first oft all: Thank you for that great Plattform!
Unfortunately, I can't find any clear information about Customz for Neo S8 plus. I'd like to install CM - can you help? Are there some files for doing so?
I've already rooted my device and installed cwm.
Freier (Werbe-)Texter, Android-Freak, iOS-Hasser
Build: http://crewrktablets.arctablet.com/?p=1913
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=706
2013/06/16
Hello, I would like to install that build also. But before I flash something wrong, wich fixes should I use?
Odys Genio Beta v1.3.3
add HDMI settings
add CRT effect
battery info fix
sdcard rw fix
The fixes are installed from sd ok, but what to do with the "addXXX" things?
And then I use the TabletUIfix and the BatteryMod (also like a fix from sd?)
And last, how I know wich sensor fix is the right?
Hope my questions are not to obvious.
Greetings,
Urm
We will see. In a first step you will only need the v1.3.3 pack, your kernel and the fromat_NAND fix.
Flash acc. to instructions.
2013/06/16
Hmm...I will need some help with the USB driver. Can't install it, always get the message that there's no driver found in the packages. (Or it's not for 64bit)
I'm now using win8.1 64bit, turned off driver signature and tested lots of drivers (original drivers from odys, driver from the build here, also drivers from the Oma Rockchip Win8Â folder. USB debugging is activated. Don't know what to try next...
(last time I tried flashing was with a neo x7 on win7, no problems there...)Â
Here are the win8.1 driver: http://crewrktablets.arctablet.com/?wpfb_dl=1206
However, haven't seen any successful win8.1 driver installation yet. Maybe you'd better use win7 ...
UrmPer aspera ad astra, we rock the Tablets !
Build: http://crewrktablets.arctablet.com/?p=1913Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=706
Thank you for reply!
But which build to use? Can't identify my NEO S8 plus Â
2012/11/19
Sorry, but I don't understand your problem.
What build do you search for?
Oma postet our CM10.1 Release for RK3066 and the kernel for the NEO S8.
The CRom should work on all RK3066 based Tablets. Only thing is to change the kernel to the right one and to install the fixes that are needed.
Did you execute reaseIDB?
Yes, first step in the RKAndroidTool is eraseIDB.
60 Guest(s)
Devices in use: Desktop (44), Phone (16)
cutierogue
