841938] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 148.873438] init: untracked pid 3173 exited
[ 149.788018] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[ 149.788134] DWC_OTG: Init: Port Power? op_state=1
[ 149.788162] DWC_OTG: Init: Power Port (0)
[ 150.232987] usb 1-1: new high speed USB device number 2 using usb20_otg
[ 150.443737] usb 1-1: New USB device found, idVendor=0781, idProduct=5567
[ 150.443774] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 150.443818] usb 1-1: Product: Firebird USB Flash Drive
[ 150.443843] usb 1-1: Manufacturer: SanDisk
[ 150.443864] usb 1-1: SerialNumber: 4C532000030907101251
[ 150.444836] scsi0 : usb-storage 1-1:1.0
[ 151.443873] scsi 0:0:0:0: Direct-Access SanDisk Cruzer Blade 1.26 PQ: 0 ANSI: 5
[ 151.445850] sd 0:0:0:0: [sda] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
[ 151.447208] sd 0:0:0:0: [sda] Write Protect is off
[ 151.447239] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 151.447961] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 151.458546] sda: sda1
[ 151.462273] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 152.441312] init: no such service 'fuse_usb_storage'
[ 153.448493] init: untracked pid 3229 exited
[ 153.448816] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 153.463089] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 154.161527] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 154.213617] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 154.263933] init: untracked pid 3231 exited
[ 158.273541] init: untracked pid 3239 exited
[ 158.775854] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 158.783508] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 160.123362] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 160.183504] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 160.865884] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 160.953287] init: untracked pid 3241 exited
[ 163.965373] init: untracked pid 3253 exited
[ 164.353115] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 164.362219] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 165.190735] qtaguid: iface_stat: stat_update() lo not found
[ 165.190811] qtaguid: iface_stat: stat_update() lo not found
[ 165.190859] qtaguid: iface_stat: stat_update() lo not found
[ 165.190888] qtaguid: iface_stat: stat_update() lo not found
[ 165.190927] qtaguid: iface_stat: stat_update() lo not found
[ 165.193302] qtaguid: iface_stat: stat_update() lo not found
[ 165.193367] qtaguid: iface_stat: stat_update() lo not found
[ 165.193414] qtaguid: iface_stat: stat_update() lo not found
[ 165.193444] qtaguid: iface_stat: stat_update() lo not found
[ 165.193496] qtaguid: iface_stat: stat_update() lo not found
[ 168.353061] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.367458] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.404918] init: untracked pid 3255 exited
[ 168.416814] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.419024] init: untracked pid 3265 exited
[ 168.430330] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.474210] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.509082] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 168.563266] init: untracked pid 3267 exited
[ 173.574294] init: untracked pid 3303 exited
[ 173.953454] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 173.975860] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 174.824040] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 174.866239] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 174.943506] init: untracked pid 3305 exited
[ 177.282512] --> mtk_cfg80211_testmode_cmd()
[ 177.282620] --> mtk_cfg80211_testmode_sw_cmd()
[ 177.291665] --> mtk_cfg80211_testmode_cmd()
[ 177.291736] --> mtk_cfg80211_testmode_sw_cmd()
[ 177.292068] --> mtk_cfg80211_testmode_cmd()
[ 177.292126] --> mtk_cfg80211_testmode_sw_cmd()
[ 178.961258] init: untracked pid 3370 exited
[ 178.963637] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 178.969977] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 179.787589] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 180.387638] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 180.501520] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 180.563526] init: untracked pid 3372 exited
[ 181.876701] vpu: power on
[ 183.569468] init: untracked pid 3386 exited
[ 184.209432] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 184.217538] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 184.323510] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 184.337611] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 184.393288] init: untracked pid 3388 exited
[ 185.882988] vpu: power off...done
[ 188.403673] init: untracked pid 3395 exited
[ 188.713925] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 188.720711] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 188.784592] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 188.797642] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 188.853273] init: untracked pid 3397 exited
[ 188.929572] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 193.790212] qtaguid: iface_stat: stat_update() lo not found
[ 193.790440] qtaguid: iface_stat: stat_update() lo not found
[ 193.790590] qtaguid: iface_stat: stat_update() lo not found
[ 193.790691] qtaguid: iface_stat: stat_update() lo not found
[ 193.790788] qtaguid: iface_stat: stat_update() lo not found
[ 193.794011] qtaguid: iface_stat: stat_update() lo not found
[ 193.794242] qtaguid: iface_stat: stat_update() lo not found
[ 193.794484] qtaguid: iface_stat: stat_update() lo not found
[ 193.794542] qtaguid: iface_stat: stat_update() lo not found
[ 193.794622] qtaguid: iface_stat: stat_update() lo not found
[ 193.863409] init: untracked pid 3418 exited
[ 194.445564] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 194.457835] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 194.586388] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 194.675304] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 194.753852] init: untracked pid 3420 exited
[ 198.781027] init: untracked pid 3430 exited
[ 199.234523] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 199.243396] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 199.293791] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 200.032718] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 200.103309] init: untracked pid 3432 exited
[ 203.111823] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 203.112006] init: untracked pid 3444 exited
[ 203.125193] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 203.174136] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 203.189180] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 203.243225] init: untracked pid 3446 exited
[ 203.481973] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 208.252644] init: untracked pid 3455 exited
[ 208.252765] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 208.265728] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 208.284150] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 208.296210] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 208.333242] init: untracked pid 3457 exited
[ 208.573765] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 211.187274] --> mtk_cfg80211_testmode_cmd()
[ 211.187474] --> mtk_cfg80211_testmode_sw_cmd()
[ 211.188241] --> mtk_cfg80211_testmode_cmd()
[ 211.188345] --> mtk_cfg80211_testmode_sw_cmd()
[ 211.205447] --> mtk_cfg80211_testmode_cmd()
[ 211.205577] --> mtk_cfg80211_testmode_sw_cmd()
[ 213.688805] init: untracked pid 3471 exited
[ 213.688957] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 213.701786] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 213.723452] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 213.736102] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 213.793253] init: untracked pid 3473 exited
[ 218.422404] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 218.423509] init: untracked pid 3575 exited
[ 218.438344] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 218.757788] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 218.798353] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 218.863366] init: untracked pid 3577 exited
[ 220.164746] qtaguid: iface_stat: stat_update() lo not found
[ 220.164944] qtaguid: iface_stat: stat_update() lo not found
[ 220.165104] qtaguid: iface_stat: stat_update() lo not found
[ 220.165178] qtaguid: iface_stat: stat_update() lo not found
[ 220.165277] qtaguid: iface_stat: stat_update() lo not found
[ 220.167139] qtaguid: iface_stat: stat_update() lo not found
[ 220.167323] qtaguid: iface_stat: stat_update() lo not found
[ 220.167457] qtaguid: iface_stat: stat_update() lo not found
[ 220.167551] qtaguid: iface_stat: stat_update() lo not found
[ 220.167613] qtaguid: iface_stat: stat_update() lo not found
[ 223.094983] qtaguid: iface_stat: stat_update() lo not found
[ 223.095409] qtaguid: iface_stat: stat_update() lo not found
[ 223.095590] qtaguid: iface_stat: stat_update() lo not found
[ 223.095840] qtaguid: iface_stat: stat_update() lo not found
[ 223.096110] qtaguid: iface_stat: stat_update() lo not found
[ 223.854197] qtaguid: iface_stat: stat_update() lo not found
[ 223.854384] qtaguid: iface_stat: stat_update() lo not found
[ 223.854467] qtaguid: iface_stat: stat_update() lo not found
[ 223.854508] qtaguid: iface_stat: stat_update() lo not found
[ 223.854577] qtaguid: iface_stat: stat_update() lo not found
[ 223.887540] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 223.894072] init: untracked pid 3655 exited
[ 223.902066] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 224.017369] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 224.056839] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 224.103384] init: untracked pid 3657 exited
[ 224.136542] qtaguid: iface_stat: stat_update() lo not found
[ 224.142091] qtaguid: iface_stat: stat_update() lo not found
[ 224.142195] qtaguid: iface_stat: stat_update() lo not found
[ 224.142243] qtaguid: iface_stat: stat_update() lo not found
[ 224.142294] qtaguid: iface_stat: stat_update() lo not found
[ 224.158188] qtaguid: iface_stat: stat_update() lo not found
[ 224.158400] qtaguid: iface_stat: stat_update() lo not found
[ 224.158488] qtaguid: iface_stat: stat_update() lo not found
[ 224.158544] qtaguid: iface_stat: stat_update() lo not found
[ 224.158627] qtaguid: iface_stat: stat_update() lo not found
[ 228.117573] init: untracked pid 3673 exited
[ 228.117943] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 228.126422] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 229.679599] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 230.536464] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 230.603765] init: untracked pid 3675 exited
[ 233.619794] init: untracked pid 3692 exited
[ 233.619946] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 233.634011] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 233.939259] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 233.962456] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 234.004012] init: untracked pid 3694 exited
[ 238.046932] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 238.266177] init: untracked pid 3706 exited
[ 239.653991] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 239.687154] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 239.925079] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 239.990629] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 240.043985] init: untracked pid 3708 exited
[ 240.212371] qtaguid: iface_stat: stat_update() lo not found
[ 240.212483] qtaguid: iface_stat: stat_update() lo not found
[ 240.212555] qtaguid: iface_stat: stat_update() lo not found
[ 240.212589] qtaguid: iface_stat: stat_update() lo not found
[ 240.212630] qtaguid: iface_stat: stat_update() lo not found
[ 240.217690] qtaguid: iface_stat: stat_update() lo not found
[ 240.217834] qtaguid: iface_stat: stat_update() lo not found
[ 240.217939] qtaguid: iface_stat: stat_update() lo not found
[ 240.218013] qtaguid: iface_stat: stat_update() lo not found
[ 240.218090] qtaguid: iface_stat: stat_update() lo not found
[ 240.872922] qtaguid: iface_stat: stat_update() lo not found
[ 240.873131] qtaguid: iface_stat: stat_update() lo not found
[ 240.873289] qtaguid: iface_stat: stat_update() lo not found
[ 240.873385] qtaguid: iface_stat: stat_update() lo not found
[ 240.873449] qtaguid: iface_stat: stat_update() lo not found
[ 243.188844] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 243.189583] init: untracked pid 3734 exited
[ 243.201721] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 244.166095] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 244.235232] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 244.283708] init: untracked pid 3736 exited
[ 246.534628] init: untracked pid 3761 exited
[ 247.216604] qtaguid: iface_stat: stat_update() lo not found
[ 247.216719] qtaguid: iface_stat: stat_update() lo not found
[ 247.216798] qtaguid: iface_stat: stat_update() lo not found
[ 247.216844] qtaguid: iface_stat: stat_update() lo not found
[ 247.216903] qtaguid: iface_stat: stat_update() lo not found
[ 247.219772] qtaguid: iface_stat: stat_update() lo not found
[ 247.219865] qtaguid: iface_stat: stat_update() lo not found
[ 247.219932] qtaguid: iface_stat: stat_update() lo not found
[ 247.219977] qtaguid: iface_stat: stat_update() lo not found
[ 247.220029] qtaguid: iface_stat: stat_update() lo not found
[ 248.542435] init: untracked pid 3780 exited
[ 248.542759] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 248.558807] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 248.571640] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 248.591065] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 248.663744] init: untracked pid 3782 exited
[ 248.895501] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
[ 249.849540] init: untracked pid 3831 exited
[ 250.310093] init: untracked pid 3833 exited
[ 253.323676] init: untracked pid 3848 exited
[ 253.324935] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 253.338678] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 253.723422] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 253.736051] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[ 253.783255] init: untracked pid 3850 exited
[ 257.059957] enter rt5631_hifi_codec_set_dai_sysclk, syclk=11289600
 "My only dream is freedom, then I dream of freedom."
68 Guest(s)
Devices in use: Desktop (59), Phone (9)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
