Teclast p76a Dual-core(m4q5)4.2.2
sjmsjjgh
Forum Posts: 19
2014/03/23 - 13:31
Try the CM10.1 build: http://crewrktablets.arctablet.com/?p=1913
I tired,not working······
sjmsjjgh
Forum Posts: 19
2014/03/23 - 13:35
The nand mass storage can't be found,but the sdcard seems working fine
netlars
Forum Posts: 149
Thanks Received: 29
2014/03/25 - 06:30
Please install the format NAND fix via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=635
The following users say thank you to netlars for this useful post:
sjmsjjgh
sjmsjjgh
Forum Posts: 19
2014/03/29 - 12:33
ok,now the nand is working,but the wifi still not~~~
netlars
Forum Posts: 149
Thanks Received: 29
2014/03/29 - 18:45
ok, fine.
next is wifi, open an terminal e.g. adb or terminal app and post the output from
cat /sys/class/rkwifi/chip
sjmsjjgh
Forum Posts: 19
2014/03/30 - 10:35
netlars said
ok, fine.
D:\adb>adb shell cat /sys/class/rkwifi/chip
RT5370V2
Is this what you need?
netlars
Forum Posts: 149
Thanks Received: 29
2014/03/30 - 11:41
ok, fine.
But the module we need.
Please zip the files in /system/lib/modules and upload it, out of your stock firmware.
2014/03/30 - 11:50
Here we go ;-)
sjmsjjgh
Forum Posts: 19
2014/03/30 - 13:33
netlars
Forum Posts: 149
Thanks Received: 29
2014/03/30 - 20:36
Oh, doubble thanks.
here first test: http://crewrktablets.arctablet.com/?wpfb_dl=1655
sjmsjjgh
Forum Posts: 19
2014/03/31 - 06:27
netlars said
Oh, doubble thanks.
not work......it turn off when you turn on
netlars
Forum Posts: 149
Thanks Received: 29
2014/03/31 - 17:10
sjmsjjgh
Forum Posts: 19
2014/04/01 - 00:15
sorry,still not work
netlars
Forum Posts: 149
Thanks Received: 29
2014/04/06 - 10:25
is the wlan module loaded?
type lsmod in the console
sjmsjjgh
Forum Posts: 19
2014/04/13 - 03:48
u0_a53@android:/ $ su
u0_a53@android:/ # busybox lsmod
Module              Size    Used by     Tainted: G
vpu_service       11791    0
rk29_ipp            9541     0
mali                 105239   8
ump                 26008    17 mali
rk30xxnand_ko   346964  0
u0_a53@android:/ #
It seems didn't load.....
63 Guest(s)
Devices in use: Desktop (57), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
