touchscreen driver for rk3066
arabi48
Forum Posts: 48
2015/01/28 - 13:16
hello all
first i have a tablet ctab800hd
rk3066 8inch dual camera
this the full dump from the tablet befor the problem
http://www.4shared.com/rar/YECn2Gkaba/full_ctab800dzgsm.html
its come withe 3.08 kernel
i try to flash a 3.036+ kernel from all 8inch tablet like tpad9 and point of view p85
for try a 4.4 version from the oma realise rom
its ok i try i was some problem withe grifix but it work after i flash kernel fot technisat the touchscreen not work proprely  i back to stock rom 100 time  the same
i dont know what i should do  for fix my touch sceen driver
2015/01/28 - 15:23
You can do nothing. A kernel has to be compiled from sources.
Use our CM10.1 build with your stock kernel.
Btw: the download archive is passwort secured.
arabi48
Forum Posts: 48
2015/01/28 - 17:13
pass     http://www.dzgsm.com
i try cm10.1 before its work fine -without wifi-  after the touchscreen problem i reflash your cm10.1 the same problem
2015/01/28 - 18:19
Pls upload dmesg log and logcat log of the running stock firmware.
arabi48
Forum Posts: 48
2015/01/28 - 18:35
i cant get a dmesg log    hhh idont know how !
new information in cwm recovry  the touchscreen work fine
arabi48
Forum Posts: 48
2015/01/28 - 20:01
2015/01/28 - 20:04
Ok, this is a logcat log. Now a dmesg log.
arabi48
Forum Posts: 48
2015/01/28 - 20:23
http://www.gulfup.com/?vndGHP
arabi48
Forum Posts: 48
2015/01/28 - 20:42
for your information i try to flash this kernel before the problem
http://crewrktablets.arctablet.com/?wpfb_dl=1889              work fine withe a bad grafix
http://crewrktablets.arctablet.com/?wpfb_dl=1601              i think after flash this the problem begin
http://crewrktablets.arctablet.com/?wpfb_dl=1251              not work and the screen is rotated
2015/01/28 - 20:55
<4>[   14.781432] =======================================================
<4>[   14.781449] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[   14.781456] =======================================================
<4>[   14.781463] MediaTek RT5370 USB WiFi driver (Powered by Rockchip,Ver 2.00) init.
Ok, tab has RT5370 wifi.
Use latest CM10.1 build v1.4, your stock kernel and install the fix via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2420
arabi48
Forum Posts: 48
2015/01/28 - 20:58
i try and tell you
arabi48
Forum Posts: 48
2015/01/28 - 21:03
volum button not work now
2015/01/28 - 21:18
Wifi works?
What do you mean by "volume button"?
arabi48
Forum Posts: 48
2015/01/28 - 21:24
in recovry i cant go anywhere becose hardwere boutton  voluume up down not work
58 Guest(s)
Devices in use: Desktop (52), Phone (6)
abdouerr
shino246
sofia7777
chimo014
vishu bhatnagar
djwood1014
