Cm for Odys Neo S8??
Stahlkreuz
Forum Posts: 11
2013/11/16 - 21:05
Hello again,
I've flashed successfully - know installing some fixes (battery, ui). It runs fantasticaly! Thank you! :)
I follow your instructions step by step, using my Vista 64bit Notebook. Everything worked - when I did my first try. Great work!
Freier (Werbe-)Texter, Android-Freak, iOS-Hasser
Urm
Forum Posts: 12
2013/11/16 - 21:08
Yep, worked now for me too.
What problems with fixes are you installing and why?
Stahlkreuz
Forum Posts: 11
2013/11/16 - 21:17
I've no battery information :-/
The fix doesn `t fix this issue... No Battery Information. Any Idea?
OK, Neo fixed it in its own. :-P everything fine
Urm
Forum Posts: 12
2013/11/16 - 22:49
still have problems. what did you install? can't get the batterie to work
Stahlkreuz
Forum Posts: 11
2013/11/17 - 12:25
When plugged in for a while it shows some information - unfortunately just until next reboot. Then it is on 0% again - but working at all.
Urm
Forum Posts: 12
2013/11/17 - 12:40
Mine will always shutdown when unplugged. Tried the Battery fix and afterwards also the tabletUI and batterie mod.
Stahlkreuz
Forum Posts: 11
2013/11/17 - 12:46
 Have you tried a factory reset after battery fix? When I did so I could work with my neo when not plugged in
2013/11/17 - 12:51
Akku is nearly empty. Load until LED gets off. Then boot into CWM and wipe battery stats (advanced).
Urm
Forum Posts: 12
2013/11/17 - 14:42
So....I now have the same behavior as Stahlkreuz. If the tablet is connected for a while the akku information is shown correctly, but after a reboot still no Information is visible. But now you can keep working, just without information.
And I have sometimes the problem, that all processes are crashing on and on again...
Doesn't seem to work good.
Stahlkreuz
Forum Posts: 11
2013/11/17 - 15:42
@oma this morning it showed me 100%. After rebooting it was 0% again. Several reboots didn't bring any change. I've already wiped battery stats. :-( could reflashing be successful? Unfortunately it's now 2 Neo with this issue.
JochenKauz
Forum Posts: 450
Thanks Received: 76
2013/11/17 - 19:01
I think we have a general problem with the battery now. I'm looking right now on source of the kernel for genio to find out what should be done to fix it in CM.
Sorry for that.
Stahlkreuz
Stahlkreuz
Forum Posts: 11
2013/11/17 - 19:41
To give you some additional information: Plugging in the device for around 5 minutes makes it generating / showing some battery stats and an charging progress. But I don't know whether it is correct what provided.
Sometimes when unplugging device before stats have been generated, it will immediately shut down. Rebooting will be successful, if plugged in again - although starting recovery is possible without plugging in. So this problem might be just a thing of android itself not of the battery.
I believe in you. :-)
Fabii
2014/12/03 - 21:20
Hello, is there any update about the battery Problem?
I have installed the CM10.1 V1.4 but the Problem is still there.
105 Guest(s)
Devices in use: Desktop (100), Phone (5)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
