2014/08/01
Is it possible to get the kitkat rom (http://crewrktablets.arctablet.com/?p=2398) running on the above tablet?
From what I understand that tablet needs a 3.0.36 kernel to run kitkat and this tablet has one with the latest stock rom (http://sumvision.com/product/cyclone-voyager/voyage-8-support.php) and has a custom kernel, although for cm10.1 (http://crewrktablets.arctablet.com/?p=1913).
Is this possible? I don't mind doing a bit of work myself I just need pointing in the right direction.
ThanksÂ
Can you pls upload a dmesg log?
KK build v1.2: http://crewrktablets.arctablet.com/?p=2982
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=862
Model fix (first guess): http://crewrktablets.arctablet.com/?wpfb_dl=1816
Use the pack as is. Change the kernel in folder rockdev/Images and flash incl. eraseIDB. Do not flash the loader!
In CWM install format_NAND and the model fix.
Did you change the kernel?
Make sure the charger is plugged. Then try vol-up and reset.
2014/08/01
Ive managed to reflash and get in into recovery by using the MASK Rom method (shorting pins 8 and 9 on the NAND) but now I cant apply the zips in recovery because it can't mount the sdcard.Â
EDIT: I mounted the sdcard to the PC formatted it using windows and dropped the zips on there then CWM was able to mount it.
So its booted  but the rotation is 90 degrees out and the screen is flickering when you do certain things
Disable HW-Overlays in developement settings.
95 Guest(s)
Devices in use: Desktop (73), Phone (20), Tablet (2)
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
