2014/04/07
I've got the Odys Titan Tablet and installed Omas Firmware Oma RK30 CM10.1 v1.3.5 and CrewRKTablets CM10.1 Wifi Fix to get at least the wlan module loaded (Titan's wifi chip is MT5931)
Unhappily my tablet does not show up any wireless networks. Does anyone know how to fix that issue or what files are needed to be copied from stock rom?
kind regards
Pls upload some logs. Open a terminal:
su
dmesg >/mnt/sdcard/dmesg.txt
Can you also pls upload the kernel for the archive?
2014/04/07
I've attached both logfiles and the kernel.
Offtopic concerning the wireless problem, but still related to the Odys Titan:
To get the battery status working again I had to put 1 into /sys/class/rk30_battery/rk30_battery_start_timer_work. (Can be put into boot image or init script, maybe you've already done this in other fixes)
Currently Online: chiduciot
82 Guest(s)
Devices in use: Desktop (70), Phone (12), Tablet (1)
kpointcom
fendt126
victorprdm1994
sif
tayten
vrtroper
