2012/11/19
Thanks,
2 things
1. What is the Wifi Manager for?
2. Please disable the WLAN Standby only for a test.
What I can see, is that there are several attempts to assign IP 0.0.0.0, so the WLAN did not receive a correct IP.
But to say more, I'll have to ask netlars, he knows better the CM10.1 than me.
peter334Per aspera ad astra, we rock the Tablets !
2013/09/29
The internal sd was not reachable with pc (xubuntu 13.10 64bit), but the tablet has no problem.
I reformatted the card with android, I still receive:
Error mounting /dev/sdb1 at /media/9651-1416: Command-line `mount -t "vfat" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush" "/dev/sdb1" "/media/9651-1416"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
If I format the card with gparted (fat32), it is not recognized by tablet anymore. CWM also can not format the sdcard ... it is gone.
I installed the sdcard rw fix.
2012/11/19
The internal sd is formatted with ext4 thru the format_nand.zip.
Don't change this.
You flashed our CM10.1 with our boot.img, you did not change this to stock right?
2013/09/29
no, all the images from CM10.1.
gparted did not recognized the sdcard partition as ext4?
now I can not format the sdcard in android, cwm, and gparted
android says, sd-card is damaged
PC - unavailable
cmw - fails, no partition
how can I restore sd-card?
I thought the internal is fat32 however is the external. That means I can use ext4 at external sd? nice
2012/11/19
You should never try to use gparted, or something else from linux thru the USB to the Tablet.
Only thing I can say now.. reflash all, including parameters and eraseIDB.
Sorry, but you have killed the partition table on the NAND I think.
2013/09/29
But I can not re flash the CM10.1. To flash the NAND zip I need to store this at internal sd, because external is not available.
After flashing, the contents on the sd card where still availabe...would stock flash work? :/
sry, but what do you mean with re flash parameters?
EDIT: ah, ok you mean ..rockdevparameters
I try to re flash stock, if this works, I can flash CM10 ...
... back to stock worked, puh ... change to my last CM10 bup
2013/09/29
Device is restored.
I'm sorry, but I was confused about the no external_sd thing. After a second nand fix install, I discovert that sdcard = external_sd
emmc = sdcard
Result: external sd is reachabe
Some more logs, but seems the same messages are repeating.
https://www.dropbox.com/s/6mvsdt59s2iiiw0/wifi2.txt
2013/09/29
JochenKauz said
Thanks,2 things
Could you contact netlars about the wifi problem?
I found another small problem, the wifi is turning off in standby, whatever I choose at wifi policy.
With the xeno 10 stock, it was chaos:
never = always on
only when connected = Default - when screen turns off
always = Never when pluged in
If I try a extended wifi lock, the app says: "Failed to modify sleep policy".
2012/11/19
I've already contacted netlars, but we have not found a solution yet.
About the chaos of the wifi state, I don't think its chaos.
The policy is called "WLAN to be turned of in standby". So the states you describe do exactly what they should do:
never = always on
only when connected = Default – when screen turns off
2013/09/29
No, the wifi policy is called "WLAN im Standby Modus aktiviert lassen" translated "Keep wifi on during sleep" ... however.
@ CM10.1 "Keep Wi-Fi on during sleep" > "always"
He is only keeping wifi on if it is plugged in.
Ok, these are not so good news, I set hope at the not yet part.
If there is something else I could try, let me know.
2013/09/29
Does something change from 1.3.3 to 1.3.4 about wifi? I could not find a chagelog.
EDIT:
Yes, you can.For wifi try this: http://crewrktablets.arctablet.com/?wpfb_dl=1303
I pick up the nice wifi fix to this thread, because it is off topic over there.
@oma
The wifi standby instruction rule is still not working, maybe you have an idea why?
51 Guest(s)
Devices in use: Desktop (45), Phone (6)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
