touchscreen driver for rk3066
2015/01/28 - 21:27
Does touch work in CWM?
2015/01/28 - 21:43
Otherwise flash this one: http://crewrktablets.arctablet.com/?wpfb_dl=449
arabi48
Forum Posts: 48
2015/01/31 - 11:33
SORRY ITS NOT WORKING
CAN THIS PROBLEM CAUSED BY A DAMAGE IN TOUCHSCREEN
IF I REPLACED AN OTHER ONE CAN FIX THE PROBLEM
2015/01/31 - 13:05
What is not working? Touch in CWM or touch in Android?
What has happend with your screen?
arabi48
Forum Posts: 48
2015/01/31 - 20:59
the cwm work fine i flashed attached file not solved no change
i have no problem with my screen its normal but the touch is inverted and i flash it before without any problem
i do some mistack change my touchsceen driver and i can not reflashed it no i try all my firmware - all working 100/100 before- now all the same inverted touchscreen thanck you for your support
2015/01/31 - 22:06
arabi48 said
after i flash kernel fot technisat the touchscreen not work proprely  i back to stock rom 100 time  the same
This kernel flashed its touch controller firmware into your chip. That's why the chip is not working properly. Obviously your stock kernel has no touch controller firmware included. Nearly no chance to recover that.
One last chance, this kernel will flash its firmware also: http://crewrktablets.arctablet.com/?wpfb_dl=1402. No idea what firmware it is and if it will fit. The kernel will most likely not boot the tab, so flash it and wait some time. Then flash your stock kernel.
To flash a kernel into the running build tick only parameter and kernel. You can load the kernel in RKAndroidTool by clicking on the empty box at the end of the kernel line.
EDIT: kernel is to big for current partition size. Use attached parameter to flash the CM10.1 v1.4 build first, incl. eraseIDB.
Good luck!
arabi48
Forum Posts: 48
2015/02/01 - 13:20
not working
is there an other kerenel withe drivers or how i can find or detect that kernel included driver
2015/02/01 - 15:10
No way. Sorry.
214 Guest(s)
Devices in use: Desktop (195), Phone (19)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
