Zync Exceed 9.7
2014/10/23 - 16:03
Da crasht das Kernel-Modul. Hast du das orginal system.img noch?
Meecrob
Forum Posts: 12
2014/10/23 - 20:39
Jap, hat etwas gedauert die auf Dropbox zu schieben ;)
https://www.dropbox.com/s/kbzsvktt6cd0z5g/system.img?dl=0
2014/10/25 - 15:27
Irgendwas ist in der Stock Firmware gegen den Kernel gepatcht. Kann ich bitte noch ein logcat haben?
Meecrob
Forum Posts: 12
2014/10/27 - 22:13
Bitteschön ;)
--------- beginning of /dev/log/main
I/installd(   99): installd firing up
E/cutils  (   99): Failed to read /data/.layout_version: No such file or directory
D/installd(   99): Upgrading /data/media for multi-user
D/installd(   99): Upgrading to shared /data/media/obb
--------- beginning of /dev/log/system
I/Vold    (   91): Vold 2.1 (the revenge) firing up
I/Netd    (   92): Netd 1.0 starting
W/InterfaceController(   92): Error (Symbol not found: ) while searching for the interface command fini function
D/Vold    (   91): Volume flash state changing -1 (Initializing) -> 0 (No-Media)
E/Vold    (   91): ---------get mtd_name is mtdblock9---
I/Vold    (   91): Call notifyStateKernel No.1 in the file of VOlume.cpp
D/Vold    (   91): began find device path
D/Vold    (   91): device path: /sys/class/usb_device/usbdev1.1/device/1-1
D/Vold    (   91): Vendor path: /sys/class/usb_device/usbdev1.1/device/1-1/idVendor
D/Vold    (   91): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    (   91): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
E/Vold    (   91): Start Misc devices Manager...
D/Vold    (   91): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
D/Vold    (   91): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
D/Vold    (   91): Volume flash state changing 0 (No-Media) -> 1 (Idle-Unmounted)
I/cm      (  125): ____ _   _ ____ _  _ ____ ____ ____ _  _ _  _ ____ ___
I/DEBUG   (   93): debuggerd: Dec 20 2013 21:09:00
I/cm      (  128): |     \_/  |__| |\ | |  | | __ |___ |\ | |\/| |  | |  \
I/cm      (  132): |___   |   |  | | \| |__| |__] |___ | \| |  | |__| |__/
I/cm      (  135): Welcome to Android 4.2.2 / CyanogenMod-10.1-20131220-UNOFFICIAL-crewrktablets
I/SurfaceFlinger(   95): SurfaceFlinger is starting
I/SurfaceFlinger(   95): use dithering
I/SurfaceFlinger(   95): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
I/run-parts(  104): mount: Invalid argument
I/mediaserver(   98): ServiceManager: 0x414ebe30
I/AudioFlinger(   98): Using default 3000 mSec as standby time.
I/CameraService(   98): CameraService started (pid=98)
D/CameraHal_Module(   98): camera_get_number_of_cameras(657): sys_graphic.cam_driver.ver:0.2.14
I/run-parts(  104): run-parts: /system/etc/init.d/50selinuxrelabel exited with code 1
D/libEGL  (   95): loaded /system/lib/egl/libEGL_mali.so
D/AndroidRuntime(   96):
D/AndroidRuntime(   96): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime(   96): CheckJNI is OFF
D/CameraHal_Module(   98): camera_get_number_of_cameras(725): Current board have 2 cameras attached.
D/MDnsDS  (   92): MDnsSdListener::Hander starting up
D/MDnsDS  (   92): MDnsSdListener starting to monitor
D/MDnsDS  (   92): Going to poll with pollCount 1
I/AudioPolicyManagerBase(   98): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
I/AudioFlinger(   98): loadHwModule() Loaded primary audio interface from LEGACY Audio HW HAL (audio) handle 1
I/AudioFlinger(   98): HAL output buffer size 1024 frames, normal mix buffer size 1024 frames
I/ViPER4Android_v2(   98): Enter EffectGetDescriptor()
I/ViPER4Android_v2(   98): EffectGetDescriptor(), uuid = 41d3c987-e6cf-11e3-a88a-11aba5d5c51b
I/AudioMixer(   98): found effect "Multichannel Downmix To Stereo" from The Android Open Source Project
I/AudioFlinger(   98): Using module 1 has the primary audio interface
I/AudioFlinger(   98): AudioFlinger's thread 0x414edcc8 ready to run
D/AudioHardwareInterface(   98): setMode(NORMAL)
W/AudioFlinger(   98): Thread AudioOut_2 cannot connect to the power manager service
D/AudioHardware(   98): AudioStreamOutALSA::setParameters() routing=2
D/AudioHardware(   98): ### setVoiceVolume
I/audio_a2dp_hw(   98): adev_open:  adev_open in A2dp_hw module
I/AudioFlinger(   98): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
I/AudioFlinger(   98): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 4
I/AudioPolicyService(   98): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/libEGL  (   95): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (   95): loaded /system/lib/egl/libGLESv2_mali.so
I/[Gralloc-3X](   95): using (fd=17)
I/[Gralloc-3X](   95): id           = fb0
I/[Gralloc-3X](   95): xres         = 1024 px
I/[Gralloc-3X](   95): yres         = 768 px
I/[Gralloc-3X](   95): xres_virtual = 1024 px
I/[Gralloc-3X](   95): yres_virtual = 2304 px
I/[Gralloc-3X](   95): bpp          = 32
I/[Gralloc-3X](   95): r            = 16:8
I/[Gralloc-3X](   95): g            =  8:8
I/[Gralloc-3X](   95): b            =  0:8
I/[Gralloc-3X](   95): format       =2
I/[Gralloc-3X](   95): width        = 202 mm (128.760391 dpi)
I/[Gralloc-3X](   95): height       = 152 mm (128.336838 dpi)
I/[Gralloc-3X](   95): refresh rate = 73.67 Hz
D/dalvikvm(   96): DexOpt: --- BEGIN 'core.jar' (bootstrap=1) ---
D/hwcomposer(   95): ONERROR: status=-2 @ hwc_device_open(1794) in
E/hwcomposer(   95): hwc_device_open(1875):Failed!
E/SurfaceFlinger(   95): composer device failed to initialize (Invalid argument)
W/SurfaceFlinger(   95): getting VSYNC period from fb HAL: 13574415
W/SurfaceFlinger(   95): no suitable EGLConfig found, trying without EGL_FRAMEBUFFER_TARGET_ANDROID
W/Trace   (   95): error opening trace file: No such file or directory (2)
I/SurfaceFlinger(   95): EGL informations:
I/SurfaceFlinger(   95): vendor    : Android
I/SurfaceFlinger(   95): version   : 1.4 Android META-EGL
I/SurfaceFlinger(   95): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer
I/SurfaceFlinger(   95): Client API: OpenGL_ES
I/SurfaceFlinger(   95): EGLSurface: 8-8-8-8, config=0x60000014
I/SurfaceFlinger(   95): OpenGL ES informations:
I/SurfaceFlinger(   95): vendor    : ARM
I/SurfaceFlinger(   95): renderer  : Mali-400 MP
I/SurfaceFlinger(   95): version   : OpenGL ES-CM 1.1
I/SurfaceFlinger(   95): extensions: GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_size_array GL_OES_point_sprite GL_OES_texture_npot GL_OES_query_matrix GL_OES_matrix_palette GL_OES_extended_matrix_palette GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_draw_texture GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_framebuffer_object GL_OES_stencil8 GL_OES_depth24 GL_ARM_rgba8 GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_OES_texture_cube_map GL_EXT_discard_framebuffer GL_EXT_robustness
I/SurfaceFlinger(   95): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger(   95): GL_MAX_VIEWPORT_DIMS = 4096 x 4096
D/SurfaceFlinger(   95): Screen acquired, type=0 flinger=0x4105e318
I/run-parts(  104): mount: No such file or directory
I/run-parts(  104): run-parts: /system/etc/init.d/91cdrom exited with code 255
I/run-parts(  104): run-parts: /system/etc/init.d/92tun exited with code 111
D/libEGL  (  373): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  (  373): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (  373): loaded /system/lib/egl/libGLESv2_mali.so
W/Trace   (  373): error opening trace file: No such file or directory (2)
D/dalvikvm(  367): Ignoring duplicate verify attempt on Ljava/lang/Object;
D/dalvikvm(  367): Ignoring duplicate verify attempt on Ljava/lang/Class;
D/dalvikvm(  367): Ignoring duplicate verify attempt on Ljava/lang/ref/Reference;
D/dalvikvm(  367): Ignoring duplicate verify attempt on Ljava/lang/ref/ReferenceQueue;
D/dalvikvm(  367): Ignoring duplicate verify attempt on Ljava/lang/ref/FinalizerReference;
I/logwrapper(  104): /system/xbin/run-parts terminated by exit(1)
D/dalvikvm(  367): DexOpt: load 48ms, verify+opt 832ms, 1616620 bytes
D/dalvikvm(   96): DexOpt: --- END 'core.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/core.jar': unzip in 100ms, rewrite 1113ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'core-junit.jar' (bootstrap=1) ---
D/dalvikvm(  407): DexOpt: load 2ms, verify+opt 6ms, 140460 bytes
D/dalvikvm(   96): DexOpt: --- END 'core-junit.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/core-junit.jar': unzip in 0ms, rewrite 25ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'bouncycastle.jar' (bootstrap=1) ---
D/dalvikvm(  408): DexOpt: load 16ms, verify+opt 247ms, 671052 bytes
D/dalvikvm(   96): DexOpt: --- END 'bouncycastle.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/bouncycastle.jar': unzip in 39ms, rewrite 337ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'ext.jar' (bootstrap=1) ---
D/dalvikvm(  409): DexOpt: load 25ms, verify+opt 358ms, 940628 bytes
D/dalvikvm(   96): DexOpt: --- END 'ext.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/ext.jar': unzip in 52ms, rewrite 460ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'framework.jar' (bootstrap=1) ---
D/dalvikvm(  410): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  410): Note: class Landroid/opengl/GLWrapperBase; has 250 unimplemented (abstract) methods
D/dalvikvm(  410): DexOpt: load 214ms, verify+opt 2174ms, 5429676 bytes
D/dalvikvm(   96): DexOpt: --- END 'framework.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/framework.jar': unzip in 402ms, rewrite 2858ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'telephony-common.jar' (bootstrap=1) ---
D/dalvikvm(  411): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  411): DexOpt: load 31ms, verify+opt 399ms, 1056476 bytes
D/dalvikvm(   96): DexOpt: --- END 'telephony-common.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/telephony-common.jar': unzip in 33ms, rewrite 495ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'mms-common.jar' (bootstrap=1) ---
D/dalvikvm(  412): DexOpt: load 3ms, verify+opt 37ms, 221020 bytes
D/dalvikvm(   96): DexOpt: --- END 'mms-common.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/mms-common.jar': unzip in 2ms, rewrite 63ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'android.policy.jar' (bootstrap=1) ---
D/dalvikvm(  413): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  413): DexOpt: load 49ms, verify+opt 199ms, 1330628 bytes
D/dalvikvm(   96): DexOpt: --- END 'android.policy.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/android.policy.jar': unzip in 19ms, rewrite 298ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'services.jar' (bootstrap=1) ---
D/dalvikvm(  414): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  414): DexOpt: load 38ms, verify+opt 887ms, 2240780 bytes
D/dalvikvm(   96): DexOpt: --- END 'services.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/services.jar': unzip in 64ms, rewrite 1040ms
D/dalvikvm(   96): DexOpt: --- BEGIN 'apache-xml.jar' (bootstrap=1) ---
D/dalvikvm(  415): DexOpt: load 26ms, verify+opt 261ms, 836812 bytes
D/dalvikvm(   96): DexOpt: --- END 'apache-xml.jar' (success) ---
D/dalvikvm(   96): DEX prep '/system/framework/apache-xml.jar': unzip in 41ms, rewrite 356ms
D/dalvikvm(   96): Trying to load lib libjavacore.so 0x0
D/dalvikvm(   96): Added shared lib libjavacore.so 0x0
D/dalvikvm(   96): Trying to load lib libnativehelper.so 0x0
D/dalvikvm(   96): Added shared lib libnativehelper.so 0x0
W/dalvikvm(   96): Failed to mount /storage as MS_SLAVE: Invalid argument
I/SamplingProfilerIntegration(   96): Profiling disabled.
I/Zygote  (   96): Preloading classes...
D/dalvikvm(   96): GC_EXPLICIT freed 36K, 9% free 427K/468K, paused 1ms+0ms, total 3ms
D/dalvikvm(   96): GC_EXPLICIT freed 3K, 5% free 495K/520K, paused 0ms+0ms, total 2ms
D/dalvikvm(   96): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(   96): GC_EXPLICIT freed 21K, 5% free 534K/560K, paused 0ms+1ms, total 3ms
D/dalvikvm(   96): GC_EXPLICIT freed 26K, 5% free 563K/592K, paused 0ms+1ms, total 2ms
W/Zygote  (   96): Class not found for preloading: android.bluetooth.BluetoothAudioGateway
W/Zygote  (   96): Class not found for preloading: android.bluetooth.HeadsetBase
W/Zygote  (   96): Class not found for preloading: undroid.content.AbstractThreadedSyncAdapter$SyncThread
D/dalvikvm(   96): GC_EXPLICIT freed 23K, 4% free 614K/640K, paused 1ms+0ms, total 3ms
D/dalvikvm(   96): GC_EXPLICIT freed 25K, 5% free 642K/672K, paused 0ms+0ms, total 2ms
D/dalvikvm(   96): GC_EXPLICIT freed 60K, 8% free 743K/808K, paused 0ms+1ms, total 3ms
D/skia    (   96): ---- failed to open </system/fonts/DroidSansTamil-Bold.ttf> as a font
D/dalvikvm(   96): GC_EXPLICIT freed 31K, 5% free 769K/808K, paused 0ms+0ms, total 3ms
D/TextLayoutCache(   96): Using debug level = 0 - Debug Enabled = 0
I/dalvikvm(   96): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI(   96): register_android_mtp_MtpDevice
D/dalvikvm(   96): GC_EXPLICIT freed 23K, 3% free 811K/836K, paused 0ms+0ms, total 3ms
D/dalvikvm(   96): GC_EXPLICIT freed 15K, 3% free 854K/872K, paused 1ms+0ms, total 4ms
D/dalvikvm(   96): GC_FOR_ALLOC freed 222K, 17% free 1144K/1368K, paused 6ms, total 6ms
D/dalvikvm(   96): GC_EXPLICIT freed 254K, 17% free 1290K/1548K, paused 1ms+1ms, total 9ms
D/dalvikvm(   96): GC_EXPLICIT freed 29K, 15% free 1316K/1548K, paused 1ms+0ms, total 8ms
D/dalvikvm(   96): GC_EXPLICIT freed 12K, 11% free 1392K/1548K, paused 1ms+0ms, total 7ms
W/Zygote  (   96): Class not found for preloading: android.server.BluetoothA2dpService
W/Zygote  (   96): Class not found for preloading: android.server.BluetoothEventLoop
W/Zygote  (   96): Class not found for preloading: android.server.BluetoothService
D/TelephonyManager(   96): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline: open failed: EACCES (Permission denied)
D/TelephonyManager(   96): /proc/cmdline=
D/dalvikvm(   96): GC_EXPLICIT freed 29K, 10% free 1428K/1580K, paused 0ms+1ms, total 6ms
D/dalvikvm(   96): GC_EXPLICIT freed 24K, 2% free 1732K/1760K, paused 1ms+1ms, total 11ms
W/Zygote  (   96): Class not found for preloading: android.util.LocaleUtil
D/dalvikvm(   96): GC_EXPLICIT freed 35K, 3% free 1764K/1804K, paused 1ms+1ms, total 9ms
D/dalvikvm(   96): GC_EXPLICIT freed 31K, 2% free 1787K/1820K, paused 1ms+0ms, total 10ms
W/Zygote  (   96): Class not found for preloading: android.view.ViewRootImpl$ResizedInfo
W/Zygote  (   96): Class not found for preloading: android.view.Window$LocalWindowManager
W/Zygote  (   96): Class not found for preloading: android.view.WindowManagerImpl$CompatModeWrapper
D/dalvikvm(   96): GC_EXPLICIT freed 30K, 2% free 1811K/1844K, paused 1ms+1ms, total 10ms
I/dalvikvm(   96): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
D/dalvikvm(   96): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
D/dalvikvm(   96): GC_EXPLICIT freed 21K, 2% free 1843K/1868K, paused 1ms+1ms, total 10ms
D/dalvikvm(   96): GC_EXPLICIT freed 25K, 2% free 1871K/1900K, paused 1ms+1ms, total 10ms
D/dalvikvm(   96): GC_EXPLICIT freed 30K, 2% free 1902K/1936K, paused 1ms+1ms, total 11ms
D/dalvikvm(   96): GC_EXPLICIT freed 26K, 2% free 1929K/1960K, paused 1ms+1ms, total 10ms
D/dalvikvm(   96): GC_EXPLICIT freed 31K, 2% free 1952K/1988K, paused 1ms+0ms, total 13ms
D/dalvikvm(   96): GC_EXPLICIT freed 28K, 2% free 1979K/2012K, paused 1ms+1ms, total 12ms
D/dalvikvm(   96): GC_EXPLICIT freed 29K, 2% free 2005K/2036K, paused 1ms+1ms, total 10ms
D/dalvikvm(   96): GC_EXPLICIT freed 39K, 2% free 2022K/2064K, paused 1ms+1ms, total 11ms
W/Zygote  (   96): Class not found for preloading: java.text.DecimalFormat$1
D/dalvikvm(   96): GC_EXPLICIT freed 41K, 3% free 2036K/2080K, paused 1ms+1ms, total 12ms
W/Zygote  (   96): Class not found for preloading: java.util.concurrent.FutureTask$Sync
W/Zygote  (   96): Class not found for preloading: java.util.concurrent.atomic.UnsafeAccess
W/Zygote  (   96): Class not found for preloading: java.util.concurrent.locks.UnsafeAccess
D/dalvikvm(   96): GC_EXPLICIT freed 41K, 3% free 2050K/2096K, paused 2ms+1ms, total 13ms
W/Zygote  (   96): Class not found for preloading: libcore.icu.ErrorCode
I/System  (   96): Loaded time zone names for  in 130ms (128ms in ICU)
I/System  (   96): Loaded time zone names for en_US in 88ms (85ms in ICU)
D/dalvikvm(   96): GC_FOR_ALLOC freed 329K, 13% free 2233K/2564K, paused 15ms, total 15ms
I/System  (   96): Loaded time zone names for de_DE in 107ms (104ms in ICU)
D/dalvikvm(   96): GC_EXPLICIT freed 176K, 16% free 2173K/2564K, paused 1ms+1ms, total 13ms
D/dalvikvm(   96): GC_EXPLICIT freed 15K, 14% free 2235K/2572K, paused 1ms+2ms, total 12ms
D/dalvikvm(   96): GC_EXPLICIT freed 52K, 12% free 2267K/2572K, paused 1ms+1ms, total 15ms
D/dalvikvm(   96): GC_EXPLICIT freed 29K, 11% free 2293K/2572K, paused 1ms+1ms, total 12ms
D/dalvikvm(   96): GC_EXPLICIT freed 38K, 11% free 2309K/2572K, paused 1ms+1ms, total 13ms
D/dalvikvm(   96): GC_EXPLICIT freed 32K, 10% free 2332K/2572K, paused 2ms+2ms, total 17ms
I/Zygote  (   96): ...preloaded 2541 classes in 2180ms.
D/dalvikvm(   96): GC_EXPLICIT freed 23K, 10% free 2336K/2576K, paused 1ms+1ms, total 13ms
I/Zygote  (   96): Preload resources disabled, skipped.
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 10% free 2336K/2576K, paused 1ms+1ms, total 13ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 10% free 2336K/2576K, paused 1ms+1ms, total 15ms
I/dalvikvm(   96): System server process 419 has been created
I/Zygote  (   96): Accepting command socket connections
E/BatteryService(  419): usbOnlinePath not found
E/BatteryService(  419): wirelessOnlinePath not found
E/BatteryService(  419): batteryTemperaturePath not found
I/sysproc (  419): Entered system_init()
I/sysproc (  419): ServiceManager: 0x5ddf55d0
D/SensorService(  419): nuSensorService starting...
E/SensorsHal(  419): couldn't find 'lightsensor-level' input device
D/SensorsHal(  419): Couldn't open /dev/lightsensor (No such file or directory)
E/SensorsHal(  419): couldn't find 'proximity' input device
D/SensorsHal(  419): Couldn't open /dev/psensor (No such file or directory)
E/SensorsHal(  419): couldn't find 'compass' input device
D/SensorsHal(  419): Couldn't open /dev/akm8975_aot (No such file or directory)
E/SensorsHal(  419): couldn't find 'gyro' input device
D/SensorsHal(  419): Couldn't open /dev/gyrosensor (No such file or directory)
D/SensorsHal(  419): GyroSensor::GyroSensor():No such file or directory
I/SensorService(  419): MMA8452Q 3-axis Accelerometer
I/SensorService(  419): AK8975 3-axis Magnetic field sensor
I/SensorService(  419): AK8975 Orientation sensor
I/SensorService(  419): ST 3-axis Gyroscope sensor
I/SensorService(  419): AL3006Proximity sensor
I/SensorService(  419): AL3006 light sensor
I/sysproc (  419): System server: starting Android runtime.
I/sysproc (  419): System server: starting Android services.
D/SensorService(  419): nuSensorService thread starting...
I/sysproc (  419): System server: entering thread pool.
I/installd(   99): new connection
I/SystemServer(  419): Entered the Android system server!
I/SystemServer(  419): Waiting for installd to be ready.
I/SystemServer(  419): Enabled StrictMode logging for UI Looper
I/Installer(  419): connecting...
I/SystemServer(  419): Entropy Mixer
W/EntropyMixer(  419): No existing entropy file -- first boot?
I/SystemServer(  419): Enabled StrictMode logging for WM Looper
I/SystemServer(  419): Power Manager
I/SystemServer(  419): Activity Manager
I/ActivityManager(  419): Memory class: 48
I/SystemServer(  419): Display Manager
I/ActivityManager(  419): Enabled StrictMode logging for AThread's Looper
I/SystemServer(  419): Telephony Registry
I/SystemServer(  419): Scheduling Policy
I/DisplayManagerService(  419): Display device added: DisplayDeviceInfo{"Integrierter Bildschirm": 1024 x 768, 73.668 fps, density 160, 128.76039 x 128.33684 dpi, touch INTERNAL, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS, rotation 0, type BUILT_IN, address null}
I/SystemServer(  419): Package Manager
D/SELinuxMMAC(  419): Couldn't find install policy /data/security/mac_permissions.xml
D/SELinuxMMAC(  419): Couldn't find install policy /system/etc/security/mac_permissions.xml
D/SELinuxMMAC(  419): MMAC install disabled.
I/PackageManager(  419): No settings file; creating initial state
W/dalvikvm(  440): method Landroid/test/InstrumentationTestRunner$StringResultPrinter;.print incorrectly overrides package-private method with same name in Ljunit/textui/ResultPrinter;
D/dalvikvm(  440): DexOpt: load 8ms, verify+opt 39ms, 519900 bytes
D/dalvikvm(  441): DexOpt: load 2ms, verify+opt 0ms, 80348 bytes
D/dalvikvm(  442): DexOpt: load 4ms, verify+opt 12ms, 134756 bytes
D/dalvikvm(  443): DexOpt: load 2ms, verify+opt 2ms, 116780 bytes
D/dalvikvm(  444): DexOpt: load 4ms, verify+opt 17ms, 185100 bytes
D/dalvikvm(  445): DexOpt: load 16ms, verify+opt 78ms, 601308 bytes
D/dalvikvm(  446): DexOpt: load 3ms, verify+opt 2ms, 124180 bytes
D/dalvikvm(  447): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  447): DexOpt: load 3ms, verify+opt 3ms, 135452 bytes
D/dalvikvm(  448): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  448): DexOpt: load 3ms, verify+opt 13ms, 211564 bytes
D/dalvikvm(  449): DexOpt: load 2ms, verify+opt 4ms, 112820 bytes
D/dalvikvm(  450): DexOpt: load 2ms, verify+opt 2ms, 106980 bytes
D/dalvikvm(  451): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  451): DexOpt: load 5ms, verify+opt 30ms, 363284 bytes
D/dalvikvm(  452): DexOpt: load 2ms, verify+opt 3ms, 113196 bytes
D/dalvikvm(  453): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  453): DexOpt: load 3ms, verify+opt 16ms, 214316 bytes
D/dalvikvm(  454): DexOpt: load 2ms, verify+opt 2ms, 120692 bytes
D/dalvikvm(  455): DexOpt: load 7ms, verify+opt 6ms, 106468 bytes
D/dalvikvm(  456): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  456): DexOpt: load 3ms, verify+opt 44ms, 478860 bytes
D/dalvikvm(  457): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  457): DexOpt: load 2ms, verify+opt 4ms, 145380 bytes
D/dalvikvm(  458): DexOpt: load 3ms, verify+opt 3ms, 127148 bytes
I/PackageManager(  419): /system/framework/framework-res.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 3079K, 44% free 4382K/7696K, paused 2ms+1ms, total 22ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 6ms
D/dalvikvm(  419): GC_CONCURRENT freed 145K, 39% free 4748K/7696K, paused 1ms+2ms, total 23ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 8ms
D/dalvikvm(  419): GC_CONCURRENT freed 131K, 33% free 5218K/7696K, paused 1ms+1ms, total 25ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 10ms
D/dalvikvm(  419): GC_CONCURRENT freed 575K, 31% free 5362K/7696K, paused 2ms+2ms, total 27ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 7ms
D/dalvikvm(  419): GC_CONCURRENT freed 168K, 23% free 5949K/7696K, paused 2ms+2ms, total 31ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 15ms
I/PackageManager(  419): /system/app/NetworkLocation.apk changed; collecting certs
I/PackageManager(  419): New shared user com.google.uid.shared: id=10000
D/dalvikvm(  419): GC_CONCURRENT freed 855K, 23% free 5972K/7696K, paused 2ms+14ms, total 34ms
I/PackageManager(  419): /system/app/PhotoTable.apk changed; collecting certs
I/PackageManager(  419): /system/app/TelephonyProvider.apk changed; collecting certs
I/PackageManager(  419): /system/app/DownloadProvider.apk changed; collecting certs
I/PackageManager(  419): New shared user android.media: id=10002
I/PackageManager(  419): /system/app/ApplicationsProvider.apk changed; collecting certs
I/PackageManager(  419): New shared user android.uid.shared: id=10003
I/PackageManager(  419): /system/app/ccc71.st.cpu.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 3757K, 61% free 3066K/7696K, paused 2ms+7ms, total 50ms
I/PackageManager(  419): /system/app/com.thomassafca.theme.touchwiz.five.free.apk changed; collecting certs
W/PackageParser(  419): Unknown element under <manifest>: meta-data at /system/app/com.thomassafca.theme.touchwiz.five.free.apk Binary XML file line #8
D/dalvikvm(  419): GC_CONCURRENT freed 321K, 60% free 3129K/7696K, paused 3ms+1ms, total 15ms
D/dalvikvm(  419): GC_CONCURRENT freed 344K, 58% free 3269K/7696K, paused 2ms+1ms, total 19ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 218K, 55% free 3493K/7696K, paused 10ms, total 10ms
D/dalvikvm(  419): GC_CONCURRENT freed 312K, 54% free 3601K/7696K, paused 2ms+1ms, total 14ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 468K, 54% free 3615K/7696K, paused 14ms, total 14ms
D/dalvikvm(  419): GC_CONCURRENT freed 126K, 49% free 3931K/7696K, paused 1ms+1ms, total 12ms
D/dalvikvm(  419): GC_CONCURRENT freed 412K, 48% free 4023K/7696K, paused 1ms+2ms, total 19ms
D/dalvikvm(  419): GC_CONCURRENT freed 108K, 43% free 4427K/7696K, paused 1ms+2ms, total 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 117K, 38% free 4830K/7696K, paused 1ms+1ms, total 23ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 11ms
D/dalvikvm(  419): GC_CONCURRENT freed 470K, 36% free 4982K/7696K, paused 1ms+1ms, total 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 140K, 29% free 5502K/7696K, paused 2ms+1ms, total 29ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 5ms
I/PackageManager(  419): /system/app/com.google.android.ears.apk changed; collecting certs
I/PackageManager(  419): /system/app/Exchange2.apk changed; collecting certs
I/PackageManager(  419): /system/app/GoogleServicesFramework.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 844K, 30% free 5448K/7696K, paused 3ms+19ms, total 36ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 1ms
I/PackageManager(  419): /system/app/VisualizationWallpapers.apk changed; collecting certs
I/PackageManager(  419): /system/app/CMWallpapers.apk changed; collecting certs
I/PackageManager(  419): /system/app/ChromeBookmarksSyncAdapter.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 3010K, 59% free 3184K/7696K, paused 2ms+2ms, total 30ms
I/PackageManager(  419): /system/app/ThemeChooser.apk changed; collecting certs
I/PackageManager(  419): /system/app/Apollo.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 406K, 59% free 3187K/7696K, paused 2ms+5ms, total 26ms
I/PackageManager(  419): /system/app/VpnDialogs.apk changed; collecting certs
I/PackageManager(  419): /system/app/MediaUploader.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 483K, 59% free 3180K/7696K, paused 2ms+2ms, total 15ms
I/PackageManager(  419): /system/app/com.tmobile.theme.HTC.EleganceX.apk changed; collecting certs
W/PackageParser(  419): Unknown element under <manifest>: activity at /system/app/com.tmobile.theme.HTC.EleganceX.apk Binary XML file line #33
D/dalvikvm(  419): GC_CONCURRENT freed 400K, 58% free 3297K/7696K, paused 2ms+2ms, total 22ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 3ms
D/dalvikvm(  419): GC_CONCURRENT freed 186K, 53% free 3638K/7696K, paused 3ms+2ms, total 25ms
D/dalvikvm(  419): GC_CONCURRENT freed 130K, 49% free 3948K/7696K, paused 2ms+1ms, total 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 164K, 45% free 4296K/7696K, paused 1ms+2ms, total 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 148K, 40% free 4659K/7696K, paused 2ms+2ms, total 30ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 12ms
D/dalvikvm(  419): GC_CONCURRENT freed 367K, 37% free 4871K/7696K, paused 3ms+1ms, total 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 417K, 35% free 5061K/7696K, paused 2ms+1ms, total 31ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 26ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 188K, 34% free 5127K/7696K, paused 17ms, total 17ms
I/dalvikvm-heap(  419): Grow heap (frag case) to 6.231MB for 520614-byte allocation
D/dalvikvm(  419): GC_FOR_ALLOC freed 254K, 35% free 5381K/8208K, paused 20ms, total 20ms
I/dalvikvm-heap(  419): Grow heap (frag case) to 6.977MB for 1042884-byte allocation
D/dalvikvm(  419): GC_CONCURRENT freed 0K, 31% free 6400K/9228K, paused 2ms+1ms, total 23ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 16ms
I/dalvikvm-heap(  419): Grow heap (frag case) to 7.707MB for 764295-byte allocation
D/dalvikvm(  419): GC_CONCURRENT freed 1585K, 40% free 6062K/9976K, paused 2ms+1ms, total 21ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 444K, 39% free 6127K/9976K, paused 19ms, total 19ms
I/dalvikvm-heap(  419): Grow heap (frag case) to 7.708MB for 1044464-byte allocation
D/dalvikvm(  419): GC_CONCURRENT freed 0K, 36% free 7147K/11000K, paused 2ms+1ms, total 20ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 13ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 1645K, 41% free 6491K/11000K, paused 23ms, total 23ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 380K, 38% free 6874K/11000K, paused 18ms, total 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 0K, 29% free 7894K/11000K, paused 3ms+1ms, total 25ms
I/dalvikvm-heap(  419): Grow heap (frag case) to 9.166MB for 764253-byte allocation
D/dalvikvm(  419): GC_FOR_ALLOC freed 1634K, 37% free 7517K/11748K, paused 23ms, total 23ms
D/dalvikvm(  419): GC_CONCURRENT freed 265K, 28% free 8547K/11748K, paused 1ms+2ms, total 32ms
D/dalvikvm(  419): GC_CONCURRENT freed 320K, 17% free 9779K/11748K, paused 2ms+3ms, total 53ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 27ms
D/dalvikvm(  419): GC_CONCURRENT freed 336K, 6% free 11242K/11864K, paused 2ms+2ms, total 48ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 35ms
D/dalvikvm(  419): GC_CONCURRENT freed 1847K, 16% free 11445K/13528K, paused 1ms+2ms, total 48ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 32ms
D/dalvikvm(  419): GC_CONCURRENT freed 439K, 5% free 13054K/13728K, paused 1ms+2ms, total 56ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 40ms
D/dalvikvm(  419): GC_CONCURRENT freed 445K, 5% free 14659K/15340K, paused 2ms+2ms, total 66ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 43ms
I/PackageManager(  419): /system/app/hu.sztupy.android.usbhostcontroller.apk changed; collecting certs
I/PackageManager(  419): /system/app/GoogleCalendarSyncAdapter.apk changed; collecting certs
I/PackageManager(  419): New shared user com.google.android.calendar.uid.shared: id=10015
I/PackageManager(  419): /system/app/ThemeManager.apk changed; collecting certs
I/PackageManager(  419): /system/app/de.draisberghof.pppwidget.apk changed; collecting certs
I/PackageManager(  419): /system/app/CertInstaller.apk changed; collecting certs
I/PackageManager(  419): /system/app/GoogleLoginService.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 3008K, 20% free 13697K/16944K, paused 2ms+51ms, total 79ms
I/PackageManager(  419): /system/app/CellBroadcastReceiver.apk changed; collecting certs
I/PackageManager(  419): /system/app/GoogleFeedback.apk changed; collecting certs
I/PackageManager(  419): /system/app/PackageInstaller.apk changed; collecting certs
I/PackageManager(  419): /system/app/BackupRestoreConfirmation.apk changed; collecting certs
I/PackageManager(  419): /system/app/Galaxy4.apk changed; collecting certs
I/PackageManager(  419): /system/app/com.teslacoilsw.launcher.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 11786K, 77% free 3940K/16944K, paused 2ms+4ms, total 53ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 50ms
D/dalvikvm(  419): GC_CONCURRENT freed 742K, 79% free 3599K/16944K, paused 2ms+2ms, total 23ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 20ms
D/dalvikvm(  419): GC_CONCURRENT freed 278K, 78% free 3828K/16944K, paused 1ms+2ms, total 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 106K, 76% free 4221K/16944K, paused 2ms+2ms, total 19ms
D/dalvikvm(  419): GC_CONCURRENT freed 314K, 74% free 4418K/16944K, paused 2ms+1ms, total 31ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 9ms
I/PackageManager(  419): /system/app/ConfigUpdater.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 197K, 73% free 4737K/16944K, paused 2ms+3ms, total 27ms
I/PackageManager(  419): /system/app/Email2.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 498K, 72% free 4832K/16944K, paused 2ms+9ms, total 24ms
I/PackageManager(  419): /system/app/KeyChain.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 1843K, 80% free 3516K/16944K, paused 2ms+4ms, total 25ms
I/PackageManager(  419): /system/app/jackpal.androidterm.apk changed; collecting certs
I/PackageManager(  419): /system/app/MediaProvider.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 728K, 81% free 3289K/16944K, paused 1ms+3ms, total 20ms
I/PackageManager(  419): /system/app/Browser.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 413K, 81% free 3385K/16944K, paused 1ms+3ms, total 18ms
I/PackageManager(  419): /system/app/DownloadProviderUi.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 361K, 80% free 3508K/16944K, paused 1ms+5ms, total 20ms
I/PackageManager(  419): /system/app/com.mxtech.videoplayer.ad.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 553K, 80% free 3456K/16944K, paused 2ms+1ms, total 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 223K, 78% free 3745K/16944K, paused 2ms+2ms, total 20ms
I/PackageManager(  419): New shared user com.mxtech: id=10028
W/PackageManager(  419): Package com.mxtech.videoplayer.ad desires unavailable shared library com.sec.android.app.multiwindow; ignoring!
I/PackageManager(  419): /system/app/Calendar.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 319K, 77% free 3925K/16944K, paused 2ms+4ms, total 21ms
I/PackageManager(  419): /system/app/OneTimeInitializer.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 744K, 79% free 3636K/16944K, paused 2ms+2ms, total 26ms
I/PackageManager(  419): /system/app/Calculator.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 311K, 78% free 3813K/16944K, paused 3ms+4ms, total 22ms
I/PackageManager(  419): /system/app/DeskClock.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 608K, 79% free 3716K/16944K, paused 1ms+3ms, total 19ms
D/dalvikvm(  419): GC_CONCURRENT freed 394K, 78% free 3759K/16944K, paused 1ms+1ms, total 27ms
I/PackageManager(  419): /system/app/LatinImeDictionaryPack.apk changed; collecting certs
I/PackageManager(  419): /system/app/LiveWallpapersPicker.apk changed; collecting certs
I/PackageManager(  419): /system/app/org.riceknight.gs2reboot.apk changed; collecting certs
I/PackageManager(  419): /system/app/CalendarProvider.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 385K, 78% free 3884K/16944K, paused 1ms+4ms, total 25ms
I/PackageManager(  419): New shared user android.uid.calendar: id=10036
I/PackageManager(  419): /system/app/org.adaway.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 697K, 79% free 3699K/16944K, paused 2ms+2ms, total 24ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 17ms
D/dalvikvm(  419): GC_CONCURRENT freed 416K, 78% free 3795K/16944K, paused 1ms+3ms, total 19ms
D/dalvikvm(  419): GC_CONCURRENT freed 220K, 77% free 4041K/16944K, paused 1ms+3ms, total 19ms
I/PackageManager(  419): /system/app/NoiseField.apk changed; collecting certs
I/PackageManager(  419): /system/app/GooglePartnerSetup.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 318K, 76% free 4235K/16944K, paused 1ms+6ms, total 26ms
I/PackageManager(  419): /system/app/PicoTts.apk changed; collecting certs
I/PackageManager(  419): /system/app/Trebuchet.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 1132K, 79% free 3594K/16944K, paused 2ms+4ms, total 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 334K, 78% free 3772K/16944K, paused 2ms+2ms, total 21ms
I/PackageManager(  419): /system/app/com.google.android.gm.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 228K, 77% free 4056K/16944K, paused 1ms+7ms, total 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 604K, 77% free 3953K/16944K, paused 3ms+2ms, total 23ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 19ms
D/dalvikvm(  419): GC_CONCURRENT freed 382K, 77% free 3967K/16944K, paused 2ms+1ms, total 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 274K, 76% free 4174K/16944K, paused 2ms+3ms, total 27ms
D/dalvikvm(  419): GC_CONCURRENT freed 111K, 73% free 4575K/16944K, paused 1ms+2ms, total 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 319K, 72% free 4815K/16944K, paused 2ms+2ms, total 27ms
I/PackageManager(  419): /system/app/VoicePlus.apk changed; collecting certs
I/PackageManager(  419): /system/app/GoogleTTS.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 506K, 71% free 4925K/16944K, paused 1ms+9ms, total 25ms
I/PackageManager(  419): /system/app/Phone.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 1780K, 78% free 3790K/16944K, paused 2ms+2ms, total 24ms
I/PackageManager(  419): /system/app/com.zdvdev.sef.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 301K, 77% free 4001K/16944K, paused 1ms+2ms, total 19ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 18ms
D/dalvikvm(  419): GC_CONCURRENT freed 604K, 77% free 3908K/16944K, paused 1ms+3ms, total 33ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 14ms
D/dalvikvm(  419): GC_CONCURRENT freed 211K, 76% free 4208K/16944K, paused 2ms+2ms, total 28ms
I/PackageManager(  419): /system/app/FusedLocation.apk changed; collecting certs
I/PackageManager(  419): /system/app/DefaultContainerService.apk changed; collecting certs
I/PackageManager(  419): /system/app/HTMLViewer.apk changed; collecting certs
I/PackageManager(  419): /system/app/VoiceSearchStub.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 492K, 76% free 4228K/16944K, paused 1ms+7ms, total 30ms
I/PackageManager(  419): /system/app/com.rhmsoft.fm.hd.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 859K, 78% free 3829K/16944K, paused 2ms+1ms, total 21ms
D/dalvikvm(  419): GC_CONCURRENT freed 316K, 77% free 4022K/16944K, paused 2ms+2ms, total 21ms
D/dalvikvm(  419): GC_CONCURRENT freed 335K, 76% free 4198K/16944K, paused 2ms+4ms, total 25ms
D/dalvikvm(  419): GC_CONCURRENT freed 237K, 74% free 4467K/16944K, paused 11ms+2ms, total 35ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 283K, 73% free 4715K/16944K, paused 1ms+3ms, total 29ms
W/PackageManager(  419): Package com.rhmsoft.fm.hd desires unavailable shared library com.sec.android.app.multiwindow; ignoring!
I/PackageManager(  419): /system/app/LatinIME.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 414K, 72% free 4875K/16944K, paused 1ms+11ms, total 29ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 23ms
D/dalvikvm(  419): GC_CONCURRENT freed 1449K, 77% free 4059K/16944K, paused 3ms+3ms, total 29ms
D/dalvikvm(  419): GC_CONCURRENT freed 173K, 75% free 4346K/16944K, paused 1ms+2ms, total 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 248K, 73% free 4610K/16944K, paused 2ms+2ms, total 28ms
I/PackageManager(  419): /system/app/Contacts.apk changed; collecting certs
W/PackageParser(  419): No actions in intent filter at /system/app/Contacts.apk Binary XML file line #546
D/dalvikvm(  419): GC_CONCURRENT freed 434K, 73% free 4725K/16944K, paused 2ms+7ms, total 30ms
D/dalvikvm(  419): GC_CONCURRENT freed 1219K, 76% free 4101K/16944K, paused 2ms+3ms, total 30ms
I/PackageManager(  419): /system/app/SharedStorageBackup.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 274K, 75% free 4337K/16944K, paused 2ms+3ms, total 32ms
I/PackageManager(  419): /system/app/Bluetooth.apk changed; collecting certs
W/PackageParser(  419): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #208
W/PackageParser(  419): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #235
I/PackageManager(  419): /system/app/Settings.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 335K, 74% free 4514K/16944K, paused 2ms+7ms, total 32ms
D/dalvikvm(  419): GC_CONCURRENT freed 933K, 76% free 4082K/16944K, paused 2ms+1ms, total 23ms
D/dalvikvm(  419): GC_CONCURRENT freed 246K, 75% free 4239K/16944K, paused 2ms+2ms, total 23ms
D/dalvikvm(  419): GC_CONCURRENT freed 305K, 75% free 4395K/16944K, paused 2ms+1ms, total 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 280K, 73% free 4628K/16944K, paused 1ms+3ms, total 29ms
D/dalvikvm(  419): GC_CONCURRENT freed 206K, 72% free 4903K/16944K, paused 1ms+1ms, total 25ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 21ms
D/dalvikvm(  419): GC_CONCURRENT freed 244K, 69% free 5300K/16944K, paused 1ms+2ms, total 27ms
W/PackageParser(  419): Unknown element under <application>: library at /system/app/com.google.android.gms.apk Binary XML file line #155
I/PackageManager(  419): /system/app/com.google.android.gms.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 442K, 67% free 5599K/16944K, paused 2ms+9ms, total 30ms
D/dalvikvm(  419): GC_CONCURRENT freed 2066K, 75% free 4335K/16944K, paused 2ms+2ms, total 30ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 24ms
D/dalvikvm(  419): GC_CONCURRENT freed 308K, 74% free 4539K/16944K, paused 1ms+6ms, total 33ms
D/dalvikvm(  419): GC_CONCURRENT freed 122K, 71% free 4958K/16944K, paused 2ms+2ms, total 32ms
D/dalvikvm(  419): GC_CONCURRENT freed 320K, 69% free 5292K/16944K, paused 3ms+2ms, total 40ms
I/PackageManager(  419): /system/app/MagicSmokeWallpapers.apk changed; collecting certs
I/PackageManager(  419): /system/app/HoloSpiralWallpaper.apk changed; collecting certs
I/PackageManager(  419): /system/app/WAPPushManager.apk changed; collecting certs
I/PackageManager(  419): /system/app/InputDevices.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 683K, 69% free 5346K/16944K, paused 2ms+10ms, total 36ms
I/PackageManager(  419): /system/app/com.google.android.googlequicksearchbox.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 1569K, 74% free 4528K/16944K, paused 1ms+2ms, total 33ms
D/dalvikvm(  419): GC_CONCURRENT freed 391K, 73% free 4683K/16944K, paused 2ms+3ms, total 28ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 258K, 71% free 4939K/16944K, paused 22ms, total 22ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 374K, 71% free 5052K/16944K, paused 22ms, total 22ms
D/dalvikvm(  419): GC_CONCURRENT freed 419K, 70% free 5241K/16944K, paused 2ms+1ms, total 27ms
D/dalvikvm(  419): GC_CONCURRENT freed 496K, 68% free 5471K/16944K, paused 2ms+3ms, total 36ms
D/dalvikvm(  419): GC_CONCURRENT freed 168K, 65% free 6085K/16944K, paused 3ms+2ms, total 37ms
D/dalvikvm(  419): GC_CONCURRENT freed 199K, 60% free 6822K/16944K, paused 1ms+2ms, total 37ms
D/dalvikvm(  419): GC_CONCURRENT freed 701K, 58% free 7242K/16944K, paused 1ms+2ms, total 39ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 25ms
D/dalvikvm(  419): GC_CONCURRENT freed 277K, 52% free 8191K/16944K, paused 1ms+2ms, total 43ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 28ms
I/PackageManager(  419): /system/app/GoogleContactsSyncAdapter.apk changed; collecting certs
W/ResourceType(  419): Failure getting entry for 0x7f040018 (t=3 e=24) in package 0 (error -75)
I/PackageManager(  419): /system/app/Gallery2.apk changed; collecting certs
W/PackageParser(  419): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #220
W/PackageParser(  419): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #223
D/dalvikvm(  419): GC_CONCURRENT freed 1330K, 51% free 8324K/16944K, paused 1ms+20ms, total 48ms
I/PackageManager(  419): /system/app/com.android.vending.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 4318K, 68% free 5497K/16944K, paused 2ms+7ms, total 46ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 42ms
D/dalvikvm(  419): GC_CONCURRENT freed 1341K, 71% free 4945K/16944K, paused 2ms+4ms, total 43ms
D/dalvikvm(  419): GC_CONCURRENT freed 263K, 69% free 5332K/16944K, paused 2ms+4ms, total 31ms
D/dalvikvm(  419): GC_CONCURRENT freed 387K, 67% free 5692K/16944K, paused 3ms+2ms, total 47ms
W/PackageParser(  419): /system/app/com.nikhilb.lcm11.apk (at Binary XML file line #10): Requires newer sdk version #19 (current version is #17)
I/PackageManager(  419): /system/app/FaceLock.apk changed; collecting certs
I/PackageManager(  419): /system/app/CMUpdater.apk changed; collecting certs
I/PackageManager(  419): /system/app/PhaseBeam.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 600K, 66% free 5930K/16944K, paused 3ms+17ms, total 49ms
I/PackageManager(  419): /system/app/LiveWallpapers.apk changed; collecting certs
I/PackageManager(  419): /system/app/ContactsProvider.apk changed; collecting certs
I/PackageManager(  419): /system/app/DrmProvider.apk changed; collecting certs
I/PackageManager(  419): /system/app/BasicDreams.apk changed; collecting certs
I/PackageManager(  419): /system/app/SystemUI.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 2290K, 74% free 4537K/16944K, paused 11ms+4ms, total 43ms
D/dalvikvm(  419): GC_CONCURRENT freed 411K, 73% free 4652K/16944K, paused 2ms+2ms, total 30ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 548K, 73% free 4629K/16944K, paused 21ms, total 21ms
D/dalvikvm(  419): GC_CONCURRENT freed 234K, 71% free 4967K/16944K, paused 1ms+3ms, total 27ms
D/dalvikvm(  419): GC_CONCURRENT freed 299K, 69% free 5325K/16944K, paused 1ms+3ms, total 31ms
I/PackageManager(  419): /system/app/LockClock.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 502K, 68% free 5568K/16944K, paused 2ms+8ms, total 34ms
I/PackageManager(  419): /system/app/com.vipercn.viper4android4x.apk changed; collecting certs
I/PackageManager(  419): /system/app/Development.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 1535K, 72% free 4839K/16944K, paused 2ms+4ms, total 40ms
I/PackageManager(  419): /system/app/GoogleBackupTransport.apk changed; collecting certs
I/PackageManager(  419): /system/app/UserDictionaryProvider.apk changed; collecting certs
I/PackageManager(  419): /system/app/TalkBack.apk changed; collecting certs
I/PackageManager(  419): New shared user com.google.android.marvin.feedback: id=10068
I/PackageManager(  419): /system/app/Provision.apk changed; collecting certs
D/dalvikvm(  419): GC_CONCURRENT freed 976K, 74% free 4484K/16944K, paused 2ms+3ms, total 31ms
I/PackageManager(  419): /system/app/SettingsProvider.apk changed; collecting certs
D/PackageManager(  419): No files in app dir /vendor/app
I/PackageManager(  419): Time to scan packages: 12.477 seconds
W/PackageManager(  419): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager(  419): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
W/PackageManager(  419): Unknown permission com.android.chrome.TOS_ACKED in package com.google.android.gsf.login
W/PackageManager(  419): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager(  419): Unknown permission android.permission.MMS_PUSH in package com.android.bluetooth
W/PackageManager(  419): Not granting permission android.permission.INTERACT_ACROSS_USERS_FULL to package de.draisberghof.pppwidget (protectionLevel=2 flags=0x8be45)
W/PackageManager(  419): Unknown permission com.htc.launcher.permission.READ_SETTINGS in package com.teslacoilsw.launcher
W/PackageManager(  419): Unknown permission com.cyanogenmod.trebuchet.permission.READ_SETTINGS in package com.teslacoilsw.launcher
W/PackageManager(  419): Unknown permission org.adw.launcher.permission.READ_SETTINGS in package com.teslacoilsw.launcher
W/PackageManager(  419): Unknown permission org.adwfreak.launcher.permission.READ_SETTINGS in package com.teslacoilsw.launcher
W/PackageManager(  419): Unknown permission com.anddoes.launcher.permission.READ_SETTINGS in package com.teslacoilsw.launcher
W/PackageManager(  419): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager(  419): Unknown permission android.permission.LOCATION_HARDWARE in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.GET_APP_OPS_STATS in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.UPDATE_APP_OPS_STATS in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.ACCESS_NETWORK_CONDITIONS in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.MANAGE_DEVICE_ADMINS in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.BLUETOOTH_PRIVILEGED in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.CAPTURE_AUDIO_OUTPUT in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.CAPTURE_VIDEO_OUTPUT in package com.google.android.gms
W/PackageManager(  419): Unknown permission android.permission.CAPTURE_SECURE_VIDEO_OUTPUT in package com.google.android.gms
W/PackageManager(  419): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
W/PackageManager(  419): Unknown permission com.google.android.voicesearch.SHORTCUTS_ACCESS in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Unknown permission com.google.googlenav.friend.permission.OPT_IN in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Unknown permission com.google.android.apps.maps.permission.PREFETCH in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Unknown permission com.android.chrome.PRERENDER_URL in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Unknown permission android.permission.CAPTURE_AUDIO_HOTWORD in package com.google.android.googlequicksearchbox
W/PackageManager(  419): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0xabe45)
W/PackageManager(  419): Unknown permission android.permission.ACCESS_4G_RADIO_DISABLE in package com.android.systemui
W/PackageManager(  419): Unknown permission android.permission.ACCESS_4G_STATE in package com.android.systemui
W/PackageManager(  419): Unknown permission android.permission.CHANGE_4G_STATE in package com.android.systemui
W/PackageManager(  419): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.exchange
W/PackageManager(  419): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.email
W/PackageManager(  419): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
W/PackageManager(  419): Unknown permission com.android.deskclock.worldclock.permissions.WRITE_DATABASE in package com.android.deskclock
W/PackageManager(  419): Not granting permission android.permission.READ_DREAM_STATE to package com.google.android.gsf (protectionLevel=2 flags=0x83e45)
V/PackageManager(  419): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateActivity
V/PackageManager(  419): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService
V/PackageManager(  419): Disabling com.google.android.gsf/com.google.android.gsf.update.SystemUpdateService$Receiver
D/dalvikvm(  419): GC_CONCURRENT freed 543K, 74% free 4476K/16944K, paused 2ms+2ms, total 39ms
D/dalvikvm(  419): GC_EXPLICIT freed 299K, 75% free 4288K/16944K, paused 1ms+2ms, total 33ms
D/dalvikvm(  419): DexOpt: --- BEGIN 'SettingsProvider.apk' (bootstrap=0) ---
I/SystemServer(  419): User Service
I/SystemServer(  419): Account Manager
I/SystemServer(  419): Content Manager
I/SystemServer(  419): System Content Providers
D/dalvikvm(  462): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  462): DexOpt: load 5ms, verify+opt 49ms, 543380 bytes
D/dalvikvm(  419): DexOpt: --- END 'SettingsProvider.apk' (success) ---
D/dalvikvm(  419): DEX prep '/system/app/SettingsProvider.apk': unzip in 1ms, rewrite 80ms
E/SQLiteLog(  419): (1) no such table: secure
I/SyncManager(  419): No initial accounts
I/SyncManager(  419): No initial status
I/SyncManager(  419): No initial pending operations
I/SyncManager(  419): No initial statistics
D/SettingsProvider(  419): Generated and saved new ANDROID_ID [d5753ca4e761b611] for user 0
I/DeviceHandlerService(  419): No device specific handler lib was defined.
I/Lights  (  419): >>> Enter light_device_open:backlight
I/Lights  (  419): >>> Enter light_device_open:keyboard
I/Lights  (  419): >>> Enter light_device_open:buttons
I/Lights  (  419): >>> Enter light_device_open:battery
I/Lights  (  419): >>> Enter light_device_open:notifications
I/Lights  (  419): >>> Enter light_device_open:attention
I/Lights  (  419): >>> Enter light_device_open:bluetooth
I/Lights  (  419): >>> undefine light id
I/Lights  (  419): >>> Enter light_device_open:wifi
I/Lights  (  419): >>> Enter light_device_open:caps
I/Lights  (  419): >>> Enter light_device_open:func
I/SystemServer(  419): Device Handler Service
I/SystemServer(  419): Lights Service
I/SystemServer(  419): Battery Service
E/Lights  (  419): write_int failed to open sys/class/leds/battery_led/brightness
I/libsuspend(  419): Selected early suspend
I/libsuspend(  419): Starting early suspend unblocker thread
D/PermissionCache(   95): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (559 us)
D/SurfaceFlinger(   95):  screen was previously acquired
D/AlarmManagerService(  419): Kernel timezone updated to -60 minutes west of GMT
I/SystemServer(  419): Vibrator Service
I/SystemServer(  419): Alarm Manager
I/SystemServer(  419): Init Watchdog
I/SystemServer(  419): Input Manager
I/InputManager(  419): Initializing input manager, mUseDevInputEventForAudioJack=true
I/SystemServer(  419): Window Manager
D/dalvikvm(  419): GC_CONCURRENT freed 214K, 73% free 4585K/16944K, paused 2ms+3ms, total 43ms
I/AwesomePlayer(   98): AwesomePlayer::AwesomePlayer()in
I/        (   98): new RKOMXPlugin
I/AwesomePlayer(   98): AwesomePlayer::AwesomePlayer()aftermClient.connect()
I/InputManager(  419): Starting input manager
I/SystemServer(  419): Bluetooth Manager Service
W/Trace   (   98): error opening trace file: No such file or directory (2)
D/EventHub(  419): No input device configuration file found for device 'ft5x0x_touch'.
I/EventHub(  419): New device: id=1, fd=98, path='/dev/input/event1', name='ft5x0x_touch', classes=0x14, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=false, usingClockIoctl=false
D/EventHub(  419): No input device configuration file found for device 'rk29-keypad'.
D/BluetoothManagerService(  419): Loading stored name and address
D/BluetoothManagerService(  419): Stored bluetooth Name=null,Address=null
I/SystemServer(  419): Input Method Service
I/EventHub(  419): New device: id=2, fd=99, path='/dev/input/event0', name='rk29-keypad', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/rk29-keypad.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=true, usingSuspendBlockIoctl=false, usingClockIoctl=false
D/EventHub(  419): No input device configuration file found for device 'gsensor'.
D/FrameQueueManage(   98): FrameQueueManage::Displayframe stoped
I/FrameQueueManage(   98): FrameQueueManage::~FrameQueueManage end!
I/InputReader(  419): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader(  419): Device added: id=0, name='rk29-keypad', sources=0x00000101
I/InputReader(  419):   Touch device 'ft5x0x_touch' could not query the properties of its associated display.  The device will be inoperable until the display size becomes available.
I/InputReader(  419): Device added: id=1, name='ft5x0x_touch', sources=0x00001002
W/Trace   (  419): error opening trace file: No such file or directory (2)
W/InputMethodManagerService(  419): No IME selected. Choose the most applicable IME.
I/InputMethodManagerService(  419): No default found, using com.android.inputmethod.latin/.LatinIME
I/InputReader(  419): Reconfiguring input devices.  changes=0x00000004
I/InputReader(  419): Device reconfigured: id=1, name='ft5x0x_touch', size 1024x768, orientation 0, mode 1, display id 0
I/SystemServer(  419): Accessibility Manager
I/ActivityManager(  419): Config changes=1df8 {1.0 ?mcc?mnc de_DE ldltr sw721dp w1024dp h695dp 160dpi xlrg land ?uimode ?night finger -keyb/h/h -nav/h s.2 themeResource=null}
I/PackageManager(  419): Running dexopt on: com.google.android.location
D/dalvikvm(  491): DexOpt: load 15ms, verify+opt 133ms, 752540 bytes
I/PackageManager(  419): Running dexopt on: com.android.dreams.phototable
D/dalvikvm(  493): DexOpt: load 20ms, verify+opt 20ms, 403964 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.telephony
D/dalvikvm(  494): DexOpt: load 4ms, verify+opt 29ms, 262548 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.downloads
D/dalvikvm(  495): DexOpt: load 10ms, verify+opt 58ms, 515492 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.applications
I/InputDispatcher(  419): Dropped event because input dispatch is disabled.
D/dalvikvm(  496): DexOpt: load 5ms, verify+opt 31ms, 356708 bytes
I/PackageManager(  419): Running dexopt on: ccc71.st.cpu
D/dalvikvm(  419): GC_CONCURRENT freed 451K, 74% free 4570K/16944K, paused 4ms+2ms, total 35ms
D/dalvikvm(  497): DexOpt: load 48ms, verify+opt 246ms, 978100 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.ears
D/dalvikvm(  498): DexOpt: load 24ms, verify+opt 139ms, 970564 bytes
I/PackageManager(  419): Running dexopt on: com.android.exchange
D/dalvikvm(  499): DexOpt: load 56ms, verify+opt 362ms, 1711484 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.gsf
D/dalvikvm(  500): DexOpt: load 32ms, verify+opt 316ms, 1394996 bytes
I/PackageManager(  419): Running dexopt on: com.android.musicvis
D/dalvikvm(  501): DexOpt: load 6ms, verify+opt 8ms, 188284 bytes
I/PackageManager(  419): Running dexopt on: com.cyanogenmod.CMWallpapers
D/dalvikvm(  502): DexOpt: load 4ms, verify+opt 18ms, 276900 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.syncadapters.bookmarks
D/dalvikvm(  503): DexOpt: load 11ms, verify+opt 91ms, 539340 bytes
I/PackageManager(  419): Running dexopt on: com.tmobile.themechooser
D/dalvikvm(  504): DexOpt: load 10ms, verify+opt 18ms, 361516 bytes
I/PackageManager(  419): Running dexopt on: com.andrew.apollo
D/dalvikvm(  505): DexOpt: load 48ms, verify+opt 145ms, 1119548 bytes
I/PackageManager(  419): Running dexopt on: com.android.vpndialogs
D/dalvikvm(  506): DexOpt: load 5ms, verify+opt 17ms, 278348 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.apps.uploader
D/dalvikvm(  507): DexOpt: load 18ms, verify+opt 122ms, 898084 bytes
I/PackageManager(  419): Running dexopt on: com.tmobile.theme.HTC.EleganceX
D/dalvikvm(  508): DexOpt: load 6ms, verify+opt 0ms, 113740 bytes
I/PackageManager(  419): Running dexopt on: hu.sztupy.android.usbhostcontroller
D/dalvikvm(  509): DexOpt: load 18ms, verify+opt 57ms, 631020 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.syncadapters.calendar
D/dalvikvm(  510): DexOpt: load 8ms, verify+opt 65ms, 402964 bytes
I/PackageManager(  419): Running dexopt on: com.tmobile.thememanager
D/dalvikvm(  511): DexOpt: load 3ms, verify+opt 12ms, 252412 bytes
I/PackageManager(  419): Running dexopt on: de.draisberghof.pppwidget
D/dalvikvm(  512): DexOpt: load 6ms, verify+opt 34ms, 378708 bytes
I/PackageManager(  419): Running dexopt on: com.android.certinstaller
D/dalvikvm(  513): DexOpt: load 6ms, verify+opt 24ms, 359324 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.gsf.login
D/dalvikvm(  514): DexOpt: load 31ms, verify+opt 134ms, 1022540 bytes
I/PackageManager(  419): Running dexopt on: com.android.cellbroadcastreceiver
D/dalvikvm(  515): DexOpt: load 12ms, verify+opt 34ms, 532100 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.feedback
D/dalvikvm(  516): DexOpt: load 10ms, verify+opt 81ms, 739460 bytes
I/PackageManager(  419): Running dexopt on: com.android.packageinstaller
D/dalvikvm(  517): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  517): DexOpt: load 14ms, verify+opt 41ms, 530884 bytes
I/PackageManager(  419): Running dexopt on: com.android.backupconfirm
D/dalvikvm(  518): DexOpt: load 5ms, verify+opt 11ms, 226036 bytes
I/PackageManager(  419): Running dexopt on: com.android.galaxy4
D/dalvikvm(  519): DexOpt: load 8ms, verify+opt 5ms, 241708 bytes
I/PackageManager(  419): Running dexopt on: com.teslacoilsw.launcher
D/dalvikvm(  520): DexOpt: 'Landroid/view/RemotableViewMethod;' has an earlier definition; blocking out
D/dalvikvm(  520): DexOpt: not verifying/optimizing 'Landroid/view/RemotableViewMethod;': multiple definitions
W/dalvikvm(  520): DexOpt: pure-abstract method 'equals' in Lo/instance;
D/dalvikvm(  520): DexOpt: load 135ms, verify+opt 641ms, 2453444 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.configupdater
D/dalvikvm(  521): DexOpt: load 57ms, verify+opt 361ms, 1897508 bytes
I/PackageManager(  419): Running dexopt on: com.android.email
D/dalvikvm(  522): DexOpt: load 101ms, verify+opt 469ms, 2356716 bytes
I/PackageManager(  419): Running dexopt on: com.android.keychain
D/dalvikvm(  523): DexOpt: load 6ms, verify+opt 29ms, 380196 bytes
I/PackageManager(  419): Running dexopt on: jackpal.androidterm
D/dalvikvm(  524): DexOpt: 'Landroid/annotation/SuppressLint;' has an earlier definition; blocking out
D/dalvikvm(  524): DexOpt: 'Landroid/annotation/TargetApi;' has an earlier definition; blocking out
D/dalvikvm(  524): DexOpt: not verifying/optimizing 'Landroid/annotation/SuppressLint;': multiple definitions
D/dalvikvm(  524): DexOpt: not verifying/optimizing 'Landroid/annotation/TargetApi;': multiple definitions
D/dalvikvm(  524): DexOpt: load 20ms, verify+opt 53ms, 612764 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.media
D/dalvikvm(  525): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  525): DexOpt: load 6ms, verify+opt 57ms, 506804 bytes
I/PackageManager(  419): Running dexopt on: com.android.browser
D/dalvikvm(  526): DexOpt: load 77ms, verify+opt 207ms, 1564508 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.downloads.ui
D/dalvikvm(  527): DexOpt: load 11ms, verify+opt 31ms, 429820 bytes
I/PackageManager(  419): Running dexopt on: com.mxtech.videoplayer.ad
D/dalvikvm(  528): DexOpt: 'Landroid/media/MediaMetadataRetriever;' has an earlier definition; blocking out
D/dalvikvm(  528): DexOpt: 'Landroid/media/ThumbnailUtils;' has an earlier definition; blocking out
D/dalvikvm(  528): DexOpt: 'Lorg/ccil/cowan/tagsoup/HTMLSchema;' has an earlier definition; blocking out
D/dalvikvm(  528): DexOpt: 'Lorg/ccil/cowan/tagsoup/Parser;' has an earlier definition; blocking out
D/dalvikvm(  528): DexOpt: not verifying/optimizing 'Landroid/media/MediaMetadataRetriever;': multiple definitions
D/dalvikvm(  528): DexOpt: not verifying/optimizing 'Landroid/media/ThumbnailUtils;': multiple definitions
I/dalvikvm(  528): DexOpt: not resolving ambiguous class 'Landroid/media/MediaMetadataRetriever;'
I/dalvikvm(  528): DexOpt: not resolving ambiguous class 'Landroid/media/ThumbnailUtils;'
I/dalvikvm(  528): DexOpt: not resolving ambiguous class 'Lorg/ccil/cowan/tagsoup/Parser;'
I/dalvikvm(  528): DexOpt: not resolving ambiguous class 'Lorg/ccil/cowan/tagsoup/HTMLSchema;'
D/dalvikvm(  528): DexOpt: not verifying/optimizing 'Lorg/ccil/cowan/tagsoup/HTMLSchema;': multiple definitions
D/dalvikvm(  528): DexOpt: not verifying/optimizing 'Lorg/ccil/cowan/tagsoup/Parser;': multiple definitions
D/dalvikvm(  528): DexOpt: load 71ms, verify+opt 453ms, 1649708 bytes
I/PackageManager(  419): Running dexopt on: com.android.calendar
D/dalvikvm(  529): DexOpt: load 48ms, verify+opt 188ms, 1136596 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.onetimeinitializer
D/dalvikvm(  530): DexOpt: load 3ms, verify+opt 3ms, 156500 bytes
I/PackageManager(  419): Running dexopt on: com.android.calculator2
D/dalvikvm(  531): DexOpt: load 43ms, verify+opt 112ms, 885772 bytes
I/PackageManager(  419): Running dexopt on: com.android.deskclock
D/dalvikvm(  532): DexOpt: load 44ms, verify+opt 116ms, 1020028 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.inputmethod.latin.dictionarypack
D/dalvikvm(  533): DexOpt: load 18ms, verify+opt 49ms, 626300 bytes
I/PackageManager(  419): Running dexopt on: com.android.wallpaper.livepicker
D/dalvikvm(  534): DexOpt: load 5ms, verify+opt 26ms, 356524 bytes
I/PackageManager(  419): Running dexopt on: org.riceknight.gs2reboot
D/dalvikvm(  535): DexOpt: load 4ms, verify+opt 2ms, 169212 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.calendar
D/dalvikvm(  536): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  536): DexOpt: load 10ms, verify+opt 91ms, 609948 bytes
I/PackageManager(  419): Running dexopt on: org.adaway
W/dalvikvm(  537): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawDividersHorizontal incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
W/dalvikvm(  537): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawDividersVertical incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
W/dalvikvm(  537): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawHorizontalDivider incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
W/dalvikvm(  537): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawVerticalDivider incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
D/dalvikvm(  537): DexOpt: load 71ms, verify+opt 251ms, 1526964 bytes
I/PackageManager(  419): Running dexopt on: com.android.noisefield
D/dalvikvm(  538): DexOpt: load 6ms, verify+opt 5ms, 261316 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.partnersetup
D/dalvikvm(  539): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  539): DexOpt: load 10ms, verify+opt 71ms, 666412 bytes
I/PackageManager(  419): Running dexopt on: com.svox.pico
D/dalvikvm(  540): DexOpt: load 6ms, verify+opt 5ms, 219636 bytes
I/PackageManager(  419): Running dexopt on: com.cyanogenmod.trebuchet
D/dalvikvm(  541): DexOpt: load 77ms, verify+opt 194ms, 1109724 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.gm
D/dalvikvm(  542): DexOpt: load 125ms, verify+opt 885ms, 2764108 bytes
I/PackageManager(  419): Running dexopt on: org.cyanogenmod.voiceplus
D/dalvikvm(  543): DexOpt: load 14ms, verify+opt 115ms, 786140 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.tts
D/dalvikvm(  544): DexOpt: load 52ms, verify+opt 261ms, 1650068 bytes
I/PackageManager(  419): Running dexopt on: com.android.phone
D/dalvikvm(  545): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  545): DexOpt: load 27ms, verify+opt 173ms, 1120524 bytes
I/PackageManager(  419): Running dexopt on: com.zdvdev.sef
I/dalvikvm(  546): DexOpt: access denied from Landroid/support/v4/app/NotificationCompatApi20; to field Landroid/app/Notification;.actions
I/dalvikvm(  546): DexOpt: access denied from Landroid/support/v4/app/NotificationCompatKitKat; to field Landroid/app/Notification;.actions
D/dalvikvm(  546): DexOpt: load 98ms, verify+opt 438ms, 1946732 bytes
I/PackageManager(  419): Running dexopt on: com.android.location.fused
D/dalvikvm(  547): DexOpt: load 3ms, verify+opt 2ms, 142900 bytes
I/PackageManager(  419): Running dexopt on: com.android.defcontainer
D/dalvikvm(  548): DexOpt: load 3ms, verify+opt 6ms, 203604 bytes
I/PackageManager(  419): Running dexopt on: com.android.htmlviewer
D/dalvikvm(  549): DexOpt: load 5ms, verify+opt 12ms, 247468 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.voicesearch
D/dalvikvm(  550): DexOpt: load 2ms, verify+opt 1ms, 110708 bytes
I/PackageManager(  419): Running dexopt on: com.rhmsoft.fm.hd
D/dalvikvm(  551): Note: class Lcom/google/android/gms/games/internal/IGamesService$Stub; has 186 unimplemented (abstract) methods
D/dalvikvm(  551): DexOpt: load 204ms, verify+opt 1594ms, 4782252 bytes
I/PackageManager(  419): Running dexopt on: com.android.inputmethod.latin
D/dalvikvm(  552): DexOpt: load 26ms, verify+opt 135ms, 934460 bytes
I/PackageManager(  419): Running dexopt on: com.android.contacts
D/dalvikvm(  553): DexOpt: load 81ms, verify+opt 378ms, 1920044 bytes
I/PackageManager(  419): Running dexopt on: com.android.sharedstoragebackup
D/dalvikvm(  554): DexOpt: load 3ms, verify+opt 1ms, 120620 bytes
I/PackageManager(  419): Running dexopt on: com.android.bluetooth
D/dalvikvm(  555): DexOpt: load 15ms, verify+opt 179ms, 855836 bytes
I/PackageManager(  419): Running dexopt on: com.android.settings
D/dalvikvm(  556): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  556): DexOpt: load 89ms, verify+opt 499ms, 2643916 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.gms
D/dalvikvm(  557): DexOpt: load 221ms, verify+opt 2481ms, 5620092 bytes
I/PackageManager(  419): Running dexopt on: com.android.magicsmoke
D/dalvikvm(  558): DexOpt: load 5ms, verify+opt 7ms, 274468 bytes
I/PackageManager(  419): Running dexopt on: com.android.wallpaper.holospiral
D/dalvikvm(  559): DexOpt: load 6ms, verify+opt 4ms, 256644 bytes
I/PackageManager(  419): Running dexopt on: com.android.smspush
D/dalvikvm(  560): DexOpt: load 4ms, verify+opt 5ms, 140604 bytes
I/PackageManager(  419): Running dexopt on: com.android.inputdevices
D/dalvikvm(  561): DexOpt: load 2ms, verify+opt 1ms, 97500 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.googlequicksearchbox
D/dalvikvm(  562): DexOpt: 'Landroid/util/Pools;' has an earlier definition; blocking out
D/dalvikvm(  562): DexOpt: not verifying/optimizing 'Landroid/util/Pools;': multiple definitions
D/dalvikvm(  562): DexOpt: load 253ms, verify+opt 1657ms, 5869116 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.syncadapters.contacts
D/dalvikvm(  563): DexOpt: load 10ms, verify+opt 101ms, 541100 bytes
I/PackageManager(  419): Running dexopt on: com.android.gallery3d
D/dalvikvm(  564): DexOpt: load 72ms, verify+opt 379ms, 1917908 bytes
I/PackageManager(  419): Running dexopt on: com.android.vending
D/dalvikvm(  565): DexOpt: 'Lcom/android/internal/os/PkgUsageStats$1;' has an earlier definition; blocking out
D/dalvikvm(  565): DexOpt: 'Lcom/android/internal/os/PkgUsageStats;' has an earlier definition; blocking out
D/dalvikvm(  565): DexOpt: not verifying/optimizing 'Lcom/android/internal/os/PkgUsageStats$1;': multiple definitions
D/dalvikvm(  565): DexOpt: not verifying/optimizing 'Lcom/android/internal/os/PkgUsageStats;': multiple definitions
I/dalvikvm(  565): DexOpt: not resolving ambiguous class 'Lcom/android/internal/os/PkgUsageStats;'
D/dalvikvm(  565): DexOpt: load 136ms, verify+opt 776ms, 3175708 bytes
I/PackageManager(  419): Running dexopt on: com.android.facelock
D/dalvikvm(  566): DexOpt: load 12ms, verify+opt 27ms, 408428 bytes
I/PackageManager(  419): Running dexopt on: com.cyanogenmod.updater
D/dalvikvm(  567): DexOpt: load 6ms, verify+opt 44ms, 501684 bytes
I/PackageManager(  419): Running dexopt on: com.android.phasebeam
D/dalvikvm(  568): DexOpt: load 6ms, verify+opt 5ms, 249564 bytes
D/dalvikvm(  569): DexOpt: load 8ms, verify+opt 16ms, 400180 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.contacts
D/dalvikvm(  570): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  570): DexOpt: load 12ms, verify+opt 148ms, 740812 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.drm
D/dalvikvm(  571): DexOpt: load 3ms, verify+opt 4ms, 149260 bytes
I/PackageManager(  419): Running dexopt on: com.android.dreams.basic
D/dalvikvm(  572): DexOpt: load 3ms, verify+opt 5ms, 188596 bytes
I/PackageManager(  419): Running dexopt on: com.android.systemui
D/dalvikvm(  573): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  573): DexOpt: load 54ms, verify+opt 189ms, 1388020 bytes
I/PackageManager(  419): Running dexopt on: com.cyanogenmod.lockclock
D/dalvikvm(  574): DexOpt: load 8ms, verify+opt 28ms, 464988 bytes
I/PackageManager(  419): Running dexopt on: com.vipercn.viper4android4x
D/dalvikvm(  575): DexOpt: load 23ms, verify+opt 145ms, 976172 bytes
I/PackageManager(  419): Running dexopt on: com.android.development
D/dalvikvm(  576): Note: class Landroid/app/ActivityManagerNative; has 158 unimplemented (abstract) methods
D/dalvikvm(  576): DexOpt: load 17ms, verify+opt 59ms, 699084 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.backup
D/dalvikvm(  577): DexOpt: load 11ms, verify+opt 68ms, 599164 bytes
I/PackageManager(  419): Running dexopt on: com.android.providers.userdictionary
D/dalvikvm(  578): DexOpt: load 3ms, verify+opt 5ms, 165540 bytes
I/PackageManager(  419): Running dexopt on: com.google.android.marvin.talkback
D/dalvikvm(  579): DexOpt: load 39ms, verify+opt 162ms, 1109212 bytes
I/PackageManager(  419): Running dexopt on: com.android.provision
D/dalvikvm(  580): DexOpt: load 4ms, verify+opt 1ms, 133820 bytes
I/SystemServer(  419): Mount Service
D/MountService(  419): got storage path: /mnt/sdcard description: Interner Speicher primary: true removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  419): addVolumeLocked() StorageVolume [mStorageId=0 mPath=/mnt/sdcard mDescriptionId=17040724 mPrimary=true mRemovable=true mEmulated=false mMtpReserveSpace=100 mAllowMassStorage=true mMaxFileSize=0 mOwner=null]
D/MountService(  419): got storage path: /mnt/external_sd description: SD-Karte primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService(  419): addVolumeLocked() StorageVolume [mStorageId=0 mPath=/mnt/external_sd mDescriptionId=17040725 mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=100 mAllowMassStorage=true mMaxFileSize=0 mOwner=null]
D/MountService(  419): got storage path: /mnt/usb_storage description: USB-Speicher primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService(  419): addVolumeLocked() StorageVolume [mStorageId=0 mPath=/mnt/usb_storage mDescriptionId=17040726 mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=100 mAllowMassStorage=false mMaxFileSize=0 mOwner=null]
I/SystemServer(  419): LockSettingsService
I/SystemServer(  419): Device Policy
I/SystemServer(  419): Status Bar
I/PackageManager(  419): Updating external media status from unmounted to unmounted
I/PackageManager(  419): No secure containers on sdcard
I/SystemServer(  419): Clipboard Service
I/SystemServer(  419): NetworkManagement Service
D/MountService(  419): volume state changed for /mnt/sdcard (null -> unmounted)
D/MountService(  419): volume state changed for /mnt/external_sd (null -> unmounted)
D/MountService(  419): volume state changed for /mnt/usb_storage (null -> removed)
W/MountService(  419): getSecureContainerList() called when storage not mounted
I/SystemServer(  419): Text Service Manager Service
W/PackageManager(  419): Not granting permission android.permission.INTERACT_ACROSS_USERS_FULL to package de.draisberghof.pppwidget (protectionLevel=2 flags=0x88be45)
W/PackageManager(  419): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x89be45)
W/PackageManager(  419): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0x8abe45)
W/PackageManager(  419): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x88be45)
W/PackageManager(  419): Not granting permission android.permission.READ_DREAM_STATE to package com.google.android.gsf (protectionLevel=2 flags=0x883e45)
D/dalvikvm(  419): GC_CONCURRENT freed 326K, 72% free 4767K/16888K, paused 3ms+3ms, total 34ms
I/SystemServer(  419): NetworkStats Service
I/SystemServer(  419): NetworkPolicy Service
I/SystemServer(  419): Wi-Fi P2pService
E/CommandListener(   92): Failed to open /proc/sys/net/ipv6/conf/wlan0/disable_ipv6: No such file or directory
E/WifiStateMachine(  419): Failed to disable IPv6: java.lang.IllegalStateException: command '1 interface ipv6 wlan0 disable' failed with '400 1 Failed to change IPv6 state (No such file or directory)'
I/SystemServer(  419): Wi-Fi Service
I/SystemServer(  419): Connectivity Service
D/ConnectivityService(  419): ConnectivityService starting up
E/ConnectivityService(  419): Error in networkAttributes - ignoring attempt to use undefined radio 7 in network type 7
E/MobileDataStateTracker(  419): default: Ignoring feature request because could not acquire PhoneService
E/MobileDataStateTracker(  419): default: Could not enable APN type "default"
I/WifiService(  419): WifiService starting up with Wi-Fi disabled
D/EthernetService(  419): EthernetService() : Entered.
I/SystemServer(  419): Ethernet Service
I/SystemServer(  419): Network Service Discovery Service
D/NsdService(  419): Network service discovery enabled true
I/SystemServer(  419): Throttle Service
I/SystemServer(  419): FM receiver Service
I/        (  419): registerAndroidFmRadioReceiver
I/        (  419): registerAndroidFmRadioTransmitter
I/FmReceiverService(  419): FmReceiverService created
I/FmTransmitterService(  419): FmTransmitterService created
I/SystemServer(  419): FM transmitter Service
I/SystemServer(  419): UpdateLock Service
I/SystemServer(  419): Profile Manager
W/Profile (  419): Null Pointer - UUID not found for Standard.  New UUID generated: 1f35c58e-302e-404c-aea9-fdcaa7319669
W/Profile (  419): Null Pointer - UUID not found for Arbeit.  New UUID generated: f6a43951-0f63-4028-8513-d8e19418f207
W/Profile (  419): Null Pointer - UUID not found for Zu Hause.  New UUID generated: 0bd693c9-cfd9-4ee6-ad80-324f459cc69d
W/Profile (  419): Null Pointer - UUID not found for Lautlos.  New UUID generated: 714e5443-31ea-470a-a760-3b42ddd22e61
W/Profile (  419): Null Pointer - UUID not found for Nacht.  New UUID generated: 7b60e0cf-6840-4358-8d30-ea9c0d4cf541
D/ProfileService(  419): Set active profile to: 1f35c58e-302e-404c-aea9-fdcaa7319669 - Standard
D/ProfileService(  419): Saving profile data...
D/dalvikvm(  419): GC_CONCURRENT freed 401K, 71% free 4972K/16888K, paused 2ms+2ms, total 33ms
D/ProfileService(  419): Save completed.
I/SystemServer(  419): Notification Manager
I/SystemServer(  419): Device Storage Monitor
I/SystemServer(  419): Location Manager
I/SystemServer(  419): Country Detector
I/SystemServer(  419): Search Service
I/SystemServer(  419): DropBox Service
I/SystemServer(  419): Wallpaper Service
W/WallpaperService(  419): no current wallpaper -- first boot?
I/SystemServer(  419): Audio Service
I/SystemServer(  419): Dock Observer
W/DockObserver(  419): This kernel does not have dock station support
I/SystemServer(  419): Wired Accessory Observer
W/WiredAccessoryManager(  419): This kernel does not have usb audio support
W/WiredAccessoryManager(  419): This kernel does not have samsung usb dock audio support
I/SystemServer(  419): USB Service
I/SystemServer(  419): Serial Service
I/SystemServer(  419): Twilight Service
I/SystemServer(  419): UI Mode Manager Service
I/SystemServer(  419): Backup Service
V/BackupManagerService(  419): No ancestral data
I/BackupManagerService(  419): Backup enabled => false
I/SystemServer(  419): AppWidget Service
I/SystemServer(  419): Recognition Service
I/SystemServer(  419): DiskStats Service
I/SystemServer(  419): SamplingProfiler Service
I/SystemServer(  419): NetworkTimeUpdateService
I/SystemServer(  419): CommonTimeManagementService
D/dalvikvm(  419): GC_CONCURRENT freed 535K, 70% free 5095K/16888K, paused 2ms+3ms, total 43ms
I/SystemServer(  419): CertBlacklister
I/SystemServer(  419): Dreams Service
I/SystemServer(  419): AssetRedirectionManager Service
I/SystemServer(  419): Pie Delivery Service
I/WindowManager(  419): SAFE MODE not enabled
D/dalvikvm(  419): JIT started for system_server
E/SQLiteLog(  419): (1) no such table: locksettings
I/LockSettingsService(  419): Migrated lock settings to new location
I/keystore(  100): uid: 1000 action: z -> 7 state: 3 -> 3 retry: 4
I/Lights  (  419): >>> Enter set_keyboard_light
W/PackageManager(  419): Removing dangling preferred activity: ComponentInfo{com.google.android.apps.maps/com.google.android.maps.MapsActivity}
I/ActivityManager(  419): Sending system update to ComponentInfo{com.google.android.gsf/com.google.android.gsf.loginservice.MigrateToAccountManagerBroadcastReceiver} for user 0
I/ActivityManager(  419): Sending system update to ComponentInfo{com.android.providers.media/com.android.providers.media.MediaUpgradeReceiver} for user 0
I/ActivityManager(  419): Sending system update to ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver} for user 0
I/ActivityManager(  419): Sending system update to ComponentInfo{com.google.android.googlequicksearchbox/com.google.android.googlequicksearchbox.GelStubAppWatcher} for user 0
I/ActivityManager(  419): Sending system update to ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver} for user 0
I/SystemServer(  419): Enabled StrictMode for system server main thread.
I/Zygote  (  419): Process: zygote socket opened
I/ActivityManager(  419): Start proc com.google.process.gapps for broadcast com.google.android.gsf/.loginservice.MigrateToAccountManagerBroadcastReceiver: pid=608 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
I/ActivityManager(  419): Launching preboot mode app: ProcessRecord{41264c38 608:com.google.process.gapps/u0a10000}
W/Trace   (  608): error opening trace file: No such file or directory (2)
D/GoogleLoginService(  608): no legacy android id exists to migrate
D/GoogleLoginService(  608): skipping migration because /data/data/com.google.android.gsf/databases/accounts.db doesn't exist
D/GoogleLoginService(  608): disabling the migration script since the migration is complete
I/ActivityManager(  419): Start proc android.process.media for broadcast com.android.providers.media/.MediaUpgradeReceiver: pid=627 uid=10002 gids={50002, 1015, 1023, 1024, 1028, 2001, 3003, 3007}
W/Trace   (  627): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Launching preboot mode app: ProcessRecord{41cbc198 627:android.process.media/u0a10002}
I/ActivityManager(  419): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver: pid=642 uid=10036 gids={50036, 3003, 1015, 1023, 1028}
W/Trace   (  642): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Launching preboot mode app: ProcessRecord{413952c0 642:com.android.providers.calendar/u0a10036}
I/ActivityManager(  419): Start proc com.google.android.googlequicksearchbox:search for broadcast com.google.android.googlequicksearchbox/.GelStubAppWatcher: pid=657 uid=10056 gids={50056, 3003, 1028, 3002, 1015, 1023}
I/ActivityManager(  419): Launching preboot mode app: ProcessRecord{41ea6488 657:com.google.android.googlequicksearchbox:search/u0a10056}
W/Trace   (  657): error opening trace file: No such file or directory (2)
V/GelStubAppWatcher(  657): onReceive: android.intent.action.PRE_BOOT_COMPLETED
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.LauncherProvider}) disabled
D/dalvikvm(  419): GC_CONCURRENT freed 628K, 70% free 5156K/16888K, paused 3ms+6ms, total 52ms
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.PreloadReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.InstallShortcutReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.UninstallShortcutReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.UserInitializeReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.PackageChangedReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.android.launcher3.WallpaperCropActivity}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.google.android.launcher.GelWallpaperPickerActivity}) disabled
D/dalvikvm(  419): GC_CONCURRENT freed 746K, 70% free 5110K/16888K, paused 2ms+2ms, total 41ms
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.google.android.launcher.MarketUpdateReceiver}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.google.android.velvet.tg.SetupWizardOptInIntroActivity}) disabled
V/GelStubAppWatcher(  657): setting GEL component (ComponentInfo{com.google.android.googlequicksearchbox/com.google.android.launcher.GEL}) disabled
I/ActivityManager(  419): Start proc android.process.acore for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver: pid=671 uid=10003 gids={50003, 3003, 1015, 1023, 1028}
W/Trace   (  671): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Launching preboot mode app: ProcessRecord{418e0fd0 671:android.process.acore/u0a10003}
I/ContactsDatabaseHelper(  671): Bootstrapping database version: 706
I/ContactsProviderV1(  671): Bootstrapping database legacy support
I/ActivityManager(  419): Writing new set of last done pre-boot receivers...
D/dalvikvm(  419): GC_CONCURRENT freed 622K, 70% free 5180K/16888K, paused 2ms+2ms, total 33ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 29ms
I/ActivityManager(  419): Removing system update proc: ProcessRecord{41264c38 608:com.google.process.gapps/u0a10000}
I/ActivityManager(  419): Killing proc 608:com.google.process.gapps/u0a10000: system update done
I/ActivityManager(  419): Removing system update proc: ProcessRecord{41cbc198 627:android.process.media/u0a10002}
I/ActivityManager(  419): Killing proc 627:android.process.media/u0a10002: system update done
I/ActivityManager(  419): Removing system update proc: ProcessRecord{413952c0 642:com.android.providers.calendar/u0a10036}
I/ActivityManager(  419): Killing proc 642:com.android.providers.calendar/u0a10036: system update done
I/ActivityManager(  419): Removing system update proc: ProcessRecord{41ea6488 657:com.google.android.googlequicksearchbox:search/u0a10056}
I/ActivityManager(  419): Killing proc 657:com.google.android.googlequicksearchbox:search/u0a10056: system update done
I/ActivityManager(  419): Removing system update proc: ProcessRecord{418e0fd0 671:android.process.acore/u0a10003}
I/ActivityManager(  419): Killing proc 671:android.process.acore/u0a10003: system update done
I/ActivityManager(  419): System now ready
W/ActivityManager(  419): Can't find mystery application for StrictMode from pid=671 uid=10003: android.os.BinderProxy@411b5698
I/SystemServer(  419): Making services ready
I/ActivityManager(  419): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=685 uid=10064 gids={50064, 1028, 1015, 1023, 3002, 3001, 1006}
D/NetworkManagementService(  419): enabling bandwidth control
E/Vold    (   91): --------mountVol,storage_policy=0-----
I/Vold    (   91): /dev/block/vold/179:1 being considered for volume sdcard
I/Vold    (   91): Call notifyStateKernel No.1 in the file of VOlume.cpp
D/Vold    (   91): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking)
D/MountService(  419): volume state changed for /mnt/external_sd (unmounted -> checking)
D/MountService(  419): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/external_sd (has extras) } to UserHandle{-1}
D/Vold    (   91): Volume sdcard state changing 3 (Checking) -> 4 (Mounted)
I/Vold    (   91): /dev/block/vold/31:9 being considered for volume flash
D/Vold    (   91): Volume flash state changing 1 (Idle-Unmounted) -> 3 (Checking)
D/MountService(  419): volume state changed for /mnt/external_sd (checking -> mounted)
D/MountService(  419): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/external_sd (has extras) } to UserHandle{-1}
I//system/bin/fsck_msdos(   91): ** /dev/block/vold/31:9
D/MountService(  419): volume state changed for /mnt/sdcard (unmounted -> checking)
D/MountService(  419): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/sdcard (has extras) } to UserHandle{-1}
I//system/bin/fsck_msdos(   91): Invalid signature in boot block: 0000
I/logwrapper(   91): /system/bin/fsck_msdos terminated by exit(2)
E/Vold    (   91): Filesystem check failed (not a FAT filesystem)
W/Vold    (   91): /dev/block/vold/31:9 does not contain a FAT filesystem
E/Vold    (   91): /dev/block/vold/31:9 failed FS checks (No data available),but try as NTFS again
D/Vold    (   91): Volume flash state changing 3 (Checking) -> 1 (Idle-Unmounted)
D/MountService(  419): volume state changed for /mnt/sdcard (checking -> unmounted)
D/MountService(  419): sendStorageIntent Intent { act=android.intent.action.MEDIA_UNMOUNTED dat=file:///mnt/sdcard (has extras) } to UserHandle{-1}
W/Trace   (  685): error opening trace file: No such file or directory (2)
E/Vold    (   91): /dev/block/vold/31:9 failed to mount via VFAT (Invalid argument) Try to mount uses NTFS ...
D/SystemUIService(  685): loading: class com.android.systemui.statusbar.phone.PhoneStatusBar
D/SystemUIService(  685): running: com.android.systemui.statusbar.phone.PhoneStatusBar@411830f0
I/StatusBarManagerService(  419): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@412494e8
I/logwrapper(   91): /system/bin/ntfs-3g terminated by exit(12)
I/Vold    (   91):  /system/bin/ntfs-3g /dev/block/vold/31:9 /mnt/secure/staging
E/Vold    (   91): Mount NTFS device form /dev/block/vold/31:9 to /mnt/secure/staging failed
E/Vold    (   91): /dev/block/vold/31:9 failed to mount via VNTFS (I/O error)
E/Vold    (   91): Volume flash found no suitable devices for mounting :(
W/Vold    (   91): Duplicate state (1)
D/MountService(  419): volume state changed for /mnt/sdcard (unmounted -> unmountable)
D/MountService(  419): sendStorageIntent Intent { act=android.intent.action.MEDIA_UNMOUNTABLE dat=file:///mnt/sdcard (has extras) } to UserHandle{-1}
E/MountService(  419): Boot-time mount failed (-4)
I/keystore(  100): uid: 1000 action: e -> 7 state: 3 -> 3 retry: 4
I/PowerWidget(  685): Clearing any old widget stuffs
I/PowerWidget(  685): Setting up widget
I/PowerWidget(  685): Default buttons being loaded
I/PowerWidget(  685): Button list: toggleWifi|toggleBluetooth|toggleGPS|toggleSound
W/Settings(  419): Setting usb_mass_storage_enabled has moved from android.provider.Settings.Secure to android.provider.Settings.Global.
I/ActivityManager(  419): Config changes=200 {1.0 ?mcc?mnc de_DE ldltr sw721dp w1024dp h695dp 160dpi xlrg land finger -keyb/h/h -nav/h s.3 themeResource=null}
W/ContextImpl(  419): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1093 com.android.server.usb.UsbSettingsManager.deviceAttached:619 com.android.server.usb.UsbHostManager.usbDeviceAdded:156 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:38
W/AppWidgetServiceImpl(  419): Failed to read state: java.io.FileNotFoundException: /data/system/users/0/appwidgets.xml: open failed: ENOENT (No such file or directory)
D/BluetoothManagerService(  419): Message: 20
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@4129f760:true
D/BluetoothAdapter(  685): 1093079064: getState() :  mService = null. Returning STATE_OFF
W/InputMethodManagerService(  419): Ignoring setImeWindowStatus of uid 1000 token: null
I/QuickSettingsController(  685): Default tiles being loaded
I/QuickSettingsController(  685): Tiles list: toggleUser|toggleBrightness|toggleSettings|toggleWifi|toggleMobileData|toggleBattery|toggleAirplane|toggleBluetooth
W/InputMethodManagerService(  419): Reset the default IME as "Resource" is ready here.
I/InputMethodManagerService(  419): Selected default: com.android.inputmethod.latin/.LatinIME
I/ActivityManager(  419): Config changes=20 {1.0 ?mcc?mnc de_DE ldltr sw721dp w1024dp h695dp 160dpi xlrg land finger -keyb/v/h -nav/h s.4 themeResource=null}
I/ActivityManager(  419): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=750 uid=10051 gids={50051, 1028}
I/LocationBlacklist(  419): whitelist: []
I/LocationBlacklist(  419): blacklist: []
W/InputMethodManagerService(  419): Illegal subtype state: old subtype = null, new subtype = android.view.inputmethod.InputMethodSubtype@2e2cbe61
E/ThrottleService(  419): Error reading data file
I/CommonTimeManagementService(  419): No common time service detected on this platform.  Common time services will be unavailable.
I/InputReader(  419): Reconfiguring input devices.  changes=0x00000020
I/InputReader(  419): Reconfiguring input devices.  changes=0x00000010
W/Trace   (  750): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Start proc com.android.phone for added application com.android.phone: pid=770 uid=1001 gids={41001, 3002, 3001, 3003, 1015, 1023, 1028}
D/dalvikvm(  775): Late-enabling CheckJNI
I/ActivityManager(  419): Start proc com.vipercn.viper4android4x for added application com.vipercn.viper4android4x: pid=775 uid=10066 gids={50066, 3002, 3003, 1015, 1023, 1028}
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.settings/.CryptKeeper} from pid 0
D/dalvikvm(   96): GC_EXPLICIT freed 36K, 70% free 2349K/7696K, paused 1ms+2ms, total 42ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 3ms+2ms, total 28ms
D/dalvikvm(  419): GC_CONCURRENT freed 499K, 69% free 5367K/16888K, paused 4ms+22ms, total 179ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+1ms, total 25ms
W/ThrottleService(  419): unable to find stats for iface rmnet0
I/ActivityManager(  419): Start proc com.android.settings for activity com.android.settings/.CryptKeeper: pid=789 uid=1000 gids={41000, 1015, 1023, 1028, 3002, 3001, 3003, 3007}
I/LatinIME(  750): Hardware accelerated drawing: true
I/ActivityManager(  419): Start proc com.google.process.location for service com.google.android.location/.NetworkLocationService: pid=824 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
W/SubtypeLocale(  750): KeyboardLayoutSet not found, use QWERTY: locale=hu_ZZ extraValue=AsciiCapable,SupportTouchPositionCorrection
W/Trace   (  770): error opening trace file: No such file or directory (2)
W/Trace   (  775): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Start proc android.process.acore for content provider com.android.providers.contacts/.ContactsProvider2: pid=841 uid=10003 gids={50003, 3003, 1015, 1023, 1028}
I/ActivityManager(  419): Start proc android.process.media for broadcast com.android.providers.downloads/.DownloadReceiver: pid=846 uid=10002 gids={50002, 1015, 1023, 1024, 1028, 2001, 3003, 3007}
W/Trace   (  789): error opening trace file: No such file or directory (2)
W/Trace   (  824): error opening trace file: No such file or directory (2)
W/Trace   (  841): error opening trace file: No such file or directory (2)
W/TelephonyProvider(  770): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
D/TelephonyManager(  770): getLteOnCdmaMode=0 curVal=-1 product_type='' lteOnCdmaProductType=''
W/InputAttributes(  750): No editor info for this field. Bug?
D/PhoneStatusBar(  685): disable: < expand icons alerts ticker system_info back home recent clock search >
I/ActivityManager(  419): Start proc com.android.location.fused for service com.android.location.fused/.FusedLocationService: pid=901 uid=10046 gids={50046, 1028}
W/Trace   (  846): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Start proc com.google.android.inputmethod.latin.dictionarypack for content provider com.google.android.inputmethod.latin.dictionarypack/.DictionaryProvider: pid=908 uid=10033 gids={50033, 3003, 1015, 1023, 1028}
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity} from pid 0
D/dalvikvm(  419): GC_CONCURRENT freed 707K, 68% free 5416K/16888K, paused 4ms+4ms, total 131ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 59ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 50ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 45ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 67ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 66ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 20ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 27ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 65ms
W/Settings(  770): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value.
W/Settings(  770): Setting auto_time has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only global URI.
I/ActivityManager(  419): Start proc com.android.provision for activity com.android.provision/.DefaultActivity: pid=935 uid=10069 gids={50069, 1028}
W/Settings(  770): Setting auto_time_zone has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only global URI.
W/Trace   (  908): error opening trace file: No such file or directory (2)
W/Trace   (  901): error opening trace file: No such file or directory (2)
W/BackupManagerService(  419): dataChanged but no participant pkg='com.android.providers.settings' uid=10064
I/ActivityManager(  419): Start proc com.google.process.gapps for content provider com.google.android.gsf/.settings.GoogleSettingsProvider: pid=947 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
D/BluetoothManagerService(  419): Message: 300
D/BluetoothManagerService(  419): MESSAGE_USER_SWITCHED
W/Trace   (  935): error opening trace file: No such file or directory (2)
I/DownloadManager(  846): in removeSpuriousFiles
I/DownloadManager(  846): Upgrading downloads database from version 0 to version 108, which will destroy all old data
I/ActivityManager(  419): Start proc com.android.smspush for service com.android.smspush/.WapPushManager: pid=962 uid=10055 gids={50055, 1028}
D/        (  770): [ApnContext:default] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:default] setRetryCount: 0
D/        (  770): [ApnContext:mms] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:mms] setRetryCount: 0
D/        (  770): [ApnContext:supl] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:supl] setRetryCount: 0
D/        (  770): [ApnContext:hipri] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:hipri] setRetryCount: 0
D/        (  770): [ApnContext:fota] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:fota] setRetryCount: 0
D/        (  770): [ApnContext:ims] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:ims] setRetryCount: 0
D/        (  770): [ApnContext:cbs] set reason as dataEnabled,current state IDLE
D/        (  770): [ApnContext:cbs] setRetryCount: 0
D/MediaScannerReceiver(  846): action: android.intent.action.MEDIA_MOUNTED path: /mnt/external_sd
W/Trace   (  947): error opening trace file: No such file or directory (2)
W/BackupManagerService(  419): dataChanged but no participant pkg='com.android.providers.settings' uid=10069
D/SystemUIService(  685): loading: class com.android.systemui.power.PowerUI
D/SystemUIService(  685): running: com.android.systemui.power.PowerUI@41374720
D/CallManager(  770): registerPhone(GSM Handler (com.android.internal.telephony.PhoneProxy) {411a3e10})
W/Trace   (  962): error opening trace file: No such file or directory (2)
D/SystemUIService(  685): loading: class com.android.systemui.media.RingtonePlayer
D/SystemUIService(  685): running: com.android.systemui.media.RingtonePlayer@41375898
E/UserHistoryDictionary(  750): when loading: file not foundjava.io.FileNotFoundException: /data/data/com.android.inputmethod.latin/files/UserHistoryDictionary.de.dict: open failed: ENOENT (No such file or directory)
D/MediaScannerReceiver(  846): action: android.intent.action.MEDIA_UNMOUNTED path: /mnt/sdcard
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@41cb1a68:true
W/MediaProvider(  846): no database for scanned volume external
I/ContactsDatabaseHelper(  841): Bootstrapping database version: 706
D/dalvikvm(  419): GC_CONCURRENT freed 578K, 67% free 5583K/16888K, paused 11ms+14ms, total 80ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 51ms
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=android/com.android.internal.app.ResolverActivity} from pid 0
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (10 > 0 bytes)
I/ActivityManager(  419): Start proc system:ui for activity android/com.android.internal.app.ResolverActivity: pid=997 uid=1000 gids={41000, 1015, 1023, 1028, 3002, 3001, 3003, 3007}
I/FusedLocation(  901): engine started (com.android.location.fused)
I/GservicesProvider(  947): Gservices pushing to system: true; secure/global: true
E/MediaProvider(  846): /mnt/sdcard volume ID: -1
D/FileUtils(  846): Trying to get UUID for /mnt/sdcard
I/Choreographer(  685): Skipped 94 frames!  The application may be doing too much work on its main thread.
E/MediaProvider(  846): /mnt/sdcard UUID: -1
I/ActivityManager(  419): Start proc com.google.android.partnersetup for broadcast com.google.android.partnersetup/.PhoneStateReceiver: pid=1016 uid=10039 gids={50039, 3003, 1028}
D/dalvikvm(   96): GC_EXPLICIT freed 38K, 70% free 2349K/7696K, paused 2ms+4ms, total 18ms
D/CallNotifier(  770): CallNotifier: mSignalInfoToneGenerator created when toneplay
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+2ms, total 23ms
W/Trace   ( 1016): error opening trace file: No such file or directory (2)
I/MediaProvider(  846): External volume is not (yet) mounted, cannot attach.
W/MediaScannerService(  846): failed to open media database
W/Trace   (  997): error opening trace file: No such file or directory (2)
D/NetworkLocationClient(  824): binding to Intent { act=com.google.android.location.internal.ANDROID_NLP pkg=com.google.android.location }
W/MediaScanner(  846): Error opening directory '/mnt/sdcard/', skipping: Permission denied.
E/MediaScannerJNI(  846): An exception was thrown by callback 'scanFile'.
D/dalvikvm(  419): GC_CONCURRENT freed 895K, 68% free 5500K/16888K, paused 4ms+8ms, total 108ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 33ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 34ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 36ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 31ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 30ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 37ms
E/MediaScannerJNI(  846): java.lang.NullPointerException
E/MediaScannerJNI(  846):     at android.media.MediaScanner.makeEntryFor(MediaScanner.java:1489)
E/MediaScannerJNI(  846):     at android.media.MediaScanner$MyMediaScannerClient.beginFile(MediaScanner.java:472)
E/MediaScannerJNI(  846):     at android.media.MediaScanner$MyMediaScannerClient.doScanFile(MediaScanner.java:526)
E/MediaScannerJNI(  846):     at android.media.MediaScanner$MyMediaScannerClient.scanFile(MediaScanner.java:518)
E/MediaScannerJNI(  846):     at android.media.MediaScanner.processDirectory(Native Method)
E/MediaScannerJNI(  846):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1302)
E/MediaScannerJNI(  846):     at com.android.providers.media.MediaScannerService.scan(MediaScannerService.java:105)
E/MediaScannerJNI(  846):     at com.android.providers.media.MediaScannerService.access$300(MediaScannerService.java:49)
E/MediaScannerJNI(  846):     at com.android.providers.media.MediaScannerService$ServiceHandler.handleMessage(MediaScannerService.java:285)
E/MediaScannerJNI(  846):     at android.os.Handler.dispatchMessage(Handler.java:99)
E/MediaScannerJNI(  846):     at android.os.Looper.loop(Looper.java:137)
E/MediaScannerJNI(  846):     at com.android.providers.media.MediaScannerService.run(MediaScannerService.java:186)
E/MediaScannerJNI(  846):     at java.lang.Thread.run(Thread.java:856)
E/MediaScannerJNI(  846): An error occurred while scanning directory '/mnt/external_sd'.
W/MediaScanner(  846): Error opening directory '/mnt/usb_storage/', skipping: Permission denied.
V/MediaScanner(  846): pruneDeadThumbnailFiles... null
V/MediaScanner(  846): /pruneDeadThumbnailFiles... null
D/libEGL  (  685): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  (  685): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (  685): loaded /system/lib/egl/libGLESv2_mali.so
D/DebugService(  770): DebugService DebugService:
D/TelephonyDebugService(  770): TelephonyDebugService()
D/OpenGLRenderer(  685): Enabling debug mode 0
D/libEGL  (  997): loaded /system/lib/egl/libEGL_mali.so
E/BluetoothPhoneService(  770): Could not get a handle on Connection object for the call
W/CallNotifier(  770): Got onMwiChanged() on non-voice-capable device! Ignoring...
D/libEGL  (  997): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (  997): loaded /system/lib/egl/libGLESv2_mali.so
V/SmsStorageMonitor(  770): Memory status report to modem pending : mStorageAvailable = false
I/PhoneApp(  770): Headset phone created, binding local service.
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@41d88308:true
D/BluetoothAdapter(  789): 1092192328: getState() :  mService = null. Returning STATE_OFF
D/OpenGLRenderer(  997): Enabling debug mode 0
W/ContextImpl(  789): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothInputDevice.<init>:240 android.bluetooth.BluetoothAdapter.getProfileProxy:1169 com.android.settings.bluetooth.LocalBluetoothAdapter.getProfileProxy:94
I/DownloadManager(  846): Initiating request for download 1
D/BluetoothPan(  789): BluetoothPan() call bindService
D/BluetoothPan(  789): BluetoothPan(), bindService called
I/gmmInternalNlpService(  824): internal NLP onStart(com.google.android.location.internal.ANDROID_NLP) com.google.android.location
W/ContextImpl(  789): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPan.<init>:141 android.bluetooth.BluetoothAdapter.getProfileProxy:1172 com.android.settings.bluetooth.PanProfile.<init>:73
D/LocalBluetoothProfileManager(  789): LocalBluetoothProfileManager construction complete
W/ContextImpl(  789): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPbap.<init>:161 com.android.settings.bluetooth.PbapServerProfile.<init>:68 com.android.settings.bluetooth.LocalBluetoothProfileManager.<init>:124
D/NetworkLocationClient(  824): onServiceConnected to ComponentInfo{com.google.android.location/com.google.android.location.internal.server.NetworkLocationService}
I/ActivityManager(  419): Start proc com.google.android.gms for broadcast com.google.android.gms/com.google.android.location.internal.NlpNetworkProviderSettingsUpdateReceiver: pid=1061 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
I/ActivityManager(  419): Displayed android/com.android.internal.app.ResolverActivity: +735ms (total +1s747ms)
W/Trace   ( 1061): error opening trace file: No such file or directory (2)
E/WiredAccessoryManager(  419): No state change.
V/WiredAccessoryManager(  419): notifyWiredAccessoryChanged: when=0 bits= mask=14
V/WiredAccessoryManager(  419): newName=h2w newState=0 headsetState=0 prev headsetState=0
V/WiredAccessoryManager(  419): init()
D/BluetoothManagerService(  419): Added callback: android.bluetooth.BluetoothAdapter$1@418d9630:true
W/ContextImpl(  419): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.bluetooth.BluetoothHeadset.<init>:273 android.bluetooth.BluetoothAdapter.getProfileProxy:1163 android.media.AudioService.getBluetoothHeadset:2182 android.media.AudioService.access$2800:104
W/ContextImpl(  419): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.bluetooth.BluetoothA2dp.<init>:160 android.bluetooth.BluetoothAdapter.getProfileProxy:1166 android.media.AudioService$AudioServiceBroadcastReceiver.onReceive:4069 android.app.LoadedApk$ReceiverDispatcher$Args.run:758
I/Choreographer(  685): Skipped 51 frames!  The application may be doing too much work on its main thread.
D/BluetoothManagerService(  419): Retrieving Bluetooth Adapter name and address...
D/BluetoothManagerService(  419): getNameAndAddress(): mBluetooth = null mBinding = false
D/BluetoothManagerService(  419): Message: 200
D/BluetoothManagerService(  419): MESSAGE_GET_NAME_AND_ADDRESS
D/BluetoothManagerService(  419): Binding to service to get name and address
I/ActivityManager(  419): Start proc com.android.bluetooth for service com.android.bluetooth/.btservice.AdapterService: pid=1092 uid=1002 gids={41002, 3003, 3002, 3001, 1015, 1023, 3005, 1016, 3008, 1028}
W/Trace   ( 1092): error opening trace file: No such file or directory (2)
W/DownloadManager(  846): Aborting request for download 1: no network connection available
V/ProvidersChangedReceiver(  824): Not calling apply-settings: debugClause is true
V/ProvidersChangedReceiver(  824): and Android NLP is ANDROID minProtocolVersion 1 maxProtocolVersion 1 releaseVersion 10
V/ProvidersChangedReceiver(  824): and build Version is 17
D/AdapterServiceConfig( 1092): Adding HeadsetService
D/AdapterServiceConfig( 1092): Adding A2dpService
D/AdapterServiceConfig( 1092): Adding HidService
D/AdapterServiceConfig( 1092): Adding HealthService
D/AdapterServiceConfig( 1092): Adding PanService
V/SipBroadcastReceiver(  770): SIP VOIP not supported: android.net.sip.SIP_SERVICE_UP
D/BluetoothAdapterService( 1092): REFCOUNT: CREATED. INSTANCE_COUNT1
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@412fc128:true
D/BluetoothAdapterState( 1092): make
I/bluedroid( 1092): init
E/bt-btif ( 1092): ## btif_config_get assert section && *section && key && *key && name && *name && bytes && type failed at line:182 ##
I/bte_conf( 1092): Attempt to load stack conf from /etc/bluetooth/bt_stack.conf
D/btif_config_util( 1092): btif_config_save_file(L153): in file name:/data/misc/bluedroid/bt_config.new
I/bluedroid( 1092): get_profile_interface socket
D/BluetoothManagerService(  419): BluetoothServiceConnection: connected to AdapterService
D/BluetoothManagerService(  419): Message: 40
D/BluetoothManagerService(  419): MESSAGE_BLUETOOTH_SERVICE_CONNECTED
D/BluetoothManagerService(  419): Message: 201
D/BluetoothManagerService(  419): MESSAGE_SAVE_NAME_AND_ADDRESS
D/BluetoothAdapterService( 1092): Broadcasting updateAdapterState() to 0 receivers.
D/BluetoothBondStateMachine( 1092): make
I/GKI_LINUX( 1092): gki_task_entry: gki_task_entry task_id=1 [BTIF] starting
I/BluetoothBondStateMachine( 1092): StableState(): Entering Off State
I/dalvikvm( 1061): Could not find method android.app.admin.DevicePolicyManager.isDeviceOwnerApp, referenced from method com.google.android.gms.init.InitializeIntentService.onHandleIntent
W/dalvikvm( 1061): VFY: unable to resolve virtual method 2062: Landroid/app/admin/DevicePolicyManager;.isDeviceOwnerApp (Ljava/lang/String;)Z
D/dalvikvm( 1061): VFY: replacing opcode 0x6e at 0x00f4
D/dalvikvm(  685): GC_FOR_ALLOC freed 771K, 50% free 3887K/7696K, paused 28ms, total 47ms
I/dalvikvm-heap(  685): Grow heap (frag case) to 12.336MB for 8192016-byte allocation
D/BluetoothManagerService(  419): Bluetooth Adapter name changed to Rockchip based Tablet
D/BluetoothManagerService(  419): Stored Bluetooth name: Rockchip based Tablet
D/BluetoothHeadset(  770): Proxy object connected
D/BluetoothAdapterService(1092110040)( 1092): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@41186018
D/HeadsetService( 1092): Received start request. Starting profile...
D/dalvikvm(  419): GC_CONCURRENT freed 570K, 67% free 5681K/16888K, paused 16ms+68ms, total 227ms
D/BluetoothHeadset(  419): Proxy object connected
D/BluetoothAdapter(  419): 1099797824: getState() :  mService = null. Returning STATE_OFF
I/BluetoothHeadsetServiceJni( 1092): classInitNative: succeeds
D/HeadsetStateMachine( 1092): make
D/GCM     (  947): COMPAT: Multi user ser=0 current=0
D/dalvikvm(  685): GC_CONCURRENT freed 42K, 25% free 11845K/15700K, paused 3ms+7ms, total 75ms
E/dalvikvm( 1061): Could not find class 'android.app.AppOpsManager', referenced from method axp.a
W/dalvikvm( 1061): VFY: unable to resolve check-cast 386 (Landroid/app/AppOpsManager;) in Laxp;
D/dalvikvm( 1061): VFY: replacing opcode 0x1f at 0x000e
I/ContactsProviderV1(  841): Bootstrapping database legacy support
I/bluedroid( 1092): get_profile_interface handsfree
E/bt-btif ( 1092): btif_enable_service: current services:0x40
D/BluetoothA2dp(  419): Proxy object connected
D/A2dpService( 1092): Received start request. Starting profile...
I/BluetoothA2dpServiceJni( 1092): classInitNative: succeeds
D/A2dpStateMachine( 1092): make
I/ViPER4Android(  775): Starting service, reason = BootCompletedReceiver
I/dalvikvm(  824): Could not find method android.os.UserManager.getApplicationRestrictions, referenced from method aod.b
W/dalvikvm(  824): VFY: unable to resolve virtual method 3258: Landroid/os/UserManager;.getApplicationRestrictions (Ljava/lang/String;)Landroid/os/Bundle;
D/dalvikvm(  824): VFY: replacing opcode 0x6e at 0x0012
I/dalvikvm(  824): Could not find method android.accounts.AccountManager.getAccountsByTypeForPackage, referenced from method aod.c
W/dalvikvm(  824): VFY: unable to resolve virtual method 1804: Landroid/accounts/AccountManager;.getAccountsByTypeForPackage (Ljava/lang/String;Ljava/lang/String;)[Landroid/accounts/Account;
D/dalvikvm(  824): VFY: replacing opcode 0x6e at 0x000c
I/dalvikvm(  824): Could not find method android.os.UserManager.getUserRestrictions, referenced from method aod.d
W/dalvikvm(  824): VFY: unable to resolve virtual method 3260: Landroid/os/UserManager;.getUserRestrictions ()Landroid/os/Bundle;
D/dalvikvm(  824): VFY: replacing opcode 0x6e at 0x000f
I/bluedroid( 1092): get_profile_interface a2dp
I/ViPER4Android(  775): Creating global V4ADSPModule ...
I/RecoverySystem(  419): No recovery log file
I/GKI_LINUX( 1092): gki_task_entry: gki_task_entry task_id=2 [A2DP-MEDIA] starting
E/bt-btif ( 1092): btif_enable_service: current services:0x40040
I/ViPER4Android_v2(   98): Enter EffectCreate()
I/ViPER4Android_v2(   98): EffectCreate(), uuid = 41d3c987-e6cf-11e3-a88a-11aba5d5c51b
I/ViPER4Android_v2(   98): EffectCreate(), v4a standard effect (normal), Constructing ProcessUnit_FX
W/DropBoxManagerService(  419): Dropping: SYSTEM_BOOT (260 > 0 bytes)
D/A2dpStateMachine( 1092): Enter Disconnected: -2
I/BluetoothHidServiceJni( 1092): classInitNative: succeeds
I/BootReceiver(  419): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
I/ViPER4Android_v2(   98): Convolver: Constructing new convolver instance, NEON enabled.
I/ViPER4Android_v2(   98): Convolver: Partitioned segment size = 2048.
D/HidService( 1092): Received start request. Starting profile...
I/bluedroid( 1092): get_profile_interface hidhost
E/bt-btif ( 1092): btif_enable_service: current services:0x140040
I/BluetoothHealthServiceJni( 1092): classInitNative: succeeds
D/dalvikvm(  685): GC_FOR_ALLOC freed <1K, 25% free 11845K/15700K, paused 35ms, total 35ms
D/HealthService( 1092): Received start request. Starting profile...
I/bluedroid( 1092): get_profile_interface health
I/BluetoothPanServiceJni( 1092): classInitNative(L105): succeeds
I/dalvikvm-heap(  685): Grow heap (frag case) to 16.295MB for 4194320-byte allocation
I/ViPER4Android_v2(   98): Convolver: Resetting instance.
I/ViPER4Android_v2(   98): Creating ViPER4Android FX v2
I/ViPER4Android_v2(   98): Effect command, code = 0, size = 0
I/ViPER4Android_v2(   98): ViPER4Android enter configure
I/ViPER4Android_v2(   98): Configuring samplerate, in = 44100, out = 44100
I/ViPER4Android_v2(   98): Configuring channels, in = 3, out = 3
I/ViPER4Android_v2(   98): Configuring channels, in = 2, out = 2
I/ViPER4Android_v2(   98): Configuring input sample format, in = 1
I/ViPER4Android_v2(   98): Configuring output sample format, out = 1
I/ViPER4Android_v2(   98): Configuring input buffer access mode, in = 1
I/ViPER4Android_v2(   98): Configuring output buffer access mode, out = 0
I/ViPER4Android_v2(   98): ViPER4Android configuring successful
D/dalvikvm(  685): GC_CONCURRENT freed 0K, 20% free 15943K/19800K, paused 2ms+3ms, total 31ms
D/BluetoothInputDevice(  789): Proxy object connected
D/HidProfile(  789): Bluetooth service connected
I/ViPER4Android(  775): Creating viper4android module, 41d3c987-e6cf-11e3-a88a-11aba5d5c51b
D/dalvikvm(  419): GC_FOR_ALLOC freed 550K, 66% free 5837K/16888K, paused 103ms, total 103ms
W/DropBoxManagerService(  419): Dropping: SYSTEM_LAST_KMSG (10 > 0 bytes)
I/ActivityManager(  419): Start proc ccc71.st.cpu for broadcast ccc71.st.cpu/.pmw_booter: pid=1147 uid=10004 gids={50004, 1015, 1023, 3003, 1028}
D/PanService( 1092): Received start request. Starting profile...
D/BluetoothPanServiceJni( 1092): initializeNative(L110): pan
I/bluedroid( 1092): get_profile_interface pan
D/BluetoothAdapterService( 1092): Profile still not running:com.android.bluetooth.hdp.HealthService
D/BluetoothAdapterService( 1092): Profile still not running:com.android.bluetooth.pan.PanService
I/bluedroid( 1092): enable
E/NotificationService(  419): Ignoring notification with icon==0: Notification(pri=0 contentView=null vibrate=null sound=null defaults=0x0 flags=0x62 kind=[null])
D/HeadsetPhoneState( 1092): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=1
I/bt_hci_bdroid( 1092): init
I/bt_vendor( 1092): init
I/bt_vnd_conf( 1092): Attempt to load conf from /etc/bluetooth/bt_vendor.conf
D/bt_vendor( 1092): op for 5
D/bt_vendor( 1092): op for 0
D/bt_upio ( 1092): is_emulator_context : 0
D/bt_upio ( 1092): is_rfkill_disabled ? [0]
W/GCM     (  947): DIR: /data/data/com.google.android.gms/app_APP /data/data/com.google.android.gsf
I/bt_hci_bdroid( 1092): bt_hc_worker_thread started
I/Choreographer(  685): Skipped 53 frames!  The application may be doing too much work on its main thread.
I/ViPER4Android(  775): Service launched.
I/ViPER4Android(  775): Begin system update(speaker)
I/ViPER4Android(  775): ShowNotification(): show_notify = false
I/ViPER4Android(  775): <+++++++++++++++ Update global effect +++++++++++++++>
I/ViPER4Android(  775): updateSystem(): Commiting effects type
D/bt_upio ( 1092): Delay 500ms for bluetooth power up
D/BluetoothPan(  789): BluetoothPAN Proxy object connected
D/PanProfile(  789): Bluetooth service connected
I/ViPER4Android(  775): updateSystem(): Commiting speaker-fx parameters
I/ViPER4Android(  775): updateSystem(): Updating FIR Equalizer.
I/SurfaceFlinger(   95): Boot is finished (54450 ms)
I/ViPER4Android(  775): updateSystem(): Updating Reverberation.
I/ViPER4Android(  775): updateSystem(): Updating Convolver.
I/ViPER4Android(  775): updateSystem(): Updating eXtraLoud.
I/ViPER4Android(  775): updateSystem(): Updating Limiter.
I/ViPER4Android(  775): System updated.
I/ViPER4Android(  775): <++++++++++++++++++++++++++++++++++++++++++++++++++++>
I/ViPER4Android(  775): <+++++++++++++++ Update local effect +++++++++++++++>
I/ViPER4Android(  775): <+++++++++++++++++++++++++++++++++++++++++++++++++++>
W/Trace   ( 1147): error opening trace file: No such file or directory (2)
W/cpu_tweaker( 1147): Loading exception handler onto file /mnt/sdcard/st_crash_reports.txt
D/cpu_tweaker( 1147): pmw_booter got intent: android.intent.action.BOOT_COMPLETED
D/dalvikvm(  419): GC_CONCURRENT freed 949K, 66% free 5762K/16888K, paused 6ms+4ms, total 123ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 80ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 32ms
I/ActivityManager(  419): Start proc com.android.exchange for broadcast com.android.exchange/.service.ExchangeBroadcastReceiver: pid=1169 uid=10007 gids={50007, 3003, 1015, 1023, 1028}
D/GCM     (  947): GcmService start Intent { act=com.google.android.gms.INITIALIZE flg=0x10 pkg=com.google.android.gms cmp=com.google.android.gms/.gcm.GcmService } com.google.android.gms.INITIALIZE
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 92ms
W/Trace   ( 1169): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Start proc de.draisberghof.pppwidget for broadcast de.draisberghof.pppwidget/.PPPWidgetProvider: pid=1192 uid=10016 gids={50016, 1015, 1023, 1028}
W/Trace   ( 1192): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Start proc com.android.cellbroadcastreceiver for broadcast com.android.cellbroadcastreceiver/.CellBroadcastReceiver: pid=1206 uid=10018 gids={50018, 1028}
W/Trace   ( 1206): error opening trace file: No such file or directory (2)
W/Resources( 1206): Converting to string: TypedValue{t=0x10/d=0x4 a=-1}
D/CellBroadcastReceiver( 1206): onReceive Intent { act=android.intent.action.BOOT_COMPLETED flg=0x10 cmp=com.android.cellbroadcastreceiver/.CellBroadcastReceiver (has extras) }
D/CellBroadcastReceiver( 1206): Registering for ServiceState updates
D/CellBroadcastReceiver( 1206): Service state changed! 1 Full: 1 home null null null  Unknown CSS not supported -1 -1 RoamInd=-1 DefRoamInd=-1 EmergOnly=false
I/ActivityManager(  419): Start proc com.google.android.configupdater for broadcast com.google.android.configupdater/.CertPinUpdateRequestReceiver: pid=1223 uid=10024 gids={50024, 3003, 2001, 1028}
D/ExchangeService( 1169): !!! EAS ExchangeService, onStartCommand, startingUp = false, running = false
W/Trace   ( 1223): error opening trace file: No such file or directory (2)
E/UpdateRequestReceiver( 1223): ignoring update request
I/ActivityManager(  419): Start proc com.android.email for service com.android.email/.service.AccountService: pid=1244 uid=10025 gids={50025, 3003, 1015, 1023, 1028}
E/Lights  (  419): write_int failed to open sys/class/leds/rk29_key_led/brightness
I/PowerManagerService(  419): Boot animation finished.
W/Trace   ( 1244): error opening trace file: No such file or directory (2)
I/GCoreUlr(  824): Ensuring that reporting is stopped because of reasons: (no Google accounts)
D/GCoreFlp(  824): Unknown pending intent to remove.
I/GCoreUlr(  824): Unbound from all location providers
E/dalvikvm(  824): Could not find class 'android.app.AppOpsManager', referenced from method axp.a
W/dalvikvm(  824): VFY: unable to resolve check-cast 386 (Landroid/app/AppOpsManager;) in Laxp;
D/dalvikvm(  824): VFY: replacing opcode 0x1f at 0x000e
D/GeofencerStateMachine(  824): Creating GeofencerStateMachine
W/dalvikvm(  824): Unable to resolve superclass of Lfcn; (2364)
W/dalvikvm(  824): Link of class 'Lfcn;' failed
W/dalvikvm(  824): VFY: unable to find class referenced in signature (Lfcn;)
I/dalvikvm(  824): Could not find method fcn.a, referenced from method fbw.<init>
W/dalvikvm(  824): VFY: unable to resolve static method 33665: Lfcn;.a ()Lfcn;
D/dalvikvm(  824): VFY: replacing opcode 0x71 at 0x001c
I/Email   ( 1244): Onetime initialization: 1
D/Eas Debug( 1169): Logging:
I/Email   ( 1244): Onetime initialization: 2
I/EventLogService(  947): Aggregate from 0 (log), 0 (data)
I/dalvikvm(  824): Could not find method fcn.b, referenced from method fbw.g
W/dalvikvm(  824): VFY: unable to resolve virtual method 33666: Lfcn;.b ()Lfbs;
D/dalvikvm(  824): VFY: replacing opcode 0x6e at 0x000d
D/ExchangeService( 1169): Received deviceId from Email app: android1414443959421
D/ExchangeService( 1169): Reconciling accounts...
D/EmailProvider( 1244): Creating EmailProvider database
W/DropBoxManagerService(  419): Dropping: event_log (34 > 0 bytes)
D/ExchangeService( 1169): !!! EAS ExchangeService, onStartCommand, startingUp = true, running = false
V/GeofencerHelper(  824): Initializing geofence's system cache.
E/GeofenceStateCache(  824): Unable to load state, all registered geofences are lost.
W/DropBoxManagerService(  419): Dropping: event_data (51 > 0 bytes)
I/GeofencerStateMachine(  824): Network location disabled.
D/bt_vendor( 1092): op for 3
I/bt_userial_vendor( 1092): userial vendor open: opening /dev/ttyS0
I/bt_userial_vendor( 1092): device fd = 57 open
D/bt_vendor( 1092): op for 1
I/GKI_LINUX( 1092): gki_task_entry: gki_task_entry task_id=0 [BTU] starting
I/ActivityManager(  419): Start proc com.google.android.onetimeinitializer for broadcast com.google.android.onetimeinitializer/.OneTimeInitializerReceiver: pid=1305 uid=10030 gids={50030, 1028}
W/Trace   ( 1305): error opening trace file: No such file or directory (2)
I/MediaProvider(  846): Upgrading media database from version 0 to 511, which will destroy all old data
V/OneTimeInitializerReceiver( 1305): OneTimeInitializerReceiver.onReceive
V/OneTimeService( 1305): OneTimeService.onHandleIntent
V/OneTimeService( 1305): Updating shortcuts
I/ActivityManager(  419): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=1323 uid=10032 gids={50032, 1028, 3003}
E/ActivityThread( 1305): Failed to find provider info for com.android.launcher2.settings
I/PeopleSync( 1061): First sync
I/dalvikvm( 1061): Could not find method android.os.UserManager.getApplicationRestrictions, referenced from method aod.b
W/dalvikvm( 1061): VFY: unable to resolve virtual method 3258: Landroid/os/UserManager;.getApplicationRestrictions (Ljava/lang/String;)Landroid/os/Bundle;
D/dalvikvm( 1061): VFY: replacing opcode 0x6e at 0x0012
I/dalvikvm( 1061): Could not find method android.accounts.AccountManager.getAccountsByTypeForPackage, referenced from method aod.c
W/dalvikvm( 1061): VFY: unable to resolve virtual method 1804: Landroid/accounts/AccountManager;.getAccountsByTypeForPackage (Ljava/lang/String;Ljava/lang/String;)[Landroid/accounts/Account;
D/dalvikvm( 1061): VFY: replacing opcode 0x6e at 0x000c
I/dalvikvm( 1061): Could not find method android.os.UserManager.getUserRestrictions, referenced from method aod.d
W/dalvikvm( 1061): VFY: unable to resolve virtual method 3260: Landroid/os/UserManager;.getUserRestrictions ()Landroid/os/Bundle;
D/dalvikvm( 1061): VFY: replacing opcode 0x6e at 0x000f
W/Trace   ( 1323): error opening trace file: No such file or directory (2)
V/AlarmClock( 1323): No next alarm
W/BackupManagerService(  419): dataChanged but no participant pkg='com.android.providers.settings' uid=10032
V/AlarmClock( 1323): AlarmInitReceiver - Reset timers and clear stopwatch data
V/AlarmClock( 1323): AlarmInitReceiver - resetting volume button default
V/AlarmClock( 1323): AlarmInitReceiver finished
I/ActivityManager(  419): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=1341 uid=10036 gids={50036, 3003, 1015, 1023, 1028}
D/dalvikvm(   96): GC_EXPLICIT freed 38K, 70% free 2349K/7696K, paused 2ms+1ms, total 18ms
W/Trace   ( 1341): error opening trace file: No such file or directory (2)
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+1ms, total 16ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 2ms+2ms, total 16ms
I/CalendarDatabaseHelper( 1341): Bootstrapping database
I/LocationInitializer( 1061): Initiliazing location.
I/PeopleDatabaseHelper( 1061): cleanUpNonGplusAccounts done.
I/PeopleSearchIndexManage( 1061): ICU version changed from unknown to 4.8.1.1
I/ActivityManager(  419): Start proc org.adaway for broadcast org.adaway/.service.BootReceiver: pid=1363 uid=10037 gids={50037, 3003, 1015, 1023, 1028}
V/GA-SERVICE( 1061): Thread[IntentService[InitializeIntentService],5,main]: Update service enabled state to: 2
I/PeopleSearchIndexManage( 1061): Rebuilding index...
D/dalvikvm(  419): GC_CONCURRENT freed 916K, 67% free 5641K/16888K, paused 4ms+3ms, total 80ms
I/ActivityManager(  419): Start proc com.google.android.gms.ui for service com.google.android.gms/.auth.authzen.GcmReceiverService: pid=1381 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
W/Trace   ( 1363): error opening trace file: No such file or directory (2)
E/MDM     ( 1061): Missing android_id
I/PeopleSearchIndexManage( 1061): Rebuilding index done.
W/Trace   ( 1381): error opening trace file: No such file or directory (2)
D/EmailProvider( 1244): Creating EmailProviderBody database
E/ProtoRequest( 1061): want to send authenticated request, but no Google account on device
V/AuthZen ( 1381): Received a GCM message.
I/ActivityManager(  419): Start proc com.google.android.gm for broadcast com.google.android.gm/.GoogleMailDeviceStartupReceiver: pid=1407 uid=10042 gids={50042, 3003, 1015, 1023, 1028}
D/dalvikvm(  947): GC_EXPLICIT freed 2525K, 66% free 2640K/7696K, paused 1ms+4ms, total 31ms
E/SQLiteLog( 1244): (1) no such table: Account
W/EmailProvider( 1244): Exception cleaning EmailProvider.dbandroid.database.sqlite.SQLiteException: no such table: Account (code 1): , while compiling: delete from Account WHERE displayName ISNULL;
W/Trace   ( 1407): error opening trace file: No such file or directory (2)
I/dalvikvm( 1407): Could not find method android.os.Trace.endSection, referenced from method com.android.mail.utils.R.AP
W/dalvikvm( 1407): VFY: unable to resolve static method 1173: Landroid/os/Trace;.endSection ()V
D/dalvikvm( 1407): VFY: replacing opcode 0x71 at 0x0006
I/dalvikvm( 1407): Could not find method android.app.ActivityManager.isLowRamDevice, referenced from method com.android.mail.utils.R.aP
W/dalvikvm( 1407): VFY: unable to resolve virtual method 133: Landroid/app/ActivityManager;.isLowRamDevice ()Z
D/dalvikvm( 1407): VFY: replacing opcode 0x6e at 0x000e
I/dalvikvm( 1407): Could not find method android.os.Trace.beginSection, referenced from method com.android.mail.utils.R.eC
W/dalvikvm( 1407): VFY: unable to resolve static method 1172: Landroid/os/Trace;.beginSection (Ljava/lang/String;)V
I/dalvikvm( 1407): Could not find method com.android.mail.browse.j.getNotificationUri, referenced from method com.android.mail.browse.k.getNotificationUri
W/dalvikvm( 1407): VFY: unable to resolve virtual method 7061: Lcom/android/mail/browse/j;.getNotificationUri ()Landroid/net/Uri;
D/dalvikvm( 1407): VFY: replacing opcode 0x6e at 0x0008
W/GAV2    ( 1407): Thread[main,5,main]: Need to call initialize() and be in fallback mode to start dispatch.
D/EmailProvider( 1244): fromDatabase accounts: 0
D/EmailProvider( 1244): ending toDatabase transaction; copyCount = 0
D/EmailProvider( 1244): ending fromDatabase transaction; copyCount = 0
I/RlzPingService( 1016): Setting next ping for 1415048760342
I/ActivityManager(  419): Start proc com.google.android.gsf.login for service com.google.android.gsf.login/com.google.android.gsf.loginservice.GoogleLoginService: pid=1431 uid=10000 gids={50000, 3003, 1007, 1028, 1015, 1023, 1006, 2001, 3006}
I/ActivityManager(  419): Start proc org.cyanogenmod.voiceplus for broadcast org.cyanogenmod.voiceplus/.PackageChangeReceiver: pid=1445 uid=10043 gids={50043, 3003, 1028}
W/Trace   ( 1431): error opening trace file: No such file or directory (2)
W/Trace   ( 1445): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Force stopping package org.cyanogenmod.voiceplus appid=10043 user=0
I/ActivityManager(  419): Killing proc 1445:org.cyanogenmod.voiceplus/u0a10043: force stop org.cyanogenmod.voiceplus
I/ActivityManager(  419): Start proc com.zdvdev.sef for broadcast com.zdvdev.sef/.BootReceiver: pid=1469 uid=10045 gids={50045, 3003, 1028}
D/dalvikvm(  419): GC_CONCURRENT freed 726K, 67% free 5741K/16888K, paused 4ms+4ms, total 74ms
W/Trace   ( 1469): error opening trace file: No such file or directory (2)
D/CMStats (  789): Set alarm for first sync.
D/CMStats (  789): Next sync attempt in : 23 hours
E/Icing   ( 1061): There is no storage capacity, icing will not index
I/BootReceiver(  789): Restore disabled by user preference.
I/ContactDirectoryManager(  841): deleted 0 stale rows which don't have any relevant directory
E/dalvikvm( 1061): Could not find class 'android.content.RestrictionEntry', referenced from method com.google.android.gms.app.receiver.GetRestrictionsReceiver.onReceive
W/dalvikvm( 1061): VFY: unable to resolve new-instance 435 (Landroid/content/RestrictionEntry;) in Lcom/google/android/gms/app/receiver/GetRestrictionsReceiver;
D/dalvikvm( 1061): VFY: replacing opcode 0x22 at 0x0033
D/dalvikvm( 1061): DexOpt: unable to opt direct call 0x08ec at 0x39 in Lcom/google/android/gms/app/receiver/GetRestrictionsReceiver;.onReceive
I/ContactDirectoryManager(  841): Discovered 0 contact directories in 521ms
V/AuthZen ( 1381): Received broadcast action: android.intent.action.BOOT_COMPLETED
I/ContactsDatabaseHelper(  841): Switching to locale de_DE
D/GCM     (  947): GcmService start Intent { act=android.intent.action.BOOT_COMPLETED flg=0x10 cmp=com.google.android.gms/.gcm.GcmService (has extras) } android.intent.action.BOOT_COMPLETED
W/ActivityManager(  419): Unable to start service Intent { cmp=com.android.email/.service.AttachmentDownloadService } U=0: not found
I/ActivityManager(  419): Start proc com.google.android.googlequicksearchbox:search for broadcast com.google.android.googlequicksearchbox/com.google.android.search.core.StartUpReceiver: pid=1522 uid=10056 gids={50056, 3003, 1028, 3002, 1015, 1023}
W/Trace   ( 1522): error opening trace file: No such file or directory (2)
D/dalvikvm( 1061): No JNI_OnLoad found in /system/lib/libAppDataSearch.so 0x4117cd70, skipping init
D/Icing   ( 1061): Upgrading storage to version to 0
W/dalvikvm( 1522): VFY: unable to resolve static field 159 (CONTENT_URI) in Landroid/provider/ContactsContract$DeletedContacts;
D/dalvikvm( 1522): VFY: replacing opcode 0x62 at 0x001a
I/dalvikvm( 1522): Could not find method android.view.View.isInLayout, referenced from method com.google.android.shared.util.Util.assertNotInLayout
W/dalvikvm( 1522): VFY: unable to resolve virtual method 3645: Landroid/view/View;.isInLayout ()Z
D/dalvikvm( 1522): VFY: replacing opcode 0x6e at 0x0006
I/dalvikvm( 1522): Could not find method android.app.ActivityManager.isLowRamDevice, referenced from method com.google.android.shared.util.Util.isLowRamDevice
W/dalvikvm( 1522): VFY: unable to resolve virtual method 201: Landroid/app/ActivityManager;.isLowRamDevice ()Z
D/dalvikvm( 1522): VFY: replacing opcode 0x6e at 0x000f
D/Icing   ( 1061): Upgrading storage to version to 1
D/Icing   ( 1061): Upgrading storage to version to 2
D/Icing   ( 1061): Upgrading storage to version to 3
D/Icing   ( 1061): Upgrading storage to version to 4
D/Icing   ( 1061): Upgrading storage to version to 5
D/Icing   ( 1061): Upgrading storage to version to 6
D/Icing   ( 1061): Upgrading storage to version to 7
D/Icing   ( 1061): Upgrading storage to version to 8
D/Icing   ( 1061): Upgrading storage to version to 9
D/Icing   ( 1061): Upgrading storage to version to 10
D/Icing   ( 1061): Upgrading storage to version to 11
D/Icing   ( 1061): Upgrading storage to version to 12
D/Icing   ( 1061): Upgrading storage to version to 13
D/Icing   ( 1061): Upgrading storage to version to 14
D/Icing   ( 1061): Upgrading storage to version to 15
D/Icing   ( 1061): Upgrading storage to version to 16
D/Icing   ( 1061): Upgrading storage to version to 17
D/Icing   ( 1061): Upgrading storage to version to 18
D/Icing   ( 1061): Upgrading storage to version to 19
E/Icing   ( 1061): Opening file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.h for write failed: No such file or directory
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.h
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.n
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.x
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.s
E/Icing   ( 1061): Couldn't create a URI mapping store
E/Icing   ( 1061): Couldn't upgrade native from version -1 to 26
E/Icing   ( 1061): Clearing storage
I/Search.SharedPreferencesProto( 1522): load shared preferences: file not found
I/dalvikvm( 1522): Could not find method android.app.AlarmManager.setExact, referenced from method com.google.android.search.core.util.AlarmHelper.setExact
W/dalvikvm( 1522): VFY: unable to resolve virtual method 208: Landroid/app/AlarmManager;.setExact (IJLandroid/app/PendingIntent;)V
D/dalvikvm( 1522): VFY: replacing opcode 0x6e at 0x0008
I/CalendarProvider2( 1341): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 1341): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
I/Email   ( 1244): Onetime initialization: completed.
I/ActivityManager(  419): Start proc com.google.android.voicesearch for content provider com.google.android.voicesearch/.VoiceSearchSettingsProvider: pid=1543 uid=10049 gids={50049, 1028}
W/Trace   ( 1543): error opening trace file: No such file or directory (2)
E/BluetoothManagerService(  419): waitForOnOff time out
D/BluetoothManagerService(  419): Stored Bluetoothaddress: 42:2D:B9:74:DD:80
I/BluetoothAdapterState( 1092): CURRENT_STATE=PENDING: Deferring request USER_TURN_OFF
D/Icing   ( 1061): Clearing docstore and index
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.index
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.display.h
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.display.n
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.display.x
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.display.s
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.display.deleted
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.lexicon.h
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.lexicon.n
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.lexicon.x
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.lexicon.s
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.lexicon.deleted
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lite.hb
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lexicon.h
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lexicon.n
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lexicon.x
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lexicon.s
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.lexicon.deleted
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.display.h
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.display.n
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.display.x
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.display.s
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/idx.display.deleted
D/Icing   ( 1061): Clearing /data/data/com.google.android.gms/files/AppDataSearch/main/cur from uninitialized state
D/Icing   ( 1061): Removing all document store files for /data/data/com.google.android.gms/files/AppDataSearch/main/cur
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.docids
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.perdocdata
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.cscoring
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.docs
D/Icing   ( 1061): Deleting file /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.urifps.deleted
D/Icing   ( 1061): Init last flush num docs 0 last docstore size 0
D/Icing   ( 1061): Docid map file has no data, nothing to scan
D/Icing   ( 1061): File /data/data/com.google.android.gms/files/AppDataSearch/main/cur/ds.perdocdata contains 0 records of size 6
V/Icing   ( 1061): Found fdatasync
D/Icing   ( 1061): Init docstore ok num docs 0 bytes 0
V/Icing   ( 1061): Creating new hit buffer
V/Icing   ( 1061): Lite index crc computed in 0.048ms
V/Icing   ( 1061): Lite index created ok
V/Icing   ( 1061): Warming lite-index took 0.010ms
V/Icing   ( 1061): Warming lexicon took 0.003ms
V/Icing   ( 1061): Warming display mappings took 0.003ms
D/Icing   ( 1061): Init index ok num docs 0
D/Icing   ( 1061): Init done
E/SQLiteLog(  846): (1) no such table: files
I/ContactsDatabaseHelper(  841): Locale change completed in 565ms
V/AuthZen ( 1381): Authzen is disabled
I/ActivityManager(  419): No longer want com.google.android.inputmethod.latin.dictionarypack (pid 908): empty #17
I/ActivityManager(  419): No longer want ccc71.st.cpu (pid 1147): empty #17
W/ProcessStats(  419): Skipping unknown process pid 1147
E/WVMExtractor(   98): Failed to open libwvm.so
I/ContactsDatabaseHelper(  841): Locale change completed in 99ms
D/dalvikvm(  419): GC_CONCURRENT freed 718K, 66% free 5798K/16888K, paused 17ms+4ms, total 81ms
E/MDM     ( 1061): Unable to send response
I/ContactsFTS(  841): Rebuild contact search index in 76ms, 0 contacts
I/ContactsProvider(  841): Upgrading aggregation algorithm
I/ContactAggregator(  841): Marked all visible contacts for aggregation: 0 raw contacts, 2 ms
I/ContactsProvider(  841): Aggregation algorithm upgraded for 0 raw contacts in 14ms
D/HandsFreeIntentActivity( 1522): shouldBeEnabled: locale=de-DE
D/HandsFreeIntentActivity( 1522): doesSystemAppExist: android.intent.action.VOICE_COMMAND
D/HandsFreeIntentActivity( 1522): No system app found
D/HandsFreeIntentActivity( 1522): Voice dialer enabled state: true
I/ActivityManager(  419): No longer want de.draisberghof.pppwidget (pid 1192): empty #17
I/ActivityManager(  419): No longer want com.google.android.configupdater (pid 1223): empty #17
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: FORCE_ALL, C: FORCE_ALL
V/GelStubAppWatcher( 1522): onReceive: android.intent.action.BOOT_COMPLETED
W/Search.ConcurrentUtils( 1522): Executor queue length is now 5. Perhaps some tasks are too long, or the pool is too small. [IntentService[Velvet.VelvetBackgroundTasksImpl]]
I/ActivityManager(  419): Start proc com.android.gallery3d for broadcast com.android.gallery3d/com.android.camera.DisableCameraReceiver: pid=1577 uid=10057 gids={50057, 1006, 3003, 1015, 1023, 1028}
W/Trace   ( 1577): error opening trace file: No such file or directory (2)
D/CameraHal_Module(   98): camera_get_camera_info(770): camera_0 facing(0), orientation(0)
I/DisableCameraReceiver( 1577): back camera found: 0
I/Search.GservicesUpdateTask( 1522): Updating Gservices keys
I/ActivityManager(  419): Start proc com.cyanogenmod.updater for broadcast com.cyanogenmod.updater/.receiver.UpdateCheckReceiver: pid=1597 uid=10060 gids={50060, 3003, 1015, 1023, 2001, 1028}
W/Trace   ( 1597): error opening trace file: No such file or directory (2)
I/UpdateCheckReceiver( 1597): Scheduling future, repeating update checks.
I/Search.RefreshSearchDomainAndCookiesTask( 1522): refreshing search domain
D/dalvikvm(   96): GC_EXPLICIT freed 38K, 70% free 2349K/7696K, paused 1ms+7ms, total 22ms
I/ActivityManager(  419): Start proc com.cyanogenmod.lockclock for broadcast com.cyanogenmod.lockclock/.ClockWidgetProvider: pid=1616 uid=10065 gids={50065, 3003, 1028}
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+2ms, total 17ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+1ms, total 15ms
W/Search.SearchUrlHelper( 1522): Auth token not ready, no auth header set.
I/UpdateCheckService( 1597): Could not check for updates. Not connected to the network.
I/ActivityManager(  419): No longer want com.android.cellbroadcastreceiver (pid 1206): empty #17
D/UserHistoryDictIOUtils(  750): end writing
D/dalvikvm(  419): GC_CONCURRENT freed 769K, 66% free 5888K/16888K, paused 12ms+4ms, total 70ms
I/ActivityManager(  419): Start proc com.google.android.inputmethod.latin.dictionarypack for content provider com.google.android.inputmethod.latin.dictionarypack/.DictionaryProvider: pid=1636 uid=10033 gids={50033, 3003, 1015, 1023, 1028}
W/Trace   ( 1616): error opening trace file: No such file or directory (2)
W/Trace   ( 1636): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): No longer want com.google.android.onetimeinitializer (pid 1305): empty #17
D/WeatherUpdateService( 1616): Service started, but shouldn't update ... stopping
I/ActivityManager(  419): No longer want com.android.deskclock (pid 1323): empty #17
W/GStaticConfiguration( 1522): No valid gstatic url found.
W/Search.LoginHelper( 1522): InterruptedException while waiting for token.
I/ActivityManager(  419): Start proc org.cyanogenmod.voiceplus for broadcast org.cyanogenmod.voiceplus/.PackageChangeReceiver: pid=1669 uid=10043 gids={50043, 3003, 1028}
W/Trace   ( 1669): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Killing proc 1669:org.cyanogenmod.voiceplus/u0a10043: force stop org.cyanogenmod.voiceplus
W/Search.RefreshSearchDomainAndCookiesTask( 1522): Search parameters fetch failed: java.net.UnknownHostException: Unable to resolve host "www.google.com": No address associated with hostname
W/Search.RefreshSearchDomainAndCookiesTask( 1522): refresh interrupted
D/SystemBroadcastService( 1061): Received broadcast action=android.intent.action.PACKAGE_CHANGED and uri=
E/MetadataRetrieverClient(   98): failed to extract an album art
V/GelStubAppWatcher( 1522): onReceive: android.intent.action.PACKAGE_CHANGED
I/ActivityManager(  419): Start proc com.android.vending for broadcast com.android.vending/com.google.android.finsky.widget.consumption.NowPlayingWidgetProvider: pid=1692 uid=10058 gids={50058, 3003, 1015, 1023, 1028}
W/BackupManagerService(  419): dataChanged but no participant pkg='com.android.providers.settings' uid=10002
W/Trace   ( 1692): error opening trace file: No such file or directory (2)
D/Finsky  ( 1692): [1] FinskyApp.onCreate: Initializing network with DFE https://android.clients.google.com/fdfe/
D/Finsky  ( 1692): [1] DailyHygiene.goMakeHygieneIfDirty: Dirty, need more hygiene.
I/DownloadManager(  846): Initiating request for download 2
W/Settings( 1692): Setting download_manager_max_bytes_over_mobile has moved from android.provider.Settings.Secure to android.provider.Settings.Global.
W/Settings( 1692): Setting download_manager_recommended_max_bytes_over_mobile has moved from android.provider.Settings.Secure to android.provider.Settings.Global.
D/dalvikvm(  419): GC_CONCURRENT freed 853K, 66% free 5861K/16888K, paused 5ms+4ms, total 72ms
W/Finsky  ( 1692): [1] FinskyApp.getCurrentAccount: No account configured on this device.
W/Finsky  ( 1692): [1] FinskyApp.getDfeApi: No account configured on this device.
W/DownloadManager(  846): Aborting request for download 2: no network connection available
I/ActivityManager(  419): Start proc com.android.calendar for broadcast com.android.calendar/.alerts.AlertReceiver: pid=1726 uid=10029 gids={50029, 3003, 1028}
I/ActivityManager(  419): No longer want org.adaway (pid 1363): empty #17
W/Trace   ( 1726): error opening trace file: No such file or directory (2)
D/AlertReceiver( 1726): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertUtils( 1726): Flushing old alerts from shared prefs table
D/AlertService( 1726): 0 Action = android.intent.action.PROVIDER_CHANGED
D/AlertService( 1726): Beginning updateAlertNotification
D/Finsky  ( 1692): [1] GmsCoreHelper.cleanupNlp: result=false type=4
D/Finsky  ( 1692): [1] RestoreTracker.stopServiceIfDone: Restore complete with 0 success and 0 failed.
W/Uploader( 1061): No account for auth token provided
I/ActivityManager(  419): Start proc org.cyanogenmod.voiceplus for broadcast org.cyanogenmod.voiceplus/.PackageChangeReceiver: pid=1756 uid=10043 gids={50043, 3003, 1028}
D/AlertService( 1726): No fired or scheduled alerts
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: org.cyanogenmod.voiceplus, C: MAYBE
W/Trace   ( 1756): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): Killing proc 1756:org.cyanogenmod.voiceplus/u0a10043: force stop org.cyanogenmod.voiceplus
I/ActivityManager(  419): No longer want com.android.email (pid 1244): empty #17
I/ActivityManager(  419): No longer want com.android.exchange (pid 1169): empty #18
D/Uploader( 1061): Network request failed class java.net.UnknownHostException(Unable to resolve host "play.googleapis.com": No address associated with hostname)
I/ActivityManager(  419): Start proc org.cyanogenmod.voiceplus for broadcast org.cyanogenmod.voiceplus/.PackageChangeReceiver: pid=1775 uid=10043 gids={50043, 3003, 1028}
W/Trace   ( 1775): error opening trace file: No such file or directory (2)
I/Icing   ( 1061): Not enough disk space for indexing trimmable
W/ActivityManager(  419): Permission denied: checkComponentPermission() owningUid=10056
I/ActivityManager(  419): No longer want com.google.android.gsf.login (pid 1431): empty #17
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (3822 > 0 bytes)
D/dalvikvm( 1061): GC_EXPLICIT freed 2144K, 63% free 2879K/7696K, paused 2ms+4ms, total 43ms
D/dalvikvm(  419): GC_CONCURRENT freed 744K, 66% free 5872K/16888K, paused 3ms+5ms, total 52ms
D/BluetoothManagerService(  419): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@414ee8c0 mBinding = false
D/BluetoothManagerService(  419): Sending unbind request.
D/BluetoothAdapterService( 1092): Cleaning up adapter native....
I/GKI_LINUX( 1092): gki_task_entry: gki_task task_id=1 [BTIF] terminating
I/GKI_LINUX( 1092): GKI_exit_task: GKI_exit_task 1 done
I/GKI_LINUX( 1092): GKI_destroy_task: GKI_shutdown(): task [BTIF] terminated
I/GKI_LINUX( 1092): gki_task_entry: gki_task task_id=2 [A2DP-MEDIA] terminating
I/GKI_LINUX( 1092): GKI_exit_task: GKI_exit_task 2 done
I/        ( 1092): BTE_InitTraceLevels -- TRC_HCI
I/        ( 1092): BTE_InitTraceLevels -- TRC_L2CAP
I/        ( 1092): BTE_InitTraceLevels -- TRC_RFCOMM
I/        ( 1092): BTE_InitTraceLevels -- TRC_AVDT
I/        ( 1092): BTE_InitTraceLevels -- TRC_AVRC
I/        ( 1092): BTE_InitTraceLevels -- TRC_A2D
I/        ( 1092): BTE_InitTraceLevels -- TRC_BNEP
I/        ( 1092): BTE_InitTraceLevels -- TRC_BTM
I/        ( 1092): BTE_InitTraceLevels -- TRC_PAN
I/        ( 1092): BTE_InitTraceLevels -- TRC_SDP
I/        ( 1092): BTE_InitTraceLevels -- TRC_BTAPP
I/        ( 1092): BTE_InitTraceLevels -- TRC_BTIF
I/dalvikvm(  419): Jit: resizing JitTable from 4096 to 8192
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.google.android.partnersetup, C: MAYBE
D/dalvikvm(  419): GC_CONCURRENT freed 802K, 65% free 5953K/16888K, paused 9ms+6ms, total 79ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 35ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 43ms
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.google.android.gsf, C: MAYBE
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.android.provision, C: MAYBE
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.google.android.googlequicksearchbox, C: MAYBE
W/GAV2    ( 1407): Thread[GAThread,5,main]: Service unavailable (code=1), will retry.
W/ActivityManager(  419): Unable to start service Intent { act=com.google.android.gms.analytics.service.START cmp=com.google.android.gms/.analytics.service.AnalyticsService (has extras) } U=0: not found
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.android.vending, C: MAYBE
I/GAV2    ( 1407): Thread[GAThread,5,main]: No campaign data found.
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.android.gallery3d, C: MAYBE
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.android.settings, C: MAYBE
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.android.email, C: MAYBE
D/dalvikvm(  419): GC_CONCURRENT freed 842K, 65% free 5938K/16888K, paused 4ms+6ms, total 80ms
D/dalvikvm(  947): GC_EXPLICIT freed 329K, 66% free 2655K/7696K, paused 3ms+2ms, total 25ms
D/dalvikvm( 1061): GC_CONCURRENT freed 459K, 64% free 2808K/7696K, paused 3ms+7ms, total 41ms
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.google.android.gms, C: MAYBE
I/Icing.InternalIcingCorporaProvider( 1522): Updating corpora: A: com.google.android.gm, C: MAYBE
D/dalvikvm( 1522): GC_CONCURRENT freed 3924K, 56% free 3418K/7696K, paused 3ms+3ms, total 53ms
D/dalvikvm( 1522): GC_CONCURRENT freed 457K, 57% free 3360K/7696K, paused 8ms+2ms, total 32ms
D/dalvikvm(  419): GC_EXPLICIT freed 651K, 66% free 5871K/16888K, paused 3ms+4ms, total 52ms
D/dalvikvm(  846): GC_EXPLICIT freed 992K, 61% free 3027K/7696K, paused 2ms+4ms, total 28ms
D/dalvikvm(  846): GC_CONCURRENT freed 574K, 63% free 2871K/7696K, paused 1ms+1ms, total 17ms
D/dalvikvm(  846): GC_CONCURRENT freed 437K, 63% free 2851K/7696K, paused 1ms+1ms, total 15ms
D/dalvikvm(  846): GC_CONCURRENT freed 422K, 63% free 2851K/7696K, paused 2ms+2ms, total 17ms
D/dalvikvm(  846): GC_CONCURRENT freed 440K, 64% free 2837K/7696K, paused 1ms+1ms, total 15ms
W/GAV2    ( 1407): Thread[Service Reconnect,5,main]: Service unavailable (code=1), using local store.
D/dalvikvm(  846): GC_CONCURRENT freed 623K, 67% free 2612K/7696K, paused 1ms+6ms, total 21ms
W/ActivityManager(  419): Timeout executing service: ServiceRecord{4138fd50 u0 com.android.bluetooth/.btservice.AdapterService}
I/Process (  419): Sending signal. PID: 1092 SIG: 3
I/dalvikvm( 1092): threadid=3: reacting to signal 3
I/dalvikvm( 1092): Wrote stack traces to '/data/anr/traces.txt'
I/Process (  419): Sending signal. PID: 419 SIG: 3
I/dalvikvm(  419): threadid=3: reacting to signal 3
E/SensorsHal(  419): poll() failed (Interrupted system call)
I/dalvikvm(  419): Wrote stack traces to '/data/anr/traces.txt'
I/Process (  419): Sending signal. PID: 770 SIG: 3
I/dalvikvm(  770): threadid=3: reacting to signal 3
I/dalvikvm(  770): Wrote stack traces to '/data/anr/traces.txt'
I/Process (  419): Sending signal. PID: 685 SIG: 3
I/dalvikvm(  685): threadid=3: reacting to signal 3
I/dalvikvm(  685): Wrote stack traces to '/data/anr/traces.txt'
I/Process (  419): Sending signal. PID: 775 SIG: 3
I/dalvikvm(  775): threadid=3: reacting to signal 3
I/dalvikvm(  775): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm(  419): GC_CONCURRENT freed 724K, 65% free 6031K/16888K, paused 2ms+3ms, total 47ms
D/dalvikvm(  419): GC_EXPLICIT freed 226K, 64% free 6087K/16888K, paused 2ms+4ms, total 52ms
E/ActivityManager(  419): ANR in com.android.bluetooth
E/ActivityManager(  419): Reason: Executing service com.android.bluetooth/.btservice.AdapterService
E/ActivityManager(  419): Load: 1.03 / 0.38 / 0.14
E/ActivityManager(  419): CPU usage from 12084ms to 0ms ago:
E/ActivityManager(  419):   9.6% 685/com.android.systemui: 6.4% user + 3.1% kernel / faults: 112 minor
E/ActivityManager(  419):   9.5% 9/ksoftirqd/1: 0% user + 9.5% kernel
E/ActivityManager(  419):   9.2% 95/surfaceflinger: 4.9% user + 4.3% kernel
E/ActivityManager(  419):   2.9% 419/system_server: 2.5% user + 0.4% kernel / faults: 29 minor
E/ActivityManager(  419):   1.4% 3/ksoftirqd/0: 0% user + 1.4% kernel
E/ActivityManager(  419):   1.1% 492/kworker/0:4: 0% user + 1.1% kernel
E/ActivityManager(  419):   0.6% 1092/com.android.bluetooth: 0.5% user + 0% kernel
E/ActivityManager(  419):   0.3% 5/kworker/u:0: 0% user + 0.3% kernel
E/ActivityManager(  419):   0.1% 26/kworker/u:1: 0% user + 0.1% kernel
E/ActivityManager(  419):   0.2% 460/kworker/u:3: 0% user + 0.2% kernel
E/ActivityManager(  419):   0.2% 1797/kworker/u:4: 0% user + 0.2% kernel
E/ActivityManager(  419):   0.1% 13/kconsole: 0% user + 0.1% kernel
E/ActivityManager(  419):   0.1% 208/kworker/1:2: 0.1% user + 0% kernel
E/ActivityManager(  419):   0.1% 846/android.process.media: 0.1% user + 0% kernel / faults: 61 minor
E/ActivityManager(  419):   0% 18/irq/58-rk30-adc: 0% user + 0% kernel
E/ActivityManager(  419):   0% 750/com.android.inputmethod.latin: 0% user + 0% kernel
E/ActivityManager(  419): 15% TOTAL: 6.1% user + 9.2% kernel + 0.4% softirq
E/ActivityManager(  419): CPU usage from 667ms to 1180ms later:
E/ActivityManager(  419):   5.4% 3/ksoftirqd/0: 0% user + 5.4% kernel
E/ActivityManager(  419):   7.4% 419/system_server: 1.8% user + 5.5% kernel
E/ActivityManager(  419):     5.5% 436/ActivityManager: 0% user + 5.5% kernel
E/ActivityManager(  419):   3.7% 95/surfaceflinger: 1.8% user + 1.8% kernel
E/ActivityManager(  419):     1.8% 174/SurfaceFlinger: 0% user + 1.8% kernel
E/ActivityManager(  419):     1.8% 371/EventThread: 1.8% user + 0% kernel
E/ActivityManager(  419):     1.8% 372/Binder_1: 0% user + 1.8% kernel
E/ActivityManager(  419):   3.7% 685/com.android.systemui: 3.7% user + 0% kernel / faults: 2 minor
E/ActivityManager(  419):     3.7% 685/ndroid.systemui: 1.8% user + 1.8% kernel
E/ActivityManager(  419):   1.9% 9/ksoftirqd/1: 0% user + 1.9% kernel
E/ActivityManager(  419):   1.6% 1797/kworker/u:4: 0% user + 1.6% kernel
E/ActivityManager(  419): 11% TOTAL: 2.9% user + 8.8% kernel
W/ActivityManager(  419): Killing ProcessRecord{41ca3920 1092:com.android.bluetooth/1002}: background ANR
D/BluetoothHeadset(  770): Proxy object disconnected
D/BluetoothHeadset(  419): Proxy object disconnected
D/BluetoothA2dp(  419): Proxy object disconnected
D/BluetoothInputDevice(  789): Proxy object disconnected
D/HidProfile(  789): Bluetooth service disconnected
D/BluetoothPan(  789): BluetoothPAN Proxy object disconnected
D/PanProfile(  789): Bluetooth service disconnected
I/ActivityManager(  419): Process com.android.bluetooth (pid 1092) has died.
W/ActivityManager(  419): Scheduling restart of crashed service com.android.bluetooth/.hfp.HeadsetService in 5000ms
W/ActivityManager(  419): Scheduling restart of crashed service com.android.bluetooth/.a2dp.A2dpService in 14999ms
W/ActivityManager(  419): Scheduling restart of crashed service com.android.bluetooth/.pan.PanService in 24999ms
W/ActivityManager(  419): Scheduling restart of crashed service com.android.bluetooth/.hdp.HealthService in 34999ms
W/ActivityManager(  419): Scheduling restart of crashed service com.android.bluetooth/.hid.HidService in 34999ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 339K, 62% free 6449K/16888K, paused 38ms, total 38ms
D/dalvikvm(  419): GC_CONCURRENT freed 1297K, 64% free 6180K/16888K, paused 3ms+3ms, total 37ms
W/DropBoxManagerService(  419): Dropping: system_app_anr (10 > 0 bytes)
I/ActivityManager(  419): Start proc com.android.bluetooth for service com.android.bluetooth/.hfp.HeadsetService: pid=1825 uid=1002 gids={41002, 3003, 3002, 3001, 1015, 1023, 3005, 1016, 3008, 1028}
W/Trace   ( 1825): error opening trace file: No such file or directory (2)
D/AdapterServiceConfig( 1825): Adding HeadsetService
D/AdapterServiceConfig( 1825): Adding A2dpService
D/AdapterServiceConfig( 1825): Adding HidService
D/AdapterServiceConfig( 1825): Adding HealthService
D/AdapterServiceConfig( 1825): Adding PanService
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@41c1ffb8:true
I/BluetoothPanServiceJni( 1825): classInitNative(L105): succeeds
I/BluetoothHidServiceJni( 1825): classInitNative: succeeds
D/AudioHardware(   98): AudioHardware pcm playback is exiting standby.
D/AudioHardware(   98): openPcmOut_l() mPcmOpenCnt: 0
D/alsa_pcm(   98): pcm_open(0x0003f000)
D/alsa_pcm(   98): pcm_open() period sz multiplier 16
D/alsa_pcm(   98): pcm_open() period cnt 6
D/alsa_pcm(   98): pcm_open() period_cnt 6 period_sz 1024 channels 2
D/PermissionCache(   95): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (165 us)
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x13000000 cmp=com.teslacoilsw.launcher/com.android.launcher2.Launcher} from pid 997
I/PackageManager(  419):   Action: "android.intent.action.MAIN"
I/PackageManager(  419):   Category: "android.intent.category.HOME"
I/PackageManager(  419):   Category: "android.intent.category.DEFAULT"
I/ActivityManager(  419): Start proc com.teslacoilsw.launcher for activity com.teslacoilsw.launcher/com.android.launcher2.Launcher: pid=1840 uid=10023 gids={50023, 3003, 1015, 1023, 1028}
I/PackageManager(  419): Adding preferred activity ComponentInfo{com.teslacoilsw.launcher/com.android.launcher2.Launcher} for user 0 :
W/Trace   ( 1840): error opening trace file: No such file or directory (2)
W/ActivityManager(  419): Duplicate finish request for ActivityRecord{411a02d8 u0 android/com.android.internal.app.ResolverActivity}
W/Resources( 1840): Converting to int: TypedValue{t=0x3/d=0x10 "2" a=-1}
W/Resources( 1840): Converting to int: TypedValue{t=0x3/d=0xf "1" a=-1}
W/Resources( 1840): Converting to string: TypedValue{t=0x10/d=0x3 a=-1}
D/ACRA    ( 1840): Set OnSharedPreferenceChangeListener.
V/Nova    ( 1840): onActivityCreated com.android.launcher2.Launcher@4124a870 LAND 4,3MB free of 7,5MB total with max 48,0MB
I/dalvikvm( 1840): Could not find method android.provider.Telephony$Sms.getDefaultSmsPackage, referenced from method o.Kn.M6
W/dalvikvm( 1840): VFY: unable to resolve static method 1135: Landroid/provider/Telephony$Sms;.getDefaultSmsPackage (Landroid/content/Context;)Ljava/lang/String;
D/dalvikvm( 1840): VFY: replacing opcode 0x71 at 0x0083
E/Crashlytics( 1840): Failed to retrieve settings from https://settings.crashlytics.com/spi/v2/platforms/android/apps/com.teslacoilsw.launcher/settings
D/dalvikvm(  685): GC_FOR_ALLOC freed 12180K, 50% free 3877K/7700K, paused 19ms, total 20ms
I/dalvikvm-heap(  685): Grow heap (frag case) to 12.326MB for 8192016-byte allocation
D/dalvikvm(  685): GC_CONCURRENT freed 5K, 25% free 11871K/15704K, paused 3ms+1ms, total 17ms
D/libEGL  ( 1840): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  ( 1840): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  ( 1840): loaded /system/lib/egl/libGLESv2_mali.so
D/OpenGLRenderer( 1840): Enabling debug mode 0
E/Nova.Workspace( 1840): The Hotseat screen must be >= 0 and < 1 (was 1); skipping child
E/Nova.Workspace( 1840): The Hotseat screen must be >= 0 and < 1 (was 2); skipping child
D/dalvikvm(  685): GC_FOR_ALLOC freed <1K, 25% free 11871K/15704K, paused 12ms, total 12ms
I/dalvikvm-heap(  685): Grow heap (frag case) to 17.989MB for 5943312-byte allocation
D/dalvikvm(  685): GC_CONCURRENT freed 0K, 18% free 17675K/21512K, paused 3ms+2ms, total 17ms
I/ActivityManager(  419): Displayed com.teslacoilsw.launcher/com.android.launcher2.Launcher: +707ms
I/ActivityManager(  419): No longer want com.zdvdev.sef (pid 1469): empty #17
I/ActivityManager(  419): Start proc com.tmobile.thememanager for content provider com.tmobile.thememanager/.provider.ThemesProvider: pid=1873 uid=1300 gids={41300, -1, 1028}
W/Trace   ( 1873): error opening trace file: No such file or directory (2)
I/ThemeManager( 1873): ThemesProvider out of sync: inserting com.thomassafca.theme.touchwiz.five.free/TouchWiz
I/ThemeManager( 1873): ThemesProvider out of sync: inserting com.tmobile.theme.HTC.EleganceX/HTC.EleganceX
D/dalvikvm(  419): GC_CONCURRENT freed 1032K, 65% free 6070K/16888K, paused 5ms+6ms, total 75ms
I/ThemeManager( 1873): VerifyInstalledThemesThread took 97 ms.
I/ActivityManager(  419): No longer want com.android.settings (pid 789): empty #17
I/ActivityManager(  419): No longer want com.google.android.gms.ui (pid 1381): empty #17
D/dalvikvm( 1840): GC_CONCURRENT freed 2981K, 44% free 4372K/7696K, paused 2ms+2ms, total 29ms
D/dalvikvm( 1840): GC_CONCURRENT freed 479K, 42% free 4471K/7696K, paused 2ms+2ms, total 17ms
D/dalvikvm( 1840): GC_CONCURRENT freed 378K, 39% free 4696K/7696K, paused 3ms+3ms, total 49ms
D/dalvikvm( 1840): GC_EXPLICIT freed 97K, 41% free 4608K/7696K, paused 3ms+2ms, total 40ms
D/dalvikvm( 1840): GC_CONCURRENT freed 393K, 37% free 4865K/7696K, paused 2ms+2ms, total 20ms
D/dalvikvm( 1840): WAIT_FOR_CONCURRENT_GC blocked 19ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 275K, 37% free 4868K/7696K, paused 15ms, total 15ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 5.831MB for 360016-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 392K, 36% free 5175K/8048K, paused 16ms, total 16ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 147K, 33% free 5404K/8048K, paused 20ms, total 20ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 6.163MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 180K, 33% free 5529K/8204K, paused 14ms, total 14ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 142K, 33% free 5559K/8204K, paused 14ms, total 14ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 6.323MB for 167952-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 12K, 32% free 5722K/8372K, paused 16ms, total 17ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 6.628MB for 321568-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 1K, 30% free 6102K/8688K, paused 26ms, total 26ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 6.843MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 1K, 30% free 6256K/8844K, paused 17ms, total 17ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 6.994MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 1K, 29% free 6411K/9000K, paused 19ms, total 19ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 7.145MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 572K, 34% free 6086K/9156K, paused 14ms, total 14ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 77K, 29% free 6521K/9156K, paused 26ms, total 26ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 7.488MB for 405424-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 14K, 27% free 7020K/9552K, paused 27ms, total 27ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 7.741MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 185K, 27% free 7140K/9708K, paused 19ms, total 19ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 513K, 30% free 6874K/9708K, paused 22ms, total 23ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 235K, 29% free 6966K/9708K, paused 16ms, total 16ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 7.687MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 22K, 27% free 7262K/9864K, paused 20ms, total 20ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 7.977MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 130K, 28% free 7294K/10020K, paused 15ms, total 15ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.007MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 1K, 27% free 7449K/10176K, paused 17ms, total 17ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.192MB for 193616-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 6K, 27% free 7634K/10368K, paused 25ms, total 25ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.339MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 40K, 26% free 7815K/10524K, paused 22ms, total 24ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.516MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 2K, 26% free 7968K/10680K, paused 28ms, total 28ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.666MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 380K, 29% free 7765K/10836K, paused 28ms, total 28ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 8.708MB for 411152-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 414K, 28% free 8094K/11240K, paused 14ms, total 15ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 205K, 27% free 8267K/11240K, paused 16ms, total 16ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 28K, 26% free 8397K/11240K, paused 15ms, total 15ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 9.240MB for 321568-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 239K, 27% free 8535K/11556K, paused 21ms, total 22ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 1K, 25% free 8689K/11556K, paused 18ms, total 18ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 9.370MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 330K, 27% free 8621K/11712K, paused 27ms, total 27ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 273K, 28% free 8519K/11712K, paused 25ms, total 26ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 9.438MB for 403664-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 21K, 23% free 9403K/12108K, paused 20ms, total 21ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 10.067MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 4K, 23% free 9560K/12264K, paused 32ms, total 32ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 10.220MB for 158776-byte allocation
D/dalvikvm( 1840): GC_FOR_ALLOC freed 764K, 28% free 9049K/12420K, paused 26ms, total 26ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 78K, 27% free 9137K/12420K, paused 33ms, total 34ms
I/dalvikvm-heap( 1840): Grow heap (frag case) to 10.173MB for 543184-byte allocation
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.email/.activity.Welcome bnds=[512,360][512,360]} from pid 1840
I/ActivityManager(  419): Start proc com.android.email for activity com.android.email/.activity.Welcome: pid=1893 uid=10025 gids={50025, 3003, 1015, 1023, 1028}
W/Trace   ( 1893): error opening trace file: No such file or directory (2)
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (10 > 0 bytes)
D/dalvikvm(   96): GC_EXPLICIT freed 38K, 70% free 2349K/7696K, paused 2ms+1ms, total 19ms
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 1ms+2ms, total 18ms
I/ActivityManager(  419): Start proc com.android.exchange for service com.android.exchange/.ExchangeService: pid=1910 uid=10007 gids={50007, 3003, 1015, 1023, 1028}
D/dalvikvm(   96): GC_EXPLICIT freed <1K, 70% free 2349K/7696K, paused 2ms+2ms, total 18ms
W/Trace   ( 1910): error opening trace file: No such file or directory (2)
D/ExchangeService( 1910): !!! EAS ExchangeService, onCreate
D/ExchangeService( 1910): !!! EAS ExchangeService, onStartCommand, startingUp = false, running = false
D/ExchangeService( 1910): !!! EAS ExchangeService, onStartCommand, startingUp = true, running = false
D/ExchangeService( 1910): Received deviceId from Email app: android1414443959421
D/ExchangeService( 1910): Reconciling accounts...
D/Eas Debug( 1910): Logging:
E/SQLiteLog( 1893): (1) no such table: Account
W/EmailProvider( 1893): Exception cleaning EmailProvider.dbandroid.database.sqlite.SQLiteException: no such table: Account (code 1): , while compiling: delete from Account WHERE displayName ISNULL;
D/EmailProvider( 1893): fromDatabase accounts: 0
D/EmailProvider( 1893): ending toDatabase transaction; copyCount = 0
D/EmailProvider( 1893): ending fromDatabase transaction; copyCount = 0
D/libEGL  ( 1893): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  ( 1893): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  ( 1893): loaded /system/lib/egl/libGLESv2_mali.so
D/OpenGLRenderer( 1893): Enabling debug mode 0
I/ActivityManager(  419): No longer want com.google.android.voicesearch (pid 1543): empty #17
I/ActivityManager(  419): START u0 {flg=0x2000000 cmp=com.android.email/.activity.setup.AccountSetupBasics (has extras)} from pid 1893
I/ActivityManager(  419): Displayed com.android.email/.activity.Welcome: +521ms
I/ActivityManager(  419): Displayed com.android.email/.activity.setup.AccountSetupBasics: +209ms
W/ActivityManager(  419): Duplicate finish request for ActivityRecord{4123f5b8 u0 com.android.email/.activity.Welcome}
D/dalvikvm(  419): GC_CONCURRENT freed 567K, 63% free 6366K/16888K, paused 12ms+6ms, total 87ms
D/libEGL  (  750): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  (  750): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (  750): loaded /system/lib/egl/libGLESv2_mali.so
D/OpenGLRenderer(  750): Enabling debug mode 0
D/AudioHardware(   98): AudioHardware pcm playback is going to standby.
D/AudioHardware(   98): closePcmOut_l() mPcmOpenCnt: 1
W/IInputConnectionWrapper( 1893): showStatusIcon on inactive InputConnection
I/ActivityManager(  419): No longer want com.google.android.partnersetup (pid 1016): empty #17
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings bnds=[512,360][512,360]} from pid 1840
I/ActivityManager(  419): Start proc com.android.settings for activity com.android.settings/.Settings: pid=1953 uid=1000 gids={41000, 1015, 1023, 1028, 3002, 3001, 3003, 3007}
W/Trace   ( 1953): error opening trace file: No such file or directory (2)
D/BluetoothManagerService(  419): Message: 20
D/BluetoothManagerService(  419): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@415a3518:true
D/BluetoothAdapter( 1953): 1092668632: getState() :  mService = null. Returning STATE_OFF
D/BluetoothManagerService(  419): Message: 30
D/BluetoothPan( 1953): BluetoothPan() call bindService
D/BluetoothPan( 1953): BluetoothPan(), bindService called
W/ContextImpl( 1953): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothInputDevice.<init>:240 android.bluetooth.BluetoothAdapter.getProfileProxy:1169 com.android.settings.bluetooth.LocalBluetoothAdapter.getProfileProxy:94
W/ContextImpl( 1953): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPan.<init>:141 android.bluetooth.BluetoothAdapter.getProfileProxy:1172 com.android.settings.bluetooth.PanProfile.<init>:73
D/LocalBluetoothProfileManager( 1953): LocalBluetoothProfileManager construction complete
W/ContextImpl( 1953): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1467 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPbap.<init>:161 com.android.settings.bluetooth.PbapServerProfile.<init>:68 com.android.settings.bluetooth.LocalBluetoothProfileManager.<init>:124
D/BluetoothInputDevice( 1953): Proxy object connected
D/HidProfile( 1953): Bluetooth service connected
D/BluetoothPan( 1953): BluetoothPAN Proxy object connected
D/PanProfile( 1953): Bluetooth service connected
D/libEGL  ( 1953): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  ( 1953): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  ( 1953): loaded /system/lib/egl/libGLESv2_mali.so
D/OpenGLRenderer( 1953): Enabling debug mode 0
I/ActivityManager(  419): Displayed com.android.settings/.Settings: +592ms
D/dalvikvm( 1840): GC_FOR_ALLOC freed 726K, 27% free 9452K/12844K, paused 27ms, total 29ms
D/WifiHW  (  419): Read wifi chip type OK ! wifi_chip_type = RTL8188CU
D/WifiHW  (  419): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/8192cu.ko, DRIVER_MODULE_ARG =
D/WifiService(  419): setWifiEnabled: true pid=1953, uid=1000
D/BluetoothAdapter(  685): 1093079064: getState() :  mService = null. Returning STATE_OFF
D/WifiHW  (  419): wifi_load_driver: driver load failed
D/WifiHW  (  419): Unable to unload driver module "wlan": No such file or directory
E/WifiStateMachine(  419): Failed to load driver!
E/WifiStateMachine(  419): DriverFailedState
W/SocketClient(   92): write error (Broken pipe)
I/ViPER4Android_v2(   98): Driver general communication
I/ViPER4Android_v2(   98): Driver and server are alive
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (3229 > 0 bytes)
D/dalvikvm(  419): GC_CONCURRENT freed 923K, 63% free 6391K/16888K, paused 3ms+4ms, total 49ms
D/dalvikvm( 1061): GC_CONCURRENT freed 419K, 64% free 2833K/7696K, paused 2ms+3ms, total 21ms
I/NotificationService(  419): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@41606488
I/NotificationService(  419): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@41606ab8
I/NotificationService(  419): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@412a57c0
I/NotificationService(  419): cancelToast pkg=com.android.settings callback=android.app.ITransientNotification$Stub$Proxy@4165b210
E/Cryptfs (   91): not running with encryption, aborting
D/PermissionCache(   95): checking android.permission.HARDWARE_TEST for uid=1000 => granted (222 us)
W/InputMethodManagerService(  419): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@415a2f60 attribute=null, token = android.os.BinderProxy@4123b018
W/InputMethodManagerService(  419): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@41340310 (uid=1000 pid=1953)
I/ActivityManager(  419): No longer want com.cyanogenmod.updater (pid 1597): empty #17
I/ActivityManager(  419): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.teslacoilsw.launcher/com.android.launcher2.Launcher} from pid 419
I/ActivityManager(  419): Start proc com.google.android.apps.uploader for broadcast com.google.android.apps.uploader/com.google.android.picasasync.BatteryReceiver: pid=2007 uid=10012 gids={50012, 3003, 1015, 1023, 1028}
W/Trace   ( 2007): error opening trace file: No such file or directory (2)
I/ActivityManager(  419): No longer want com.google.android.inputmethod.latin.dictionarypack (pid 1636): empty #17
D/PicasaUploader( 2007): System upgrade from null to 4.2.2
D/PicasaUploader( 2007):    wifiOnlyPhoto changed to true
D/PicasaUploader( 2007):    wifiOnlyVideo changed to true
D/PicasaUploader( 2007):    syncOnBattery changed to true
D/PicasaUploaderSync( 2007): sync account database
D/PicasaUploaderSync( 2007): accounts in DB=0
D/PicasaUploaderSyncManager( 2007): background data: true
D/PicasaUploaderSyncManager( 2007): battery info: false
E/Lights  (  419): write_int failed to open sys/class/leds/battery_led/brightness
W/ThrottleService(  419): unable to find stats for iface rmnet0
E/ThrottleService(  419): Error reading data file
I/InputReader(  419): Reconfiguring input devices.  changes=0x00000004
I/InputReader(  419): Device reconfigured: id=1, name='ft5x0x_touch', size 1024x768, orientation 1, mode 1, display id 0
I/ActivityManager(  419): Config changes=480 {1.0 ?mcc?mnc de_DE ldltr sw721dp w768dp h951dp 160dpi xlrg port finger -keyb/v/h -nav/h s.5 themeResource=null}
V/Nova    ( 1840): onActivityDestroyed com.android.launcher2.Launcher@4124a870 3,2MB free of 12,5MB total with max 48,0MB
V/Nova    ( 1840): onActivityCreated com.android.launcher2.Launcher@411e36f0 PORT 3,2MB free of 12,5MB total with max 48,0MB
D/dalvikvm(  685): GC_CONCURRENT freed 9311K, 52% free 10325K/21504K, paused 3ms+5ms, total 22ms
D/dalvikvm( 1840): GC_CONCURRENT freed 3471K, 39% free 7914K/12844K, paused 1ms+3ms, total 28ms
D/dalvikvm( 1840): WAIT_FOR_CONCURRENT_GC blocked 26ms
D/dalvikvm(  419): GC_CONCURRENT freed 837K, 62% free 6443K/16888K, paused 3ms+4ms, total 58ms
D/dalvikvm(  419): GC_EXPLICIT freed 78K, 63% free 6373K/16888K, paused 9ms+4ms, total 73ms
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (2421 > 0 bytes)
D/PhoneStatusBar(  685): disable: < expand ICONS* alerts TICKER* system_info back home recent CLOCK* search >
D/PhoneStatusBar(  685): disable: < expand icons* alerts ticker* system_info back home recent clock* search >
W/InputMethodManagerService(  419): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@41d85e48 attribute=null, token = android.os.BinderProxy@412dbea8
I/PowerManagerService(  419): Going to sleep due to screen timeout...
D/libEGL  (  419): loaded /system/lib/egl/libEGL_mali.so
D/libEGL  (  419): loaded /system/lib/egl/libGLESv1_CM_mali.so
D/libEGL  (  419): loaded /system/lib/egl/libGLESv2_mali.so
D/SurfaceFlinger(   95): Screen released, type=0 flinger=0x4105e318
I/keystore(  100): uid: 1000 action: z -> 7 state: 3 -> 3 retry: 4
I/WindowManager(  419): No lock screen!
I/ViPER4Android(  775): mScreenOnReceiver::onReceive()
D/AccelerometerListener(  770): enable(false)
D/PowerManagerService-JNI(  419): Excessive delay in autosuspend_enable() while turning screen off: 111ms
D/dalvikvm(  419): GC_CONCURRENT freed 904K, 62% free 6433K/16888K, paused 12ms+3ms, total 88ms
D/dalvikvm(  419): GC_FOR_ALLOC freed 412K, 60% free 6828K/16888K, paused 34ms, total 34ms
D/dalvikvm(  419): GC_CONCURRENT freed 451K, 56% free 7499K/16888K, paused 3ms+4ms, total 43ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 33ms
D/PhoneStatusBar(  685): disable: < expand icons alerts ticker system_info back home RECENT* clock search >
V/TAG     (  419): bug 7643792: fitSystemWindows([0,25][0,0])
I/InputReader(  419): Device reconfigured: id=1, name='ft5x0x_touch', size 1024x768, orientation 0, mode 1, display id 0
I/ActivityManager(  419): Config changes=480 {1.0 ?mcc?mnc de_DE ldltr sw721dp w1024dp h695dp 160dpi xlrg land finger -keyb/v/h -nav/h s.6 themeResource=null}
W/IInputConnectionWrapper( 1840): beginBatchEdit on inactive InputConnection
W/IInputConnectionWrapper( 1840): endBatchEdit on inactive InputConnection
V/Nova    ( 1840): onActivityDestroyed com.android.launcher2.Launcher@411e36f0 3,5MB free of 12,3MB total with max 48,0MB
V/TAG     (  419): bug 7643792: fitSystemWindows([0,0][0,0])
D/OpenGLRenderer(  419): Enabling debug mode 0
D/dalvikvm( 1840): GC_EXPLICIT freed 2365K, 48% free 6656K/12588K, paused 2ms+7ms, total 64ms
V/Nova    ( 1840): onActivityCreated com.android.launcher2.Launcher@41191a48 LAND 5,8MB free of 12,3MB total with max 48,0MB
D/dalvikvm(  419): GC_CONCURRENT freed 754K, 53% free 8038K/16888K, paused 3ms+16ms, total 114ms
D/PhoneStatusBar(  685): disable: < expand icons alerts ticker system_info BACK* HOME* RECENT CLOCK* search >
D/dalvikvm( 1840): GC_CONCURRENT freed 2079K, 53% free 5941K/12588K, paused 2ms+2ms, total 19ms
D/dalvikvm( 1840): WAIT_FOR_CONCURRENT_GC blocked 3ms
D/dalvikvm(  419): GC_CONCURRENT freed 742K, 49% free 8722K/16888K, paused 4ms+5ms, total 75ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 10ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 12ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 11ms
D/dalvikvm(  419): WAIT_FOR_CONCURRENT_GC blocked 14ms
W/WindowManager(  419): App freeze timeout expired.
W/DropBoxManagerService(  419): Dropping: system_app_strictmode (401 > 0 bytes)
2014/10/28 - 17:22
Der Kernel meldet zwar einen RTL8188, es ist aber vermutlich keiner verbaut. Geladen werden soll ein RTL8192.
D/WifiHW  (  419): Unable to unload driver module “wlan”: No such file or directory
Die build.prop adressiert einen RTL8723.
ro.zed.isRtl8723=true
Das ist Müll, wenn die Guys den Kernel gegen das Build patchen, anstatt es im JB richtig zum machen.
Schwierig. Melde mich, wenn mir dazu noch was einfällt.
Meecrob
Forum Posts: 12
2014/10/28 - 19:30
Teste das mal bitte: http://crewrktablets.arctablet.com/?wpfb_dl=1573
Abgesehen von der falschen Auflösung, hat sich bezüglich WLAN leider nichts geändert. Die Stock-Firmware hat ein 8188eu.ko und ein 8192cu.ko Modul, lässt sich das eventuell in CM10.1 nutzen?
85 Guest(s)
Devices in use: Desktop (80), Phone (5)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
