2015/12/29
Hello, excuse me for my English I French I have a big problem with my tablet 'clust cl4c97-ret' Clone of Aoson m33.Â
I install the oma xoro pad
http://crewrktablets.arctablet.com/?p=3319
Everything worked except the percentage of battery remaining to 0%.Â
I install  Oma Chuwi V88 V5.1 Default Battery Percentage (10.6 MiB) And the tablet reboot normally except after the animation oma the screen remains black. I access the cwm, do a wipe cache / data etc ... but still nothing. I format in cwm system size / cache / data etc ...
Now my tablet always starts in recovery mode. I specify that the USB Debugging mode is not activated and my computer no detected even my tablet I try to detect with adb sideload and androidsdk and other but no detected.Â
I try to install a new roms with cwm but i have a different error, example : no app2sd or status 7/0 or problem with lastlog and log.
And when a firmware successfully installed it does not launch.
I don't have a download mode and my tablet boot en recovery only.
I want to try installed the rom oma xoro pad kitkat via sd card but I can't because I have 6 .img
Boot.img ' Â recovery.img ' Â misc.img ' update.img ' Â system.img and kernel.img
But for install rom with cwm is not possible.Â
I download a .zip with META-INF and SYSTEM files but i do not know where to place the .img files.
Can you help me oma please. If you have this firmware that I could install with cwm.
Thank you so much.
 "My only dream is freedom, then I dream of freedom."
Be careful thinking a tab is a "clones of". Every tab has it's own kernel.
Is the stock firmware available or did you at least a dump of it?
2015/12/29
Thank you for answering. Â
No I have not the stock firmware and the store does not.
But the Rom xoro pad kitkat with kernel # 132 worked perfectly for months, until I moved the file chiwi V88 default percentage...Â
If you have this rom in zip format for install via recovery cwm with microSD?
2015/12/29
This my tablette and this tablet is product by this store.
Tablette tactile 9,7''Capacitif 10 points Full HD - Résolution 2048 x 1536 px - Processeur Quad-Core (1,6Ghz) RK3188 - RAM 2 Go DDR3 - Mémoire 16 Go - G-sensor - Port micro USB 2.0 / HDMI -Wifi MT5931
FlashTool is the way. Which Windows? What keys are present? Reset hole?
Power and Volume keys?
Make sure USB cable and Power Supply is plugged. Then hard power-off (hold Power for about 12 sec). You should hear a sound on your PC. Then hold Power and Vol+ until RKAndroidTool recognizes a loader device. You should also hear a sound.
I guess this is more a driver issue. Here is a driver assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2016
Uninstall driver first, then istnall.
105 Guest(s)
Devices in use: Desktop (90), Phone (14), Tablet (1)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
