2013/12/18
Hello to all, my name is Dimitrios and I managed to get my hands on a vero tab, rebranded rk3066 from Greece, running a 3.08+ kernel and I would very much like to load a 4.2 or preferably when its out a 4.4 rom, what would the steps be to doing that? Which rom should I load?
Thanks any and all for your help
Root the tab and dump the images first: http://crewrktablets.arctablet.com/?wpfb_dl=1264
Upload them to a filehoster and post the link here.
If you do not already have the RK driver running use this: http://crewrktablets.arctablet.com/?wpfb_dl=1187
2012/12/06
hello
this ist the software for tab
http://www.sendspace.com/file/n35p6e
Greek support
oktabit.gr > http://www.oktabit.gr/product_details.asp?productid=249-94-VRTA9724
forum.oktabit.gr
Ok, thx. Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1304
Try the CM10.1 build: http://crewrktablets.arctablet.com/?p=1913
EressendilPer aspera ad astra, we rock the Tablets !
2012/12/06
hello
Happy new year
1.decompress with 7zip (change kernel in folder rockdev/Image)
2.copy format_NAND_fix (and other fixes) to sd-card
3.boot tab into flash mode
4.run RKAndroidTool as admin: EraseIDB, Run
5.first boot into CWM: install format_NAND_fix (and other fixes) from sd-card
6.reboot, wait 4 min
2013/12/18
So I tried it, and for whatever reason I couldn't even root the poor thing. I downloaded the files from here
And I uninstalled, then tried to install the drivers, and I get an error message. "No found driver inf".
Then I try to root, I run OMA RK root and dump, in admin mode (im running Vista unfortunately) and I get a message saying adb is not recognised. Tried both normal and recovery mode, so I assume I am doing something wrong.
Any help greatly appreciated!
2012/12/06
Eressendil said
So I tried it, and for whatever reason I couldn't even root the poor thing. I downloaded the files from hereOma7144 said
Any help greatly appreciated!you need only two things, there is already root with inside >
http://www.arctablet.com/blog/forum/crewrktablets-rk3066-entwicklung-customroms-development-croms/vero-a9724-help/#p35057Ok, thx. Kernel is here: http://crewrktablets.arctablet.com/?wpfb_dl=1304
you can you read times even in the Greek side there is also something for root
Currently Online: Azabatxe1
143 Guest(s)
Devices in use: Desktop (138), Phone (6)
jacksonrid
usdown
ibob64
