2012/09/27
Well,
Hi Oma, ihave testing the last beta (1.3.2) in my tablets Cube U30gt-h and Mini. And i encounter this tips:
Cube U30GT-H:
The audio A2DP not work in the headphones. They synchronize correct in the Bt Menu but the sound still output through the internal speaker.
The USB transfer not work at all. I plug the USB cable between the Computer and tablet and nothing happend.
Cube U30GT-MINI:
The touch panel not work. The rom load OK but you can't do anything, only the volume buttons and the power.
Thanks for your hard work to make this tablets better with this good support.
2013/05/23
Aitors20 Have the u30GTH Dual core and have ran both programs Cmod and AOSP w/o any of the fixes besides NANDs. The recovery.img is also a problem requiring the cwm 6.0.1.3. Your Usb is in settings, tap storage, go to top right corner to load your usb connections menu, and tap the (MT-) option for your internal and external cards. Mine is not the mini, but have been impressed by both builds.
CappyBob -You don't own it, til you break it.-
2012/09/27
Thanks for your answer CappyBob, the USB now work with the MTP option ON, i don't know why the Mass Storage not work; No in My PC appears a Multimedia device instead a drive.
With The other problem, I made a mistake in the title....When i put NAD, i liked to said "AND" because i have the two hardwares, the U30GT-H AND MINI .....I'm sorry.
2013/09/13
After many attemps i got CM10.1 working on MINI. System is Beta 1.3.3 from Oma and i used a modified kernel which supports usb hubs and overclocking upto 1.6 GHz. It runs smoothly and after few fixes there is no problem except a short lag during display rotations. (at least none i noticed).
Wi-Fi workaround :
- Copy rkwifi.ko, wlan.ko and 8188eu.ko from stock rom
- Rename "8188eu.ko" to "8192cu.ko" (module load by default in CM10.1)
Used fixes :
NAND Fix : http://crewrktablets.arctablet.com/?wpfb_dl=920
Just a quick note to judge if there is interest of having a ready to flash firmware based on OMA and Crew RKTablets CM10.1 (Android 4.2.2) and conquistador comments ? The corresponding firmware would be a single update.img file, to be flashed with Rockchip Batch Tool 1.7.
Please post below if you are interested and you would like the default kernel of the FMA one (overclock and brightness mods).
Currently Online: andreive
75 Guest(s)
Devices in use: Desktop (67), Phone (9)
hans41
rickybk
soniya07
ironmangitar
