Is the firmware for U30GT-HS available?
2013/01/01
indeed it is! here is kasty rooted version. http://www.arctablet.com/blog/forum/cube-u30gt/cube-u30gt-hs-u30gt-h-rooted-firmware-from-official-version-1-01-dated-20130225/
wolfangerPer aspera ad astra, we rock the Tablets !
Did you execute eraseIDB?
Hm, which build is it? Which resolution has the tab?
This one comes as update.img ... what have you done?
Anyway, pls test with this build: http://crewrktablets.arctablet.com/?p=1913
Ok. I can't see any problem. Flash-log looks fine.
In general boot-loop into CWM indicates images are not properly written or not fitting to partitions or there are errors on the NAND.
Install the stock image and then try a clean installation again.
Currently Online: fantom0308, MINIX2021
108 Guest(s)
Devices in use: Desktop (101), Phone (9)
beelink
TheMentor
smalec
marek.test@gmail.com
MINIX2021
extendedtn
