2014/12/13
 Hello Developers....
After spending a long time I have successfully managed to Root the device and install CWM for Spice Mi 1010 tab.
Can a kind person could guide me to get a custom rom with a higher version then the stock rom.
This is a great tab with RK3066, Specs are given below,
GENERAL | 2G Network | N/A |
SIM | No | |
Announced | 2013, January | |
Status | Available. Released 2013, January |
SOUND | Alert types | N/A |
Loudspeaker | Yes | |
3.5mm jack | Yes |
DISPLAY | Type | IPS LCD capacitive touchscreen 10.1 inch |
Size | 1280 x 800 pixels, 10.0 inches (~151 ppi pixel density) | |
Multitouch | Yes |
MEMORY | Card slot | microSD, up to 32 GB |
DATA | GPRS | No |
EDGE | No | |
WLAN | Yes | |
Bluetooth | No | |
USB | microUSB |
CAMERA | Primary | 3.15 MP, 2048 x 1536 pixels |
Video | Yes | |
Secondary | VGA |
FEATURES | OS | Android OS, v4.1 (Jelly Bean) |
Sensors | Accelerometer | |
Messaging | Email, Push Email, IM | |
Browser | HTML | |
Radio | No | |
GPS | No | |
Java | Yes, via Java MIDP emulator | |
Colors | Silver | |
 | - HDMI port - MP3/AAC/WMA/WAV/FLAC player - MP4/WMV/H.264 player - Document viewer - Photo viewer/editor |
BATTERY | Â | Non-removable Li-Po 7600 mAh battery |
This information has been taken from GSMarena
I have found a few thread with CM 10.1, that may be compatible, however I could not get any guide for this tab.
Any help will be really grateful
I am attaching the Kernel file that I have managed to found.
Pls provide a dmesg log.
aashishPer aspera ad astra, we rock the Tablets !
<5>[Â Â Â 0.000000] Linux version 3.0.8+ (root@forise2_linux) (gcc version 4.4.3 (GCC) ) #461 SMP PREEMPT Sat Dec 22 21:13:54 CST 2012
<4>[Â Â 20.477099] Current WiFi chip is RTL8188CU.
Ok, you are running the kernel that's already in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=1550
Do a backup with CWM.
Build is here: http://crewrktablets.arctablet.com/?p=1913
Latest build is v1.4. Download the pack and change your kernel in folder rockdev/Images.
Instructions are also on the blog.
Try with the generic stock recovery first.
2014/12/13
Sorry... gone for a marriage reception.. just came back.. I tried to rename the stock update.img to system.img and tried with the tool provided. it did not work. however I used Rockchip batch tool 1.5 and installed the stock rom.. it seems to be working. Not sure why the CM rom is not working.
No, you should use this recovery http://crewrktablets.arctablet.com/?wpfb_dl=1036 instead of the included.
2014/12/13
No, you should use this recovery http://crewrktablets.arctablet.com/?wpfb_dl=1036 instead of the included.- Oma -
Hi there,
any update after I sent you the link for the stock rom please ..Â
Sorry, not really aware of that. Where?
2014/12/13
Apologies... seems the PM did not reach you
Please find the link below for the stock rom
http://www.mediafire.com/download/gu9znbf45cep2ub/Spice-MI-1010-Stellar-Pad-V12.zip
Currently Online: VMILCINOV
64 Guest(s)
Devices in use: Desktop (62), Phone (3)
VMILCINOV
