2013/11/17
Hi, i own a tablet from versus uk based on rk3066. I tried to flash CM10.1 without success.
Here's how i did it:
1. Downloaded firmware from versus uk http://www.versusuk.com/support/downloads/7vdc.html
2. After some googling i managed to extract kernel.img from the firmware using imgRePackerRk
3. Replaced kernel.img on rockdev/Image
4. Flashed in RKAndroidTool and result was ok
Problem: Tablet did not boot recovery (stuck in bootloader mode, i think)
If someone has any solution please tell me, i have been waiting for a rom since i got the tablet because i can't connect it to my university wifi using PEAP MSCHAPV2 (i think it's a 4.1 source problem - no solution has worked)
Thank you in advance.
Here is the kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1221
Try again incl. eraseIDB.
glutamatePer aspera ad astra, we rock the Tablets !
2013/09/29
I have the same problem with the xelio 10 pro.
How did you know that there is a 4.1 4.1 source problem and not a kernel/driver problem?
2013/11/17
Thanks for the fast answer Oma =) i will try it now (i didn't say it but i erased IDB)
edit: I flashed the rom and it boots but the ui is very big and i can't see the nav bar. The recovery can't mount the internal memory and i tried flashing the other recovery that worked and still the same.
peter334 said
I have the same problem with the xelio 10 pro.How did you know that there is a 4.1 4.1 source problem and not a kernel/driver problem?
I am not sure but i tried changing the wpa_supplicant (manually/using WiFi Advanced app) to the correct options and it did not work. I've read somewhere that the solution was using the source from the 4.2 but i did not knew how to build a rom and didn't have time to learn, so i waited. Let's see if this will work (fingers crossed)
2013/11/17
Hi, i did not try the generic stock recovery. Do you think it the internal storage will work with it?
edit: It worked! I tried flashing your recovery after but it was still the same, then i flashed the one i had before and it works.
The ui is good now but the wifi and the bluetooth doesn't work. The bluetooth is not very important to me but the wifi was the main reason for trying this rom. I would be very thankful if there was some fix (i can flash through CWM now).
71 Guest(s)
Devices in use: Desktop (67), Phone (4)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
