2013/09/29
I am searching for a new kernel for the odys xelio 10 pro (xeno 10), but there is nothing.
Current (stock) kernel is 3.0.8+, it would maybe relevant to fix the wifi isse at eurodam (802.1x + PEAP/ MSCHAPv2) networks and brings kitkat threw the tab.
Could someone build a new one?
Regards,
peter334
identical tablets:
TB1010, xelio10pro, xeno10, HKC x101
2012/11/19
Unfortunately the Xelio 10 Pro uses a screen driver that is totally unknown to us, so we are unable to build a custom kernel with working display.
2013/09/29
hm... could I do anything to help with the identification? exist maybe another driver which fit to the screen model?
btw. is it possible to use the game fix at v.1.3.4Â ? I would keep this version because of "highest performance"
peter334Per aspera ad astra, we rock the Tablets !
The screen is not totally unknown. It seems to be similar to an iPad display. Unfortunately this display has a controller inside that needs some initialization sequences sent to it. Additionally it uses a dataline configuration between the video unit and the display that is not standard and in the available know video modes supported by the kernel lcdc driver.
The Xelio 10pro and it's 3.0.8 kernel ist sort of horror, I know. Everytime you switch between Apps, it takes several long delays until you can do anything. In Chrome it needs ages for swtiching between tabs. But I tested many of our CROMs and they work fine, they look good, but they do have the same delays and lags, that the original ODYS image has. Even the old Xpress having half of the memory and only a single core CPU, feels great and fast compared to this (as long as you use the new kernel and JB image)
So I still need little bit of time as my every day job eats me up a bit for the next weeks. But I am at it.
Regards
Astralix
2013/09/29
Yes, you can.For wifi try this: http://crewrktablets.arctablet.com/?wpfb_dl=1303
I tried today and wifi connection worked, I will observe this some time.
Astralix said
...The Xelio 10pro and it's 3.0.8 kernel ist sort of horror, I know. Everytime you switch between Apps, it takes several long delays until you can do anything. In Chrome it needs ages for swtiching between tabs. ...
Yes, I know this problem.
It is good to know that someone is on it, I hope for a future kernel release.
Sorry to say, but... No.
You should re-install and then try to configure any app to use SD-Card as memory as much as possible but only if the App has options to configure it.
RK did not open up it's memory driver so no chance to find the root cause for the lag.
Regards
Astralix
92 Guest(s)
Devices in use: Desktop (81), Phone (9), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
