2012/10/07
I've installed the CM10.1 by Oma on my NextWolf 7, using the kernel and the orientation fix as described on the page.
First I had to use the stock recovery as the tablet always started in recovery mode, but after that I've installed the correct recovery.
Everything is working fine and I love the ROM but one thing isn't working: tilt and rotation.
Is there any fix for this or anything I can do?
I cannot play racing games with tilt steering and also the screen doesn't rotate, I have to use an app to force the orientation.
Thanks & Ciao,
Alfred
Should be sensor fix 4, as documented here: http://crewrktablets.arctablet.com/?p=1913
76 Guest(s)
Devices in use: Desktop (63), Phone (13)
hans41
rickybk
soniya07
ironmangitar
