Updating TrekStor Ventos 10.1 (ST10216-2A) to Android 4.4?
Any way to update this device to a more recent ROM/kernel/Android version?
gylu
151
2015/04/28 - 21:03
awl said
Hello gylu,
sorry, but after looking into both files, I fear we still have a misunderstanding:
The log files that you have provided is still also based on the kernel for ST-10216-2A:
Linux version 3.0.8+ (chenwj@tchipserver2) (gcc version 4.4.3 (GCC) ) #42 SMP PREEMPT Mon Dec 2 11:50:45 CST 2013
You need to switch back your tablet to the stock (factory provided) 10216-2 (without A) firmware from Trekstor and then send me the output of the dmesg and logcat logs when the tablet boots with the stock kernel and ROM.
I truly hope that you do have a backup of your stock firmware. Otherwise, as you can see here (sorry, in German):
http://www.android-hilfe.de/surftab-ventos-10-1-forum/620035-ventos-10-1-v2-firmware.html
you might be out of luck, as the firmware seems no longer available for download... Frown
You can of course try to request the file from user "STyLiShEr" in this forum or also contact Trekstor support by phone and ask them to send this binary firmware file to you. As stated in the above thread, what you need should be a file called ST10216-v2_FW_pack.zip.
Hope this helps & best regards,
awl
I'll try to contact him. Or Trekstor 😉
ps. German is no problem for me...
Thanks.
sunfire840321
152
2016/02/23 - 14:30
i'm using the ST-10216-1.
What changes do i need to get it working on ST-10216-1?
Greetings sunfire
awl
Forum Posts: 90
153
2016/02/23 - 23:58
Sorry, I cannot provide any meaningful help about the ST-10216-1, as it has different hardware and a different kernel. So unfortunately, you are on your own on this device... 🙁
Best regards,
awl
sunfire840321
154
2016/02/25 - 13:33
Thx for reply.
Is there any android version after 4.1.1. for ST-10216-1?
155
2016/02/25 - 17:44
Can you point me to the stock firmware and if possible upload a dmesg log?
sunfire840321
156
2016/02/27 - 16:02
The stock firmware can you download here:
The log is in the attachment.
Thx for help.
Greetings sunfire
157
2016/02/27 - 19:27
I can't see the wifi chip in the log. Open a terminal and type:
cat /sys/class/rkwifi/chip
Post the result.
sunfire840321
158
2016/02/28 - 12:11
The result is: RK903
159
2016/02/28 - 14:43
Build: http://crewrktablets.arctablet.com/?p=1913
Kernel/parameter: http://crewrktablets.arctablet.com/?wpfb_dl=2832
Just replace parameter in folder rockdev and kernel in folder rockdev/Image before flash.
sunfire840321
160
2016/03/01 - 00:28
Thx for ur really quick response.
After flashing the tablet hangs in the cwm with multiple mount errors.
Should i flash stock recovery explained here:
Greetings sunfire
161
2016/03/01 - 17:29
Yes. Pls rename the included recovery to CWM first.
sunfire840321
162
2016/03/01 - 19:31
Thx a lot now it works.
It also upgrades the hardware, now i'm proud owner of a nexus 7 😉
Greetings sunfire
163
2016/03/01 - 19:55
Fine.
You can flash the CWM now. Rename it to recovery and flash it. Only tick paramerter, misc and recovery.
sunfire840321
164
2016/03/13 - 13:38
Thx a lot, it works great.
But i think the battery is little bit crazy now.
Is android 4.2.2. the last working version?
Greetings sunfire
165
2016/03/13 - 14:51
On a 3.0.8+ kernel - yes.
66 Guest(s)
Devices in use: Desktop (61), Phone (5)
rk.13
siwinfi64
dangphat
dpc
ngu
