2012/11/19
Sorry I'm a little bit lost at this point.
What exactly did you do?
2013/09/29
I flashed the CM10.1 image with my kernel and installed the NAND fix. After that the tablet booted
The CWM recovery is a bit strange. I can not load the fix from external-sd, this card is not even shown at mounts and storage. I do not know what sd-ext is, but it is not working. If I try to create a nandroid image, it is not possible at my internal sd card, only at the external ...
ok, I just flashed the image, so I had not enough time for testing. But I did not find the superuser program to take a look at the settings.
Which fixed should I flash now? and after each fix a reboot?
EDIT: ah, su is @ settings
2012/11/19
wait, you have no extern_sd shown in CWM?
if you make in CWM install zip from external sd, this does not work?
2012/11/19
now it has booted?
Great. the graphic errors were mentioned before.
But how did you a format_nand without having external_sd? Never seen this before.
2013/09/29
I have 2 sd cards, one is the internal sdcard (Â permanently installed) and one external.
I could not flash the zip from external
-> so reflash original image -> copy zip to internal sd -> reflash CM10 -> flash zip with CMW
I had this RK30GENERIC_CWM previously installed. External sd is available, but flashing the fixes seems not to work.
2012/11/19
yes, its normal to have 2 sd cards.
The internal sdcard should be mounted at /mnt/sdcard and the external one on /mnt/external_sd.
I have never the case that external_sd is not available... I'll have to ask Oma tomorrow about that, thats not normal and could cause weired errors.
peter334Per aspera ad astra, we rock the Tablets !
2013/09/29
A small report as my first impression:
- WLAN is connecting! jey
- CM 10 is working fine
but is not every time, where other devices establish solid connection, I would describe it as:
- connection is unstable
- package loss
- connection loss (but can reconnect after some time)
- slow connection, till it is connected but no transfers
I will observe this some days.
2012/11/19
Is this issue always on all WLAN networks happening?
I don't think that using another kernel will be possiblle, cause as far as I know the kernel you are using is your stock kernel, and another kernel is not available.
You have linked similar issues at code.google discussion. There were made changes to wpa_supplicant, perhaps CM did not receive this changes, something I could try to check. If CM did not merge the AOSP changes, then we could make a merge on our own.
2012/11/19
and perhaps a logcat/dmesg could help to see what happens to the WLAN.
2013/09/29
Not at all networks, my home wlan is working with wpa2.
The uni network is the problem.
uni network:
encryption WPA2 + AES
authentication: 802.1x + PEAP/ MSCHAPv2
I tested to more networks, but last time I tried to connect to a public wlan, it also failed.
@the google thread I see only one post, which could help
https://code.google.com/p/android/issues/detail?id=36638#c27
But this is not permanent and I do not know now how to compile that.
http://abload.de/img/img_20131121_134736c4evn.jpg
66 Guest(s)
Devices in use: Desktop (60), Phone (6)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
