2014/01/09
Hi Oma! Can you help me fix my WiFi tablet Prestigio pmp5780. Wi-Fi enabled, but comes endless search for wifi. This fix does not correct my problem http://crewrktablets.arctablet.com/?wpfb_dl=1247Â WiFi does not work on CM 10 and 4.2.2.
Please help me. I hope for your help
Pls boot tab fresh and try to enable wifi a few times.
Open the terminal and:
su
dmesg >/mnt/sdcard/dmesg.txt
Upload the logs.
2014/01/09
Upload the logs.
Laid out on the Russian file sharing
http://rghost.ru/private/51863685/2e77d32194268997467912ba04f7a05f — dmesg
http://rghost.ru/private/51865508/a830e2118a36f830b902358912d90963 — logcat
I have noticed a problem with mapping the battery, after reboot the tablet charge reset
the action is not allowed, because the file is marked as private and the key you provided is not correct
Just zip and attach to the post.
2014/01/09
uploaded to file sharing dropbox
https://www.dropbox.com/s/d3pv28w50s1w337/dmesg.txt — dmesg
https://www.dropbox.com/s/ykybfq9agmbcdpv/logcat.txt — logcat
Fehler (404)
2014/01/09
Hello Oma! Created a topic again, because you did not help me. Can you help me fix my WiFi tablet Prestigio pmp5780. Wi-Fi enabled, but comes endless search for wifi. This fix does not correct my problem http://crewrktablets.arctablet.com/?wpfb_dl=1247 WiFi does not work on CM 10 and 4.2.2.
This dmesg, logcat logs from android 4.2.2 and 4.1.1(standart firmware)
2012/11/19
I merged your new topic with your first topic.
Please don't make more then one topic regarding the same problem. It does not help and only makes it harder to understand for other users.
Ok, wifi chip is MT5931: http://www.mediatek.com/_en/01_products/04_pro.php?sn=1052
But: the driver seems to be in the kernel.
Can you pls try with the CM10 build: http://crewrktablets.arctablet.com/?wpfb_dl=1436
2014/01/09
Ok, wifi chip is MT5931: http://www.mediatek.com/_en/01_products/04_pro.php?sn=1052But: the driver seems to be in the kernel.
This fix http://crewrktablets.arctablet.com/?wpfb_dl=1247Â corrects only the power button is not working WiFi, but after installing this fix http://crewrktablets.arctablet.com/?wpfb_dl=1436Â button on WiFi is not working again
67 Guest(s)
Devices in use: Desktop (55), Phone (12)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
