Crew RKTablets Genius by Oma CM10.1 v1.4 on PIPO Smart S2 3G always enter CWM recovery
psion77
2016/02/16 - 10:20
Hi, I flashed Crew RKTablets Genius by Oma CM10.1 v1.4 on my pipo s2, folow by instruction ...reset data/factory reset => reboot => wait 4 min.   and every reboot pipo open cwm recovery.
I made two more attempts, nothing has changed, what can I do to fix it?
2016/02/16 - 20:10
Did you execute EraseIDB?
Also it is documented that one should use the stock recovery first: http://crewrktablets.arctablet.com/?p=1913
psion77
2016/02/16 - 21:42
Yes I do EraseIDB.
I replace cwm on version 6.0.3.1 and kernel 3.0.8 for s2, it work fine except 3G and front camera
the camera is not relevant, but 3G does not work it is worse.
with the default kernel(the archive) tablet to charge without turning on, but not working sensor and screen resolution was 1024x600, and for these two reasons is absolutely useless ((
default kernel 3.0.36 ?
94 Guest(s)
Devices in use: Desktop (76), Phone (18)
cutierogue
hans41
